  3. M0025-2 Camera Alone - Camera Server Segmentation Fault
10 Posts 3 Posters 1.7k Views 1 Watching
  • A Offline
    aharvey
    I have a VOXL2 board running system image 1.4.1 and has voxl-camera-server version 1.3.5. I have the M0025-2 camera. It is connected to the M0076 Interposer and then connected that to J7 on the VOXL2. No matter what camera configuration I seem to try, the voxl-camera-server always throws a segmentation fault when it tries to start. I hope I'm doing something wrong, but I can't rule out bad hardware. Is there something I'm doing wrong or other troubleshooting to try?
      That implies a hardware issue. Are you sure things are connected in the correct direction? Can you share a picture of your setup?
      Also, please make sure power is off when changing components
      • Adrian HidalgoA Offline
        Adrian Hidalgo
        @aharvey have you looked at our docs?
          Adrian Hidalgo
          wrote on last edited by Adrian Hidalgo
          *Lego not included
          • A Offline
            aharvey
            @Chad-Sweet said in M0025-2 Camera Alone - Camera Server Segmentation Fault:
            Here is my setup. I have read the docs but nothing has helped. Maybe I have a bad interposer?
            • A Offline
              aharvey
              wrote on last edited by aharvey
              I have tried connecting the interposer to J8 and J6 with the same results.
                Adrian Hidalgo
                Will be released within a week
                In the meantime you will have to use M0084 on J7
                A 1 Reply Last reply
                  aharvey
                  @Adrian-Hidalgo
                  So unless I update the image to 1.5.3, I need to use "M0084 VOXL 2 Dual Camera Adapter" and NOT "M0076 Interposer"?
                  Adrian HidalgoA 1 Reply Last reply
                  • A aharvey
                    @Adrian-Hidalgo
                    Adrian Hidalgo
                    @aharvey Yes, that's correct. It'll be available in about a week, what I hear from software
                    • A Offline
                      aharvey
                      I updated to the beta 1.5.3 image and this camera now works with it on its own. Thanks!
