  3. VOXL PWM AUX servo operate
7 Posts 3 Posters 1.3k Views 2 Watching
  • bensusanaB Offline
    bensusanaB Offline
    bensusana
    Re: VOXL PWM AUX output not working
    Hi guys
    im recently going through the same problem as mention above.
    just to be clear , i know that channel 5-6 (in pwm breakout board) are use used for gimbal , i want to know how can i use one of them to operate simple servo .
    i tried exactly the same as @Cole-Mathieu tried in his post with no successes.
      I don't think we have used a Flight Core PWM to control a servo at ModalAI
      Have you reviewed the PX4 docs? The Flight Core is a pretty standard PX4 flight controller, like a pixhawk
      https://docs.px4.io/main/en/peripherals/pwm_escs_and_servo.html#pwm-servos-and-escs-motor-controllers
      • wilkinsafW Offline
        wilkinsafW Offline
        wilkinsaf
        I know that it works as we have gotten them to work with fixed wing servos.
        However, this was not an RC passthrough but something the flight controller was in control of.
        What is your PWM_AUX_MIN1 and PWM_AUX_MAX1 set to? Does the PWM min and max match the actually min and max of the servo on your gimbal?
          wilkinsafW Offline
          wilkinsaf
          Putting together some outline into our setup to post on here
            wilkinsafW Offline
            wilkinsaf
            @bensusana
            https://www.youtube.com/watch?v=fxfyrUW3EyA
            I should have said "Aux 1 mapped to channel 5 FOR QUAD COPTER LAYOUT" instead of "for VOXL Flight"
            but other than that let me know if you have any questions
            bensusanaB 1 Reply Last reply
            • wilkinsafW wilkinsaf
              @bensusana
              bensusanaB Offline
              bensusanaB Offline
              bensusana
              @wilkinsaf first of all huge thanks for the effort of making this video 🙂 ,
              bottom line it worked !
              only after i reset to default all the parameters like you showed in the video , now we have to figure what was wrong in our parameters that prevent this from working ( we tried the same thing with no success ! ).
              now for next step we trying controls this servo through mavlink command without RC involved .
              again thank you , much appreciate.
              wilkinsafW 1 Reply Last reply
              • bensusanaB bensusana
                wilkinsafW Offline
                wilkinsafW Offline
                wilkinsaf
                @bensusana absolutely. Feel free to email me if you need a bit more dedicated support andrew.wilkins@ascendengineer.com.
                We have a bit of experience with ModalAIs products
