    HITL Starling/Voxl2
    1399
    • tiralonghipolT
      tiralonghipol
      hi,
      I know it has been asked several times and I already went through all the answers (I think). Still cannot figure out what am I doing wrong.
      I am trying to run HITL with gazebo connected via usb-ftdi as reported in the awesome documentation. I know it is not the cable cause I can both 'cat /dev/ttyUSB0' and get data and when I run
      gazebo Tools/simulation/gazebo-classic/sitl_gazebo-classic/worlds/hitl_iris_flex.world
      Opened serial device /dev/ttyUSB0
      I of course followed the video from Zach but here is the output when I run voxl-px4-hitl on voxl2:
      voxl-px4-hitl
      Found DSP signature file
      INFO  [muorb] SLPI: muorb aggregator thread running
      INFO  [muorb] SLPI: Creating pthread test_MUORB
      INFO  [muorb] SLPI: Successfully created px4 task PX4_test_MUORB with tid 2097656
      INFO  [muorb] SLPI: Successfully created px4 task PX4_test_MUORB with tid 2097655
      INFO  [muorb] SLPI: Successfully created px4 task PX4_test_MUORB with tid 2097654
      INFO  [muorb] SLPI: Successfully created px4 task PX4_test_MUORB with tid 2097653
      ______  __   __    ___
      | ___ \ \ \ / /   /   |
      | |_/ /  \ V /   / /| |
      |  __/   /   \  / /_| |
      | |     / /^\ \ \___  |
      \_|     \/   \/     |_/
      px4 starting.
      INFO  [px4] startup script: /bin/sh /usr/bin/voxl-px4-hitl-start 0
      INFO  [muorb] SLPI: Advertising remote topic log_message
      INFO  [muorb] SLPI: Starting param sync THREAD
      Running on M0054
      INFO  [muorb] SLPI: before starting the qshell_entry task
      INFO  [muorb] SLPI: Creating pthread qshell
      INFO  [muorb] SLPI: qshell entry.....
      INFO  [muorb] SLPI: Successfully created px4 task PX4_qshell with tid 2097652
      INFO  [muorb] SLPI: Init app map initialized
      INFO  [muorb] SLPI: after starting the qshell_entry task
      INFO  [param] selected parameter default file /data/px4/param/hitl_parameters
      INFO  [muorb] SLPI: Marking DeviceNode(parameter_client_reset_request) as advertised in process_remote_topic
      INFO  [muorb] SLPI: Advertising remote topic parameter_update
      INFO  [muorb] SLPI: Marking DeviceNode(parameter_client_set_value_request) as advertised in process_remote_to
      INFO  [muorb] SLPI: Marking DeviceNode(parameter_server_set_used_response) as advertised in process_remote_to
      INFO  [parameters] BSON document size 1656 bytes, decoded 1656 bytes (INT32:43, FLOAT:36)
      INFO  [logger] logger started (mode=all)
      INFO  [logger] Start file log (type: full)
      INFO  [logger] [logger] /data/px4/log/2023-11-02/13_05_28.ulg
      INFO  [muorb] SLPI: Advertising remote topic mavlink_log
      INFO  [muorb] SLPI: Advertising remote topic event
      INFO  [logger] Opened full log file: /data/px4/log/2023-11-02/13_05_28.ulg
      INFO  [muorb] SLPI: Advertising remote topic logger_status
      INFO  [qshell] Send cmd: 'sensors start -h'
      INFO  [muorb] SLPI: qshell gotten: sensors start -h
      INFO  [muorb] SLPI:   arg0 = 'sensors'
      INFO  [muorb] SLPI:   arg1 = 'start'
      INFO  [muorb] SLPI:   arg2 = '-h'
      INFO  [uORB] Advertising remote topic sensor_selection
      INFO  [uORB] Advertising remote topic sensors_status_imu
      INFO  [uORB] Advertising remote topic vehicle_acceleration
      INFO  [uORB] Advertising remote topic vehicle_angular_velocity
      INFO  [uORB] Advertising remote topic sensor_combined
      INFO  [uORB] Advertising remote topic vehicle_air_data
      INFO  [uORB] Advertising remote topic vehicle_gps_position
      INFO  [muorb] SLPI: Ok executing command: sensors start -h
      INFO  [qshell] qshell return value timestamp: 815009623, local time: 815017199
      INFO  [muorb] SLPI: qshell gotten: ekf2 start
      INFO  [qshell] Send cmd: 'ekf2 start'
      INFO  [muorb] SLPI:   arg0 = 'ekf2'
      INFO  [uORB] Advertising remote topic vehicle_attitude
      INFO  [uORB] Advertising remote topic vehicle_local_position
      INFO  [uORB] Advertising remote topic estimator_event_flags
      INFO  [uORB] Advertising remote topic estimator_innovation_test_ratios
      INFO  [uORB] Advertising remote topic estimator_innovation_variances
      INFO  [uORB] Advertising remote topic estimator_innovations
      INFO  [uORB] Advertising remote topic estimator_sensor_bias
      INFO  [uORB] Advertising remote topic estimator_states
      INFO  [uORB] Advertising remote topic estimator_status_flags
      INFO  [muorb] SLPI: Ok executing command: ekf2 start
      INFO  [qshell] qshell return value timestamp: 815334178, local time: 815338611
      INFO  [qshell] Send cmd: 'mc_pos_control start'
      INFO  [muorb] SLPI: qshell gotten: mc_pos_control start
      INFO  [muorb] SLPI:   arg0 = 'mc_pos_control'
      INFO  [uORB] Advertising remote topic takeoff_status
      INFO  [muorb] SLPI: Ok executing command: mc_pos_control start
      INFO  [qshell] qshell return value timestamp: 815491755, local time: 815493222
      INFO  [qshell] Send cmd: 'mc_att_control start'
      INFO  [muorb] SLPI: qshell gotten: mc_att_control start
      INFO  [muorb] SLPI:   arg0 = 'mc_att_control'
      INFO  [muorb] SLPI: Ok executing command: mc_att_control start
      INFO  [qshell] qshell return value timestamp: 815560077, local time: 815562711
      INFO  [qshell] Send cmd: 'mc_rate_control start'
      INFO  [muorb] SLPI: qshell gotten: mc_rate_control start
      INFO  [muorb] SLPI:   arg0 = 'mc_rate_control'
      INFO  [uORB] Advertising remote topic rate_ctrl_status
      INFO  [muorb] SLPI: Ok executing command: mc_rate_control start
      INFO  [qshell] qshell return value timestamp: 815678230, local time: 815682065
      INFO  [qshell] Send cmd: 'mc_hover_thrust_estimator start'
      INFO  [muorb] SLPI: qshell gotten: mc_hover_thrust_estimator start
      INFO  [muorb] SLPI:   arg0 = 'mc_hover_thrust_estimator'
      INFO  [muorb] SLPI: Ok executing command: mc_hover_thrust_estimator start
      INFO  [qshell] qshell return value timestamp: 815746736, local time: 815748268
      INFO  [qshell] Send cmd: 'mc_autotune_attitude_control start'
      INFO  [muorb] SLPI: qshell gotten: mc_autotune_attitude_control start
      INFO  [muorb] SLPI:   arg0 = 'mc_autotune_attitude_control'
      INFO  [uORB] Advertising remote topic autotune_attitude_control_status
      INFO  [muorb] SLPI: Ok executing command: mc_autotune_attitude_control start
      INFO  [qshell] qshell return value timestamp: 815789804, local time: 815791337
      INFO  [qshell] Send cmd: 'land_detector start multicopter'
      INFO  [muorb] SLPI: qshell gotten: land_detector start multicopter
      INFO  [muorb] SLPI:   arg0 = 'land_detector'
      INFO  [muorb] SLPI:   arg2 = 'multicopter'
      INFO  [muorb] SLPI: Ok executing command: land_detector start multicopter
      INFO  [qshell] qshell return value timestamp: 815839581, local time: 815841469
      INFO  [uORB] Advertising remote topic vehicle_land_detected
      INFO  [qshell] Send cmd: 'manual_control start'
      INFO  [muorb] SLPI: qshell gotten: manual_control start
      INFO  [muorb] SLPI:   arg0 = 'manual_control'
      INFO  [muorb] SLPI: Ok executing command: manual_control start
      INFO  [uORB] Advertising remote topic manual_control_setpoint
      INFO  [qshell] qshell return value timestamp: 815912276, local time: 815914468
      INFO  [qshell] Send cmd: 'control_allocator start'
      INFO  [muorb] SLPI: qshell gotten: control_allocator start
      INFO  [muorb] SLPI:   arg0 = 'control_allocator'
      INFO  [uORB] Advertising remote topic control_allocator_status
      INFO  [uORB] Marking DeviceNode(control_allocator_status) as advertised in process_remote_topic
      INFO  [uORB] Advertising remote topic actuator_motors
      INFO  [uORB] Advertising remote topic actuator_servos
      INFO  [uORB] Advertising remote topic actuator_servos_trim
      INFO  [muorb] SLPI: Ok executing command: control_allocator start
      INFO  [qshell] qshell return value timestamp: 816195197, local time: 816196869
      INFO  [muorb] SLPI: qshell gotten: rc_update start
      INFO  [muorb] SLPI:   arg0 = 'rc_update'
      INFO  [qshell] Send cmd: 'rc_update start'
      INFO  [muorb] SLPI: Ok executing command: rc_update start
      INFO  [qshell] qshell return value timestamp: 816521809, local time: 816523074
      INFO  [qshell] Send cmd: 'commander start -h'
      INFO  [muorb] SLPI: qshell gotten: commander start -h
      INFO  [muorb] SLPI:   arg0 = 'commander'
      INFO  [muorb] SLPI: Creating pthread commander
      INFO  [muorb] SLPI: Successfully created px4 task PX4_commander with tid 2097647
      INFO  [uORB] Advertising remote topic led_control
      INFO  [muorb] SLPI: LED: open /dev/led0 failed (22)
      INFO  [uORB] Advertising remote topic tune_control
      INFO  [muorb] SLPI: Ok executing command: commander start -h
      INFO  [qshell] qshell return value timestamp: 816759292, local time: 816761239
      INFO  [muorb] SLPI: orb_advertise_multi: failed to set queue size
      INFO  [muorb] SLPI: Preflight Fail: Accel Sensor 0 missing
      INFO  [muorb] SLPI: Preflight Fail: barometer 0 missing
      INFO  [muorb] SLPI: Preflight Fail: ekf2 missing data
      INFO  [muorb] SLPI: Preflight Fail: Gyro Sensor 0 missing
      INFO  [uORB] Advertising remote topic health_report
      INFO  [uORB] Advertising remote topic failsafe_flags
      INFO  [uORB] Advertising remote topic actuator_armed
      INFO  [uORB] Advertising remote topic vehicle_control_mode
      INFO  [uORB] Advertising remote topic vehicle_status
      INFO  [uORB] Advertising remote topic failure_detector_status
      INFO  [qshell] Send cmd: 'commander mode posctl'
      INFO  [muorb] SLPI: qshell gotten: commander mode posctl
      INFO  [muorb] SLPI:   arg1 = 'mode'
      INFO  [muorb] SLPI:   arg2 = 'posctl'
      INFO  [uORB] Advertising remote topic vehicle_command
      INFO  [muorb] SLPI: Ok executing command: commander mode posctl
      INFO  [qshell] qshell return value timestamp: 816809125, local time: 816812053
      INFO  [uORB] Advertising remote topic vehicle_command_ack
      INFO  [qshell] Send cmd: 'param_set_selector start'
      INFO  [muorb] SLPI: qshell gotten: param_set_selector start
      INFO  [muorb] SLPI:   arg0 = 'param_set_selector'
      INFO  [muorb] SLPI: Ok executing command: param_set_selector start
      INFO  [qshell] qshell return value timestamp: 816848368, local time: 816850576
      INFO  [qshell] Send cmd: 'flight_mode_manager start'
      INFO  [muorb] SLPI: qshell gotten: flight_mode_manager start
      INFO  [muorb] SLPI:   arg0 = 'flight_mode_manager'
      INFO  [uORB] Marking DeviceNode(vehicle_command) as advertised in process_remote_topic
      INFO  [muorb] SLPI: Ok executing command: flight_mode_manager start
      INFO  [qshell] qshell return value timestamp: 816974943, local time: 816976246
      INFO  [dataman] data manager file '/data/px4/dataman' size is 7866640 bytes
      INFO  [muorb] SLPI: Advertising remote topic transponder_report
      INFO  [muorb] SLPI: Advertising remote topic rtl_time_estimate
      INFO  [muorb] SLPI: Advertising remote topic position_setpoint_triplet
      INFO  [qshell] Send cmd: 'pwm_out_sim start -m hil'
      INFO  [muorb] SLPI: qshell gotten: pwm_out_sim start -m hil
      INFO  [muorb] SLPI:   arg0 = 'pwm_out_sim'
      INFO  [muorb] SLPI:   arg2 = '-m'
      INFO  [muorb] SLPI:   arg3 = 'hil'
      INFO  [uORB] Advertising remote topic actuator_outputs
      INFO  [muorb] SLPI: Ok executing command: pwm_out_sim start -m hil
      INFO  [uORB] Advertising remote topic actuator_outputs_sim
      INFO  [qshell] qshell return value timestamp: 818185249, local time: 818187816
      INFO  [qshell] Send cmd: 'dsp_hitl start'
      INFO  [muorb] SLPI: qshell gotten: dsp_hitl start
      INFO  [muorb] SLPI:   arg0 = 'dsp_hitl'
      INFO  [muorb] SLPI: Creating pthread dsp_hitl__main
      INFO  [muorb] SLPI: Successfully created px4 task PX4_dsp_hitl__main with tid 2097645
      INFO  [muorb] SLPI: Ok executing command: dsp_hitl start
      **ERROR [muorb] SLPI: Port is open: 0**
      INFO  [muorb] SLPI: Got 5 from orb_subscribe
      INFO  [qshell] qshell return value timestamp: 818227135, local time: 818228965
      INFO  [uORB] Advertising remote topic esc_status
      INFO  [mavlink] mode: Onboard, data rate: 100000 B/s on udp port 14556 remote port 14557
      INFO  [muorb] SLPI: Advertising remote topic telemetry_status
      INFO  [mavlink] partner IP: 127.0.0.1
      INFO  [muorb] SLPI: Advertising remote topic timesync_status
      INFO  [mavlink] mode: Normal, data rate: 100000 B/s on udp port 14558 remote port 14559
      INFO  [muorb] SLPI: Marking DeviceNode(telemetry_status) as advertised in process_remote_topic
      INFO  [uORB] Advertising remote topic vehicle_imu
      INFO  [uORB] Advertising remote topic vehicle_imu_status
      INFO  [muorb] SLPI: Preflight Fail: No valid data from Accel 0
      INFO  [muorb] SLPI: Preflight Fail: No valid data from Gyro 0
      INFO  [mavlink] MAVLink only on localhost (set param MAV_{i}_BROADCAST = 1 to enable network)
      pxh>
      the only thing I find suspicious about this is:
      any hint on what could be wrong?
      thank you,
      ModeratorM Eric KatzfeyE 3 Replies Last reply Reply Quote 0
      • ModeratorM
        Moderator ModalAI Team @tiralonghipol
        @tiralonghipol can you please share the version of software you are using as well as a picture of your setup (specifically the wiring)?
        • Eric KatzfeyE
          Eric Katzfey ModalAI Team @tiralonghipol
          @tiralonghipol said in HITL Starling/Voxl2:
          Port is open
          That isn't actually an error. It was only output as an error to make it stand out. It's really just an indication that the serial port was opened successfully. We should probably change that to a regular info message instead of an error report.
          tiralonghipolT 1 Reply Last reply Reply Quote 0
          • tiralonghipolT
            tiralonghipol @Eric Katzfey
            @Eric-Katzfey of course sorry I forgot!
            system-image: 1.6.2-M0054-14.1a-perf
            kernel: #1 SMP PREEMPT Fri May 19 22:19:33 UTC 2023 4.19.125
            hw version: M0054
            px4-ver all
            HW arch: MODALAI_VOXL2
            PX4 git-hash: d21e9718a77d72334e03dff79f2a7cb8e413b3a9
            PX4 version: 1.14.0 0 (17694720)
            PX4 git-branch: voxl-dev
            Vendor version: 2.0.56 0 (33568768)
            OS: Linux
            OS version: Release 4.19.125 (68386303)
            Build datetime: Nov 1 2023 15:16:24
            Build uri: localhost
            Build variant: default
            Toolchain: GNU GCC, 7.5.0
            PX4GUID: 100a41444f4d5649414c324c584f30303030
            UNKNOWN MCU
            this cable I'm using also has visual feedback on rx/tx with a green/red led
            I then suspect it is not a wiring issue but of course I might be wrong
            • Eric KatzfeyE
              This part is telling us that there is no accelerometer, gyro, or barometer data. This is the data that is supposed to come in from gazebo over the serial link. So there is something wrong with that data transfer. Could be a cable issue of some type. At the px4 console what do you get when you enter qshell dsp_hitl status?
              • tiralonghipolT
                @Eric-Katzfey thank you for the reply
                this is the output to the command you suggested:
                pxh> qshell dsp_hitl status
                INFO  [qshell] Send cmd: 'dsp_hitl status'
                INFO  [muorb] SLPI: qshell gotten: dsp_hitl status
                INFO  [muorb] SLPI:   arg1 = 'status'
                INFO  [muorb] SLPI: Running: no
                INFO  [muorb] SLPI: Status of IMU_Data counter: 0
                INFO  [muorb] SLPI: Value of current accel x, y, z data: 0.000000, 0.000000, 0.000000
                INFO  [muorb] SLPI: Value of current gyro x, y, z data: 0.000000, 0.000000, 0.000000
                INFO  [muorb] SLPI: Value of HIL_Sensor counter: 0
                INFO  [muorb] SLPI: Value of Heartbeat counter: 4
                INFO  [muorb] SLPI: Value of Vision data counter: 0
                INFO  [muorb] SLPI: Value of GPS Data counter: 0
                INFO  [muorb] SLPI: Ok executing command: dsp_hitl status
                INFO  [qshell] qshell return value timestamp: 59399090, local time: 59402895
                pxh>
                then I thought ok, maybe id did not start for some reason.
                I then run
                qshell dsp_hitl start
                INFO  [muorb] SLPI: Successfully created px4 task PX4_dsp_hitl__main with tid 2097643
                ERROR [muorb] SLPI: Port in use: 2 (22)
                ERROR [muorb] SLPI: Port is open: -1
                INFO  [uORB] Marking DeviceNode(sensor_accel) as advertised in process_remote_topic
                INFO  [uORB] Marking DeviceNode(sensor_gyro) as advertised in process_remote_topic
                INFO  [qshell] qshell return value timestamp: 1093811038, local time: 1093815063
                pxh> INFO  [muorb] SLPI: Got 8 from orb_subscribe
                INFO  [uORB] Marking DeviceNode(vehicle_imu) as advertised in process_remote_topic
                INFO  [uORB] Marking DeviceNode(vehicle_imu_status) as advertised in process_remote_topic
                Eric KatzfeyE 2 Replies Last reply Reply Quote 0
                • Eric KatzfeyE
                  @tiralonghipol Yeah, so that status tells us that it isn't getting any data over the serial port. So we need to figure out why not. In your first post you show that you start gazebo with:
                  Was that a typo? It should be hitl_iris.world not hitl_iris_flex.world. I'm not sure if that would cause a problem or not. Do you have a way to diagnose the serial cable? Can you reverse the tx and rx pins and see if that changes things? Can you look at the output of the cable tx line with an oscilloscope to see if you can detect data being sent by gazebo?
                  • Eric KatzfeyE
                    @tiralonghipol You shouldn't have to start dsp_hitl. If you start px4 with the voxl-px4-hitl command then it will be started automatically.
