  3. uvc_get_stream_ctrl_format_size failed
39 Posts 3 Posters 23.3k Views 3 Watching
  • KrisK Offline
    KrisK Offline
    Kris
    Re: voxl-streamer client repetitive connect/disconnect
    I am having the same issue that @wilkinsaf was having.
    I am using a different H.264 camera but the errors are the same uvc_get_stream_ctrl_format_size failedand the guidFormat is the same 59555932-0000-1000-8000-00aa00389b71.
    I tried to download the ipk that was posted in this thread, but it is no longer available.
    Could I have the new link for this http://voxl-packages.modalai.com/dev/libuvc_1.0.2_202112182223.ipk please?
    FYI, this is my camera information and I am trying to use it on the Seeker.
    voxl:~$ voxl-version
    system-image: 3.8.0
    kernel:       #1 SMP PREEMPT Tue Apr 26 18:08:39 UTC 2022 3.18.71-perf
    hw version:   VOXL
    voxl-suite:   0.7.0
     Service Name         |  Version  |  Enabled  |   Running   |  CPU Usage
     docker-autorun       |    1.2.4  | Disabled  | Not Running |
     docker-daemon        |    1.2.4  | Disabled  | Not Running |
     modallink-relink     |   0.15.1  | Disabled  | Not Running |
     voxl-camera-server   |    0.9.1  |  Enabled  |   Running   |    18.7
     voxl-cpu-monitor     |    0.2.5  |  Enabled  |   Running   |     0.0
     voxl-dfs-server      |    0.2.6  |  Enabled  |   Running   |     4.1
     voxl-imu-server      |    1.0.1  |  Enabled  |   Running   |     0.0
     voxl-mavlink-server  |    0.1.1  |  Enabled  |   Running   |     2.0
     voxl-modem           |   0.15.1  | Disabled  | Not Running |
     voxl-portal          |    0.2.6  |  Enabled  |   Running   |     0.0
     voxl-qvio-server     |    0.4.6  |  Enabled  |   Running   |     8.3
     voxl-streamer        |    0.3.1  | Disabled  | Not Running |
     voxl-tag-detector    |    0.0.4  | Disabled  | Not Running |
     voxl-tflite-server   |    0.2.3  | Disabled  | Not Running |
     voxl-time-sync       |    1.1.1  | Disabled  | Not Running |
     voxl-vision-px4      |    1.0.5  |  Enabled  |   Running   |     2.0
     voxl-wait-for-fs     |    1.1.1  |  Enabled  |  Completed  |
    voxl:~$ opkg list-installed | grep "voxl"
    libvoxl-cutils - 0.1.1
    voxl-camera-calibration - 0.1.5
    voxl-cpu-monitor - 0.2.5
    voxl-docker-support - 1.2.4
    voxl-gphoto2-server - 0.0.10
    voxl-jpeg-turbo - 2.1.3-4
    voxl-libgphoto2 - 0.0.4
    voxl-libuvc - 1.0.6
    voxl-logger - 0.1.2
    voxl-mavlink - 0.0.7
    voxl-mavlink-server - 0.1.1
    voxl-modem - 0.15.1
    voxl-mongoose - 7.6.0
    voxl-mpa-to-ros - 0.3.2
    voxl-mpa-tools - 0.6.3
    voxl-opencv - 4.5.5-1
    voxl-portal - 0.2.6
    voxl-qvio-server - 0.4.6
    voxl-streamer - 0.3.1
    voxl-suite - 0.7.0
    voxl-tag-detector - 0.0.4
    voxl-tflite-server - 0.2.3
    voxl-utils - 1.1.1
    voxl-uvc-server - 0.1.1
    voxl-vision-px4 - 1.0.5
    voxl-vpn - 0.0.6
    voxl:~$ opkg list-installed | grep "modal"
    libmodal-cv - 0.0.5
    libmodal-exposure - 0.0.7
    libmodal-json - 0.4.2
    libmodal-pipe - 2.1.7
    voxl:~$ lsusb
    Bus 001 Device 003: ID 2560:c184
    Bus 001 Device 002: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub
    voxl:~$ voxl-uvc-server -s
    *** START DEVICE LIST ***
    Found device 1
    Got device descriptor for 2560:c184 (null)
    Found device 2560:c184
    uvc_open failed, Return code: No such device (-4)
    *** END DEVICE LIST ***
    voxl:~$ lsusb -v -d 2560:c184
    Bus 001 Device 006: ID 2560:c184
    Device Descriptor:
      bLength                18
      bDescriptorType         1
      bcdUSB               2.00
      bDeviceClass          239 Miscellaneous Device
      bDeviceSubClass         2
      bDeviceProtocol         1 Interface Association
      bMaxPacketSize0        64
      idVendor           0x2560
      idProduct          0xc184
      bcdDevice            1.00
      iManufacturer           1 e-ConSystems
      iProduct                2 e-CAM83_USB
      iSerial                 3 00.00.01
      bNumConfigurations      1
      Configuration Descriptor:
        bLength                 9
        bDescriptorType         2
        wTotalLength          601
        bNumInterfaces          3
        bConfigurationValue     1
        iConfiguration          0
        bmAttributes         0xc0
          Self Powered
        MaxPower              100mA
        Interface Association:
          bLength                 8
          bDescriptorType        11
          bFirstInterface         0
          bInterfaceCount         3
          bFunctionClass         14 Video
          bFunctionSubClass       3 Video Interface Collection
          bFunctionProtocol       0
          iFunction               0
        Interface Descriptor:
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        0
          bAlternateSetting       0
          bNumEndpoints           1
          bInterfaceClass        14 Video
          bInterfaceSubClass      1 Video Control
          bInterfaceProtocol      0
          iInterface              0
          VideoControl Interface Descriptor:
            bLength                14
            bDescriptorType        36
            bDescriptorSubtype      1 (HEADER)
            bcdUVC               1.00
            wTotalLength           90
            dwClockFrequency       48.000000MHz
            bInCollection           2
            baInterfaceNr( 0)       1
            baInterfaceNr( 1)       2
            bLength                18
            bDescriptorType        36
            bDescriptorSubtype      2 (INPUT_TERMINAL)
            bTerminalID             1
            wTerminalType      0x0201 Camera Sensor
            bAssocTerminal          0
            iTerminal               0
            wObjectiveFocalLengthMin      0
            wObjectiveFocalLengthMax      0
            wOcularFocalLength            0
            bControlSize                  3
            bmControls           0x00008a0a
              Auto-Exposure Mode
              Exposure Time (Absolute)
              Zoom (Absolute)
              PanTilt (Absolute)
              Reserved
            bLength                11
            bDescriptorType        36
            bDescriptorSubtype      5 (PROCESSING_UNIT)
          Warning: Descriptor too short
            bUnitID                 2
            bSourceID               1
            wMaxMultiplier          0
            bControlSize            2
            bmControls     0x00001753
              Brightness
              Contrast
              Sharpness
              White Balance Temperature
              Backlight Compensation
              Gain
              Power Line Frequency
              White Balance Temperature, Auto
            iProcessing             0
            bmVideoStandards     0x1d
              None
              PAL - 625/50
              SECAM - 625/50
              NTSC - 625/50
            bLength                29
            bDescriptorType        36
            bDescriptorSubtype      6 (EXTENSION_UNIT)
            bUnitID                 3
            guidExtensionCode         {82066163-7050-ab49-b8cc-b3855e8d221d}
            bNumControl             0
            bNrPins                 1
            baSourceID( 0)          2
            bControlSize            4
            bmControls( 0)       0xff
            bmControls( 1)       0xff
            bmControls( 2)       0xff
            bmControls( 3)       0xff
            iExtension              0
            bLength                 9
            bDescriptorType        36
            bDescriptorSubtype      3 (OUTPUT_TERMINAL)
            bTerminalID             4
            wTerminalType      0x0101 USB Streaming
            bAssocTerminal          0
            bSourceID               3
            iTerminal               0
            bLength                 9
            bDescriptorType        36
            bTerminalID             5
            bAssocTerminal          0
            bSourceID               3
            iTerminal               0
          Endpoint Descriptor:
            bLength                 7
            bDescriptorType         5
            bEndpointAddress     0x87  EP 7 IN
            bmAttributes            3
              Transfer Type            Interrupt
              Synch Type               None
              Usage Type               Data
            wMaxPacketSize     0x0020  1x 32 bytes
            bInterval               1
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        1
          bAlternateSetting       0
          bNumEndpoints           0
          bInterfaceSubClass      2 Video Streaming
          iInterface              0
          VideoStreaming Interface Descriptor:
            bLength                            14
            bDescriptorType                    36
            bDescriptorSubtype                  1 (INPUT_HEADER)
            bNumFormats                         1
            wTotalLength                      106
            bEndPointAddress                  129
            bmInfo                              0
            bTerminalLink                       4
            bStillCaptureMethod                 1
            bTriggerSupport                     0
            bTriggerUsage                       0
            bControlSize                        1
            bmaControls( 0)                    28
            bLength                            28
            bDescriptorType                    36
            bDescriptorSubtype                 16 (FORMAT_FRAME_BASED)
            bFormatIndex                        1
            bNumFrameDescriptors                2
            guidFormat                            {48323634-0000-1000-8000-00aa00389b71}
            bBitsPerPixel                      16
            bDefaultFrameIndex                  1
            bAspectRatioX                       0
            bAspectRatioY                       0
            bmInterlaceFlags                 0x00
              Interlaced stream or variable: No
              Fields per frame: 2 fields
              Field 1 first: No
              Field pattern: Field 1 only
              bCopyProtect                      0
              bVariableSize                     1
            bLength                            34
            bDescriptorType                    36
            bDescriptorSubtype                 17 (FRAME_FRAME_BASED)
            bFrameIndex                         1
            bmCapabilities                   0x00
              Still image unsupported
            wWidth                           3840
            wHeight                          2160
            dwMinBitRate                165888000
            dwMaxBitRate                995328000
            dwDefaultFrameInterval         666666
            bFrameIntervalType                  2
            dwBytesPerLine                      0
            dwFrameInterval( 0)            333333
            dwFrameInterval( 1)            666666
            bLength                            30
            bDescriptorType                    36
            bFrameIndex                         2
            bmCapabilities                   0x00
            wWidth                           1920
            wHeight                          1080
            dwDefaultFrameInterval         333333
            bFrameIntervalType                  1
            dwBytesPerLine                      0
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        1
          bAlternateSetting       1
          bNumEndpoints           1
          iInterface              0
            bLength                 7
            bDescriptorType         5
            bEndpointAddress     0x81  EP 1 IN
            bmAttributes            5
              Transfer Type            Isochronous
              Synch Type               Asynchronous
              Usage Type               Data
            wMaxPacketSize     0x0080  1x 128 bytes
            bInterval               1
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        1
          bAlternateSetting       2
          bNumEndpoints           1
          iInterface              0
            bLength                 7
            bDescriptorType         5
            bmAttributes            5
              Usage Type               Data
            wMaxPacketSize     0x0180  1x 384 bytes
            bInterval               1
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        1
          bAlternateSetting       3
          bNumEndpoints           1
          iInterface              0
            bLength                 7
            bDescriptorType         5
            bmAttributes            5
              Usage Type               Data
            wMaxPacketSize     0x0200  1x 512 bytes
            bInterval               1
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        1
          bAlternateSetting       4
          bNumEndpoints           1
          iInterface              0
            bLength                 7
            bDescriptorType         5
            bmAttributes            5
              Usage Type               Data
            wMaxPacketSize     0x0a80  2x 640 bytes
            bInterval               1
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        1
          bAlternateSetting       5
          bNumEndpoints           1
          iInterface              0
            bLength                 7
            bDescriptorType         5
            bmAttributes            5
              Usage Type               Data
            wMaxPacketSize     0x0b00  2x 768 bytes
            bInterval               1
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        1
          bAlternateSetting       6
          bNumEndpoints           1
          iInterface              0
            bLength                 7
            bDescriptorType         5
            bmAttributes            5
              Usage Type               Data
            wMaxPacketSize     0x0b80  2x 896 bytes
            bInterval               1
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        1
          bAlternateSetting       7
          bNumEndpoints           1
          iInterface              0
            bLength                 7
            bDescriptorType         5
            bmAttributes            5
              Usage Type               Data
            wMaxPacketSize     0x0bfc  2x 1020 bytes
            bInterval               1
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        2
          bAlternateSetting       0
          bNumEndpoints           0
          iInterface              0
            bLength                            15
            bDescriptorType                    36
            bNumFormats                         2
            wTotalLength                      125
            bEndPointAddress                  136
            bmInfo                              0
            bTerminalLink                       5
            bTriggerSupport                     0
            bTriggerUsage                       0
            bControlSize                        1
            bmaControls( 0)                    27
            bmaControls( 1)                    27
            bLength                            27
            bDescriptorType                    36
            bDescriptorSubtype                  4 (FORMAT_UNCOMPRESSED)
            bFormatIndex                        1
            bNumFrameDescriptors                1
            guidFormat                            {59555932-0000-1000-8000-00aa00389b71}
            bBitsPerPixel                      16
            bAspectRatioX                       0
            bAspectRatioY                       0
              Field 1 first: No
              bCopyProtect                      0
            bLength                            30
            bDescriptorType                    36
            bDescriptorSubtype                  5 (FRAME_UNCOMPRESSED)
            bFrameIndex                         1
            bmCapabilities                   0x00
            wWidth                            640
            wHeight                           480
            dwMinBitRate                 24576000
            dwMaxBitRate                147456000
            dwMaxVideoFrameBufferSize      614400
            dwFrameInterval( 0)            666666
            bLength                             6
            bDescriptorType                    36
            bDescriptorSubtype                 13 (COLORFORMAT)
            bColorPrimaries                     1 (BT.709,sRGB)
            bTransferCharacteristics            1 (BT.709)
            bMatrixCoefficients                 4 (SMPTE 170M (BT.601))
            bLength                            11
            bDescriptorType                    36
            bDescriptorSubtype                  6 (FORMAT_MJPEG)
            bFormatIndex                        2
            bFlags                              1
              Fixed-size samples: Yes
            bAspectRatioX                       0
            bAspectRatioY                       0
              Fields per frame: 1 fields
              Field 1 first: No
              bCopyProtect                      0
            bLength                            30
            bDescriptorType                    36
            bDescriptorSubtype                  7 (FRAME_MJPEG)
            bFrameIndex                         1
            bmCapabilities                   0x00
            wWidth                           1920
            wHeight                          1080
            bLength                             6
            bDescriptorType                    36
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        2
          bAlternateSetting       1
          bNumEndpoints           1
          iInterface              0
            bLength                 7
            bDescriptorType         5
            bEndpointAddress     0x88  EP 8 IN
            bmAttributes            5
              Usage Type               Data
            bInterval               1
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        2
          bAlternateSetting       2
          bNumEndpoints           1
          iInterface              0
            bLength                 7
            bDescriptorType         5
            bmAttributes            5
              Usage Type               Data
            bInterval               1
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        2
          bAlternateSetting       3
          bNumEndpoints           1
          iInterface              0
            bLength                 7
            bDescriptorType         5
            bmAttributes            5
              Usage Type               Data
            bInterval               1
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        2
          bAlternateSetting       4
          bNumEndpoints           1
          iInterface              0
            bLength                 7
            bDescriptorType         5
            bmAttributes            5
              Usage Type               Data
            bInterval               1
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        2
          bAlternateSetting       5
          bNumEndpoints           1
          iInterface              0
            bLength                 7
            bDescriptorType         5
            bmAttributes            5
              Usage Type               Data
            bInterval               1
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        2
          bAlternateSetting       6
          bNumEndpoints           1
          iInterface              0
            bLength                 7
            bDescriptorType         5
            bmAttributes            5
              Usage Type               Data
            bInterval               1
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        2
          bAlternateSetting       7
          bNumEndpoints           1
          iInterface              0
            bLength                 7
            bDescriptorType         5
            bmAttributes            5
              Usage Type               Data
            bInterval               1
    Device Qualifier (for other device speed):
      bLength                10
      bDescriptorType         6
      bcdUSB               2.00
      bDeviceSubClass         2
      bMaxPacketSize0        64
    can't get debug descriptor: Resource temporarily unavailable
    Device Status:     0x0001
      Self Powered
    KrisK 1 Reply Last reply
    • KrisK Kris
      system-image: 3.8.0
      hw version:   VOXL
      voxl-suite:   0.7.0
      voxl-libuvc - 1.0.6
      voxl-logger - 0.1.2
      voxl-modem - 0.15.1
      voxl-portal - 0.2.6
      voxl-suite - 0.7.0
      voxl-utils - 1.1.1
      voxl-vpn - 0.0.6
      libmodal-cv - 0.0.5
      voxl:~$ lsusb
      Found device 1
      Device Descriptor:
        bLength                18
        bDescriptorType         1
        bcdUSB               2.00
        bDeviceSubClass         2
        bMaxPacketSize0        64
        idVendor           0x2560
        idProduct          0xc184
        bcdDevice            1.00
        iSerial                 3 00.00.01
          bLength                 9
          bDescriptorType         2
          wTotalLength          601
          bNumInterfaces          3
          iConfiguration          0
          bmAttributes         0xc0
            Self Powered
          MaxPower              100mA
            bLength                 8
            bDescriptorType        11
            bFirstInterface         0
            bInterfaceCount         3
            bFunctionProtocol       0
            iFunction               0
            bLength                 9
            bDescriptorType         4
            bInterfaceNumber        0
            bAlternateSetting       0
            bNumEndpoints           1
            iInterface              0
              bLength                14
              bDescriptorType        36
              bcdUVC               1.00
              wTotalLength           90
              bInCollection           2
              baInterfaceNr( 0)       1
              baInterfaceNr( 1)       2
              bLength                18
              bDescriptorType        36
              bTerminalID             1
              bAssocTerminal          0
              iTerminal               0
              bControlSize                  3
                Auto-Exposure Mode
                Zoom (Absolute)
                PanTilt (Absolute)
                Reserved
              bLength                11
              bDescriptorType        36
              bUnitID                 2
              bSourceID               1
              wMaxMultiplier          0
              bControlSize            2
                Brightness
                Contrast
                Sharpness
                Gain
              iProcessing             0
                None
                PAL - 625/50
                SECAM - 625/50
                NTSC - 625/50
              bLength                29
              bDescriptorType        36
              bUnitID                 3
              bNumControl             0
              bNrPins                 1
              baSourceID( 0)          2
              bControlSize            4
              bmControls( 0)       0xff
              bmControls( 1)       0xff
              bmControls( 2)       0xff
              bmControls( 3)       0xff
              iExtension              0
              bLength                 9
              bDescriptorType        36
              bTerminalID             4
              bAssocTerminal          0
              bSourceID               3
              iTerminal               0
              bLength                 9
              bDescriptorType        36
              bTerminalID             5
              bAssocTerminal          0
              bSourceID               3
              iTerminal               0
              bLength                 7
              bDescriptorType         5
              bmAttributes            3
                Synch Type               None
                Usage Type               Data
              bInterval               1
            bLength                 9
            bDescriptorType         4
            bInterfaceNumber        1
            bAlternateSetting       0
            bNumEndpoints           0
            iInterface              0
              bLength                            14
              bDescriptorType                    36
              bNumFormats                         1
              wTotalLength                      106
              bmInfo                              0
              bTerminalLink                       4
              bTriggerSupport                     0
              bTriggerUsage                       0
              bControlSize                        1
              bmaControls( 0)                    28
              bLength                            28
              bDescriptorType                    36
              bFormatIndex                        1
              bBitsPerPixel                      16
              bAspectRatioX                       0
              bAspectRatioY                       0
                Field 1 first: No
                bCopyProtect                      0
                bVariableSize                     1
              bLength                            34
              bDescriptorType                    36
              bFrameIndex                         1
              bmCapabilities                   0x00
              wWidth                           3840
              wHeight                          2160
              dwBytesPerLine                      0
              bLength                            30
              bDescriptorType                    36
              bFrameIndex                         2
              bmCapabilities                   0x00
              wWidth                           1920
              wHeight                          1080
              dwBytesPerLine                      0
            bLength                 9
            bDescriptorType         4
            bInterfaceNumber        1
            bAlternateSetting       1
            bNumEndpoints           1
            iInterface              0
              bLength                 7
              bDescriptorType         5
              bmAttributes            5
                Usage Type               Data
              bInterval               1
            bLength                 9
            bDescriptorType         4
            bInterfaceNumber        1
            bAlternateSetting       2
            bNumEndpoints           1
            iInterface              0
              bLength                 7
              bDescriptorType         5
              bmAttributes            5
                Usage Type               Data
              bInterval               1
            bLength                 9
            bDescriptorType         4
            bInterfaceNumber        1
            bAlternateSetting       3
            bNumEndpoints           1
            iInterface              0
              bLength                 7
              bDescriptorType         5
              bmAttributes            5
                Usage Type               Data
              bInterval               1
            bLength                 9
            bDescriptorType         4
            bInterfaceNumber        1
            bAlternateSetting       4
            bNumEndpoints           1
            iInterface              0
              bLength                 7
              bDescriptorType         5
              bmAttributes            5
                Usage Type               Data
              bInterval               1
            bLength                 9
            bDescriptorType         4
            bInterfaceNumber        1
            bAlternateSetting       5
            bNumEndpoints           1
            iInterface              0
              bLength                 7
              bDescriptorType         5
              bmAttributes            5
                Usage Type               Data
              bInterval               1
            bLength                 9
            bDescriptorType         4
            bInterfaceNumber        1
            bAlternateSetting       6
            bNumEndpoints           1
            iInterface              0
              bLength                 7
              bDescriptorType         5
              bmAttributes            5
                Usage Type               Data
              bInterval               1
            bLength                 9
            bDescriptorType         4
            bInterfaceNumber        1
            bAlternateSetting       7
            bNumEndpoints           1
            iInterface              0
              bLength                 7
              bDescriptorType         5
              bmAttributes            5
                Usage Type               Data
              bInterval               1
            bLength                 9
            bDescriptorType         4
            bInterfaceNumber        2
            bAlternateSetting       0
            bNumEndpoints           0
            iInterface              0
              bLength                            15
              bDescriptorType                    36
              bNumFormats                         2
              wTotalLength                      125
              bmInfo                              0
              bTerminalLink                       5
              bTriggerSupport                     0
              bTriggerUsage                       0
              bControlSize                        1
              bmaControls( 0)                    27
              bmaControls( 1)                    27
              bLength                            27
              bDescriptorType                    36
              bFormatIndex                        1
              bBitsPerPixel                      16
              bAspectRatioX                       0
              bAspectRatioY                       0
                Field 1 first: No
                bCopyProtect                      0
              bLength                            30
              bDescriptorType                    36
              bFrameIndex                         1
              bmCapabilities                   0x00
              wWidth                            640
              wHeight                           480
              bLength                             6
              bDescriptorType                    36
              bLength                            11
              bDescriptorType                    36
              bFormatIndex                        2
              bFlags                              1
              bAspectRatioX                       0
              bAspectRatioY                       0
                Field 1 first: No
                bCopyProtect                      0
              bLength                            30
              bDescriptorType                    36
              bFrameIndex                         1
              bmCapabilities                   0x00
              wWidth                           1920
              wHeight                          1080
              bLength                             6
              bDescriptorType                    36
            bLength                 9
            bDescriptorType         4
            bInterfaceNumber        2
            bAlternateSetting       1
            bNumEndpoints           1
            iInterface              0
              bLength                 7
              bDescriptorType         5
              bmAttributes            5
                Usage Type               Data
              bInterval               1
            bLength                 9
            bDescriptorType         4
            bInterfaceNumber        2
            bAlternateSetting       2
            bNumEndpoints           1
            iInterface              0
              bLength                 7
              bDescriptorType         5
              bmAttributes            5
                Usage Type               Data
              bInterval               1
            bLength                 9
            bDescriptorType         4
            bInterfaceNumber        2
            bAlternateSetting       3
            bNumEndpoints           1
            iInterface              0
              bLength                 7
              bDescriptorType         5
              bmAttributes            5
                Usage Type               Data
              bInterval               1
            bLength                 9
            bDescriptorType         4
            bInterfaceNumber        2
            bAlternateSetting       4
            bNumEndpoints           1
            iInterface              0
              bLength                 7
              bDescriptorType         5
              bmAttributes            5
                Usage Type               Data
              bInterval               1
            bLength                 9
            bDescriptorType         4
            bInterfaceNumber        2
            bAlternateSetting       5
            bNumEndpoints           1
            iInterface              0
              bLength                 7
              bDescriptorType         5
              bmAttributes            5
                Usage Type               Data
              bInterval               1
            bLength                 9
            bDescriptorType         4
            bInterfaceNumber        2
            bAlternateSetting       6
            bNumEndpoints           1
            iInterface              0
              bLength                 7
              bDescriptorType         5
              bmAttributes            5
                Usage Type               Data
              bInterval               1
            bLength                 9
            bDescriptorType         4
            bInterfaceNumber        2
            bAlternateSetting       7
            bNumEndpoints           1
            iInterface              0
              bLength                 7
              bDescriptorType         5
              bmAttributes            5
                Usage Type               Data
              bInterval               1
        bLength                10
        bDescriptorType         6
        bcdUSB               2.00
        bDeviceSubClass         2
        bMaxPacketSize0        64
        Self Powered
      KrisK Offline
      KrisK Offline
      Kris
      Below are the errors that I am getting.
      uvc_open failed
      uvc_open failed
      voxl:~$ voxl-streamer -c uvc-generic -d
      Using configuration uvc-generic
      Enabling debug messages
      Using configuration file /etc/modalai/voxl-streamer.conf
      MPA interface chosen
      Input pipe name /run/mpa/uvc/
      Output stream width 640
      Output stream height 480
      Output stream bitrate 1000000
      Output stream rotation 0
      Output frame decimator 2
      No image overlay specified
      Camera server Connected
      First frame timestamp: 3202206494106
      Second frame timestamp: 3203206232991
      Calculated frame delta in ns: 999738885
      Calculated frame delta in 100us: 9997
      Calculated input frame rate is: 1
      Output frame rate will be: 0
      ERROR: Frame size mismatch 614400 12441600
      ERROR: Timeout on input parameter initialization
      Below is my streamer.conf file
          "conf-version":"1.3",
          "configuration": "hires",
          "uvc-generic": {
              "input": {
                  "interface": "mpa",
                  "mpa-camera": "uvc" },
              "output": {
                  "stream": {
                      "rotation": 0,
                      "width": 640,
                      "height": 480,
                      "decimator": 2,
                      "bitrate": 1000000 } }
          "uvc-flir-boson": {
              "input": {
                  "interface": "mpa",
              "output": {
                  "stream": {
                      "rotation": 0,
                      "width": 640,
                      "height": 512,
                      "decimator": 2,
          "uvc-flir-lepton": {
              "input": {
                  "interface": "mpa",
              "output": {
                  "stream": {
                      "rotation": 0,
                      "width": 160,
                      "height": 120,
                      "bitrate": 500000 } }
          "hires": {
              "input": {
                  "interface": "mpa",
                  "mpa-camera": "hires" },
              "output": {
                  "stream": {
                      "rotation": 0,
                      "width": 640,
                      "height": 480,
                      "decimator": 2,
          "hires-logo": {
              "input": {
                  "interface": "mpa",
              "output": {
                  "stream": {
                      "rotation": 0,
                      "width": 640,
                      "height": 480,
                      "decimator": 2,
                      "bitrate": 1000000 } },
              "overlay": {
                  "location": "/etc/modalai/modalai.png",
                  "offset_x": -1,
                  "offset_y": -1 }
          "stereo": {
              "input": {
                  "interface": "mpa",
                  "mpa-camera": "stereo" },
              "output": {
                  "stream": {
                      "width": 640,
                      "height": 960,
                      "decimator": 2,
          "tracking": {
              "input": {
                  "interface": "mpa",
                  "mpa-camera": "tracking" },
              "output": {
                  "stream": {
                      "width": 640,
                      "height": 480,
                      "decimator": 2,
          "dfs-disparity": {
              "input": {
                  "interface": "mpa",
                  "mpa-camera": "dfs_disparity" },
              "output": {
                  "stream": {
                      "width": 640,
                      "height": 480,
                      "decimator": 2,
          "qvio-overlay": {
              "input": {
                  "interface": "mpa",
                  "mpa-camera": "qvio_overlay" },
              "output": {
                  "stream": {
                      "width": 640,
                      "height": 544,
                      "decimator": 2,
          "tflite-overlay": {
              "input": {
                  "interface": "mpa",
                  "mpa-camera": "tflite" },
              "output": {
                  "stream": {
                      "width": 640,
                      "height": 480,
                      "decimator": 2,
          "hdmi-mpa": {
              "input": {
                  "interface": "mpa",
                  "mpa-camera": "v4l2" },
              "output": {
                  "stream": {
                      "width": 640,
                      "height": 360,
                      "decimator": 2,
          "gphoto2-mpa": {
              "input": {
                  "interface": "mpa",
                  "mpa-camera": "gphoto2" },
              "output": {
                  "stream": {
                      "width": 640,
                      "height": 360,
                      "decimator": 2,
          "video-test": {
              "input": {
                  "interface": "test",
                  "frame": {
                      "width": 640,
                      "height": 480,
                      "format": "yuv420" } },
              "output": {
                  "stream": {
                      "rotation": 0,
                      "width": 640,
                      "height": 480,
                      "rate": 30,
          "uvc-video": {
              "input": {
                  "interface": "uvc",
                  "device": "/dev/video0" },
              "output": {
                  "stream": {
                      "rotation": 0,
                      "width": 640,
                      "height": 360,
                      "rate": 15,
      So, it looks like I am running into the same problem that @wilkinsaf had, but I could be wrong. Please let me know what you think.
      Thank you
      • KrisK Kris
        uvc_open failed
        uvc_open failed
            "uvc-generic": {
                "input": {
                    "interface": "mpa",
                "output": {
                    "stream": {
                        "rotation": 0,
                        "width": 640,
                        "height": 480,
                        "decimator": 2,
            "uvc-flir-boson": {
                "input": {
                    "interface": "mpa",
                "output": {
                    "stream": {
                        "rotation": 0,
                        "width": 640,
                        "height": 512,
                        "decimator": 2,
                "input": {
                    "interface": "mpa",
                "output": {
                    "stream": {
                        "rotation": 0,
                        "width": 160,
                        "height": 120,
            "hires": {
                "input": {
                    "interface": "mpa",
                "output": {
                    "stream": {
                        "rotation": 0,
                        "width": 640,
                        "height": 480,
                        "decimator": 2,
            "hires-logo": {
                "input": {
                    "interface": "mpa",
                "output": {
                    "stream": {
                        "rotation": 0,
                        "width": 640,
                        "height": 480,
                        "decimator": 2,
                "overlay": {
                    "offset_x": -1,
                    "offset_y": -1 }
            "stereo": {
                "input": {
                    "interface": "mpa",
                "output": {
                    "stream": {
                        "width": 640,
                        "height": 960,
                        "decimator": 2,
            "tracking": {
                "input": {
                    "interface": "mpa",
                "output": {
                    "stream": {
                        "width": 640,
                        "height": 480,
                        "decimator": 2,
            "dfs-disparity": {
                "input": {
                    "interface": "mpa",
                "output": {
                    "stream": {
                        "width": 640,
                        "height": 480,
                        "decimator": 2,
            "qvio-overlay": {
                "input": {
                    "interface": "mpa",
                "output": {
                    "stream": {
                        "width": 640,
                        "height": 544,
                        "decimator": 2,
            "tflite-overlay": {
                "input": {
                    "interface": "mpa",
                "output": {
                    "stream": {
                        "width": 640,
                        "height": 480,
                        "decimator": 2,
            "hdmi-mpa": {
                "input": {
                    "interface": "mpa",
                "output": {
                    "stream": {
                        "width": 640,
                        "height": 360,
                        "decimator": 2,
            "gphoto2-mpa": {
                "input": {
                    "interface": "mpa",
                "output": {
                    "stream": {
                        "width": 640,
                        "height": 360,
                        "decimator": 2,
            "video-test": {
                "input": {
                    "frame": {
                        "width": 640,
                        "height": 480,
                "output": {
                    "stream": {
                        "rotation": 0,
                        "width": 640,
                        "height": 480,
                        "rate": 30,
            "uvc-video": {
                "input": {
                    "interface": "uvc",
                "output": {
                    "stream": {
                        "rotation": 0,
                        "width": 640,
                        "height": 360,
                        "rate": 15,
        Thank you
        KrisK Offline
        KrisK Offline
        Kris
        I had also tried “decimator”: 1,
        for the UVC generic in the streamer.conf file, and that did not work either.
            "uvc-generic": {
                "input": {
                    "interface": "mpa",
                "output": {
                    "stream": {
                        "rotation": 0,
                        "width": 640,
                        "height": 480,
                        "decimator": 1,
        • KrisK Kris
              "uvc-generic": {
                  "input": {
                      "interface": "mpa",
                  "output": {
                      "stream": {
                          "rotation": 0,
                          "width": 640,
                          "height": 480,
                          "decimator": 1,
          KrisK Offline
          KrisK Offline
          Kris
          The Frame size mismatch 614400 12441600 is always the same.
          • tomT Offline
            @Kris You're on a pretty old platform release, I would start by updating to 0.9: https://developer.modalai.com/asset/view/115
            KrisK 2 Replies Last reply
              KrisK Offline
              KrisK Offline
              Kris
              @tom
              Ok, thank you. I will try that first.
                KrisK Offline
                KrisK Offline
                Kris
                @tom
                I've updated my platform to 0.9 and I am still unable to successfully open the uvc camera.
                voxl:~$ lsusb
                Bus 001 Device 008: ID 2560:c184
                voxl:~$ voxl-uvc-server -p c184
                uvc_open failed
                voxl:~$ voxl-uvc-server -v 2560
                uvc_open failed
                voxl:~$ voxl-uvc-server -d
                voxl-uvc-server starting
                Image resolution 640x480, 30 fps chosen
                UVC initialized
                Device found
                uvc_open failed
                UVC exited
                voxl-uvc-server ending
                • tomT Offline
                  @Kris Are you sure that your UVC camera is 640x480 resolution?
                    KrisK Offline
                    KrisK Offline
                    Kris
                    @tom
                    Yes, in the debug messages, it says that it is 640x480.
                    Is there another way to check the resolution?
                    • tomT Offline
                      @Kris Yeah that's just the default that voxl-uvc-server uses if not explicitly specified otherwise with the -r flag.
                      You can use show-video-device-info.sh and that may provide some clues.
                      What is the part number or make and model of the UVC camera you're using? It's possible it's supported image formats don't match up with those supported by voxl-uvc-server
                      KrisK 4 Replies Last reply
                        KrisK Offline
                        KrisK Offline
                        Kris
                        @tom Ok, Thank you I will try that now.
                        Here are some details of my UVC 2.0 camera.
                          KrisK Offline
                          KrisK Offline
                          Kris
                          @tom
                          This is all the information I get from show-video-device-info.sh
                          voxl:~$ show-video-device-info.sh
                          /dev/video2: e-CAM83_USB 2560:c184
                          /dev/video3: e-CAM83_USB 2560:c184
                          • KrisK Offline
                            KrisK Offline
                            Kris
                            wrote on last edited by Kris
                            #13
                            Is there any chance I can get 1920 x 1080 @30 fps using h264 in the voxl-uvc-server?
                            Or is 640 x 480 the only option in the voxl-uvc-server?
                            • KrisK Offline
                              KrisK Offline
                              Kris
                              The rest of the information about my current uvc camera is here.
                              • KrisK Offline
                                KrisK Offline
                                Kris
                                Additional information;
                                  KrisK Offline
                                  KrisK Offline
                                  Kris
                                  @tom
                                  I gave this a try, but no luck.
                                  voxl:~$ voxl-uvc-server -d -r 1920x1080 -f 30
                                  Image resolution 1920x1080, 30 fps chosen
                                  UVC initialized
                                  Device found
                                  uvc_open failed
                                  UVC exited
                                    KrisK Offline
                                    KrisK Offline
                                    Kris
                                    @tom
                                    /dev/video2: is h264
                                    /dev/video3: is MJPG & YUY2
                                    • KrisK Offline
                                      KrisK Offline
                                      Kris
                                      voxl:~$ voxl-uvc-server -l
                                      Found device 0
                                      uvc_open failed, Return code: I/O error (-1)
                                      Found device 0
                                      Found device 0
                                      uvc_find_device failed, Return code: No such device (-4)
                                      DEVICE CONFIGURATION (2560:c184/00.00.01) ---
                                      Status: idle
                                      VideoControl:
                                      	bcdUVC: 0x0100
                                      VideoStreaming(1):
                                      	bEndpointAddress: 129
                                      	Formats:
                                      	FrameFormat(1)
                                      		  bits per pixel: 16
                                      		  GUID: 4832363400001000800000aa00389b71 (H264)
                                      		  default frame: 1
                                      		  aspect ratio: 0x0
                                      		  interlace flags: 00
                                      		  copy protect: 00
                                      			FrameDescriptor(1)
                                      			  capabilities: 00
                                      			  bit rate: 165888000-995328000
                                      			  max frame size: 0
                                      			  default interval: 1/15
                                      			  interval[0]: 1/30
                                      			  interval[1]: 1/15
                                      			FrameDescriptor(2)
                                      			  capabilities: 00
                                      			  max frame size: 0
                                      			  default interval: 1/30
                                      			  interval[0]: 1/30
                                      VideoStreaming(2):
                                      	bEndpointAddress: 136
                                      	Formats:
                                      	UncompressedFormat(1)
                                      		  bits per pixel: 16
                                      		  GUID: 5955593200001000800000aa00389b71 (YUY2)
                                      		  default frame: 1
                                      		  aspect ratio: 0x0
                                      		  interlace flags: 00
                                      		  copy protect: 00
                                      			FrameDescriptor(1)
                                      			  capabilities: 00
                                      			  bit rate: 24576000-147456000
                                      			  max frame size: 614400
                                      			  interval[0]: 1/15
                                      	MJPEGFormat(2)
                                      		  bits per pixel: 0
                                      		  GUID: 4d4a5047000000000000000000000000 (MJPG)
                                      		  default frame: 1
                                      		  aspect ratio: 0x0
                                      		  interlace flags: 00
                                      		  copy protect: 00
                                      			FrameDescriptor(1)
                                      			  capabilities: 00
                                      			  interval[0]: 1/30
                                      END DEVICE CONFIGURATION
                                        KrisK Offline
                                        KrisK Offline
                                        Kris
                                        @tom
                                        May I ask what image formats the voxl-uvc-serversupports?
                                        • KrisK Offline
                                          KrisK Offline
                                          Kris
                                          I have a feeling that maybe the problem is deriving from my camera’s GUID Format.
                                          Does the voxl-uvc-server accept GUID: 4832363400001000800000aa00389b71
                                          for h264 format?
                                          How would I go about correcting the guidFormat to match up with the voxl-uvc-server?
