  3. Tracking camera calibration not progressing
voxl-cam
23 Posts 5 Posters 12.9k Views 3 Watching
    @KnightHawk06 ,
    Oh i understand now.. The red box in the overlay defines the region where you need the calibration pattern to be located, HOWEVER there is also a requirement for the area within that red box that the pattern must fill. So, in your case, the detected pattern is too small within the red box, so you need to bring the pattern closer to the camera.
    In calibrator.cpp, look for the following:
    //Each item represents a desired square in percentages of the image {x1,y1,x2,y2, fill threshold, #samples} from top left
    On that fisheye stereo branch i lowered the thresholds for Fisheye patterns, but not FisheyeWide patterns, so you are still having issues (after trying to bring the pattern closer), you would want to slightly lower the fill thresholds here : https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-camera-calibration/-/blob/0bce9a25c67e64a229cfcbad4b6ace3a5837ee1b/src/calibrator.cpp#L272 (maybe from 40 to 35 and from 45 to 30).
    KnightHawk06K Offline
    KnightHawk06
    wrote on last edited by KnightHawk06
    #21
    @Alex-Kushleyev Thanks, that definitely helped. I was able to get through calibration but I was moving the camera to track the board so I think there was too much motion, I tried again by keeping the camera stationary and moving the board but I was only able to get through 2 of the squares.
    This one looks like it should have advanced?
    voxl2:~$ voxl-calibrate-camera tracking_down_misp_grey -f -s 6x9 -l 0.0254
    Waiting for valid pipe...
    Please open voxl-portal in a web browser to view the camera calibrator overlay stream
    Running Calibration...
    Matrix
    [467.7722718958223, 0, 643.0951201881879;
    0, 465.4675015580457, 407.219312862067;
    0, 0, 1]
    Distortion
    [0.06879494760256116;
    -0.06189410980661297;
    0.09295232529748904;
    -0.03719414450439851]
    distortion_model: fisheye
    Re-projection error reported by calibrateCamera: 1.55185
    Calibration Failed
    Max reprojection error: 0.60
    This is most likely due to motion blur, please try again.
    Exiting Cleanly
    I went down to 30,25 % fill and was able to complete the calibration but I'm still getting the motion blur error.
    Matrix
    [469.8268457990205, 0, 645.2242591682075;
    0, 468.3299010304277, 405.5249057705095;
    0, 0, 1]
    Distortion
    [0.04544429816970399;
    -0.02133881952988525;
    0.08318821819789667;
    -0.04616442017968726]
    Re-projection error reported by calibrateCamera: 1.26416
    Calibration Failed
    Exiting Cleanly
    • KnightHawk06K KnightHawk06
      Matrix
      0, 0, 1]
      Distortion
      Calibration Failed
      Exiting Cleanly
      Matrix
      0, 0, 1]
      Distortion
      Calibration Failed
      Exiting Cleanly
      @KnightHawk06 ,
      You should double check something - is your calibration pattern perfectly flat?
      When I perform camera calibration, I use an LCD screen to display the pattern whenever possible, because the screes are typically very flat.
      In order to avoid blurring, you could (temporarily) limit the upper end of the exposure range in volx-camera-server.conf to something like 5ms and that should help. This will cause the gain to be increased (automatically) to achieve the same i mage brightness, which will result in a bit more noise, but it should be ok. After calibration, you can set the upper exposure back. Alternatively, you can set the exposure / gain from voxl2 command line like so:
      voxl-send-command tracking_down set_exp_gain 5.0 400
      (this should override the automatic exposure / gain control and set the exposure to 5ms and gain to 400 (4.0x analog gain).
      If you are still using the printed pattern, increasing the illumination in the room should also help make the image brighter and drive the exposure down, reducing the blur.
      KnightHawk06K 1 Reply Last reply
        @KnightHawk06 ,
        KnightHawk06
        @Alex-Kushleyev I initially tried using an LCD screen for the checkerboard, but the camera wasn't detecting it. Should I move the camera around when transitioning between boxes on the LCD screen?
        Afterward, I reverted to the physical checkerboard and moved slowly during calibration. Additionally, I switched to the stereo camera configuration (https://docs.modalai.com/voxl2-camera-configs/#c-10-front-stereo-only-ov7251). Calibration completed successfully, and I was able to start the voxl-dfs-server (after renaming the intrinsics/extrinsics files to match the DFS configuration).
        However, I'm still not seeing valid output data in the VOXL Portal. Both the DFS server status and journal logs appear normal. Any idea what might be causing this?
        The orientation was labeled vertical in the extrinsics file, I updated it to horizontal since the cameras are mounted in that direction, I tried both.
        voxl2:~$ voxl-calibrate-camera stereo -s 6x9 -l 0.0254
        Calibrating Left Camera
        using intrinsics guess for ov7251 stereo cam
        Matrix
        [512.0490656858071, 0, 317.943082105687;
         0, 512.9677676044445, 249.1010817824914;
         0, 0, 1]
        Distortion
        [-0.2223760024137635;
         0.2834698825913266;
         0.006375005556120415;
         0.001380405690556171;
         -0.3234049381178579]
        distortion_model: plumb_bob
        Re-projection error reported by calibrateCamera: 0.618295
        Calibration Succeded!
        Calibrating Right Camera
        Matrix
        [499.9941123870856, 0, 302.2300515222531;
         0, 500.0159138740167, 197.2845691878148;
         0, 0, 1]
        Distortion
        [-0.1920328131645855;
         0.1661211129668493;
         -9.2603546772169e-06;
         -0.0005742159007090549;
         -0.1386842520292771]
        Re-projection error reported by calibrateCamera: 0.654897
        Calibrating Extrinsics
        7 frames will be processed
        Processing non-fisheye stereo
        R
        [0.9998717783469182, -0.01301971984148091, 0.009322754990917012;
         0.01315096821001574, 0.9998132816974246, -0.01415816995820597;
         -0.009136678855605861, 0.01427895782876463, 0.9998563059074108]
        T
        [-0.09106229154044132;
         0.0003557888497092847;
         -0.01247277836064075]
        Re-projection error reported by stereoCalibrate: 0.921971
        Detected horizontal stereo pair
        Distance between cameras: 0.0911
        Extrinsics Calibration Succeded!
        Saved intrinsics to: /data/modalai/opencv_stereo_intrinsics.yml
        Saved extrinsics to: /data/modalai/opencv_stereo_extrinsics.yml
        Exiting Cleanly
        cat opencv_stereo_front_extrinsics.yml
        %YAML:1.0
        R: !!opencv-matrix
           rows: 3
           cols: 3
           dt: d
           data: [ 9.9987177834691821e-01, -1.3019719841480912e-02,
               9.3227549909170124e-03, 1.3150968210015740e-02,
               9.9981328169742456e-01, -1.4158169958205966e-02,
               -9.1366788556058610e-03, 1.4278957828764632e-02,
               9.9985630590741081e-01 ]
        T: !!opencv-matrix
           rows: 3
           cols: 1
           dt: d
           data: [ -9.1062291540441320e-02, 3.5578884970928471e-04,
               -1.2472778360640750e-02 ]
        reprojection_error: 9.2197082833254862e-01
        orientation: vertical
        calibration_time: "2025-04-29 21:24:04"
        cat opencv_stereo_front_intrinsics.yml
        %YAML:1.0
        M1: !!opencv-matrix
           rows: 3
           cols: 3
           dt: d
           data: [ 5.1204906568580714e+02, 0., 3.1794308210568698e+02, 0.,
               5.1296776760444448e+02, 2.4910108178249143e+02, 0., 0., 1. ]
        D1: !!opencv-matrix
           rows: 5
           cols: 1
           dt: d
           data: [ -2.2237600241376348e-01, 2.8346988259132661e-01,
               6.3750055561204149e-03, 1.3804056905561710e-03,
               -3.2340493811785792e-01 ]
        reprojection_error1: 6.1829492384868989e-01
        M2: !!opencv-matrix
           rows: 3
           cols: 3
           dt: d
           data: [ 4.9999411238708558e+02, 0., 3.0223005152225312e+02, 0.,
               5.0001591387401669e+02, 1.9728456918781478e+02, 0., 0., 1. ]
        D2: !!opencv-matrix
           rows: 5
           cols: 1
           dt: d
           data: [ -1.9203281316458551e-01, 1.6612111296684931e-01,
               -9.2603546772168998e-06, -5.7421590070905486e-04,
               -1.3868425202927714e-01 ]
        reprojection_error2: 6.5489679777844001e-01
        width: 640
        height: 480
