  3. Hires (M0026) Issue
Hires (M0026) Issue
19 Posts 5 Posters 3.6k Views 2 Watching
  • G Offline
    G Offline
    gauravshukla914
    wrote on last edited by gauravshukla914
    Hi @Chad-Sweet the connections are correct. When I put the other way round, I can't even log into VOXL through ssh.
    Hi @Vinny No I'm not cascading two cables on to one another. Its just one extension cable. The cable is not folded or anything. I have attached the current connection image.
    I'm using the M0036 cable (14.5 cm one). We also have a offshore team in India who are using the same setup, and its been working for them without any issues since months - So I'm sure length cannot be an issue with HIRES config.
    • G Offline
      G Offline
      gauravshukla914
      These are the logs I get when I run journalctl -u voxl-camera-server
      -- Logs begin at Thu 1970-01-01 00:00:04 UTC, end at Fri 2022-08-26 15:41:19 UTC. --
      Jan 01 00:00:06 apq8096 systemd[1]: Started voxl-camera-server.
      -- Logs begin at Thu 1970-01-01 00:00:04 UTC, end at Fri 2022-08-26 15:43:09 UTC. --
      Jan 01 00:00:08 apq8096 bash[1959]: ERROR: Camera module not opened, attempting again
      Jan 01 00:00:08 apq8096 bash[1959]: ERROR: Camera module not opened, 9 attempts remaining
      Jan 01 00:00:10 apq8096 bash[1959]: ------ voxl-camera-server: Camera server is now running
      Aug 26 15:43:07 apq8096 bash[1959]: voxl-camera-server ERROR: Error sending request 7958, ErrorCode:
      -19
      Aug 26 15:43:07 apq8096 bash[1959]: voxl-camera-server FATAL: Recieved Fatal error from camera: trac
      king
      Aug 26 15:43:07 apq8096 bash[1959]: Camera server will be stopped
      Aug 26 15:43:07 apq8096 bash[1959]: ------ voxl-camera-server WARNING: Thread: tracking result threa
      d recieved ESTOP
      Aug 26 15:43:07 apq8096 bash[1959]: ------ voxl-camera-server WARNING: Thread: hires result thread r
      ecieved ESTOP
      Aug 26 15:43:08 apq8096 bash[1959]: ------ voxl-camera-server INFO: Camera server is now stopping
      Aug 26 15:43:08 apq8096 bash[1959]: There is a chance that it may segfault here, this is a mmqcamera
      bug, ignore it
      Aug 26 15:43:08 apq8096 bash[1959]: ------ voxl-camera-server INFO: Stopping tracking camera
      Aug 26 15:43:09 apq8096 bash[1959]: ------ voxl-camera-server INFO: tracking camera stopped successf
      ully
      Aug 26 15:43:09 apq8096 bash[1959]: ------ voxl-camera-server INFO: Stopping hires camera
      Aug 26 15:43:09 apq8096 bash[1959]: ------ voxl-camera-server INFO: hires camera stopped successfull
      y
      Aug 26 15:43:09 apq8096 bash[1959]: ------ voxl-camera-server INFO: Camera server exited gracefully
      VinnyV 1 Reply Last reply
      • G gauravshukla914
        -19
        king
        d recieved ESTOP
        ecieved ESTOP
        bug, ignore it
        ully
        y
        @gauravshukla914
        Hi Gaurav,
        I've asked our Product Manager to reach out to offer a free replacement M0036 cable.
        Should you continue to have issues after receipt of the replacement cable, we might need to investigate further on the Voxl side.
        Hope this helps!
        • ? Offline
          Hey @gauravshukla914 thank you for your patience, I am a Product Manager at ModalAI. We wanted to let you know that we have sent a replacement cable that should arrive in the next day or two.
          Thank you,
          • G Offline
            G Offline
            gauravshukla914
            Hi @modalab I received one more email with product has been cancelled notice. Is the replacement cancelled?
            • G Offline
              G Offline
              gauravshukla914
              Hi @Vinny @modalab curious to know whats the update on here. Is a cable sent out already?
              • G Offline
                G Offline
                gauravshukla914
                Hi @Vinny , the problem still exists even after trying with a new cable.
                • ? Offline
                  Hey @Gaurav-Shukla we are sending out a replacement cable. Theres was a mixup internally and your order got cancelled. Would you please ship us the cable that is having issues via our RMA process. Your RMA number will be the order number for the invoice you receive. Please let us know when you receive and test the replacement.
                  Thank you,
                  • G Offline
                    G Offline
                    gauravshukla914
                    #13
                    Hi @modalab Thanks for your message. I have received one new cable from my previous communication with ModalAI (Since I had ordered 2 cables at the first place). At this point, I'm kinda convinced its not a cable issue. I have replaced cable thrice now, but it's still the same issue. What's even more weird is that, I have a “VOXL only” board with me that I sometimes use if for debugging purposes, and it's working great with this board. I’m able to get the data and also see image stream on rqt. So, this confirms that the cable is not faulty. I also compared the system images of the Voxl flight deck and just the voxl board and they are the same as well i.e 3.3.0. We also have an offshore team working in India who are using same setup (VOXL flight deck + extension cable + M0026 sensor ).
                    I feel this requires deeper investigation on the voxl side of my board as mentioned by @Vinny . As a matter of fact, even the voxl flight deck that I have is a new one. I'd like to have screen share session and look at this issue together and hopefully we might find a solution there. I already sent an email yesterday regarding the same.
                    • ? Offline
                      Hey @gauravshukla914 will you please send in the VOXL Flight deck via our RMA Process and we will provide a report on our findings.
                      Thank you,
                      • G Offline
                        G Offline
                        gauravshukla914
                        @modalab Okay, but I'm a bit confused here. The Voxl flight deck plus the extension cable plus the hires sensor (M0026) is all new(less than 3 months old). So in the RMA process, do I just need to complete the form and email it and just send the product right? without adding the diagnostic fee in the cart.
                        • G gauravshukla914
                          @gauravshukla914 Hi Gaurav, sorry for your troubles on this.
                          It is entirely possible that even new products get damaged, especially by an ESD event.
                          We'll work with you to investigate and help resolve this.
                          Thanks for working with @modalab to send this back, and I'm sure I'll be one of the ones reviewing the physical hardware so we can report back as soon as we conclude anything.
                          • G Offline
                            G Offline
                            gauravshukla914
                            Thanks @Vinny for your response. But do we have to pay the 100$ amount for diagnostic? Since this is under a 3 month product, I believe I just need to fill up the RMA document and just send the board back, right?
                            • G Offline
                              G Offline
                              gauravshukla914
                              Hi @Vinny @modalab could you confirm this RMA process would be without any cost? Please confirm so that I can begin this immediately.
                              • modaltbM Offline
                                modaltbM Offline
                                modaltb
                                Please see email thread in progress, if possible let's use one channel for communications.
