  3. QGC not connecting with computer
2 Posts 2 Posters 237 Views
  • Darshit DesaiD Offline
    Darshit Desai
    Hi everyone our QGC on the laptop is unable to connect with the drone we are not sure since we didn't change anything we verified the voxl px4 config file and the voxl vision
    This is the systemctl command I ran to debug my connection
    voxl:~$ systemctl status -l voxl-vision-px4
    ● voxl-vision-px4.service - voxl-vision-px4
       Loaded: loaded (/usr/bin/voxl-vision-px4; enabled; vendor preset: enabled)
       Active: active (running) since Thu 1970-01-01 00:00:08 UTC; 53 years 4 months ago
     Main PID: 2590 (voxl-vision-px4)
       Memory: 8.0K
          CPU: 451ms
       CGroup: /system.slice/voxl-vision-px4.service
               └─2590 /usr/bin/voxl-vision-px4
    Jan 01 00:00:08 apq8096 systemd[1]: Started voxl-vision-px4.
    Jan 01 00:00:09 apq8096 voxl-vision-px4[2590]: WARNING: voxl-mavlink-server does not appear to be running
    Jan 01 00:00:09 apq8096 voxl-vision-px4[2590]: make sure it is enabled: systemctl enable voxl-mavlink-server
    Jan 01 00:00:35 apq8096 voxl-vision-px4[2590]: WARNING: PX4 Mavlink Disconnected
    voxl:~$ voxl-inspect-services
     docker-autorun       |  Enabled  | Not Running |
     docker-daemon        |  Enabled  |   Running   |     0.0
     voxl-camera-server   |  Enabled  |   Running   |    17.0
     voxl-cpu-monitor     | Disabled  | Not Running |
     voxl-dfs-server      | Disabled  | Not Running |
     voxl-imu-server      |  Enabled  |   Running   |     1.8
     voxl-mavlink-server  |  Enabled  |   Running   |     0.0
     voxl-qvio-server     |  Enabled  |   Running   |     9.4
     voxl-tag-detector    |  Enabled  | Not Running |
     voxl-vision-px4      |  Enabled  |   Running   |     0.0
    voxl:~$
    • wilkinsafW Offline
      wilkinsafW Offline
      wilkinsaf
      wrote on last edited by wilkinsaf
      Couple of questions
      1. How are you attempting to connect to the VOXL? Wifi? Radio? etc... Also, what OS are you running (I have heard of firewalls getting in the way of connecting sometimes)?
      2. If you are connecting over wifi, what do you see when you enter the address of the VOXL into a web browser? VOXL-portal is enabled, so if you are truly connected you should see a VOXL webpage pop up
      3. Can you please put the output of these commands here cat /etc/modalai/voxl-mavlink-server.conf and cat /etc/modalai/voxl-vision-px4.conf
