    PX4 Params Lost
    227
    • S
      SMRazaRizvi
      Hi, I recently flashed my Sentinel drone, and apparently, the files under /data/px4/params are missing.
      How can I recover the following factory default params files for the Sentinel drone:
      parameters_gyro.cal
      parameters_acc.cal
      parameters_mag.cal
      parameters_level.cal
      I have tried calibrating the Compass using QGC, but it doesn't perform accurate calibration, and unless this issue is resolved, I cannot fly up the drone.
      Please help.
        Eric Katzfey ModalAI Team @SMRazaRizvi
        @SMRazaRizvi What do you mean that compass calibration is not accurate?
        • S
          SMRazaRizvi @Eric Katzfey
          I mean, even after calibration, my drone constantly drifts toward the back. Any clue?
            @SMRazaRizvi The compass provides heading information. Having a poor calibration on the compass wouldn't cause the drone to drift.
            • S
              I see. What can be the reason then?
              • ModeratorM
                Moderator ModalAI Team @SMRazaRizvi
                @SMRazaRizvi Do you have any trim settings on your controller? The level calibration could also affect
                • S
                  SMRazaRizvi @Moderator
                  @Moderator How can I check the trim settings?
                  • ModeratorM
                    have you posted your PX4 logs to logs.px4.io for analysis?
                    • S
                      @Moderator Yes I did.
                      • ModeratorM
                        @SMRazaRizvi Can you please share so we can try to help you? The logs should help diagnose why it is drifting
                        • S
                          @Moderator Here you go.
                          https://drive.google.com/drive/folders/1SHGs2EipV4wpoIZQzzzGKm-ze1DpTbI6?usp=drive_link
