  3. Building ROS node with OpenCV
31 Posts 6 Posters 11.7k Views 4 Watching
  • Chad SweetC Chad Sweet
    All of those seem likely to work, though we haven't tried them so there could be some debugging required.
    S Offline
    S Offline
    sarahl
    @Chad-Sweet any advice on the above message? it doesn't seem to like trying to build an arm64 docker image on an amd64 ubuntu machine.
    • modaltbM Offline
      modaltbM Offline
      modaltb
      @sarahl ,
      I've been messing with another project in a similar area, this link helped:
      https://github.com/multiarch/qemu-user-static
      Namely, needing to run this 'magic command' before running my arm64 docker on x86 host (to be honest I'm not fully sure what it's doing)
      docker run --rm --privileged multiarch/qemu-user-static --reset -p yes
      Another thing that's helped is adding this to my docker file:
      # required for ARM emulation
      COPY ./bin/qemu-arm-static /usr/bin/qemu-arm-static
      Where in my project, I've copied qemu-arm-static into a bin dir in my repo.
      Hope this helps!
      S 1 Reply Last reply
      • ? Offline
        #13
        Hi @modaltb ,
        As I had also storage problems like posted here, I wanted to go with the way suggested by @Chad-Sweet. I am doing the same kind of project. Merging two Docker files(Ros Kinetic and Open CV).
        I am building the images in Raspi aarch64 Ubuntu 20.04.2.
        I was able to build ROS Kinetic image without Open CV and send to VOXL m500 to load and run.
        However, when I merged two files and built I got the following error but am not sure if it is the same error with @sarahl and qemu-arm-static will help me.
        What might be the problem or solution?
        Thank you in advance,
        I pasted the output message and two relevant docker files I merged:
        I used all the docker files for ros kinetic and adapted Open CV files into that.
        General configuration for OpenCV 3.4.6 =====================================
        --   Version control:               unknown
        --   Platform:
        --     Timestamp:                   2021-04-22T21:24:55Z
        --     Host:                        Linux 5.4.0-1034-raspi aarch64
        --     CMake:                       3.5.1
        --     CMake generator:             Unix Makefiles
        --     CMake build tool:            /usr/bin/make
        --     Configuration:               Release
        --   CPU/HW features:
        --     Baseline:                    NEON FP16
        --       required:                  NEON
        --       disabled:                  VFPV3
        --   C/C++:
        --     Built as dynamic libs?:      YES
        --     C++11:                       YES
        --     C++ Compiler:                /usr/bin/c++  (ver 5.4.0)
        --     C++ flags (Release):         -std=c++11 -march=armv8-a+simd   -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wundef -Winit-self -Wpointer-arith -Wshadow -Wsign-promo -Wuninitialized -Winit-self -Wno-delete-non-virtual-dtor -Wno-comment -fdiagnostics-show-option -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections    -fvisibility=hidden -fvisibility-inlines-hidden -fopenmp -O3 -DNDEBUG  -DNDEBUG
        --     C++ flags (Debug):           -std=c++11 -march=armv8-a+simd   -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wundef -Winit-self -Wpointer-arith -Wshadow -Wsign-promo -Wuninitialized -Winit-self -Wno-delete-non-virtual-dtor -Wno-comment -fdiagnostics-show-option -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections    -fvisibility=hidden -fvisibility-inlines-hidden -fopenmp -g  -O0 -DDEBUG -D_DEBUG
        --     C Compiler:                  /usr/bin/cc
        --     C flags (Release):           -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wmissing-prototypes -Wstrict-prototypes -Wundef -Winit-self -Wpointer-arith -Wshadow -Wuninitialized -Winit-self -Wno-comment -fdiagnostics-show-option -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections    -fvisibility=hidden -fopenmp -O3 -DNDEBUG  -DNDEBUG
        --     C flags (Debug):             -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wmissing-prototypes -Wstrict-prototypes -Wundef -Winit-self -Wpointer-arith -Wshadow -Wuninitialized -Winit-self -Wno-comment -fdiagnostics-show-option -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections    -fvisibility=hidden -fopenmp -g  -O0 -DDEBUG -D_DEBUG
        --     Linker flags (Release):      -Wl,--gc-sections
        --     Linker flags (Debug):        -Wl,--gc-sections
        --     ccache:                      NO
        --     Precompiled headers:         YES
        --     Extra dependencies:          dl m pthread rt
        --     3rdparty dependencies:
        --   OpenCV modules:
        --     To be built:                 calib3d core dnn features2d flann highgui imgcodecs imgproc ml objdetect photo python2 stitching ts video videoio
        --     Disabled:                    shape superres videostab world
        --     Disabled by dependency:      -
        --     Unavailable:                 cudaarithm cudabgsegm cudacodec cudafeatures2d cudafilters cudaimgproc cudalegacy cudaobjdetect cudaoptflow cudastereo cudawarping cudev java js python3 viz
        --     Applications:                tests perf_tests apps
        --     Documentation:               NO
        --     Non-free algorithms:         NO
        --   GUI:
        --     GTK+:                        YES (ver 2.24.30)
        --       GThread :                  YES (ver 2.48.2)
        --       GtkGlExt:                  NO
        --     VTK support:                 NO
        --   Media I/O:
        --     ZLib:                        /usr/lib/aarch64-linux-gnu/libz.so (ver 1.2.8)
        --     JPEG:                        /usr/lib/aarch64-linux-gnu/libjpeg.so (ver 80)
        --     WEBP:                        build (ver encoder: 0x020e)
        --     PNG:                         /usr/lib/aarch64-linux-gnu/libpng.so (ver 1.2.54)
        --     TIFF:                        /usr/lib/aarch64-linux-gnu/libtiff.so (ver 42 / 4.0.6)
        --     JPEG 2000:                   build (ver 1.900.1)
        --     OpenEXR:                     build (ver 1.7.1)
        --     HDR:                         YES
        --     SUNRASTER:                   YES
        --     PXM:                         YES
        --   Video I/O:
        --     DC1394:                      YES (ver 2.2.4)
        --     FFMPEG:                      YES
        --       avcodec:                   YES (ver 56.60.100)
        --       avformat:                  YES (ver 56.40.101)
        --       avutil:                    YES (ver 54.31.100)
        --       swscale:                   YES (ver 3.1.101)
        --       avresample:                NO
        --     GStreamer:                   NO
        --     libv4l/libv4l2:              NO
        --     v4l/v4l2:                    linux/videodev2.h
        --   Parallel framework:            OpenMP
        --   Trace:                         YES (built-in)
        --   Other third-party libraries:
        --     Lapack:                      NO
        --     Eigen:                       NO
        --     Custom HAL:                  YES (carotene (ver 0.0.1))
        --     Protobuf:                    build (3.5.1)
        --   OpenCL:                        YES (no extra features)
        --     Include path:                /home/root/opencv-opencl/opencv-3.4.6/3rdparty/include/opencl/1.2
        --     Link libraries:              Dynamic load
        --   Python 2:
        --     Interpreter:                 /usr/bin/python2.7 (ver 2.7.12)
        --     Libraries:                   /usr/lib/aarch64-linux-gnu/libpython2.7.so (ver 2.7.12)
        --     numpy:                       /usr/lib/python2.7/dist-packages/numpy/core/include (ver 1.11.0)
        --     install path:                lib/python2.7/dist-packages/cv2/python-2.7
        --   Python (for build):            /usr/bin/python2.7
        --   Java:
        --     ant:                         NO
        --     JNI:                         NO
        --     Java wrappers:               NO
        --     Java tests:                  NO
        --   Install to:                    /usr
        -- Configuring incomplete, errors occurred!
        See also "/home/root/opencv-opencl/opencv-3.4.6/build/CMakeFiles/CMakeOutput.log".
        See also "/home/root/opencv-opencl/opencv-3.4.6/build/CMakeFiles/CMakeError.log".
        The command '/bin/sh -c cmake -DCMAKE_BUILD_TYPE=Release           -DCMAKE_INSTALL_PREFIX=/usr           -DWITH_OPENMP=ON           -DWITH_OPENCL=ON           -DHAVE_OPENCL=1           -DOPENCV_EXTRA_MODULES_PATH=/home/opencv-opencl/opencv_contrib-$opencv_version/modules           -DBUILD_opencv_aruco=ON           -DBUILD_opencv_bgsegm=OFF           -DBUILD_opencv_bioinspired=OFF           -DBUILD_opencv_ccalib=OFF           -DBUILD_opencv_cnn_3dobj=OFF           -DBUILD_opencv_cudaarithm=OFF           -DBUILD_opencv_cudabgsegm=OFF           -DBUILD_opencv_cudacodec=OFF           -DBUILD_opencv_cudafeatures2d=OFF           -DBUILD_opencv_cudafilters=OFF           -DBUILD_opencv_cudaimgproc=OFF           -DBUILD_opencv_cudalegacy=OFF           -DBUILD_opencv_cudaobjdetect=OFF           -DBUILD_opencv_cudaoptflow=OFF           -DBUILD_opencv_cudastereo=OFF           -DBUILD_opencv_cudawarping=OFF           -DBUILD_opencv_cudev=OFF           -DBUILD_opencv_cvv=OFF           -DBUILD_opencv_datasets=OFF           -DBUILD_opencv_dnn_objdetect=ON           -DBUILD_opencv_dnns_easily_fooled=OFF           -DBUILD_opencv_dnn_superres=OFF           -DBUILD_opencv_dpm=OFF           -DBUILD_opencv_face=OFF           -DBUILD_opencv_freetype=OFF           -DBUILD_opencv_fuzzy=OFF           -DBUILD_opencv_hdf=OFF           -DBUILD_opencv_hfs=OFF           -DBUILD_opencv_img_hash=OFF           -DBUILD_opencv_line_descriptor=OFF           -DBUILD_opencv_matlab=OFF           -DBUILD_opencv_optflow=OFF           -DBUILD_opencv_ovis=OFF           -DBUILD_opencv_phase_unwrapping=OFF           -DBUILD_opencv_plot=OFF           -DBUILD_opencv_quality=OFF           -DBUILD_opencv_reg=OFF           -DBUILD_opencv_rgbd=OFF           -DBUILD_opencv_saliency=OFF           -DBUILD_opencv_sfm=OFF           -DBUILD_opencv_shape=OFF           -DBUILD_opencv_stereo=OFF           -DBUILD_opencv_structured_light=OFF           -DBUILD_opencv_superres=OFF           -DBUILD_opencv_surface_matching=OFF           -DBUILD_opencv_text=OFF           -DBUILD_opencv_tracking=OFF           -DBUILD_opencv_videostab=OFF           -DBUILD_opencv_viz=OFF           -DBUILD_opencv_xfeatures2d=OFF           -DBUILD_opencv_ximgproc=OFF           -DBUILD_opencv_xobjdetect=OFF           -DBUILD_opencv_xphoto=OFF           -DCMAKE_CXX_FLAGS="${CMAKE_CXX_FLAGS} -std=c++11 -march=armv8-a+simd" ..' returned a non-zero code: 1
        Dockerfile.xenial-base
        FROM aarch64/ubuntu:xenial
        RUN apt-get update
        RUN apt-get -y upgrade
        RUN sh -c 'echo "deb http://packages.ros.org/ros/ubuntu xenial main" > /etc/apt/sources.list.d/ros-latest.list'
        RUN apt-key adv --keyserver 'hkp://keyserver.ubuntu.com:80' --recv-key C1CF6E31E6BADE8868B172B4F42ED6FBAB17C654
        RUN apt-get update && apt-get install -y python-rosdep \
          python-pip \
          python-rosinstall-generator \
          python-wstool \
          python-rosinstall \
          python-pandas \
          python-numpy \
          python-dev \
          python-defusedxml \
          build-essential \
          libboost-all-dev \
          libconsole-bridge-dev \
          libtinyxml-dev \
          sbcl-source \
          sbcl-doc \
          vim \
          sudo \
          nano \
          strace \
          libglib2.0-0 \
          libgtk2.0-dev \
          pkg-config \
          libavcodec-dev \
          libavformat-dev \
          libswscale-dev \
          libtbb2 \
          libtbb-dev \
          libjpeg-dev \
          libpng-dev \
          libtiff-dev \
          libdc1394-22-dev \
          wget \
          unzip \
          cmake \
          git
        RUN mkdir -p /home/root/opencv-opencl
        WORKDIR /home/root/opencv-opencl
        COPY modalai-opencl-dev_1.0-1.deb .
        RUN dpkg -i modalai-opencl-dev_1.0-1.deb
        CMD /bin/bash
        Dockerfile.opencv
        FROM roskinetic-xenial:base
        ARG opencv_version=4.2.0
        RUN wget https://github.com/opencv/opencv/archive/$opencv_version.zip
        RUN unzip $opencv_version.zip
        RUN rm $opencv_version.zip
        RUN wget https://github.com/opencv/opencv_contrib/archive/$opencv_version.zip
        WORKDIR opencv-$opencv_version/build
        RUN cmake -DCMAKE_BUILD_TYPE=Release \
                  -DCMAKE_INSTALL_PREFIX=/usr \
                  -DWITH_OPENMP=ON \
                  -DWITH_OPENCL=ON \
                  -DHAVE_OPENCL=1 \
                  -DOPENCV_EXTRA_MODULES_PATH=/home/opencv-opencl/opencv_contrib-$opencv_version/modules \
                  -DBUILD_opencv_aruco=ON \
                  -DBUILD_opencv_bgsegm=OFF \a
                  -DBUILD_opencv_bioinspired=OFF \
                  -DBUILD_opencv_ccalib=OFF \
                  -DBUILD_opencv_cnn_3dobj=OFF \
                  -DBUILD_opencv_cudaarithm=OFF \
                  -DBUILD_opencv_cudabgsegm=OFF \
                  -DBUILD_opencv_cudacodec=OFF \
                  -DBUILD_opencv_cudafeatures2d=OFF \
                  -DBUILD_opencv_cudafilters=OFF \
                  -DBUILD_opencv_cudaimgproc=OFF \
                  -DBUILD_opencv_cudalegacy=OFF \
                  -DBUILD_opencv_cudaobjdetect=OFF \
                  -DBUILD_opencv_cudaoptflow=OFF \
                  -DBUILD_opencv_cudastereo=OFF \
                  -DBUILD_opencv_cudawarping=OFF \
                  -DBUILD_opencv_cudev=OFF \
                  -DBUILD_opencv_cvv=OFF \
                  -DBUILD_opencv_datasets=OFF \
                  -DBUILD_opencv_dnn_objdetect=ON \
                  -DBUILD_opencv_dnns_easily_fooled=OFF \
                  -DBUILD_opencv_dnn_superres=OFF \
                  -DBUILD_opencv_dpm=OFF \
                  -DBUILD_opencv_face=OFF \
                  -DBUILD_opencv_freetype=OFF \
                  -DBUILD_opencv_fuzzy=OFF \
                  -DBUILD_opencv_hdf=OFF \
                  -DBUILD_opencv_hfs=OFF \
                  -DBUILD_opencv_img_hash=OFF \
                  -DBUILD_opencv_line_descriptor=OFF \
                  -DBUILD_opencv_matlab=OFF \
                  -DBUILD_opencv_optflow=OFF \
                  -DBUILD_opencv_ovis=OFF \
                  -DBUILD_opencv_phase_unwrapping=OFF \
                  -DBUILD_opencv_plot=OFF \
                  -DBUILD_opencv_quality=OFF \
                  -DBUILD_opencv_reg=OFF \
                  -DBUILD_opencv_rgbd=OFF \
                  -DBUILD_opencv_saliency=OFF \
                  -DBUILD_opencv_sfm=OFF \
                  -DBUILD_opencv_shape=OFF \
                  -DBUILD_opencv_stereo=OFF \
                  -DBUILD_opencv_structured_light=OFF \
                  -DBUILD_opencv_superres=OFF \
                  -DBUILD_opencv_surface_matching=OFF \
                  -DBUILD_opencv_text=OFF \
                  -DBUILD_opencv_tracking=OFF \
                  -DBUILD_opencv_videostab=OFF \
                  -DBUILD_opencv_viz=OFF \
                  -DBUILD_opencv_xfeatures2d=OFF \
                  -DBUILD_opencv_ximgproc=OFF \
                  -DBUILD_opencv_xobjdetect=OFF \
                  -DBUILD_opencv_xphoto=OFF \
        RUN make -j4
        RUN make install
        CMD ["/bin/bash"]
        ? 1 Reply Last reply
        • ? A Former User
          Hi @modaltb ,
          --   Platform:
          --     CMake:                       3.5.1
          --   CPU/HW features:
          --       required:                  NEON
          --       disabled:                  VFPV3
          --   C/C++:
          --     C++11:                       YES
          --     ccache:                      NO
          --   OpenCV modules:
          --   GUI:
          --       GtkGlExt:                  NO
          --     VTK support:                 NO
          --   Media I/O:
          --     HDR:                         YES
          --     SUNRASTER:                   YES
          --     PXM:                         YES
          --   Video I/O:
          --     FFMPEG:                      YES
          --       avresample:                NO
          --     GStreamer:                   NO
          --     Lapack:                      NO
          --     Eigen:                       NO
          --   Python 2:
          --   Java:
          --     ant:                         NO
          --     JNI:                         NO
          --     Java tests:                  NO
          --   Install to:                    /usr
          RUN apt-get update
            python-pip \
            python-wstool \
            python-rosinstall \
            python-pandas \
            python-numpy \
            python-dev \
            python-defusedxml \
            build-essential \
            libboost-all-dev \
            libtinyxml-dev \
            sbcl-source \
            sbcl-doc \
            vim \
            sudo \
            nano \
            strace \
            libglib2.0-0 \
            libgtk2.0-dev \
            pkg-config \
            libavcodec-dev \
            libavformat-dev \
            libswscale-dev \
            libtbb2 \
            libtbb-dev \
            libjpeg-dev \
            libpng-dev \
            libtiff-dev \
            libdc1394-22-dev \
            wget \
            unzip \
            cmake \
            git
          CMD /bin/bash
          Dockerfile.opencv
                    -DWITH_OPENMP=ON \
                    -DWITH_OPENCL=ON \
                    -DHAVE_OPENCL=1 \
          RUN make -j4
          RUN make install
          CMD ["/bin/bash"]
          I overcame that problem by adjusting the WORKDIR and PATH. Moreover adding sudo apt-update.
          However, I always come back to the same problem no matter what i do.
          I decided to build in my host computer and load in target to head off "No Space Problem" in the target but the problem also occurred in the host as well. I cannot proceed any how.
          Any suggestions from your side?
          /home/opencv-opencl/opencv-3.4.6/build/modules/calib3d/test_precomp.hpp:20:1: fatal error: can't write PCH file: No space left on device
           } // namespace
          compilation terminated.
          In file included from /home/opencv-opencl/opencv-3.4.6/build/modules/features2d/perf_precomp.hpp:5:0:
          /home/opencv-opencl/opencv-3.4.6/modules/features2d/include/opencv2/features2d.hpp:1426:1: fatal error: can't write PCH file: No space left on device
           } /* namespace cv */
          make: *** [all] Error 2
          The command '/bin/sh -c make -j4' returned a non-zero code: 2
          REPOSITORY                   TAG       IMAGE ID       CREATED             SIZE
          <none>                       <none>    f1a9b038119e   18 minutes ago      1.81GB
          roskinetic-xenial            v1.0      e76c6e4f806e   About an hour ago   1.98GB
          roskinetic-xenial            minimal   fcdda3d30808   3 hours ago         1.56GB
          roskinetic-xenial            base      d22679ae8e50   3 hours ago         1.37GB
          multiarch/qemu-user-static   latest    a217e72a8293   3 months ago        280MB
          hello-world                  latest    a29f45ccde2a   15 months ago       9.14kB
          aarch64/ubuntu               xenial    a7d1ddc47ced   3 years ago         110MB
          Could you @sarahl solve your issue?
          • modaltbM Offline
            modaltbM Offline
            modaltb
            Hi @Voxlady ,
            I'm scratching my head on this one, I don't have anything helpful yet but will keep an eye out!
            • modaltbM modaltb
              @sarahl ,
              Hope this helps!
              S Offline
              S Offline
              sarahl
              @modaltb thanks so much! I was actually wondering if I needed something like buildx for the multi-arch building, but I couldn't get it to work with the Ubuntu version of docker. But this seemed to fix my previous issue, so I'll see how this goes. Just trying the first command for now without the COPY line.
              @Voxlady I'll let you know if this fixes my issue. Haven't gotten to the OpenCV portion yet. I don't know what your disk storage constraints are on the raspberry pi, but I'm running on an amd64 Ubuntu 18.04 machine which hopefully will not run into storage issues. I noticed on the Voxl that what was taking up a lot of space was the docker overlays. I wonder if condensing all the dockerfiles into a single one would help (if you don't need all the intermediate images)?
              • ? Offline
                Hi @modaltb and @sarahl ,
                Thank you for your messages. It took me some trial-and-error time but I finally solved the problem by reducing the number of Docker Files as well as images. Now, everything seems working again.
                BR,
                Ayberk
                • modaltbM Offline
                  modaltbM Offline
                  modaltb
                  Thanks for the update. We really appreciate the feedback and community response!
                  S 2 Replies Last reply
                  • modaltbM modaltb
                    S Offline
                    S Offline
                    sarahl
                    @modaltb okay it finally built, but when I tried to load it onto the Voxl, it ran out of space. So now I'm trying to build a new version with fewer intermediate images and with opencl removed. Are there any other ways to make more space for docker?
                    @Voxlady were you able to load your roskinetic+opencv image to the Voxl? Did you use 4.2.0 or 3.4.6 or another opencv version?
                    • ? Offline
                      #20
                      @sarahl,
                      Yes, I was able to load the image and even download additional packages in the container.
                      1. I merged two base files from Opencv/cl and kinetic. Moreover, I put everything that's in Dockerfile.opencv into Dockerfile.xenial-packages. So, in the end I didn't have any extra Opencv-cl file. I also disabled Opencl.
                      2. Most importantly, after I built roskinetic-xenial:v1.0, I deleted other two images base and minimal. I think that's okay to delete since no error or failure has occurred so far.
                      3. Last, I used some best practices suggested by Docker. Especially, for Dockerfile.xenial-base. See sorting multi-line arguments .
                      4. I think 3.4.6 version doesn't have a corresponding release in GitHub. So, ARG opencv_version=4.2.0 in Dockerfile.opencv assigns automatically. Therefore, I went with 4.2.0.
                      Hopefully it helps.
                      All the best
                      • modaltbM modaltb
                        S Offline
                        S Offline
                        sarahl
                        @modaltb So I finally got the docker loaded, and also built cv_bridge and the camera ros driver. However, it doesn't seem to be reading in the camera (a FLIR). When I'm outside the docker, plugging in the device adds /dev/ttyACM0 and /dev/video2, the latter of which is used by the ros node. Is there something I need to do when running the docker to have access to the usb devices?
                        • modaltbM Offline
                          modaltbM Offline
                          modaltb
                          @sarahl , here's an example of how we map and HDMI adapter into docker, not exactly the same but shows the usage:
                          https://docs.modalai.com/hdmi-input-accessory-manual/#start-the-ffmpeg-docker
                          • modaltbM modaltb
                            S Offline
                            S Offline
                            sarahl
                            @modaltb thanks, I actually tried something similar by mapping /dev to /dev, and also passing it in with the --device parameter, but I'll try this out! is there a reason it's mapped as /dev to /opt in here? Should the /dev directory not be used in the docker contained? I did notice when I plugged and unplugged the device and ran ls /dev, that the device list did not update.
                            • modaltbM modaltb
                              S Offline
                              S Offline
                              sarahl
                              @modaltb actually I think it's working now, and I somehow didn't actually have to map the /dev port. Turns out I just had a typo in my launch file. 🤦 Thanks again for all the help!
                              • S Offline
                                S Offline
                                sarahl
                                @modaltb I wanted to send an update, I was able to build and run an Ubuntu 18.04 + ROS Melodic docker + OpenCV 4.2.0 (because some of my nodes weren't working on the ROS Kinetic docker), but did require using multi-line arguments as @Voxlady suggested to reduce the size enough to fit. It seems like the size constraints are somewhere around 2.7 GB virtual docker size, and stem from too many docker overlays. Is there anyway around that in case there is a need for larger docker images?
                                • modaltbM Offline
                                  modaltbM Offline
                                  modaltb
                                  Hi @sarahl , unfortunately I don't have a quick answer for this 😿
                                  • Eric KatzfeyE Offline
                                    @sarahl You could try using an SD card to build. This would give you a lot more space. You would have to change the Docker start service to tell it to use the SD card instead of /data for the build.
                                    ryan_meagherR 1 Reply Last reply
                                      ryan_meagherR Offline
                                      ryan_meagher
                                      wrote on last edited by ryan_meagher
                                      #28
                                      @Eric-Katzfey Thanks for the suggestion.
                                      For anyone else interested in doing this, these are the steps I took to accomplish this.
                                      • In order to change where the root of the docker runtime points to in the docker service go to
                                        /etc/systemd/system/docker-start.service and change the following line so that it uses the sd card(ext4 format) in the voxl ExecStart=/usr/bin/docker daemon -g /mnt/sdcard
                                      • restart the service for the changes to take effect: systemctl restart docker-start.service
                                      • Delete the directories that docker uses in the data partition:cd /data; rm -rf containers linkgraph.db overlay tmp volumes graph network repositories-overlay trust
                                      • [NOTE] The previous commands will delete any images that were previously available.
                                      • You can now run voxl-configure-docker-support.sh and a hello world image will be created
                                        and the directories that were deleted from the /data partition will be in the /mnt/sdcard
                                        directory.
                                      • You can verify that you have freed up the /data partition via df -h
                                        Thank you for following up! Added to the docs here: https://docs.modalai.com/docker-on-voxl/
                                        ryan_meagherR 2 Replies Last reply
                                          ryan_meagher
                                          @Chad-Sweet cool, happy to contribute!
