  3. PX4 Params Lost
PX4 Params Lost
11 Posts 3 Posters 801 Views 1 Watching
  • S Offline
    S Offline
    SMRazaRizvi
    Hi, I recently flashed my Sentinel drone, and apparently, the files under /data/px4/params are missing.
    How can I recover the following factory default params files for the Sentinel drone:
    parameters_gyro.cal
    parameters_acc.cal
    parameters_mag.cal
    parameters_level.cal
    I have tried calibrating the Compass using QGC, but it doesn't perform accurate calibration, and unless this issue is resolved, I cannot fly up the drone.
    Please help.
    • S SMRazaRizvi
      parameters_gyro.cal
      parameters_acc.cal
      parameters_mag.cal
      Please help.
      @SMRazaRizvi What do you mean that compass calibration is not accurate?
      S 1 Reply Last reply
        S Offline
        S Offline
        SMRazaRizvi
        @Eric-Katzfey
        I mean, even after calibration, my drone constantly drifts toward the back. Any clue?
        • S SMRazaRizvi
          @Eric-Katzfey
          @SMRazaRizvi The compass provides heading information. Having a poor calibration on the compass wouldn't cause the drone to drift.
            S Offline
            S Offline
            SMRazaRizvi
            @Eric-Katzfey
            I see. What can be the reason then?
            ModeratorM 1 Reply Last reply
            • S SMRazaRizvi
              @Eric-Katzfey
              @SMRazaRizvi Do you have any trim settings on your controller? The level calibration could also affect
              • ModeratorM Moderator
                S Offline
                S Offline
                SMRazaRizvi
                @Moderator How can I check the trim settings?
                • ModeratorM Offline
                  have you posted your PX4 logs to logs.px4.io for analysis?
                    S Offline
                    S Offline
                    SMRazaRizvi
                    @Moderator Yes I did.
                    • S SMRazaRizvi
                      @SMRazaRizvi Can you please share so we can try to help you? The logs should help diagnose why it is drifting
                        S Offline
                        S Offline
                        SMRazaRizvi
                        @Moderator Here you go.
                        https://drive.google.com/drive/folders/1SHGs2EipV4wpoIZQzzzGKm-ze1DpTbI6?usp=drive_link
