QGC not connecting with computer
Hi everyone our QGC on the laptop is unable to connect with the drone we are not sure since we didn't change anything we verified the voxl px4 config file and the voxl vision
This is the systemctl command I ran to debug my connection
voxl:~$ systemctl status -l voxl-vision-px4 ● voxl-vision-px4.service - voxl-vision-px4 Loaded: loaded (/usr/bin/voxl-vision-px4; enabled; vendor preset: enabled) Active: active (running) since Thu 1970-01-01 00:00:08 UTC; 53 years 4 months ago Main PID: 2590 (voxl-vision-px4) Memory: 8.0K CPU: 451ms CGroup: /system.slice/voxl-vision-px4.service └─2590 /usr/bin/voxl-vision-px4 Jan 01 00:00:08 apq8096 systemd[1]: Started voxl-vision-px4. Jan 01 00:00:09 apq8096 voxl-vision-px4[2590]: WARNING: voxl-mavlink-server does not appear to be running Jan 01 00:00:09 apq8096 voxl-vision-px4[2590]: make sure it is enabled: systemctl enable voxl-mavlink-server Jan 01 00:00:35 apq8096 voxl-vision-px4[2590]: WARNING: PX4 Mavlink Disconnected voxl:~$ voxl-inspect-services Service Name | Enabled | Running | CPU Usage --------------------------------------------------------------- docker-autorun | Enabled | Not Running | docker-daemon | Enabled | Running | 0.0 modallink-relink | Disabled | Not Running | voxl-camera-server | Enabled | Running | 17.0 voxl-cpu-monitor | Disabled | Not Running | voxl-dfs-server | Disabled | Not Running | voxl-imu-server | Enabled | Running | 1.8 voxl-mavlink-server | Enabled | Running | 0.0 voxl-modem | Disabled | Not Running | voxl-portal | Enabled | Running | 0.0 voxl-qvio-server | Enabled | Running | 9.4 voxl-streamer | Disabled | Not Running | voxl-tag-detector | Enabled | Not Running | voxl-tflite-server | Disabled | Not Running | voxl-time-sync | Disabled | Not Running | voxl-vision-px4 | Enabled | Running | 0.0 voxl-wait-for-fs | Enabled | Completed | voxl:~$ -
Couple of questions
- How are you attempting to connect to the VOXL? Wifi? Radio? etc... Also, what OS are you running (I have heard of firewalls getting in the way of connecting sometimes)?
- If you are connecting over wifi, what do you see when you enter the address of the VOXL into a web browser? VOXL-portal is enabled, so if you are truly connected you should see a VOXL webpage pop up
- Can you please put the output of these commands here
cat /etc/modalai/voxl-mavlink-server.confandcat /etc/modalai/voxl-vision-px4.conf
