  3. Error when running voxl-cross image on Voxl2
5 Posts 3 Posters 1.0k Views 1 Watching
  • M Offline
    M Offline
    martongonczy
    I am trying to run the voxl-cross image on the Voxl2 but after I push the image to the drone and try to run it I get this message.
    I only added a few lines to the Dockerfile (to have opencv and numpy) and changed the build command to be compatible with the target environment (linux/arm64/v8) as I had that error originally.
    Does someone know what the problem could be? I cannot find any information about this on the internet.
    • M martongonczy
      Eric KatzfeyE Online
      @martongonczy voxl-cross is a docker image you run on your host machine. It has a cross compiler to build applications to run on voxl. On voxl2 you have native compilers installed and don't need a docker.
      M 1 Reply Last reply
        M Offline
        M Offline
        martongonczy
        @Eric-Katzfey Thank you for your reply.
        So if I want to have OpenCV and Numpy installed on the drone I have to download it directly onto the drone without using Docker?
        ModeratorM 1 Reply Last reply
        • M martongonczy
          @martongonczy OpenCV is already installed on VOXL 2. numpy would require you to install it
          • ModeratorM Moderator
            M Offline
            M Offline
            martongonczy
            @Moderator thank you for your help. When I run cmake it throws an error saying that it cannot locate OpenCV, I am using
            Find the OpenCV package
            find_package(OpenCV REQUIRED)
            include_directories( ${OpenCV_INCLUDE_DIRS} )
            This is from the OpenCV documentation but it does not work for me. What could be the solution?
