Connecting USB drive to Voxl2 mini J9 connector.
Good morning. Looking in the documentation I see mention on using the J9 connector as a secondary HOST port.
My plan is to use one of the UARTs as a tty to access the device using a shell to debug our software and/or to toggle between HOST mode and the default mode.
What I can't find is a tutorial or specific steps I need to take to be able to change the port into HOST mode and back to peripheral mode. In particular:
- Software/configuration changes needed to change to HOST mode?
- Some documentation mentions needing to use special cables, while others do not.
Any examples would be fantastic.
Brendon. -
VOXL 2 Mini USB OTG negotiates automatically. There should not be a special cable required for VOXL 2 Mini
VOXL 1 required a special cable and VOXL 2 OTG does not currently work
@Moderator Thank you, that is fantastic news, and makes my life a lot easier.
@Moderator Can you take a look at my new post.
I can see that the mount command in syslog. No errors, but the mounted file system doesn't show up.Thanks,
Brendon.
