  3. Connect the VOXL 2 I/O using the UART port on the 5G modem
29 Posts 6 Posters 7.6k Views 3 Watching
  • X Offline
    X Offline
    xav04
    Hi everyone, I have been trying to connect the VOXL 2 I/O to the J9 UART/I2C port on the 5G modem but it doesn't work. Is there a way to use the UART port on the 5G modem?
    • X xav04
      @xav04 Here is an example of doing so: https://docs.modalai.com/voxl2-external-flight-controller/#using-m2-5g-modem-addon-board-m0090
        @tom also I'd recommend using the latest software release (SDK 0.9.5) to ensure the software support is there
        X 1 Reply Last reply
          X Offline
          X Offline
          xav04
          @tom Thanks! I followed the instructions, but the Voxl 2 I/O is still in waiting mode. This is a screenshot of the voxl-mavlink-server.conf file and the voxl-mavlink-server status, it's enable and running. Please let me know how to fix this.
          I'm using voxl-suite: 0.9.5
          • X xav04
            @xav04 You may find some helpful info here:
            https://docs.modalai.com/voxl2-io-user-guide/
            https://docs.modalai.com/voxl2-io-developer-guide/
            X 2 Replies Last reply
              X Offline
              X Offline
              xav04
              wrote on last edited by xav04
              @tom I was able to connect Voxl 2 I/O using the J19 UART on Voxl 2 (proving that the Voxl I/O works), but none of the devices I've tried connecting to the J9 port on the 5G modem have worked so far. The problem is "how to connect any device to J9 port on the 5G modem"
                X Offline
                X Offline
                xav04
                @tom Any advice? I still can't connect any device to the J9 UART port in the 5G modem
                • X Offline
                  X Offline
                  xav04
                  @Eric-Katzfey Hi, just wanted to ask if you can help me to connect VOXL 2 I/O or any other device that uses a UART port to the J9 on the 5G modem.
                  S 1 Reply Last reply
                  • X xav04
                    S Offline
                    S Offline
                    SMRazaRizvi
                    @xav04 Is there any update on this? I am also trying to connect an RTK GPS using the J9 UART Port on the 5G modem, but no luck still..
                    • S SMRazaRizvi
                      #10
                      @SMRazaRizvi
                      the following docs page (https://docs.modalai.com/voxl2-external-flight-controller/#using-m2-5g-modem-addon-board-m0090) shows you how to physically connect a UART device to J9 of M0090 board.
                      The corresponding UART port is mapped to CPU (not DSP where PX4 is running), and can be accessed using /dev/ttyHS2
                      Your GPS driver would need to run on the CPU.
                      if you know the baud rate of your GPS device and the GPS device sends out data by default once it is powered on, you can do a very quick test to see if anything comes into the port:
                      #assuming the device uses 115200 baud rate
                      stty -F /dev/ttyHS2 115200
                      cat /dev/ttyHS2
                      at this point, if there is data coming into the serial port, you should see some characters printed (ASCII or not depending on the format of incoming data).
                      You can also use a tool called screen to check serial port:
                      apt-get install screen
                      screen /dev/ttyHS2 115200 #assuming 115200 baud rate
                      #control-a-k then y to exit screen
                      If you don't have a device that sends out data by default, you can just do a loopback test (add a jumper between TX and RX on J9 of M0090) and then use screen, if the port is working, you should see in the terminal every letter that you type on the keyboard. If you don't see anything when you type in the screen terminal, then either loopback jumper is not correctly installed or some other issue.
                        @SMRazaRizvi
                        cat /dev/ttyHS2
                        S Offline
                        S Offline
                        SMRazaRizvi
                        @Alex-Kushleyev Thank you so much Alex!
                        I can see data coming in on the port using screen.
                        Now, how can I ask the PX4 to use this GPS data?
                        Alex KushleyevA Eric KatzfeyE 2 Replies Last reply
                        • S SMRazaRizvi
                          @SMRazaRizvi ,
                          On VOXL2, the majority of PX4 software is running on the DSP, so the GPS driver is set up to run on DSP and access the UART ports available to the DSP only.
                          Have you considered using our suggested configuration described here https://docs.modalai.com/voxl2-guides-onboard-offboard-sensors/#external-gps-mag--gnss ?
                          I will double check, but I do not think that we support running the GPS driver for PX4 on CPU.
                          • S SMRazaRizvi
                            @SMRazaRizvi Yes, you can run GPS driver on the apps processor for px4. Take a look at the file /usr/bin/voxl-px4-start. You can see in that file (a bash script) where the gps start command is issued. You can see that if the board is detected to be an RB5 (M0052) it will use gps start -d /dev/ttyHS2 to start the driver on the apps side and not the DSP side. So you will have to modify that file.
                            • S Offline
                              S Offline
                              SMRazaRizvi
                              Thanks @Alex-Kushleyev and @Eric-Katzfey
                              To avoid the complexity, I've now connected my RTK-GPS to the configuration described here: https://docs.modalai.com/voxl2-guides-onboard-offboard-sensors/#external-gps-mag--gnss
                              I'm getting the coordinate position and I am now in the process of setting the correct parameters to be set for the new GPS.
                              To confirm, I only have to adjust PX4 parameters, right?
                              • S SMRazaRizvi
                                @SMRazaRizvi We have not integrated an RTK GPS receiver before so cannot comment on the steps needed to get it working properly. Perhaps the manufacturer of the RTK GPS unit can provide some guidance on how to use it with PX4? Or the PX4 community? But if you are seeing valid data from the unit then at least the hardware seems to be connected properly.
                                S V 2 Replies Last reply
                                  S Offline
                                  S Offline
                                  SMRazaRizvi
                                  @Eric-Katzfey I see.
                                  Actually connecting my RTK-GPS to the configuration described here: https://docs.modalai.com/voxl2-guides-onboard-offboard-sensors/#external-gps-mag--gnss was not giving me RTK corrections so I am now using the J9 connector on the 5G modem, and that works fine.
                                  But another problem that I am facing is Compass Sensor 0 missing.
                                  Do you think there's some setting of the default compass that was being picked up by PX4 with the M8N GPS that came with the drone? Where can I configure the compass?
                                  • S SMRazaRizvi
                                    @SMRazaRizvi ,
                                    compass driver is started inside the voxl-px4 start-up script : /usr/bin/voxl-px4-start
                                    # Auto detect the magnetometer. If one or both of these devices
                                    # are not connected it will fail but not cause any harm.
                                    /bin/echo "Looking for qmc5883l magnetometer"
                                    qshell qmc5883l start -R 10 -X -b 1
                                    /bin/echo "Looking for ist8310 magnetometer"
                                    qshell ist8310 start -R 10 -X -b 1
                                    please note that both of these drivers are expecting the compass to be connected to the DSP i2c ports. We currently don't have compass driver that can run on the cpu side (unlike GPS). However, you could potentially splice the connection for GND, SDA, SCL and connect the i2c bus to J19 on VOXL2, so that you can use the DSP driver for the compass.. Is that an option for you?
                                      @SMRazaRizvi ,
                                      Regarding the RTK corrections not working while GPS is connected to the DSP, I am assuming you have an RTK service that downloads the data from internet and sends a mavlink message with the corrections. That mavlink message needs to be consumed by the gps driver and rtk corrections forwarded to the GPS receiver via UART. If this is not happening, then perhaps the mavlink message never gets to the GPS driver inside the DSP, potentially being filtered out somewhere (mavlink manager?). I don't have deep enough knowledge there, maybe others can comment.
                                        S Offline
                                        S Offline
                                        SMRazaRizvi
                                        @Alex-Kushleyev But the RTK corrections come in when I connect the RTK to the 5G modem over J9. What do you think makes a difference here?
                                        • S SMRazaRizvi
                                          @SMRazaRizvi When you connect the GPS to J9, you start the GPS driver on the cpu side, so there is probably nothing that filters out the mavlink messages with corrections between the rtk mavlink service and your gps driver.
                                          When starting GPS driver on the DSP, there may be a filter somewhere that prevents the rtk corrections mavlink message from reaching the DSP.
                                          That is my guess
