    Connecting USB drive to Voxl2 mini J9 connector.
    VOXL 2 Mini
    • B
      Brendon
      Good morning. Looking in the documentation I see mention on using the J9 connector as a secondary HOST port.
      My plan is to use one of the UARTs as a tty to access the device using a shell to debug our software and/or to toggle between HOST mode and the default mode.
      What I can't find is a tutorial or specific steps I need to take to be able to change the port into HOST mode and back to peripheral mode. In particular:
      • Software/configuration changes needed to change to HOST mode?
      • Some documentation mentions needing to use special cables, while others do not.
      Any examples would be fantastic.
      Brendon.
      • ModeratorM
        Moderator ModalAI Team
        VOXL 2 Mini USB OTG negotiates automatically. There should not be a special cable required for VOXL 2 Mini
        VOXL 1 required a special cable and VOXL 2 OTG does not currently work
        B 2 Replies Last reply Reply Quote 1
        • B
          Brendon @Moderator
          @Moderator Thank you, that is fantastic news, and makes my life a lot easier.
          • B
            Brendon @Moderator
            @Moderator Can you take a look at my new post.
            I can see that the mount command in syslog. No errors, but the mounted file system doesn't show up.
            Brendon.
