  2. VOXL Dev Kits
  3. VOXL Flight Deck
  4. MPA services for ROS Melodic/Noetic on VOXL
Scheduled Pinned Locked Moved VOXL Flight Deck
4 Posts 2 Posters 1.9k Views 1 Watching
  • M Offline
    M Offline
    mbahrami
    Hello
    We have successfully built a docker container running ros noetic on VOXL. We want access to data from (and to) the MPA services inside ros nodes.
    For sending control commands from a ros node to the PX4, it seems MAVROS can be modified to get it working for newer versions of ros kinetic.
    But, to make VIO data (image, IMU, ...) from the MPA pipeline available inside a ros node, the voxl_mpa_to_ros seems to be distribution dependent and is built for ros indigo being run on voxl.
    I was wondering what would be a workaround. what are the dependencies or requirements to make the above available inside a docker?
    thanks
      We've never had compatibility issues between versions of ROS for those simple sensors. Have you tried to see if it works?
      Also, the pipe data is all published to /run/mpa so you should be able to just make it available directly in the Docker when you launch it
      • M Offline
        M Offline
        mbahrami
        Thanks for the replay. yes, I'm trying them one by one, because our set-up is different.
        but, currently, there seems to be a problem with finding the dependencies in the build of voxl-mpa-to-ros.
        CMake Warning at /opt/ros/indigo/share/roscpp/cmake/roscppConfig.cmake:111 (message):
          Project 'roscpp' specifies 'NOTFOUND/usr/include' as an include dir, which
          is not found.  It does neither exist as an absolute directory nor in
          '/opt/ros/indigo/NOTFOUND/usr/include'.
        Not sure why ${catkin_INCLUDE_DIRS} inside CMakeLists.txt cannot be found. Eventually, I get Not selecting voxl-mpa-to-ros 0.3.6 due to incompatible architecture. if try to deploy the build ipk.
        I'm using voxl-emulator:V1.7 to build. I put the entire process in the following code section.
        myPC:~/git/voxl-docker/voxl-mpa-to-ros$ ls
        build.sh   CHANGELOG  deploy_to_voxl.sh      LICENSE          pkg
        catkin_ws  clean.sh   install_build_deps.sh  make_package.sh  README.md
        myPC:~/git/voxl-docker/voxl-mpa-to-ros$ sudo voxl-docker -i voxl-emulator:V1.7
        [sudo] password for myPC:
        launching image: voxl-emulator:V1.7 with the following command:
        docker run --rm -it --net=host --privileged -w /home/root --volume=/dev/bus/usb:/dev/bus/usb -e LOCAL_USER_ID=0 -e LOCAL_USER_NAME=root -e LOCAL_GID=0 -v /home/mo/git/voxl-docker/voxl-mpa-to-ros:/home/root:rw -w /home/root voxl-emulator:V1.7 /bin/bash -l
        + USER_ID=0
        + USER_NAME=root
        + GID=0
        + getent group 0
        root:x:0:
        + echo 'Starting with UID : 0'
        + useradd --shell /bin/bash -u 0 -g 0 -o -c '' -M root
        useradd: user 'root' already exists
        + addgroup root users
        + export HOME=/home/root
        + HOME=/home/root
        + ls -ld /home/root
        drwxrwxr-x 5 james host_group 4096 May  4 00:45 /home/root
        + echo 'root ALL=(ALL) NOPASSWD: ALL'
        + ls -l /etc/sudoers.d/
        total 8
        -rw-r--r-- 1 root root 30 Nov 23  2020 james
        -rw-r--r-- 1 root root 29 May  4 00:46 root
        + cat /etc/sudoers.d/root
        + chmod 777 /tmp
        + chmod 711 /usr/bin/sudo
        + chmod +s /usr/bin/sudo
        + ls -l /usr/local/bin/su-exec
        -rwxr-xr-x 1 root root 7660 Aug 14  2018 /usr/local/bin/su-exec
        + ls -l /bin/bash
        -rwxrwxrwx 1 root root 959344 Aug 12  2018 /bin/bash
        + echo 'exec /usr/local/bin/su-exec root /bin/bash' -l
        exec /usr/local/bin/su-exec root /bin/bash -l
        + exec /usr/local/bin/su-exec root /bin/bash -l
        voxl-emulator:~$ ls
        CHANGELOG  README.md  catkin_ws  deploy_to_voxl.sh      make_package.sh
        LICENSE    build.sh   clean.sh   install_build_deps.sh  pkg
        voxl-emulator:~$ ./install_build_deps.sh apq8096 stable
        using apq8096 stable repo
        adding arm64 to opkg conf
        Downloading http://voxl-packages.modalai.com/dists/apq8096/stable/binary-arm64//Packages.gz.
        Updated source 'stable'.
        installing:
        libmodal-json
        libmodal-pipe
        libvoxl-cutils
        Installing libmodal-json (0.4.3) on root.
        Downloading http://voxl-packages.modalai.com/dists/apq8096/stable/binary-arm64//libmodal-json_0.4.3.ipk.
        Configuring libmodal-json.
        Installing libmodal-pipe (2.8.2) on root.
        Downloading http://voxl-packages.modalai.com/dists/apq8096/stable/binary-arm64//libmodal-pipe_2.8.2.ipk.
        Configuring libmodal-pipe.
        Installing libvoxl-cutils (0.1.1) on root.
        Downloading http://voxl-packages.modalai.com/dists/apq8096/stable/binary-arm64//libvoxl-cutils_0.1.1.ipk.
        Configuring libvoxl-cutils.
        Done installing dependencies
        voxl-emulator:~$ ./clean.sh
        voxl-emulator:~$ ./build.sh
         Build the current project based on platform target.
         Usage:
          ./build.sh apq8096
                Build 64-bit binaries for apq8096
          ./build.sh qrb5165
                Build 64-bit binaries for qrb5165
        voxl-emulator:~$ ./build.sh apq8096
        Base path: /home/root/catkin_ws
        Source space: /home/root/catkin_ws/src
        Build space: /home/root/catkin_ws/build
        Devel space: /home/root/catkin_ws/devel
        Install space: /home/root/catkin_ws/install
        #### Running command: "cmake /home/root/catkin_ws/src -DCMAKE_BUILD_TYPE=Release -DCATKIN_DEVEL_PREFIX=/home/root/catkin_ws/devel -DCMAKE_INSTALL_PREFIX=/home/root/catkin_ws/install -G Unix Makefiles" in "/home/root/catkin_ws/build"
        -- The C compiler identification is GNU 4.9.3
        -- The CXX compiler identification is GNU 4.9.3
        -- Check for working C compiler: /usr/bin/cc
        -- Check for working C compiler: /usr/bin/cc -- works
        -- Check for working CXX compiler: /usr/bin/c++
        -- Check for working CXX compiler: /usr/bin/c++ -- works
        -- Using CATKIN_DEVEL_PREFIX: /home/root/catkin_ws/devel
        -- Using CMAKE_PREFIX_PATH: /opt/ros/indigo
        -- This workspace overlays: /opt/ros/indigo
        -- Found PythonInterp: /usr/bin/python (found version "2.7.9")
        -- Using PYTHON_EXECUTABLE: /usr/bin/python
        -- Using default Python package layout
        -- Found PY_em: /usr/lib/python2.7/site-packages/em.pyc
        -- Using empy: /usr/lib/python2.7/site-packages/em.pyc
        -- Using CATKIN_ENABLE_TESTING: ON
        -- Call enable_testing()
        -- Using CATKIN_TEST_RESULTS_DIR: /home/root/catkin_ws/build/test_results
        -- Found gtest: gtests will be built
        -- Using Python nosetests: /usr/bin/nosetests-2.7
        -- catkin 0.6.19
          '/opt/ros/indigo/NOTFOUND/usr/include'.  Ask the maintainer 'Dirk Thomas
          <dthomas@osrfoundation.org>' to fix it.
          /opt/ros/indigo/share/catkin/cmake/catkinConfig.cmake:76 (find_package)
          CMakeLists.txt:43 (find_package)
        CMake Warning at /opt/ros/indigo/share/cpp_common/cmake/cpp_commonConfig.cmake:111 (message):
          Project 'cpp_common' specifies 'NOTFOUND/usr/include' as an include dir,
          which is not found.  It does neither exist as an absolute directory nor in
          /opt/ros/indigo/share/roscpp/cmake/roscppConfig.cmake:169 (find_package)
        CMake Warning at /opt/ros/indigo/share/rostime/cmake/rostimeConfig.cmake:111 (message):
          Project 'rostime' specifies 'NOTFOUND/usr/include' as an include dir, which
          /opt/ros/indigo/share/roscpp_traits/cmake/roscpp_traitsConfig.cmake:169 (find_package)
          /opt/ros/indigo/share/roscpp_serialization/cmake/roscpp_serializationConfig.cmake:169 (find_package)
          /opt/ros/indigo/share/message_runtime/cmake/message_runtimeConfig.cmake:169 (find_package)
        CMake Warning at /opt/ros/indigo/share/rosconsole/cmake/rosconsoleConfig.cmake:111 (message):
          Project 'rosconsole' specifies
          'NOTFOUND/home/ekatzfey/build/sfpro/apq8096-le-1-0-1_ap_standard_oem.git/apps_proc/poky/build/tmp-glibc/sysroots/lib32-apq8096/usr/include'
          as an include dir, which is not found.  It does neither exist as an
          '/opt/ros/indigo/NOTFOUND/home/ekatzfey/build/sfpro/apq8096-le-1-0-1_ap_standard_oem.git/apps_proc/poky/build/tmp-glibc/sysroots/lib32-apq8096/usr/include'.
          Ask the maintainer 'Dirk Thomas <dthomas@osrfoundation.org>' to fix it.
        CMake Warning at /opt/ros/indigo/share/camera_info_manager/cmake/camera_info_managerConfig.cmake:111 (message):
          Project 'camera_info_manager' specifies 'NOTFOUND/usr/include' as an
          include dir, which is not found.  It does neither exist as an absolute
          directory nor in '/opt/ros/indigo/NOTFOUND/usr/include'.  Ask the
          maintainer 'Jack O'Quin <jack.oquin@gmail.com>, Vincent Rabaud
          <vincent.rabaud@gmail.com>' to fix it.
        CMake Warning at /opt/ros/indigo/share/pluginlib/cmake/pluginlibConfig.cmake:111 (message):
          Project 'pluginlib' specifies 'NOTFOUND/usr/include' as an include dir,
          '/opt/ros/indigo/NOTFOUND/usr/include'.  Ask the maintainer 'Mikael
          Arguedas <mikael@osrfoundation.org>' to fix it.
          /opt/ros/indigo/share/image_transport/cmake/image_transportConfig.cmake:169 (find_package)
        CMake Warning at /opt/ros/indigo/share/class_loader/cmake/class_loaderConfig.cmake:111 (message):
          Project 'class_loader' specifies 'NOTFOUND/usr/include' as an include dir,
          /opt/ros/indigo/share/pluginlib/cmake/pluginlibConfig.cmake:169 (find_package)
        CMake Warning at /opt/ros/indigo/share/rospack/cmake/rospackConfig.cmake:111 (message):
          Project 'rospack' specifies 'NOTFOUND/usr/include' as an include dir, which
          /opt/ros/indigo/share/roslib/cmake/roslibConfig.cmake:169 (find_package)
        CMake Warning at /opt/ros/indigo/share/nodelet/cmake/nodeletConfig.cmake:111 (message):
          Project 'nodelet' specifies
          Ask the maintainer 'Mikael Arguedas <mikael@osrfoundation.org>' to fix it.
          Project 'nodelet' specifies 'NOTFOUND/usr/include' as an include dir, which
        CMake Warning at /opt/ros/indigo/share/bondcpp/cmake/bondcppConfig.cmake:111 (message):
          Project 'bondcpp' specifies 'NOTFOUND/usr/include' as an include dir, which
          /opt/ros/indigo/share/nodelet/cmake/nodeletConfig.cmake:169 (find_package)
        CMake Warning at /opt/ros/indigo/share/tf2/cmake/tf2Config.cmake:111 (message):
          Project 'tf2' specifies 'NOTFOUND/usr/include' as an include dir, which is
          '/opt/ros/indigo/NOTFOUND/usr/include'.  Ask the maintainer 'Tully Foote
          <tfoote@osrfoundation.org>' to fix it.
        -- Using these message generators: gencpp;genlisp;genpy
        CMake Warning at /opt/ros/indigo/share/actionlib/cmake/actionlibConfig.cmake:111 (message):
          Project 'actionlib' specifies 'NOTFOUND/usr/include' as an include dir,
          /opt/ros/indigo/share/tf2_ros/cmake/tf2_rosConfig.cmake:169 (find_package)
        -- voxl_mpa_to_ros: 1 messages, 0 services
        -- Configuring done
        -- Generating done
        -- Build files have been written to: /home/root/catkin_ws/build
        #### Running command: "make install -j8 -l8" in "/home/root/catkin_ws/build"
        Scanning dependencies of target _voxl_mpa_to_ros_generate_messages_check_deps_AiDetection
        Scanning dependencies of target voxl_mpa_to_ros_node
        [ 13%] Building CXX object CMakeFiles/voxl_mpa_to_ros_node.dir/src/interfaces/camera_interface.cpp.o
        [ 13%] Building CXX object CMakeFiles/voxl_mpa_to_ros_node.dir/src/interfaces/vio_interface.cpp.o
        [ 20%] Building CXX object CMakeFiles/voxl_mpa_to_ros_node.dir/src/interfaces/point_cloud_interface.cpp.o
        [ 26%] Building CXX object CMakeFiles/voxl_mpa_to_ros_node.dir/src/interface_manager.cpp.o
        [ 40%] Building CXX object CMakeFiles/voxl_mpa_to_ros_node.dir/src/interfaces/ai_detection_interface.cpp.o
        [ 40%] Building CXX object CMakeFiles/voxl_mpa_to_ros_node.dir/src/interfaces/imu_interface.cpp.o
        [ 46%] Building CXX object CMakeFiles/voxl_mpa_to_ros_node.dir/src/interfaces/stereo_interface.cpp.o
        [ 46%] Built target _voxl_mpa_to_ros_generate_messages_check_deps_AiDetection
        Scanning dependencies of target voxl_mpa_to_ros_generate_messages_cpp
        [ 53%] Generating C++ code from voxl_mpa_to_ros/AiDetection.msg
        [ 53%] Built target voxl_mpa_to_ros_generate_messages_cpp
        Scanning dependencies of target voxl_mpa_to_ros_generate_messages_py
        [ 60%] Generating Python from MSG voxl_mpa_to_ros/AiDetection
        [ 66%] Generating Python msg __init__.py for voxl_mpa_to_ros
        [ 66%] Built target voxl_mpa_to_ros_generate_messages_py
        Scanning dependencies of target voxl_mpa_to_ros_generate_messages_lisp
        [ 73%] Generating Lisp code from voxl_mpa_to_ros/AiDetection.msg
        [ 73%] Built target voxl_mpa_to_ros_generate_messages_lisp
        [ 80%] Building CXX object CMakeFiles/voxl_mpa_to_ros_node.dir/src/mpa_ros_node.cpp.o
        [ 86%] Building CXX object CMakeFiles/voxl_mpa_to_ros_node.dir/src/utils/camera_helpers.cpp.o
        [ 93%] Building CXX object CMakeFiles/voxl_mpa_to_ros_node.dir/src/utils/common_utils.cpp.o
        [100%] Linking CXX executable /home/root/catkin_ws/devel/lib/voxl_mpa_to_ros/voxl_mpa_to_ros_node
        /usr/lib/gcc/arm-oemllib32-linux-gnueabi/4.9.3/../../../../arm-oemllib32-linux-gnueabi/bin/ld: warning: skipping incompatible /usr/lib64/libmodal_pipe.so while searching for modal_pipe
        /usr/lib/gcc/arm-oemllib32-linux-gnueabi/4.9.3/../../../../arm-oemllib32-linux-gnueabi/bin/ld: warning: skipping incompatible /usr/lib64/libmodal_json.so while searching for modal_json
        [100%] Built target voxl_mpa_to_ros_node
        Install the project...
        -- Install configuration: "Release"
        -- Installing: /home/root/catkin_ws/install/_setup_util.py
        -- Installing: /home/root/catkin_ws/install/env.sh
        -- Installing: /home/root/catkin_ws/install/setup.bash
        -- Installing: /home/root/catkin_ws/install/setup.sh
        -- Installing: /home/root/catkin_ws/install/setup.zsh
        -- Installing: /home/root/catkin_ws/install/.rosinstall
        -- Installing: /home/root/catkin_ws/install/share/voxl_mpa_to_ros/msg/AiDetection.msg
        -- Installing: /home/root/catkin_ws/install/share/voxl_mpa_to_ros/cmake/voxl_mpa_to_ros-msg-paths.cmake
        -- Installing: /home/root/catkin_ws/install/include/voxl_mpa_to_ros
        -- Installing: /home/root/catkin_ws/install/include/voxl_mpa_to_ros/AiDetection.h
        -- Installing: /home/root/catkin_ws/install/share/common-lisp/ros/voxl_mpa_to_ros
        -- Installing: /home/root/catkin_ws/install/share/common-lisp/ros/voxl_mpa_to_ros/msg
        -- Installing: /home/root/catkin_ws/install/share/common-lisp/ros/voxl_mpa_to_ros/msg/AiDetection.lisp
        -- Installing: /home/root/catkin_ws/install/share/common-lisp/ros/voxl_mpa_to_ros/msg/_package_AiDetection.lisp
        -- Installing: /home/root/catkin_ws/install/share/common-lisp/ros/voxl_mpa_to_ros/msg/_package.lisp
        -- Installing: /home/root/catkin_ws/install/share/common-lisp/ros/voxl_mpa_to_ros/msg/voxl_mpa_to_ros-msg.asd
        Listing /home/root/catkin_ws/devel/lib/python2.7/site-packages/voxl_mpa_to_ros ...
        Compiling /home/root/catkin_ws/devel/lib/python2.7/site-packages/voxl_mpa_to_ros/__init__.py ...
        Listing /home/root/catkin_ws/devel/lib/python2.7/site-packages/voxl_mpa_to_ros/msg ...
        Compiling /home/root/catkin_ws/devel/lib/python2.7/site-packages/voxl_mpa_to_ros/msg/_AiDetection.py ...
        Compiling /home/root/catkin_ws/devel/lib/python2.7/site-packages/voxl_mpa_to_ros/msg/__init__.py ...
        -- Installing: /home/root/catkin_ws/install/lib/python2.7/site-packages/voxl_mpa_to_ros
        -- Installing: /home/root/catkin_ws/install/lib/python2.7/site-packages/voxl_mpa_to_ros/__init__.py
        -- Installing: /home/root/catkin_ws/install/lib/python2.7/site-packages/voxl_mpa_to_ros/__init__.pyc
        -- Installing: /home/root/catkin_ws/install/lib/python2.7/site-packages/voxl_mpa_to_ros/msg
        -- Installing: /home/root/catkin_ws/install/lib/python2.7/site-packages/voxl_mpa_to_ros/msg/_AiDetection.py
        -- Installing: /home/root/catkin_ws/install/lib/python2.7/site-packages/voxl_mpa_to_ros/msg/__init__.py
        -- Installing: /home/root/catkin_ws/install/lib/python2.7/site-packages/voxl_mpa_to_ros/msg/_AiDetection.pyc
        -- Installing: /home/root/catkin_ws/install/lib/python2.7/site-packages/voxl_mpa_to_ros/msg/__init__.pyc
        -- Installing: /home/root/catkin_ws/install/lib/pkgconfig/voxl_mpa_to_ros.pc
        -- Installing: /home/root/catkin_ws/install/share/voxl_mpa_to_ros/cmake/voxl_mpa_to_ros-msg-extras.cmake
        -- Installing: /home/root/catkin_ws/install/share/voxl_mpa_to_ros/cmake/voxl_mpa_to_rosConfig.cmake
        -- Installing: /home/root/catkin_ws/install/share/voxl_mpa_to_ros/cmake/voxl_mpa_to_rosConfig-version.cmake
        -- Installing: /home/root/catkin_ws/install/share/voxl_mpa_to_ros/package.xml
        -- Installing: /home/root/catkin_ws/install/share/voxl_mpa_to_ros/launch
        -- Installing: /home/root/catkin_ws/install/share/voxl_mpa_to_ros/launch/voxl_mpa_to_ros.launch
        -- Installing: /home/root/catkin_ws/install/lib/voxl_mpa_to_ros/voxl_mpa_to_ros_node
        -- Removed runtime path from "/home/root/catkin_ws/install/lib/voxl_mpa_to_ros/voxl_mpa_to_ros_node"
        voxl-emulator:~$ ./make_package.sh ipk
        Package Name:  voxl-mpa-to-ros
        version Number:  0.3.6
        starting building IPK package
        /usr/bin/ar: creating voxl-mpa-to-ros_0.3.6.ipk
        DONE
        voxl-emulator:~$ ls
        CHANGELOG  README.md  catkin_ws  deploy_to_voxl.sh      make_package.sh  pkg
        LICENSE    build.sh   clean.sh   install_build_deps.sh  misc_files       voxl-mpa-to-ros_0.3.6.ipk
        voxl-emulator:~$ exit
        logout
        myPC:~/git/voxl-docker/voxl-mpa-to-ros$ ./deploy_to_voxl.sh
        searching for ADB device
        checking VOXL for dpkg/opkg
        opkg detected
        voxl-mpa-to-ros_0.3.6.ipk: 1 file pushed. 2.1 MB/s (838532 bytes in 0.383s)
        Unknown package 'voxl-mpa-to-ros'.
        Collected errors:
         * opkg_install_cmd: Cannot install package voxl-mpa-to-ros.
        DONE
        M 1 Reply Last reply
        • M mbahrami
          + USER_ID=0
          + USER_NAME=root
          + GID=0
          + getent group 0
          root:x:0:
          + HOME=/home/root
          + ls -ld /home/root
          total 8
          + chmod 777 /tmp
          + ls -l /bin/bash
          voxl-emulator:~$ ls
          installing:
          libmodal-json
          libmodal-pipe
          libvoxl-cutils
           Usage:
            ./build.sh apq8096
            ./build.sh qrb5165
          -- catkin 0.6.19
          -- Configuring done
          -- Generating done
          DONE
          voxl-emulator:~$ ls
          logout
          opkg detected
          Collected errors:
          DONE
          M Offline
          M Offline
          mbahrami
          wrote on last edited by mbahrami
          @Chad-Sweet
