    ESC calibration guide
    ESCs
    • Tamas Pal 0T
      Tamas Pal 0
      Do I have to keep the propeller attached with motors while calibrating the modalai v2 Rev B esc?
      These are the instruction from modalai team
      ## Calibrate ESC
      - wear safety glasses
        - make sure the propeller is clear of any obstacles and there are no items that can become airborne due to high air flow
      - calibrate the ESC's feed-forward curve
       - ```python voxl-esc-calibrate.py --id 0 --pwm-min 10 —-pwm-max 95```
        - this will step the motor through a range of power from 10% to 95%
      • Chad SweetC
        Chad Sweet ModalAI Team
        yes, you need the propellers installed to calibrate the motor+propeller RPM curve
        • M
          mbahrami
          @Chad-Sweet Is there any alternative method for calibrating the VOXL 4-in-1 ESC v2 that does not require the propellers being installed as opposed to the VOXL ESC Tools ?
          • Chad SweetC
            Without propellers you are not calibrating the ESC
