  3. VOXL 2 direct powering 5V
15 Posts 3 Posters 1.8k Views 1 Watching
  • S SethG
    just for clarity, only DS1 is lit now, and that's a solid green, all other LED's out.
    Hi @SethG
    If only DS1 is on, then the main power tree on the board is not happy... despite having a good 5V supply.
    This sounds like either a short on a plug-in board 3.3V/1.8V, from a cable connection on 3.3V, camera voltages, or your hardware has a physical damage issue.
    Can you ensure there is nothing else plugged in when you are trying this basic ADB test? (remove all plug-in boards, cables, cameras, etc...).
    If it still persists after all else has been removed, then your HW is likely in need of an RMA and we can investigate it in our labs.
    https://www.modalai.com/pages/rma
    • S Offline
      S Offline
      SethG
      I want to add some clarification since this unit has already been RMA'd once and checked out A-OK. I may be the one making the error.
      This board is in no way accessible to ADB. It is not connected to any peripherals of any form, the power supply and battery are both supplied direct from ModalAI. There is no physical damage to the board.
      On the ModalAI documentation portal, here: https://docs.modalai.com/voxl2-leds/
      it indicates that there are three LED's and that the one closet to the power supply is called "D1" and that it is called "Power Good LED" and that if the light is out, that "indicates either 3P3 VREG or emulated VBAT are not good"
      Is that true? And is it correct for me to interpret that as if the LED is out, the power on the board is therefore not good? It seems like plain english, but I want to be super sure since you guys worked so hard to QC the board once and again to QC it again on RMA.
      Now I have also taken photos of the system today, can we concur that the D1 light is in fact out? and that the components connected to it are only ModalAI components and there are absolutely no peripherals attached that might cause a short?
      Am I doing something wrong here? Can anyone spot whatever mistake I am making?
      • S Offline
        S Offline
        SethG
        VinnyV 1 Reply Last reply
        • S SethG
          @SethG That is very odd. I was one of the two team members that confirmed your board was ok visually and electrically. I watched the other team member connect to adb and run several tests including cameras and a radio link without any issues whatever using the software that was already installed on that board.
          From what you show in that photo, I also see nothing wrong and DS1 should be illuminated (we checked that too and it worked in our labs).
          The only thing I can think of is this, just to rule it out (and sorry if you did this before and wrote it above)... Did you try a different battery or a power supply (the original post questions)?
          When that RGB led is green as it is, it is confirmation of input 5V voltage ok and no over current downstream. However it doesn't indicate if the supply is *capable of supporting the current needed to boot. So I'm curious if maybe the battery is actually not good and can't supply any current despite putting out some voltage. That battery can be in deep discharge mode at 9V, but as long as there is no current demand, our power module will still put out a valid 5V but cannot provide any current if that battery cannot, nor would any part of our system in this simple config be able to identify a deep discharge cell.
          Once booted, there are tools to help figure it out but in this case, you can't even get to that point.
            This looks like an MCBL-00001 failure. If the black wiring is pulled instead of the white connector housing the black wiring can become de-seated from the connector housing creating intermittent boot failures.
            Do you have another APM or MCBL-00001 around? If not, we can send you some MCBL-00001
            • S Offline
              S Offline
              SethG
              Just got back from some field testing up North. I see you sent you sent out an extra cable so I can try that and report back today. But the failure behavior is that it runs for awhile on that battery and then just fails and will not restart for any reason. Always well above 12V.
              • S Offline
                S Offline
                SethG
                I was able to repeat the testing with the new cables you sent (thank you), same result. It'll run for an hour or so and then hard stop. After it dies, interrupting power has no effect, the board is one light only. My hunch is that after some extended period of time without power, it will become bootable again.
                Seems like a terrifying problem because it'll result in whatever it's flying just dropping out of the sky.
                I've attached more pictures and this time attached a volt meter to show the battery's at a healthy 12.3V after the failure.
                • S Offline
                  S Offline
                  SethG
                  One last thing, I checked the power via px4-listener battery_status this time and I noticed that it has a field "warning: 3" No idea what that means.
                  And yes I have three or four APMv3's and have tried them all over time, this is the only time I've ever seen a warning and none of them will keep this board running.
                    OK, this is very odd and obviously not something that is typical. Just one last question, are you running anything when you power it on?
                    From the picture it doesn't look like much could be going on, but if you have a service file or something that launches automatically there could be something going on causing the chip to overheat after some time.
                    • S Offline
                      S Offline
                      SethG
                      Nothing, it's totally vanilla VOXL2. Our code is all user space python we run manually, and this thing hasn't run really since the beginning so it has the minimum.
                      Also this time I ran Voxl-inspect-cpu every so often and it shows the processors all running in the 500-800 mhz range nothing being warm.
