  2. VOXL Compute & Autopilot
  3. VOXL 2
  4. No option for dual TOF sensor on voxl2
9 Posts 4 Posters 1.6k Views 1 Watching
  • Tamas Pal 0T Offline
    Tamas Pal 0
    I am trying to run dual TOF with tracking and hires cam on voxl2. I am currently using voxl-camera-server version -1.3.7-202301202318. There is no option for that -
    0  None
    1  Tracking + Stereo(OV7251)
    2  Tracking Only
    3  Hires + Stereo(OV7251) + Tracking
    4  Hires + Tracking
    5  TOF + Tracking
    6  Hires + TOF + Tracking
    7  TOF + Stereo(OV7251) + Tracking
    8  Hires Only
    9  TOF Only
    10 Stereo(OV7251) only
    11 Tracking + Hires + Dual Stereo(OV7251) Pairs
    12 Stereo(OV9782) only
    13 Hires + Stereo(OV7251)
    14 Stereo(OV9782) + TOF + Tracking
    How to get dual TOF running with hires and tracking cam? Please help
    • modaltbM Offline
      modaltbM Offline
      modaltb
      wrote on last edited by A Former User
      Hi @Tamas-Pal-0 ,
      I think we have a util that can be used as a work around....
      Are all 4 image sensors showing up when you run voxl-camera-server -l ?
      If so, then use those IDs and try running this helper which can get the config file setup:
      camera-server-config-helper vio0:ov7251:0 fpv:imx214:1 tof_front:pmd-tof:2 tof_rear:pmd-tof:3
      Note, the last values there are the IDs from your setup and might be different.
      Let me know if this works, I only have a single ToF with me to test so I'm not positive!
      Tamas Pal 0T 2 Replies Last reply
      • modaltbM modaltb
        Hi @Tamas-Pal-0 ,
        Tamas Pal 0
        @modaltb It's working !!! Thanks.
        By the way when will we get the update for voxl-camera-server for this ?
        • modaltbM modaltb
          Hi @Tamas-Pal-0 ,
          Tamas Pal 0
          @modaltb I am able to get the sensor data, but unable to use it in qgc side. What should be topic name for TOF sesnsors to get front and rear object distance data on qgc side like front and rear stereo pairs?
          • modaltbM Offline
            modaltbM Offline
            modaltb
            Hi @Tamas-Pal-0 ,
            I'm not totally sure, we normally use voxl-portal for this like here.
            • M Offline
              M Offline
              msberk
              wrote on last edited by msberk
              Hey there - I am facing a similar issue where I would like to use 3 or 4 ToF sensors to provide nearly complete vision around the drone. Is there a limit to only having 2 ToF sensors at the same time? When I try to run 3 ToFs then I get preview errors upon start of voxl-camera-server and it crashes. On 1.4.1-M0054-14.1a-perf
              I am trying to use the cameras in this ordering:
              HW0: ToF
              HW1: ToF
              HW2: Tracking
              HW3: HiRes
              HW4: ToF
              But when I do that I get an error on either the ToF or the Tracking (depending on the order I arrange them in voxl-camera-server.conf about not being able to find the correct preview upon starting the camera server. See configuration below:
                      "version":      0.1,
                      "cameras":      [{
                                      "name": "tof_backright",
                                      "enabled":      true,
                                      "frame_rate":   5,
                                      "type": "pmd-tof",
                                      "camera_id":    0
                                      "name": "tof_backleft",
                                      "enabled":      true,
                                      "frame_rate":   5,
                                      "type": "pmd-tof",
                                      "camera_id":    1
                                      "name": "tracking",
                                      "enabled":      true,
                                      "frame_rate":   30,
                                      "type": "ov7251",
                                      "camera_id":    2,
                                      "ae_desired_msv":       60,
                                      "ae_filter_alpha":      0.600000023841858,
                                      "ae_ignore_fraction":   0.20000000298023224,
                                      "ae_slope":     0.05000000074505806,
                                      "ae_exposure_period":   1,
                                      "ae_gain_period":       1
                                      "name": "hires",
                                      "enabled":      true,
                                      "frame_rate":   30,
                                      "type": "imx214",
                                      "camera_id":    3,
                                      "preview_width":        640,
                                      "preview_height":       480,
                                      "snapshot_width":       3840,
                                      "snapshot_height":      2160
                                      "name": "tof_front",
                                      "enabled":      true,
                                      "frame_rate":   5,
                                      "type": "pmd-tof",
                                      "camera_id":    4
              • modaltbM Offline
                modaltbM Offline
                modaltb
                At this point only two have been proven to work at a single time, see tested configurations here, https://docs.modalai.com/voxl2-camera-configs/#available-configurations
                We do want to have more than 2 going but there's some effort involved and I don't have a timeline at this point, but it's something we do want to do.
                • A Offline
                  afdrus
                  Is it possible to use 2 tofs + stereo + tracking + hires?
                  • A Offline
                    afdrus
                    Because on my voxl2 it seems that neither this configuration nor the 2TOF2 configuration is possible...
