  3. Sony RXO over USB
Sony RXO over USB
microhard
37 Posts 7 Posters 11.8k Views 5 Watching
  • Aaron BottkeA Offline
    Aaron Bottke
    wrote on last edited by Aaron Bottke
    #24
    Unless I am missing something in the command this is the result from running voxl-streamer and voxl-gphoto2.
    Thanks for all the help.
    • Aaron BottkeA Aaron Bottke
      Eric KatzfeyE Online
      @Aaron-Bottke Documentation on voxl-streamer is here: https://docs.modalai.com/voxl-streamer/
      For gphoto2 you will want to look at the gphoto2-mpa configuration in /etc/modalai/voxl-streamer.conf. You can use this configuration record by launching with voxl-streamer -c gphoto2-mpa
        Aaron Bottke
        That got it working!!! I really appreciate the help with this!!!
        My telemetry quit working though so I have to play with that and get that up and running again.
          Aaron Bottke
          #27
          The gphoto-2 seams to be breaking the voxl-vision-px4 system. Any command associated with the voxl-vision-px4 system causes the voxl to kick any adb connection then prevent any from connecting until a power cycle. I can't get both voxl-vision-px4 and gphoto2 installed and running on the same system.
          Any thoughts?
            Any thoughts?
            @Aaron-Bottke I'll take a look
              Any thoughts?
              @Aaron-Bottke I did a fresh install of system image 3.2.0 without installing any additional packages (voxl-suite). After setting up WiFi to connect to the Internet I ran these steps on voxl (over adb):
              • opkg update
              • opkg install voxl-vision-px4
              • voxl-configure-vision-px4 (Specifying no cameras)
              • Verify QGC connection with telemetry
              • opkg install voxl-gphoto2
              • opkg install voxl-streamer
              • voxl-gphoto2
              • voxl-streamer -c gphoto2-mpa
              I then see both telemetry and video in QGC.
              Aaron BottkeA 1 Reply Last reply
                • opkg update
                • voxl-gphoto2
                Aaron Bottke
                #30
                Not installing the voxl-suite at first and using opkg to install gphoto2 and voxl-streamer worked.
                Before I was following the instructions and compiling my own ipk then loading them on using adb. I've got both a video stream and telemetry over the Microhard Modem!
                  Aaron Bottke
                  Will at any point gphoto2's trigger features be ported over to the voxl-gphoto2? I want to be able to trigger a photo/video to be captured and stored on the RX0's SD in-order to achieve max resolution.
                    @Aaron-Bottke Possibly. How did you want to trigger it?
                      Aaron Bottke
                      Ultimately if I can use px4s trigger function to tell gphoto2 to trigger an image that would be idea. I should be able to use mavlink to tell when that command is given and then issue gphoto2 to issue the command. This will allow me to do high quality mapping missions with the system.
                        @Aaron-Bottke Yes, that's seems like it would be a nice addition to voxl-gphoto2. We'll put it on our to-do list.
                        R 1 Reply Last reply
                          R Offline
                          R Offline
                          restore
                          @Eric-Katzfey Was this ever done? I would like to do a similar thing and trigger an attached DSLR cameras using QGroundControl and gphoto2
                          • R restore
                            @restore No, unfortunately it has not.
                              R Offline
                              R Offline
                              restore
                              @Eric-Katzfey okay - too bad. Is it still on the to-do list or no longer in the plans?
