  3. Getting voxl-streamer running
18 Posts 6 Posters 3.7k Views 3 Watching
  • Lynn KoudsiL Offline
    Lynn Koudsi
    wrote on last edited by Lynn Koudsi
    Hi @RichieRich @MattO ,
    I've followed this thread cause I got the same issue when attempting to run voxl-streamer, but I'm now getting a different error after a clean installation of the image 3.1.1 without installing the voxl suite:
    This is all I have installed:
    Thank you in advance!
    • Eric KatzfeyE Offline
      Our dev repo is very active and occasionally we end up with some dependency mismatches in it. I fixed the problem with voxl-streamer. Can you please start with a fresh install of the system image and follow the instructions in this thread to try again? It should all be working now. Thanks!
      Lynn KoudsiL 1 Reply Last reply
        Lynn Koudsi
        @Eric-Katzfey Hi Eric,
        Thanks for the reply!
        I actually found the issue. the camera server was broadcasting under /run/mpa/hires_preview when vox-streamer was looking for run/mpa/hires/preview so I just changed that value in the script and it works 🙂
        Eric KatzfeyE Dean FortierD 2 Replies Last reply
        • Lynn KoudsiL Lynn Koudsi
          @Lynn-Koudsi Great! Yep, that was the issue 🙂
            Dean FortierD Offline
            Dean Fortier
            Hi @Lynn-Koudsi and @Eric-Katzfey,
            I am having the same issue as you Lynn where I am getting the error:
            yocto:/# voxl-streamer
            Using configuration file /etc/modalai/voxl-streamer.conf
            closing FDs for client channel 0
            ERROR: Couldn't open MPA pipe /run/mpa/hires/preview/
            Where is the script where you changed /run/mpa/hires_preview?
            Dean
              @Dean-Fortier It is in the voxl-streamer configuration file. /etc/modalai/voxl-streamer.conf.
              Dean FortierD 1 Reply Last reply
              • Dean FortierD Dean Fortier
                Dean
                @Dean-Fortier BTW, The latest software installer is now available at https://developer.modalai.com/asset. With the new release you won't need to modify the configuration file manually. (beta) VOXL Platform Release 3.2.0-0.3.4-b https://developer.modalai.com/asset/download/69
                  Dean Fortier
                  Hi @Eric-Katzfey,
                  Thanks for the tip, I installed the 3.2.0-0.3.4-b release and still have the same issue. Also I am not sure what to modify in the voxl-streamer.conf file. I modified line 6 from:
                  "mpa-camera": "hires_preview" },
                  to:
                  "mpa-camera": "hires/preview" },
                  but I think I am missing something as I am getting the same error message.
                  Dean
                    Hi @Eric-Katzfey,
                    to:
                    Dean
                    #16
                    @Dean-Fortier The issue with the path was that, originally, it was specified as "hires/preview". This is where voxl-camera-server created the pipe and where voxl-streamer looked for it. In a newer version of voxl-camera-server, the name changed to "hires_preview". Until voxl-streamer was updated, you had to manually go into the configuration file and change it yourself. Now voxl-streamer has been updated and the manual change is no longer necessary. That is what is in 3.2.0-0.3.4-b. You can take a look at the directories yourself to see what voxl-camera-server is doing. After a power cycle and before you start voxl-camera-server you should see something like this:
                    yocto:/run/mpa# ls
                    imu0  imu1
                    And then after starting voxl-camera-server you will see the new directories:
                    yocto:/run/mpa# ls
                    hires_preview  imu0  imu1  stereo  tracking
                    If you don't see those directories then the problem is somewhere else.
                    • Dean FortierD Offline
                      Dean Fortier
                      @Eric-Katzfey Thanks for the explanation, I was not starting the voxl-camera-server before.
                      When I started the voxl-camera-server, I had my camera configuration include the tracking camera which stopped the voxl-camera-server from starting correctly.
                      Once I changed my camera configuration with voxl-configure-cameras to "hires only" I was able to start the camera server and then start the voxl-streamer as well.
                        Okay, so don't do the auto download and install of packages after flashing system image 3.1.0. And don't run any of the voxl-configure-* scripts. See if you can just flash system image 3.1.0 without any other packages and then run the steps.
                        G Offline
                        G Offline
                        Gaurav Borade
