  3. Voxl2 Spektrum Receiver error
90 Posts 4 Posters 49.8k Views 3 Watching
    @Eric-Katzfey And can you wait a little longer to get more data in the log? I'd like to see the data dumps of more packets.
    Chase RileyC Offline
    Chase Riley
    @Eric-Katzfey I am able to calibrate the RC now with that Debian. Here is the log after letting it run a little longer. Let me know if you need more in the log. Would you recommend flying with this Debian File?
    INFO  [muorb] SLPI: Spektrum RC: 16 bytes from UART, protocol byte 0x03
    INFO  [muorb] SLPI: Spektrum RC: DSM message parsed successfully
    INFO  [muorb] SLPI: Spektrum RC: Publishing input_rc
    INFO  [muorb] SLPI: 0x00 0x03 0x81 0x56 0x39 0x56 0x1c 0x0c
    INFO  [muorb] SLPI: 0x44 0x00 0x4c 0x00 0x5c 0x00 0x61 0x00
    INFO  [muorb] SLPI: Ok executing command: rc_update start
    INFO  [qshell] qshell return value timestamp: 356493009, local time: 356495308
    INFO  [uORB] Advertising remote topic rc_channels
    INFO  [qshell] Send cmd: 'commander start'
    INFO  [muorb] SLPI: qshell gotten: commander start
    INFO  [muorb] SLPI:   arg0 = 'commander'
    INFO  [muorb] SLPI:   arg1 = 'start'
    INFO  [muorb] SLPI: Creating pthread commander
    INFO  [muorb] SLPI: Successfully created px4 task PX4_commander with tid 2097639
    INFO  [uORB] Advertising remote topic manual_control_input
    INFO  [uORB] Advertising remote topic manual_control_switches
    INFO  [uORB] Advertising remote topic action_request
    INFO  [uORB] Advertising remote topic led_control
    INFO  [muorb] SLPI: LED: open /dev/led0 failed (22)
    INFO  [uORB] Advertising remote topic tune_control
    INFO  [muorb] SLPI: Ok executing command: commander start
    INFO  [qshell] qshell return value timestamp: 356734246, local time: 356736417
    INFO  [uORB] Advertising remote topic event
    INFO  [uORB] Advertising remote topic health_report
    INFO  [uORB] Advertising remote topic failsafe_flags
    INFO  [uORB] Advertising remote topic actuator_armed
    INFO  [uORB] Advertising remote topic vehicle_control_mode
    INFO  [uORB] Advertising remote topic vehicle_status
    INFO  [uORB] Advertising remote topic failure_detector_status
    INFO  [uORB] Advertising remote topic vehicle_thrust_setpoint
    INFO  [uORB] Advertising remote topic vehicle_torque_setpoint
    INFO  [uORB] Advertising remote topic vehicle_attitude_setpoint
    INFO  [uORB] Advertising remote topic vehicle_rates_setpoint
    INFO  [qshell] Send cmd: 'flight_mode_manager start'
    INFO  [muorb] SLPI: qshell gotten: flight_mode_manager start
    INFO  [muorb] SLPI:   arg0 = 'flight_mode_manager'
    INFO  [muorb] SLPI: 0x44 0x00 0x4c 0x00 0x5c 0x00 0x63 0x00
    INFO  [uORB] Advertising remote topic vehicle_command
    INFO  [muorb] SLPI: Ok executing command: flight_mode_manager start
    INFO  [qshell] qshell return value timestamp: 356898624, local time: 356901074
    INFO  [dataman] data manager file '/data/px4/dataman' size is 7866640 bytes
    INFO  [muorb] SLPI: Advertising remote topic transponder_report
    INFO  [muorb] SLPI: Advertising remote topic rtl_time_estimate
    INFO  [muorb] SLPI: Advertising remote topic position_setpoint_triplet
    INFO  [modal_io_bridge] Modal IO Bridge driver starting
    INFO  [mavlink] mode: Onboard, data rate: 100000 B/s on udp port 14556 remote port 14557
    INFO  [muorb] SLPI: Advertising remote topic telemetry_status
    INFO  [mavlink] partner IP: 127.0.0.1
    INFO  [muorb] SLPI: Advertising remote topic offboard_control_mode
    INFO  [muorb] SLPI: Advertising remote topic obstacle_distance
    INFO  [muorb] SLPI: 0x44 0x00 0x4c 0x00 0x5c 0x00 0x65 0x00
    INFO  [muorb] SLPI: Advertising remote topic timesync_status
    INFO  [uORB] Advertising remote topic actuator_controls_status_0
    INFO  [mavlink] mode: Normal, data rate: 100000 B/s on udp port 14558 remote port 14559
    INFO  [muorb] SLPI: Marking DeviceNode(telemetry_status) as advertised in process_remote_topic
    INFO  [mavlink] MAVLink only on localhost (set param MAV_{i}_BROADCAST = 1 to enable network)
    pxh> INFO  [muorb] SLPI: Spektrum RC: 16 bytes from UART, protocol byte 0x03
    INFO  [muorb] SLPI: Sending initial CFG_VALSET. Attempt: 2
    INFO  [uORB] Advertising remote topic mavlink_log
    ERROR [muorb] SLPI: Preflight Fail: low battery
    INFO  [muorb] SLPI: Sending initial CFG_VALSET. Attempt: 3
    INFO  [muorb] SLPI: u-blox firmware version: SPG 3.01
    INFO  [muorb] SLPI: u-blox protocol version: 18.00
    INFO  [muorb] SLPI: u-blox module: NEO-M8N-0
    INFO  [uORB] Advertising remote topic sensor_gps
    INFO  [uORB] Advertising remote topic home_position
    INFO  [uORB] Advertising remote topic estimator_gps_status
    INFO  [uORB] Advertising remote topic estimator_aid_src_gnss_hgt
    INFO  [uORB] Advertising remote topic estimator_aid_src_gnss_pos
    INFO  [uORB] Advertising remote topic estimator_aid_src_gnss_vel
    INFO  [muorb] SLPI: Advertising remote topic mission_result
    INFO  [muorb] SLPI: Advertising remote topic ping
    • Chase RileyC Chase Riley
      Eric KatzfeyE Online
      @Chase-Riley Looks like the data is stable. It just doesn't seem the protocol byte to a stable value. Very odd. But I would try a flight with it in a carefully controlled environment in case anything goes wrong. In the worst case it could go out of control and you might not be able to use the kill switch so be safe.
        @Chase-Riley Here is a link to the transmitter we use: https://www.horizonhobby.com/product/dx6e-6-channel-dsmx-transmitter-only/SPMR6655.html
        Chase RileyC 4 Replies Last reply
          Chase Riley
          @Eric-Katzfey When getting everything tested to go out and fly I started receiving a failsafe for ESC failure. When we were working with this back in SDK 1.0 in this thread. I had the issue of the actuators tab not showing up in QGC. I can now see the actuators tab on SDK 1.1.2 however I can not test the motors and when I try to arm I receive ESC Failure message. I am not sure if this has something to do with the custom deb file like it did when I couldn't see the actuators tab.
          I can upload firmware and params to the ESC fine. Running voxl-esc-scan.py returns no issues. Any thoughts?
            Chase Riley
            wrote on last edited by Chase Riley
            #65
            @Eric-Katzfey I was able to solve the ESC issue. It was not linked to the Spektrum issue. After getting the ESC to function I was not able to control throttle on the air vehicle. I am able to calibrate the RC controller and set flight modes and so on. Everything seems normal until a arm the motors (testing in Stabilize). The motors arm and spin up but I am unable to change the speed on the motors with any input of the controller. I checked the Px4 RC params and all match previously good known params. I have inlcluded a snippet of running voxl-px4 -d with Spektrum sill with -v argument. I noticed there was another error with a different value and was also 32 bytes instead of the 16 bytes we have been seeing.
            INFO  [muorb] SLPI: 0x21 0x56 0x36 0xaa 0x54 0x00 0x63 0x00
            INFO  [muorb] SLPI: Spektrum RC: 16 bytes from UART, protocol byte 0x02
            INFO  [muorb] SLPI: 0x00 0x02 0x0b 0xf5 0x2e 0xaa 0x13 0xfe
            INFO  [muorb] SLPI: 0x21 0x56 0x36 0xaa 0x54 0x00 0x65 0x00
            INFO  [muorb] SLPI: 0x00 0x02 0x0b 0xf5 0x2e 0xaa 0x13 0xff
            INFO  [muorb] SLPI: Armed by external command
            INFO  [uORB] Advertising remote topic vehicle_command_ack
            INFO  [logger] Start file log (type: full)
            WARN  [uORB] orb_advertise_multi: failed to set queue size
            INFO  [logger] [logger] /data/px4/log/2024-01-23/16_57_27.ulg
            WARN  [mavlink] Event dropped (7, 65526)
            INFO  [logger] Opened full log file: /data/px4/log/2024-01-23/16_57_27.ulg
            INFO  [muorb] SLPI: Advertising remote topic logger_status
            WARN  [mavlink] Dropped 65519 events (seq=65526)
            INFO  [muorb] SLPI: Takeoff detected
            WARN  [mavlink] Event dropped (65527, 7)
            WARN  [mavlink] Dropped 7 events (seq=7)
            INFO  [muorb] SLPI: baudrate set to 9600
            INFO  [muorb] SLPI: Sending initial CFG_VALSET. Attempt: 1
            INFO  [muorb] SLPI: Landing detected
            ERROR [muorb] SLPI: Spektrum RC: Invalid DSM frame. 32 bytes. Protocol byte 0x02
            INFO  [muorb] SLPI: Disarmed by landing
            INFO  [uORB] Marking DeviceNode(parameter_server_set_value_request) as advertised in process_remote_topic
            INFO  [muorb] SLPI: Marking DeviceNode(parameter_server_set_value_response) as advertised in process_remote_t
              Chase Riley
              #66
              @Eric-Katzfey I am also getting my hands on a DX6e for me to test. I should be able to try that in the morning. I still would like to figure out the DX8 as well though since we already have a bunch on hand in our lab.
                @Chase-Riley Did you analyze the flight log?
                  @Chase-Riley For the DX8 there are some configuration options on the transmitter. There is DSMX versus DSM2. That may need to be changed. Have you tried the different options yet?
                    Chase Riley
                    @Eric-Katzfey I have tried all of the options in the DX8. 11, 22 and DSM2, DSMX. They all seemed to produce the same results in the logs.
                      Chase Riley
                      @Eric-Katzfey Here is a voxl-px4 log while testing with a DX6e this morning. I was able to bind and calibrate no problem. I am just not able to control the motors. Flight mode and kill switch seem to be working fine. So seems to have the same behavior as the DX8 with a error in the log for 32 bytes and 0x00.
                      INFO  [muorb] SLPI: 0x00 0x00 0x8c 0x05 0x01 0x56 0x14 0x00
                      INFO  [muorb] SLPI: 0x1b 0xf5 0x2e 0xaa 0x3c 0x00 0x34 0x00
                      INFO  [muorb] SLPI: Spektrum RC: 16 bytes from UART, protocol byte 0x00
                      INFO  [muorb] SLPI: 0x1b 0xf6 0x2e 0xaa 0x3c 0x00 0x34 0x00
                      ERROR [muorb] SLPI: Spektrum RC: Invalid DSM frame. 32 bytes. Protocol byte 0x00
                      INFO  [logger] [logger] /data/px4/log/2024-01-24/19_14_37.ulg
                      INFO  [logger] Opened full log file: /data/px4/log/2024-01-24/19_14_37.ulg
                      WARN  [mavlink] Event dropped (297, 65527)
                      WARN  [mavlink] Dropped 65230 events (seq=65527)
                        @Chase-Riley Huh, that still doesn't look right. When you calibrate you can move each stick and it shows properly in QGC? And listener input_rc shows the values moving properly when you move the sticks? What is the value of the parameter COM_RC_IN_MODE?
                          Chase Riley
                          @Eric-Katzfey yes, each stick moves correctly in QGC. listener input_rc shows all sticks move correctly. I have tested with COM_RC_IN_MODE set to 0 and 2 and both yield the same results.
                            @Chase-Riley And they are mapped correctly such that throttle is on the stick you want? Can you do listener on manual_control_setpoint and see the throttle value move when you move the throttle stick?
                              Chase Riley
                              @Eric-Katzfey RC_MAP_THROTTLE is set to Channel 3, RC_MAP_YAW is set to Channel 4, RC_MAP_ROLL is set to Channel 1, and RC_MAP_PITCH is set to Channel 2.
                              Moving the Throttle and Yaw stick while running listener manual_control_setpoint shows Throttle and Yaw changing values as it should. It also shows that Stick movement goes TRUE.
                                @Chase-Riley Then at this point I can't think of how the RC could be related to the motors not spinning up. Can you arm, try to throttle up a few times, then disarm and send us the px4 flight log?
                                  @Chase-Riley And you have tried to throttle up in manual flight mode?
                                    Chase Riley
                                    @Eric-Katzfey I have tried to spin the motors in manual mode as well with no change. I have included a drop box link with the px4 flight log you requested.
                                    https://www.dropbox.com/scl/fi/z5jnzbj44lnezjyhuzh8d/DX6e_Throttle_Test_log.ulg?rlkey=csjcwa2eu7n9g20xfah9bz7u3&dl=0
                                      @Chase-Riley I'm having some others take a look at the log file. I'm kind of stumped at the moment.
                                        Chase Riley
                                        @Eric-Katzfey Please let me know what you or your team find. This seems to be the last hurdle to getting me to flight testing. I have a shipping deadline to make on Friday with this system.
                                        Eric KatzfeyE Alex KushleyevA 2 Replies Last reply
                                          @Chase-Riley Seems like ESC param issue. Alex is going to respond with some suggestions.
