    No option for dual TOF sensor on voxl2
    1221
    • Tamas Pal 0T
      Tamas Pal 0
      I am trying to run dual TOF with tracking and hires cam on voxl2. I am currently using voxl-camera-server version -1.3.7-202301202318. There is no option for that -
      0  None
      1  Tracking + Stereo(OV7251)
      2  Tracking Only
      3  Hires + Stereo(OV7251) + Tracking
      4  Hires + Tracking
      5  TOF + Tracking
      6  Hires + TOF + Tracking
      7  TOF + Stereo(OV7251) + Tracking
      8  Hires Only
      9  TOF Only
      10 Stereo(OV7251) only
      11 Tracking + Hires + Dual Stereo(OV7251) Pairs
      12 Stereo(OV9782) only
      13 Hires + Stereo(OV7251)
      14 Stereo(OV9782) + TOF + Tracking
      How to get dual TOF running with hires and tracking cam? Please help
      • modaltbM
        modaltb ModalAI Team
        Hi @Tamas-Pal-0 ,
        I think we have a util that can be used as a work around....
        Are all 4 image sensors showing up when you run voxl-camera-server -l ?
        If so, then use those IDs and try running this helper which can get the config file setup:
        camera-server-config-helper vio0:ov7251:0 fpv:imx214:1 tof_front:pmd-tof:2 tof_rear:pmd-tof:3
        Note, the last values there are the IDs from your setup and might be different.
        Let me know if this works, I only have a single ToF with me to test so I'm not positive!
        Tamas Pal 0T 2 Replies Last reply Reply Quote 0
        • Tamas Pal 0T
          Tamas Pal 0 @modaltb
          @modaltb It's working !!! Thanks.
          By the way when will we get the update for voxl-camera-server for this ?
          • Tamas Pal 0T
            @modaltb I am able to get the sensor data, but unable to use it in qgc side. What should be topic name for TOF sesnsors to get front and rear object distance data on qgc side like front and rear stereo pairs?
            • modaltbM
              Hi @Tamas-Pal-0 ,
              I'm not totally sure, we normally use voxl-portal for this like here.
              • M
                msberk
                Hey there - I am facing a similar issue where I would like to use 3 or 4 ToF sensors to provide nearly complete vision around the drone. Is there a limit to only having 2 ToF sensors at the same time? When I try to run 3 ToFs then I get preview errors upon start of voxl-camera-server and it crashes. On 1.4.1-M0054-14.1a-perf
                I am trying to use the cameras in this ordering:
                HW0: ToF
                HW1: ToF
                HW2: Tracking
                HW3: HiRes
                HW4: ToF
                But when I do that I get an error on either the ToF or the Tracking (depending on the order I arrange them in voxl-camera-server.conf about not being able to find the correct preview upon starting the camera server. See configuration below:
                        "version":      0.1,
                        "cameras":      [{
                                        "name": "tof_backright",
                                        "enabled":      true,
                                        "frame_rate":   5,
                                        "type": "pmd-tof",
                                        "camera_id":    0
                                        "name": "tof_backleft",
                                        "enabled":      true,
                                        "frame_rate":   5,
                                        "type": "pmd-tof",
                                        "camera_id":    1
                                        "name": "tracking",
                                        "enabled":      true,
                                        "frame_rate":   30,
                                        "type": "ov7251",
                                        "camera_id":    2,
                                        "ae_desired_msv":       60,
                                        "ae_filter_alpha":      0.600000023841858,
                                        "ae_ignore_fraction":   0.20000000298023224,
                                        "ae_slope":     0.05000000074505806,
                                        "ae_exposure_period":   1,
                                        "ae_gain_period":       1
                                        "name": "hires",
                                        "enabled":      true,
                                        "frame_rate":   30,
                                        "type": "imx214",
                                        "camera_id":    3,
                                        "preview_width":        640,
                                        "preview_height":       480,
                                        "snapshot_width":       3840,
                                        "snapshot_height":      2160
                                        "name": "tof_front",
                                        "enabled":      true,
                                        "frame_rate":   5,
                                        "type": "pmd-tof",
                                        "camera_id":    4
                • modaltbM
                  At this point only two have been proven to work at a single time, see tested configurations here, https://docs.modalai.com/voxl2-camera-configs/#available-configurations
                  We do want to have more than 2 going but there's some effort involved and I don't have a timeline at this point, but it's something we do want to do.
                  • A
                    afdrus
                    Is it possible to use 2 tofs + stereo + tracking + hires?
                    • A
                      afdrus
                      Because on my voxl2 it seems that neither this configuration nor the 2TOF2 configuration is possible...
