  3. Wifi dongle hardware does not turn on sometimes
sentinel
3 Posts 3 Posters 914 Views 1 Watching
  • S Offline
    S Offline
    stevedan
    We noticed that at random moments, the Wi-Fi dongle does not turn on (the light does not blink at all). When we access the drone via adb shell, we observe that the network interface for Wi-Fi, wlan0, is not up. Attempting to bring it up does not resolve the issue. Additionally, there are times when the drone connects, and wlan0 is up, but I cannot ping the drone's IP from outside as it reports "network not reachable." From inside the drone, pinging 8.8.8.8 also does not work. What we've discovered as a temporary solution is to restart the drone using "sudo reboot now," which sometimes resolves the problem and sometimes does not. More information about the drone is available below.
    Just for your information, we also have a static IP set. I suspect it's a hardware issue because when the problem occurs, the Wi-Fi dongle is not blinking.
    Sentinel
    What version of software are you using? voxl-version is very helpful for determining software version.
    system-image: 1.6.2-M0054-14.1a-perf
    kernel:       #1 SMP PREEMPT Fri May 19 22:19:33 UTC 2023 4.19.125
    hw version:   M0054
    voxl-suite:   1.0.0~beta4
    current IP: wlan0: 192.168.1.17
    How have you configured the software? What is the output of voxl-inspect-services
    voxl2:/$ voxl-inspect-services
    Scanning services...
     Service Name          |  Enabled  |   Running   |  CPU Usage
     docker-autorun        | Disabled  | Not Running |
     docker-daemon         | Disabled  | Not Running |
     modallink-relink      | Disabled  | Not Running |
     voxl-camera-server    |  Enabled  |   Running   |    16.7%
     voxl-cpu-monitor      |  Enabled  |   Running   |     0.5%
     voxl-dfs-server       | Disabled  | Not Running |
     voxl-feature-tracker  | Disabled  | Not Running |
     voxl-flow-server      | Disabled  | Not Running |
     voxl-imu-server       |  Enabled  |   Running   |     4.8%
     voxl-lepton-server    | Disabled  | Not Running |
     voxl-mavcam-manager   |  Enabled  |   Running   |     0.0%
     voxl-mavlink-server   |  Enabled  |   Running   |     3.4%
     voxl-modem            | Disabled  | Not Running |
     voxl-portal           |  Enabled  |   Running   |     0.2%
     voxl-px4-imu-server   | Disabled  | Not Running |
     voxl-px4              |  Enabled  |   Running   |    31.9%
     voxl-qvio-server      |  Enabled  |   Running   |    40.3%
     voxl-remote-id        | Disabled  | Not Running |
     voxl-softap           | Disabled  | Not Running |
     voxl-static-ip        |  Enabled  | Not Running |
     voxl-streamer         |  Enabled  |   Running   |     0.0%
     voxl-tag-detector     | Disabled  | Not Running |
     voxl-tflite-server    | Disabled  | Not Running |
     voxl-time-sync        | Disabled  | Not Running |
     voxl-uvc-server       | Disabled  | Not Running |
     voxl-vision-hub       |  Enabled  |   Running   |     2.6%
     voxl-wait-for-fs      |  Enabled  |  Completed  |
    voxl2:/$
    Do you have any logs? Uploading PX4 logs to https://logs.px4.io can be very helpful. See details on PX4 logs here
    Not px4 specific
    Can you share pictures of your setup?
    ModeratorM tomT 2 Replies Last reply
    • S stevedan
      Sentinel
      hw version:   M0054
      voxl2:/$
      Not px4 specific
      @stevedan could it simply be loose? Maybe the radio is not getting power
      • S stevedan
        Sentinel
        hw version:   M0054
        voxl2:/$
        Not px4 specific
        @stevedan As a side note, I would recommend upgrading to the official SDK 1.0 as opposed to beta4 as there are many bug fixes between the two
