  3. Voxl-docker creates unsable HAL3 binary file
4 Posts 2 Posters 509 Views 1 Watching
  • S Offline
    S Offline
    ShauliXtend
    wrote on last edited by ShauliXtend
    I was trying to follow the guide to create a simple HAL3 example application -
    https://gitlab.com/voxl-public/support/apps-proc-examples/-/tree/master/hellocamera
    Unfortunately, when using the voxl-docker, the file created is usable when using the VOXL2.
    This is the error I received -
    hello_hal3_camera: error while loading shared libraries: libutils.so.0: wrong ELF class: ELFCLASS64
    I was also wondering if is is possible to create a VOXL2 image + SDK intended for developers so everything can be compiled natively over the board itself.
    Shauli
      That hellocamera is a really old example that predates the VOXL SDKbfor VOXL 1.
      voxl-camera-server is the supported method for accessing camera data. You can leverage that source code if you want to do something else
      S 1 Reply Last reply
      • Chad SweetC Chad Sweet
        S Offline
        S Offline
        ShauliXtend
        Hi @Chad-Sweet ,
        Thanks for letting me know. I would advice to maybe write somewhere that is not the recommended approach when using VOXL2.
          thanks for the suggestion, note added to hellocamera
