    M0025-2 Camera Alone - Camera Server Segmentation Fault
    1355
    • A
      aharvey
      I have a VOXL2 board running system image 1.4.1 and has voxl-camera-server version 1.3.5. I have the M0025-2 camera. It is connected to the M0076 Interposer and then connected that to J7 on the VOXL2. No matter what camera configuration I seem to try, the voxl-camera-server always throws a segmentation fault when it tries to start. I hope I'm doing something wrong, but I can't rule out bad hardware. Is there something I'm doing wrong or other troubleshooting to try?
      • Chad SweetC
        Chad Sweet ModalAI Team
        That implies a hardware issue. Are you sure things are connected in the correct direction? Can you share a picture of your setup?
        Also, please make sure power is off when changing components
        • Adrian HidalgoA
          Adrian Hidalgo ModalAI Team
          @aharvey have you looked at our docs?
          • Adrian HidalgoA
            *Lego not included
            • A
              aharvey
              @Chad-Sweet said in M0025-2 Camera Alone - Camera Server Segmentation Fault:
              Here is my setup. I have read the docs but nothing has helped. Maybe I have a bad interposer?
              • A
                aharvey
                I have tried connecting the interposer to J8 and J6 with the same results.
                • Adrian HidalgoA
                  Will be released within a week
                  In the meantime you will have to use M0084 on J7
                  • A
                    aharvey @Adrian Hidalgo
                    @Adrian-Hidalgo
                    So unless I update the image to 1.5.3, I need to use "M0084 VOXL 2 Dual Camera Adapter" and NOT "M0076 Interposer"?
                    Adrian HidalgoA 1 Reply Last reply Reply Quote 0
                    • Adrian HidalgoA
                      Adrian Hidalgo ModalAI Team @aharvey
                      @aharvey Yes, that's correct. It'll be available in about a week, what I hear from software
                      • A
                        aharvey
                        I updated to the beta 1.5.3 image and this camera now works with it on its own. Thanks!
