    CAN device support
    • Ansel MisfeldtA
      Ansel Misfeldt
      Is VOXL 2 eventually going to support CAN connections in the future (e.g. with a breakout board), or is that simply not a connection type that's going to be supported?
      We use a number of CAN devices with VOXL Flight / Core and it's been holding us back from adopting VOXL 2. Figured it was worth asking!
      • VinnyV
        Vinny ModalAI Team @Ansel Misfeldt
        @Ansel-Misfeldt Hi,
        The approach we will take for CANBUS right now is similar to what we have. That is, to add CANBUS, it requires the use of a FlightCore Flight Controller. So, with Voxl1, you have Voxl-Flight which integrates the FlightCore, or you add on Flight Core independantly.
        For Voxl2, you can still use a FlightCore, but we have some exciting news coming soon for a newer improved FlightCore, we will likely call it FlightCore V2 🙂
        It will retain CANBUS functionality but has a slew of other upgrades and user improvements added in, all in the same form-factor as FCv1.
        Our Docs portal is just about ready for launch and I think we did a better job up-front on this one to help our customers get running quickly.
        Stay tuned, we should be posting it for sale in the up-coming days!!
        • L
          liftedsystems
          Vinny,
          I would also like to move to the Voxl2 platform but need CAN support as most of our sensors are based on that. Any update on FlightCore V2? Thanks!
          • L
            liftedsystems
            Is there an update on availability for the new FlightCore?
            • L
              liftedsystems
              @Chad-Sweet is there an update on the FC V2? At least access to documentation for now if the product is still in the process of being finalized. I need to make my decision soon on Skynode v. Voxl2. Thank you!
              • modaltbM
                modaltb ModalAI Team
                Hi @liftedsystems , info posted here: https://docs.modalai.com/flight-core-v2/
                • VinnyV
                  Vinny ModalAI Team @liftedsystems
                  Hi @liftedsystems
                  I just saw this now.. sorry for our delays on this...
                  We respond better when you start a new thread because we ALL get notified of it internally ... Thread replies are on a "best effort" basis to check so we miss some.... but if you wish to do so, please just tag us using the "@" like you did to get Chad and we will see that at a higher level too, but new threads are always the best!
                  Thanks, and I hope Travis gave you the info you were hoping for!!
                  • B brinkap referenced this topic on
