<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[ESC calibration guide]]></title><description><![CDATA[<p dir="auto">Do I have to keep the propeller attached with motors while calibrating the modalai v2 Rev B esc?<br />
These are the instruction from modalai team</p>
<pre><code>## Calibrate ESC
- wear safety glasses
  - make sure the propeller is clear of any obstacles and there are no items that can become airborne due to high air flow
- calibrate the ESC's feed-forward curve
 - ```python voxl-esc-calibrate.py --id 0 --pwm-min 10 —-pwm-max 95```
  - this will step the motor through a range of power from 10% to 95%
]]></description><link>https://forum.modalai.com/topic/1533/esc-calibration-guide</link><generator>RSS for Node</generator><lastBuildDate>Tue, 12 May 2026 06:09:26 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/1533.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 09 Nov 2022 10:52:48 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to ESC calibration guide on Tue, 15 Nov 2022 17:14:02 GMT]]></title><description><![CDATA[<p dir="auto">Without propellers you are not calibrating the ESC</p>
]]></description><link>https://forum.modalai.com/post/7194</link><guid isPermaLink="true">https://forum.modalai.com/post/7194</guid><dc:creator><![CDATA[Chad Sweet]]></dc:creator><pubDate>Tue, 15 Nov 2022 17:14:02 GMT</pubDate></item><item><title><![CDATA[Reply to ESC calibration guide on Tue, 15 Nov 2022 14:18:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/3">@Chad-Sweet</a> Is there any alternative method for calibrating the VOXL 4-in-1 ESC v2 that does not require the propellers being installed as opposed to the <a href="https://docs.modalai.com/modal-esc-v2-manual/#voxl-esc-tools" rel="nofollow ugc">VOXL ESC Tools</a> ?</p>
]]></description><link>https://forum.modalai.com/post/7192</link><guid isPermaLink="true">https://forum.modalai.com/post/7192</guid><dc:creator><![CDATA[mbahrami]]></dc:creator><pubDate>Tue, 15 Nov 2022 14:18:36 GMT</pubDate></item><item><title><![CDATA[Reply to ESC calibration guide on Wed, 09 Nov 2022 17:35:47 GMT]]></title><description><![CDATA[<p dir="auto">yes, you need the propellers installed to calibrate the motor+propeller RPM curve</p>
]]></description><link>https://forum.modalai.com/post/7126</link><guid isPermaLink="true">https://forum.modalai.com/post/7126</guid><dc:creator><![CDATA[Chad Sweet]]></dc:creator><pubDate>Wed, 09 Nov 2022 17:35:47 GMT</pubDate></item></channel></rss>
