  3. Sony RXO over USB
Sony RXO over USB
microhard
37 Posts 7 Posters 11.6k Views 5 Watching
  • Aaron BottkeA Aaron Bottke
    The gphoto-2 seams to be breaking the voxl-vision-px4 system. Any command associated with the voxl-vision-px4 system causes the voxl to kick any adb connection then prevent any from connecting until a power cycle. I can't get both voxl-vision-px4 and gphoto2 installed and running on the same system.
    Any thoughts?
    @Aaron-Bottke I'll take a look
      Any thoughts?
      @Aaron-Bottke I did a fresh install of system image 3.2.0 without installing any additional packages (voxl-suite). After setting up WiFi to connect to the Internet I ran these steps on voxl (over adb):
      • opkg update
      • opkg install voxl-vision-px4
      • voxl-configure-vision-px4 (Specifying no cameras)
      • Verify QGC connection with telemetry
      • opkg install voxl-gphoto2
      • opkg install voxl-streamer
      • voxl-gphoto2
      • voxl-streamer -c gphoto2-mpa
      I then see both telemetry and video in QGC.
      Aaron BottkeA 1 Reply Last reply
        • opkg update
        • voxl-gphoto2
        Aaron BottkeA Offline
        Aaron Bottke
        wrote on last edited by Aaron Bottke
        #30
        Not installing the voxl-suite at first and using opkg to install gphoto2 and voxl-streamer worked.
        Before I was following the instructions and compiling my own ipk then loading them on using adb. I've got both a video stream and telemetry over the Microhard Modem!
        • Aaron BottkeA Offline
          Aaron Bottke
          Will at any point gphoto2's trigger features be ported over to the voxl-gphoto2? I want to be able to trigger a photo/video to be captured and stored on the RX0's SD in-order to achieve max resolution.
            @Aaron-Bottke Possibly. How did you want to trigger it?
              Aaron Bottke
              Ultimately if I can use px4s trigger function to tell gphoto2 to trigger an image that would be idea. I should be able to use mavlink to tell when that command is given and then issue gphoto2 to issue the command. This will allow me to do high quality mapping missions with the system.
                @Aaron-Bottke Yes, that's seems like it would be a nice addition to voxl-gphoto2. We'll put it on our to-do list.
                R 1 Reply Last reply
                  R Offline
                  R Offline
                  restore
                  @Eric-Katzfey Was this ever done? I would like to do a similar thing and trigger an attached DSLR cameras using QGroundControl and gphoto2
                  • R restore
                    @restore No, unfortunately it has not.
                      R Offline
                      R Offline
                      restore
                      @Eric-Katzfey okay - too bad. Is it still on the to-do list or no longer in the plans?
