  3. RB5 Drone not detected by computer
rb5
31 Posts 5 Posters 8.0k Views 2 Watching
    @alfa-budiman We usually ship our drones without WiFi configured in access point mode so unless you've configured it before I wouldn't expect it to be broadcasting a network.
    I will try to think of other steps forward, but I think the best way forward is to get your hands on a machine running Ubuntu 18.04 natively.
    alfa budimanA Offline
    alfa budiman
    Regarding having a computer to run ubuntu 18.04 natively, I'd need to get another computer for that. I'm currently working at a robotics lab at a university and need to contact my IT department to get another computer for the purposes of working with this drone.
    In the interim however, we do have several raspberry pi 4s. Would it be possible to work with the drone by connecting it to a raspberry pi with Ubuntu 18.04?
    Another solution would be starting my laptop off of a boot disk with ubuntu.
    Would either of these solutions be equivalent to running a machine that natively runs Ubuntu 18.04? This is meant as a temporary solution until the IT department gets me another computer.
      @alfa-budiman We haven't tested running Ubuntu 18.04 on an RPi. You could partition your laptop's hard drive and dual boot both Windows and Ubuntu:
      https://itsfoss.com/install-ubuntu-1404-dual-boot-mode-windows-8-81-uefi/
      • alfa budimanA Offline
        alfa budiman
        wrote on last edited by alfa budiman
        #16
        I managed to get another computer and it natively runs ubuntu 18.04.
        The drone is still not detected on this 3rd computer.
        To recap:
        computer 1 = personal computer with windows host and ubuntu 20.04 virtual machine
        computer 2 = school computer with windows host and ubuntu 20.04
        computer 3 = spare computer that natively runs ubuntu 18.04.
        The drone is not detected in any of those computers at all. I try lsusb and adb shell, nothing is detected. The drone is powered on and connected to an external power supply, the lights on it are on and it made the beeping sound when powered up. The usb to usb c cable connecting the drone to the computer(s) is fine, I tested it with my personal cellphone and it was detected by all 3 computers (on both host and geust os in computers 1 and 2).
        Again, your VOXL flight boards have been detected fine from computers 1 and 2, I didn't test with computer 3.
        I also tried the raspberry pi (ubuntu 20.04) and it also didnt' detect the rb5 drone.
          @alfa-budiman It sounds like the best course of action is to get an RMA inspection going so our team can inspect the drone: https://www.modalai.com/pages/rma
          We fully test / fly all of our drones before shipping so this is definitely an uncommon issue.
            alfa budiman
            #18
            Here's another issue though. My research lab has 4 of these RB5 drones. None of them are detected by were of the computers. I have a hard time believing we received 4 faulty drones (since you fully test / fly them before shipping), and I still believe the problem maybe how I'm setting them up, or something with the computers I'm using.
            Is it possible to schedule a video call with a technician or customer service rep to troubleshoot?
            Is there something I should be doing before plugging the drone to a power supply and connecting it to my computer?
              @alfa-budiman Hmm okay the fact that 4 of the drones are all exhibiting the same behavior makes me think it's not the drone either.
              Some random thoughts:
              What max current do you have your power supply set to? If you crank it up higher does that change the outcome?
              What kind of USB-C cable are you using and what kind of port are you plugging it into?
              We've seen odd issues in the past where customer's PC's weren't able to see the RB5 when using a USB-C to USB-C cable. A solution for one customer was to plug in his USB-C to USB-A cable to a USB2.0 slot instead of USB3.0.
                alfa budiman
                1 - I'm using an external power supply set to 12V and connected to a power outlet on the wall. It is a BK precision power supply, the max current is 3 A and it is not engaging the current limiter when testing the drone.
                2 - I'm using a USB-C to USB-A cable. This cable works fine, I tested it with my cellphone on all 3 computers.
                3 - The computer that natively runs linux has both USB 1.0 and USB 2.0 ports and we tested the drones on all the ports on this computer.
                  @alfa-budiman On the pc that runs linux natively, can you capture the output of dmesg -wH while plugging in the powered RB5? That way we can see if it is recognizing anything being plugged in at all.
                    alfa budiman
                    #22
                    This is the output of dmesg -wH
                    It doesn't all fit in one post so I have to send it over 3 posts.
                    Note that this machine does not have a wifi adapter; my cellphone is plugged in to tether it and provide internet.
                    modal-ai-work@modalaiwork-DX4320:~$ dmesg -wH
                    [Jun27 13:18] Linux version 5.4.0-84-generic (buildd@lcy01-amd64-007) (gcc version 7.5.0 (Ubuntu 7.5.0-3ubuntu1~18.04)) #94~18.04.1-Ubuntu SMP Thu Aug 26 23:17:46 UTC 2021 (Ubuntu 5.4.0-84.94~18.04.1-generic 5.4.133)
                    [  +0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-5.4.0-84-generic root=UUID=e785e6d4-17a2-4d06-972c-ab96e980c8d2 ro quiet splash vt.handoff=1
                    [  +0.000000] KERNEL supported cpus:
                    [  +0.000000]   Intel GenuineIntel
                    [  +0.000000]   AMD AuthenticAMD
                    [  +0.000000]   Hygon HygonGenuine
                    [  +0.000000]   Centaur CentaurHauls
                    [  +0.000000]   zhaoxin   Shanghai
                    [  +0.000000] x86/fpu: x87 FPU will use FXSAVE
                    [  +0.000000] BIOS-provided physical RAM map:
                    [  +0.000000] BIOS-e820: [mem 0x0000000000000000-0x0000000000099bff] usable
                    [  +0.000000] BIOS-e820: [mem 0x0000000000099c00-0x000000000009ffff] reserved
                    [  +0.000000] BIOS-e820: [mem 0x00000000000e2000-0x00000000000fffff] reserved
                    [  +0.000000] BIOS-e820: [mem 0x0000000000100000-0x00000000cfe8ffff] usable
                    [  +0.000000] BIOS-e820: [mem 0x00000000cfe90000-0x00000000cfe9dfff] ACPI data
                    [  +0.000000] BIOS-e820: [mem 0x00000000cfe9e000-0x00000000cfedffff] ACPI NVS
                    [  +0.000000] BIOS-e820: [mem 0x00000000cfee0000-0x00000000cfefffff] reserved
                    [  +0.000000] BIOS-e820: [mem 0x00000000fff00000-0x00000000ffffffff] reserved
                    [  +0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000019fffffff] usable
                    [  +0.000000] NX (Execute Disable) protection: active
                    [  +0.000000] SMBIOS 2.6 present.
                    [  +0.000000] DMI: Gateway DX4320/DX4320, BIOS P01-A2 04/21/2010
                    [  +0.000000] tsc: Fast TSC calibration using PIT
                    [  +0.000000] tsc: Detected 2800.111 MHz processor
                    [  +0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
                    [  +0.000002] e820: remove [mem 0x000a0000-0x000fffff] usable
                    [  +0.007417] AGP: No AGP bridge found
                    [  +0.000070] last_pfn = 0x1a0000 max_arch_pfn = 0x400000000
                    [  +0.000004] MTRR default type: uncachable
                    [  +0.000001] MTRR fixed ranges enabled:
                    [  +0.000001]   00000-9FFFF write-back
                    [  +0.000001]   A0000-EFFFF uncachable
                    [  +0.000001]   F0000-FFFFF write-protect
                    [  +0.000001] MTRR variable ranges enabled:
                    [  +0.000001]   0 base 000000000000 mask FFFF80000000 write-back
                    [  +0.000002]   1 base 000080000000 mask FFFFC0000000 write-back
                    [  +0.000001]   2 base 0000C0000000 mask FFFFF0000000 write-back
                    [  +0.000001]   3 disabled
                    [  +0.000000]   4 disabled
                    [  +0.000001]   5 disabled
                    [  +0.000000]   6 disabled
                    [  +0.000001]   7 disabled
                    [  +0.000001] TOM2: 00000001b0000000 aka 6912M
                    [  +0.000873] x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
                    [  +0.000059] e820: update [mem 0xd0000000-0xffffffff] usable ==> reserved
                    [  +0.000006] last_pfn = 0xcfe90 max_arch_pfn = 0x400000000
                    [  +0.003937] found SMP MP-table at [mem 0x000ff780-0x000ff78f]
                    [  +0.014125] check: Scanning 1 areas for low memory corruption
                    [  +0.000040] Using GB pages for direct mapping
                    [  +0.000242] RAMDISK: [mem 0x32d63000-0x356a8fff]
                    [  +0.000008] ACPI: Early table checksum verification disabled
                    [  +0.000005] ACPI: RSDP 0x00000000000FAF60 000024 (v02 ACPIAM)
                    [  +0.000003] ACPI: XSDT 0x00000000CFE90100 00006C (v01 ACRSYS ACRPRDCT 20100421 MSFT 00000097)
                    [  +0.000006] ACPI: FACP 0x00000000CFE90290 0000F4 (v04 ACRSYS FACP1733 20100421 MSFT 00000097)
                    [  +0.000005] ACPI BIOS Warning (bug): 32/64X length mismatch in FADT/Gpe0Block: 64/32 (20190816/tbfadt-569)
                    [  +0.000004] ACPI: DSDT 0x00000000CFE905D0 006ACB (v02 9B3A1  9B3A1022 00000022 INTL 20051117)
                    [  +0.000003] ACPI: FACS 0x00000000CFE9E000 000040
                    [  +0.000002] ACPI: FACS 0x00000000CFE9E000 000040
                    [  +0.000002] ACPI: APIC 0x00000000CFE90390 00007C (v02 ACRSYS APIC1733 20100421 MSFT 00000097)
                    [  +0.000003] ACPI: MCFG 0x00000000CFE90410 00003C (v01 ACRSYS OEMMCFG  20100421 MSFT 00000097)
                    [  +0.000003] ACPI: SLIC 0x00000000CFE90450 000176 (v01 ACRSYS ACRPRDCT 20100421 MSFT 00000097)
                    [  +0.000002] ACPI: OEMB 0x00000000CFE9E040 000072 (v01 ACRSYS OEMB1733 20100421 MSFT 00000097)
                    [  +0.000003] ACPI: SRAT 0x00000000CFE970A0 0000E8 (v03 AMD    FAM_F_10 00000002 AMD  00000001)
                    [  +0.000003] ACPI: HPET 0x00000000CFE97190 000038 (v01 ACRSYS OEMHPET  20100421 MSFT 00000097)
                    [  +0.000003] ACPI: AWMI 0x00000000CFE9E0C0 00004E (v01 ACRSYS OEMB1733 20100421 MSFT 00000097)
                    [  +0.000002] ACPI: SSDT 0x00000000CFE971D0 00088C (v01 A M I  POWERNOW 00000001 AMD  00000001)
                    [  +0.000003] ACPI: Reserving FACP table memory at [mem 0xcfe90290-0xcfe90383]
                    [  +0.000001] ACPI: Reserving DSDT table memory at [mem 0xcfe905d0-0xcfe9709a]
                    [  +0.000001] ACPI: Reserving FACS table memory at [mem 0xcfe9e000-0xcfe9e03f]
                    [  +0.000000] ACPI: Reserving FACS table memory at [mem 0xcfe9e000-0xcfe9e03f]
                    [  +0.000001] ACPI: Reserving APIC table memory at [mem 0xcfe90390-0xcfe9040b]
                    [  +0.000001] ACPI: Reserving MCFG table memory at [mem 0xcfe90410-0xcfe9044b]
                    [  +0.000001] ACPI: Reserving SLIC table memory at [mem 0xcfe90450-0xcfe905c5]
                    [  +0.000001] ACPI: Reserving OEMB table memory at [mem 0xcfe9e040-0xcfe9e0b1]
                    [  +0.000000] ACPI: Reserving SRAT table memory at [mem 0xcfe970a0-0xcfe97187]
                    [  +0.000001] ACPI: Reserving HPET table memory at [mem 0xcfe97190-0xcfe971c7]
                    [  +0.000001] ACPI: Reserving AWMI table memory at [mem 0xcfe9e0c0-0xcfe9e10d]
                    [  +0.000001] ACPI: Reserving SSDT table memory at [mem 0xcfe971d0-0xcfe97a5b]
                    [  +0.000045] ACPI: Local APIC address 0xfee00000
                    [  +0.000054] SRAT: PXM 0 -> APIC 0x00 -> Node 0
                    [  +0.000001] SRAT: PXM 0 -> APIC 0x01 -> Node 0
                    [  +0.000001] SRAT: PXM 0 -> APIC 0x02 -> Node 0
                    [  +0.000000] SRAT: PXM 0 -> APIC 0x03 -> Node 0
                    [  +0.000003] ACPI: SRAT: Node 0 PXM 0 [mem 0x00000000-0x0009ffff]
                    [  +0.000001] ACPI: SRAT: Node 0 PXM 0 [mem 0x00100000-0xcfffffff]
                    [  +0.000001] ACPI: SRAT: Node 0 PXM 0 [mem 0x100000000-0x1afffffff]
                    [  +0.000002] NUMA: Node 0 [mem 0x00000000-0x0009ffff] + [mem 0x00100000-0xcfffffff] -> [mem 0x00000000-0xcfffffff]
                    [  +0.000002] NUMA: Node 0 [mem 0x00000000-0xcfffffff] + [mem 0x100000000-0x19fffffff] -> [mem 0x00000000-0x19fffffff]
                    [  +0.000009] NODE_DATA(0) allocated [mem 0x19ffd3000-0x19fffdfff]
                    [  +0.000332] Zone ranges:
                    [  +0.000001]   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
                    [  +0.000001]   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
                    [  +0.000001]   Normal   [mem 0x0000000100000000-0x000000019fffffff]
                    [  +0.000001]   Device   empty
                    [  +0.000001] Movable zone start for each node
                    [  +0.000004] Early memory node ranges
                    [  +0.000001]   node   0: [mem 0x0000000000001000-0x0000000000098fff]
                    [  +0.000001]   node   0: [mem 0x0000000000100000-0x00000000cfe8ffff]
                    [  +0.000001]   node   0: [mem 0x0000000100000000-0x000000019fffffff]
                    [  +0.000009] Zeroed struct page in unavailable ranges: 472 pages
                    [  +0.000002] Initmem setup node 0 [mem 0x0000000000001000-0x000000019fffffff]
                    [  +0.000001] On node 0 totalpages: 1506856
                    [  +0.000001]   DMA zone: 64 pages used for memmap
                    [  +0.000000]   DMA zone: 21 pages reserved
                    [  +0.000001]   DMA zone: 3992 pages, LIFO batch:0
                    [  +0.000068]   DMA32 zone: 13243 pages used for memmap
                    [  +0.000001]   DMA32 zone: 847504 pages, LIFO batch:63
                    [  +0.017958]   Normal zone: 10240 pages used for memmap
                    [  +0.000001]   Normal zone: 655360 pages, LIFO batch:63
                    [  +0.013505] ACPI: PM-Timer IO Port: 0x808
                    [  +0.000002] ACPI: Local APIC address 0xfee00000
                    [  +0.000015] IOAPIC[0]: apic_id 4, version 33, address 0xfec00000, GSI 0-23
                    [  +0.000002] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
                    [  +0.000001] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level)
                    [  +0.000001] ACPI: IRQ0 used by override.
                    [  +0.000002] ACPI: IRQ9 used by override.
                    [  +0.000001] Using ACPI (MADT) for SMP configuration information
                    [  +0.000002] ACPI: HPET id: 0x8300 base: 0xfed00000
                    [  +0.000004] smpboot: Allowing 6 CPUs, 2 hotplug CPUs
                    [  +0.000015] PM: Registered nosave memory: [mem 0x00000000-0x00000fff]
                    [  +0.000001] PM: Registered nosave memory: [mem 0x00099000-0x00099fff]
                    [  +0.000001] PM: Registered nosave memory: [mem 0x0009a000-0x0009ffff]
                    [  +0.000001] PM: Registered nosave memory: [mem 0x000a0000-0x000e1fff]
                    [  +0.000000] PM: Registered nosave memory: [mem 0x000e2000-0x000fffff]
                    [  +0.000002] PM: Registered nosave memory: [mem 0xcfe90000-0xcfe9dfff]
                    [  +0.000000] PM: Registered nosave memory: [mem 0xcfe9e000-0xcfedffff]
                    [  +0.000001] PM: Registered nosave memory: [mem 0xcfee0000-0xcfefffff]
                    [  +0.000001] PM: Registered nosave memory: [mem 0xcff00000-0xffefffff]
                    [  +0.000000] PM: Registered nosave memory: [mem 0xfff00000-0xffffffff]
                    [  +0.000002] [mem 0xcff00000-0xffefffff] available for PCI devices
                    [  +0.000001] Booting paravirtualized kernel on bare hardware
                    [  +0.000003] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns
                    [  +0.000007] setup_percpu: NR_CPUS:8192 nr_cpumask_bits:6 nr_cpu_ids:6 nr_node_ids:1
                    [  +0.000793] percpu: Embedded 55 pages/cpu s188416 r8192 d28672 u262144
                    [  +0.000007] pcpu-alloc: s188416 r8192 d28672 u262144 alloc=1*2097152
                    [  +0.000001] pcpu-alloc: [0] 0 1 2 3 4 5 - -
                    [  +0.000033] Built 1 zonelists, mobility grouping on.  Total pages: 1483288
                    [  +0.000001] Policy zone: Normal
                    [  +0.000001] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.4.0-84-generic root=UUID=e785e6d4-17a2-4d06-972c-ab96e980c8d2 ro quiet splash vt.handoff=1
                    [  +0.002138] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
                    [  +0.001029] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
                    [  +0.000030] mem auto-init: stack:off, heap alloc:on, heap free:off
                    [  +0.016697] AGP: Checking aperture...
                    [  +0.007413] AGP: No AGP bridge found
                    [  +0.000002] AGP: Node 0: aperture [bus addr 0xf820000000-0xf821ffffff] (32MB)
                    [  +0.000001] Aperture beyond 4GB. Ignoring.
                    [  +0.000000] AGP: Your BIOS doesn't leave an aperture memory hole
                    [  +0.000001] AGP: Please enable the IOMMU option in the BIOS setup
                    [  +0.000000] AGP: This costs you 64MB of RAM
                    [  +0.000003] AGP: Mapping aperture over RAM [mem 0xc4000000-0xc7ffffff] (65536KB)
                    [  +0.000003] PM: Registered nosave memory: [mem 0xc4000000-0xc7ffffff]
                    [  +0.030723] Memory: 5712752K/6027424K available (14339K kernel code, 2381K rwdata, 4984K rodata, 2716K init, 5004K bss, 314672K reserved, 0K cma-reserved)
                    [  +0.000007] random: get_random_u64 called from __kmem_cache_create+0x41/0x550 with crng_init=0
                    [  +0.000212] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
                    [  +0.000018] ftrace: allocating 44320 entries in 174 pages
                    [  +0.016067] rcu: Hierarchical RCU implementation.
                    [  +0.000002] rcu: 	RCU restricting CPUs from NR_CPUS=8192 to nr_cpu_ids=6.
                    [  +0.000001] 	Tasks RCU enabled.
                    [  +0.000001] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
                    [  +0.000001] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
                    [  +0.003429] NR_IRQS: 524544, nr_irqs: 472, preallocated irqs: 16
                    [  +0.000353] spurious 8259A interrupt: IRQ7.
                    [  +0.000009] vt handoff: transparent VT on vt#1
                    [  +0.000010] Console: colour dummy device 80x25
                    [  +0.000005] printk: console [tty0] enabled
                    [  +0.000022] ACPI: Core revision 20190816
                    [  +0.000145] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484873504 ns
                    [  +0.000016] APIC: Switch to symmetric I/O mode setup
                    [  +0.000448] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
                    [  +0.019552] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x285ca9e108c, max_idle_ns: 440795313830 ns
                    [  +0.000005] Calibrating delay loop (skipped), value calculated using timer frequency.. 5600.22 BogoMIPS (lpj=11200444)
                    [  +0.000002] pid_max: default: 32768 minimum: 301
                    [  +0.000041] LSM: Security Framework initializing
                    [  +0.000014] Yama: becoming mindful.
                    [  +0.000046] AppArmor: AppArmor initialized
                    [  +0.000067] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
                    [  +0.000030] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
                    [  +0.000017] *** VALIDATE tmpfs ***
                    [  +0.000172] *** VALIDATE proc ***
                    [  +0.000071] *** VALIDATE cgroup1 ***
                    [  +0.000001] *** VALIDATE cgroup2 ***
                    [  +0.000052] LVT offset 0 assigned for vector 0xf9
                    [  +0.000003] process: using AMD E400 aware idle routine
                    [  +0.000001] Last level iTLB entries: 4KB 512, 2MB 16, 4MB 8
                    [  +0.000001] Last level dTLB entries: 4KB 512, 2MB 128, 4MB 64, 1GB 0
                    [  +0.000003] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
                    [  +0.000002] Spectre V2 : Mitigation: Full AMD retpoline
                    [  +0.000001] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
                    [  +0.000129] Freeing SMP alternatives memory: 40K
                    [  +0.002941] process: System has AMD C1E enabled
                    [  +0.108138] process: Switch to broadcast mode on CPU0
                    [  +0.000006] smpboot: CPU0: AMD Phenom(tm) II X4 820 Processor (family: 0x10, model: 0x4, stepping: 0x2)
                    [  +0.000132] Performance Events: AMD PMU driver.
                    [  +0.000003] ... version:                0
                    [  +0.000001] ... bit width:              48
                    [  +0.000000] ... generic registers:      4
                    [  +0.000001] ... value mask:             0000ffffffffffff
                    [  +0.000000] ... max period:             00007fffffffffff
                    [  +0.000001] ... fixed-purpose events:   0
                    [  +0.000000] ... event mask:             000000000000000f
                    [  +0.000043] rcu: Hierarchical SRCU implementation.
                    [  +0.000077] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
                    [  +0.000000] smp: Bringing up secondary CPUs ...
                    [  +0.000000] x86: Booting SMP configuration:
                    [  +0.000000] .... node  #0, CPUs:      #1
                    [  -0.274184] process: Switch to broadcast mode on CPU1
                    [  +0.274184]  #2
                    [  -0.274184] process: Switch to broadcast mode on CPU2
                    [  +0.276378]  #3
                    [  -0.276378] process: Switch to broadcast mode on CPU3
                    [  +0.278253] smp: Brought up 1 node, 4 CPUs
                    [  +0.000000] smpboot: Max logical packages: 2
                    [  +0.000000] smpboot: Total of 4 processors activated (22400.88 BogoMIPS)
                    [  +0.004346] devtmpfs: initialized
                    [  +0.000000] x86/mm: Memory block size: 128MB
                    [  +0.000247] PM: Registering ACPI NVS region [mem 0xcfe9e000-0xcfedffff] (270336 bytes)
                    [  +0.000000] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
                    [  +0.000000] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
                    [  +0.000000] pinctrl core: initialized pinctrl subsystem
                    [  +0.000000] PM: RTC time: 17:18:55, date: 2022-06-27
                    [  +0.000000] NET: Registered protocol family 16
                    [  +0.000000] audit: initializing netlink subsys (disabled)
                    [  +0.000000] audit: type=2000 audit(1656350335.140:1): state=initialized audit_enabled=0 res=1
                    [  +0.000000] EISA bus registered
                    [  +0.000000] cpuidle: using governor ladder
                    [  +0.000000] cpuidle: using governor menu
                    [  +0.000000] node 0 link 0: io port [1000, ffffff]
                    [  +0.000000] TOM: 00000000d0000000 aka 3328M
                    [  +0.000000] Fam 10h mmconf [mem 0xe0000000-0xefffffff]
                    [  +0.000000] node 0 link 0: mmio [a0000, bffff]
                    [  +0.000000] node 0 link 0: mmio [d0000000, efffffff] ==> [d0000000, dfffffff]
                    [  +0.000000] node 0 link 0: mmio [f0000000, fe6fffff]
                    [  +0.000000] node 0 link 0: mmio [fe700000, fe8fffff]
                    [  +0.000000] node 0 link 0: mmio [fe900000, ffefffff]
                    [  +0.000000] TOM2: 00000001b0000000 aka 6912M
                    [  +0.000000] bus: [bus 00-07] on node 0 link 0
                    [  +0.000000] bus: 00 [io  0x0000-0xffff]
                    [  +0.000000] bus: 00 [mem 0x000a0000-0x000bffff]
                    [  +0.000000] bus: 00 [mem 0xd0000000-0xdfffffff]
                    [  +0.000000] bus: 00 [mem 0xf0000000-0xffffffff]
                    [  +0.000000] bus: 00 [mem 0x1b0000000-0xfcffffffff]
                    [  +0.000000] ACPI: bus type PCI registered
                    [  +0.000000] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
                    [  +0.000000] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
                    [  +0.000000] PCI: not using MMCONFIG
                    [  +0.000000] PCI: Using configuration type 1 for base access
                    [  +0.000000] PCI: Using configuration type 1 for extended access
                    [  +0.000000] mtrr: your CPUs had inconsistent variable MTRR settings
                    [  +0.000000] mtrr: probably your BIOS does not setup all CPUs.
                    [  +0.000000] mtrr: corrected configuration.
                    [  +0.003631] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
                    [  +0.000000] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
                    [  +0.000000] ACPI: Added _OSI(Module Device)
                    [  +0.000000] ACPI: Added _OSI(Processor Device)
                    [  +0.000000] ACPI: Added _OSI(3.0 _SCP Extensions)
                    [  +0.000000] ACPI: Added _OSI(Processor Aggregator Device)
                    [  +0.000000] ACPI: Added _OSI(Linux-Dell-Video)
                    [  +0.000000] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
                    [  +0.000000] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
                    [  +0.007540] ACPI: 2 ACPI AML tables successfully acquired and loaded
                    [  +0.002950] ACPI: Interpreter enabled
                    [  +0.000020] ACPI: (supports S0 S3 S4 S5)
                    [  +0.000001] ACPI: Using IOAPIC for interrupt routing
                    [  +0.000034] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
                    [  +0.002788] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in ACPI motherboard resources
                    [  +0.000014] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
                    [  +0.001001] ACPI: Enabled 10 GPEs in block 00 to 1F
                    [  +0.011757] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
                    [  +0.000006] acpi PNP0A03:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI HPX-Type3]
                    [  +0.000325] acpi PNP0A03:00: _OSC: platform does not support [SHPCHotplug LTR]
                    [  +0.000236] acpi PNP0A03:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
                    [  +0.000403] PCI host bridge to bus 0000:00
                    [  +0.000002] pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
                    [  +0.000002] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
                    [  +0.000001] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
                    [  +0.000002] pci_bus 0000:00: root bus resource [mem 0x000d0000-0x000dffff window]
                    [  +0.000001] pci_bus 0000:00: root bus resource [mem 0xcff00000-0xdfffffff window]
                    [  +0.000001] pci_bus 0000:00: root bus resource [mem 0xf0000000-0xfed44fff window]
                    [  +0.000001] pci_bus 0000:00: root bus resource [bus 00-ff]
                    [  +0.000011] pci 0000:00:00.0: [1022:9601] type 00 class 0x060000
                    [  +0.000139] pci 0000:00:01.0: [1022:9602] type 01 class 0x060400
                    [  +0.000173] pci 0000:00:11.0: [1002:4391] type 00 class 0x010601
                    [  +0.000020] pci 0000:00:11.0: reg 0x10: [io  0xc000-0xc007]
                    [  +0.000008] pci 0000:00:11.0: reg 0x14: [io  0xb000-0xb003]
                    [  +0.000008] pci 0000:00:11.0: reg 0x18: [io  0xa000-0xa007]
                    [  +0.000007] pci 0000:00:11.0: reg 0x1c: [io  0x9000-0x9003]
                    [  +0.000008] pci 0000:00:11.0: reg 0x20: [io  0x8000-0x800f]
                    [  +0.000008] pci 0000:00:11.0: reg 0x24: [mem 0xfe6ffc00-0xfe6fffff]
                    [  +0.000151] pci 0000:00:12.0: [1002:4397] type 00 class 0x0c0310
                    [  +0.000016] pci 0000:00:12.0: reg 0x10: [mem 0xfe6fe000-0xfe6fefff]
                    [  +0.000168] pci 0000:00:12.2: [1002:4396] type 00 class 0x0c0320
                    [  +0.000019] pci 0000:00:12.2: reg 0x10: [mem 0xfe6ff800-0xfe6ff8ff]
                    [  +0.000071] pci 0000:00:12.2: supports D1 D2
                    [  +0.000001] pci 0000:00:12.2: PME# supported from D0 D1 D2 D3hot
                    [  +0.000108] pci 0000:00:13.0: [1002:4397] type 00 class 0x0c0310
                    [  +0.000015] pci 0000:00:13.0: reg 0x10: [mem 0xfe6fd000-0xfe6fdfff]
                    [  +0.000183] pci 0000:00:13.2: [1002:4396] type 00 class 0x0c0320
                    [  +0.000019] pci 0000:00:13.2: reg 0x10: [mem 0xfe6ff400-0xfe6ff4ff]
                    [  +0.000070] pci 0000:00:13.2: supports D1 D2
                    [  +0.000001] pci 0000:00:13.2: PME# supported from D0 D1 D2 D3hot
                    [  +0.000107] pci 0000:00:14.0: [1002:4385] type 00 class 0x0c0500
                    [  +0.000194] pci 0000:00:14.2: [1002:4383] type 00 class 0x040300
                    [  +0.000021] pci 0000:00:14.2: reg 0x10: [mem 0xfe6f4000-0xfe6f7fff 64bit]
                    [  +0.000058] pci 0000:00:14.2: PME# supported from D0 D3hot D3cold
                    [  +0.000138] pci 0000:00:14.3: [1002:439d] type 00 class 0x060100
                    [  +0.000157] pci 0000:00:14.4: [1002:4384] type 01 class 0x060401
                    [  +0.000143] pci 0000:00:14.5: [1002:4399] type 00 class 0x0c0310
                    [  +0.000016] pci 0000:00:14.5: reg 0x10: [mem 0xfe6fc000-0xfe6fcfff]
                    [  +0.000189] pci 0000:00:15.0: [1002:43a0] type 01 class 0x060400
                    [  +0.000042] pci 0000:00:15.0: enabling Extended Tags
                    [  +0.000044] pci 0000:00:15.0: supports D1 D2
                    [  +0.000119] pci 0000:00:16.0: [1002:4397] type 00 class 0x0c0310
                    [  +0.000015] pci 0000:00:16.0: reg 0x10: [mem 0xfe6f3000-0xfe6f3fff]
                    [  +0.000184] pci 0000:00:16.2: [1002:4396] type 00 class 0x0c0320
                    [  +0.000018] pci 0000:00:16.2: reg 0x10: [mem 0xfe6ff000-0xfe6ff0ff]
                    [  +0.000070] pci 0000:00:16.2: supports D1 D2
                    [  +0.000002] pci 0000:00:16.2: PME# supported from D0 D1 D2 D3hot
                    [  +0.000140] pci 0000:00:18.0: [1022:1200] type 00 class 0x060000
                    [  +0.000085] pci 0000:00:18.1: [1022:1201] type 00 class 0x060000
                    [  +0.000083] pci 0000:00:18.2: [1022:1202] type 00 class 0x060000
                    [  +0.000082] pci 0000:00:18.3: [1022:1203] type 00 class 0x060000
                    [  +0.000092] pci 0000:00:18.4: [1022:1204] type 00 class 0x060000
                    [  +0.000121] pci_bus 0000:01: extended config space not accessible
                    [  +0.000034] pci 0000:01:05.0: [1002:9715] type 00 class 0x030000
                    [  +0.000007] pci 0000:01:05.0: reg 0x10: [mem 0xd0000000-0xdfffffff pref]
                    [  +0.000003] pci 0000:01:05.0: reg 0x14: [io  0xd000-0xd0ff]
                    [  +0.000004] pci 0000:01:05.0: reg 0x18: [mem 0xfe8f0000-0xfe8fffff]
                    [  +0.000007] pci 0000:01:05.0: reg 0x24: [mem 0xfe700000-0xfe7fffff]
                    [  +0.000019] pci 0000:01:05.0: supports D1 D2
                    [  +0.000046] pci 0000:01:05.1: [1002:970f] type 00 class 0x040300
                    [  +0.000006] pci 0000:01:05.1: reg 0x10: [mem 0xfe8e8000-0xfe8ebfff]
                    [  +0.000029] pci 0000:01:05.1: supports D1 D2
                    [  +0.000054] pci 0000:00:01.0: PCI bridge to [bus 01]
                    [  +0.000003] pci 0000:00:01.0:   bridge window [io  0xd000-0xdfff]
                    [  +0.000001] pci 0000:00:01.0:   bridge window [mem 0xfe700000-0xfe8fffff]
                    [  +0.000003] pci 0000:00:01.0:   bridge window [mem 0xd0000000-0xdfffffff 64bit pref]
                    [  +0.000010] pci_bus 0000:02: extended config space not accessible
                    [  +0.000056] pci 0000:00:14.4: PCI bridge to [bus 02] (subtractive decode)
                    [  +0.000007] pci 0000:00:14.4:   bridge window [io  0x0000-0x0cf7 window] (subtractive decode)
                    [  +0.000002] pci 0000:00:14.4:   bridge window [io  0x0d00-0xffff window] (subtractive decode)
                    [  +0.000001] pci 0000:00:14.4:   bridge window [mem 0x000a0000-0x000bffff window] (subtractive decode)
                    [  +0.000001] pci 0000:00:14.4:   bridge window [mem 0x000d0000-0x000dffff window] (subtractive decode)
                    [  +0.000001] pci 0000:00:14.4:   bridge window [mem 0xcff00000-0xdfffffff window] (subtractive decode)
                    [  +0.000001] pci 0000:00:14.4:   bridge window [mem 0xf0000000-0xfed44fff window] (subtractive decode)
                    [  +0.000056] pci 0000:03:00.0: [10ec:8168] type 00 class 0x020000
                    [  +0.000029] pci 0000:03:00.0: reg 0x10: [io  0xe800-0xe8ff]
                    [  +0.000028] pci 0000:03:00.0: reg 0x18: [mem 0xfdfff000-0xfdffffff 64bit pref]
                    [  +0.000017] pci 0000:03:00.0: reg 0x20: [mem 0xfdff8000-0xfdffbfff 64bit pref]
                    [  +0.000011] pci 0000:03:00.0: reg 0x30: [mem 0xfe9e0000-0xfe9fffff pref]
                    [  +0.000093] pci 0000:03:00.0: supports D1 D2
                    [  +0.000001] pci 0000:03:00.0: PME# supported from D0 D1 D2 D3hot D3cold
                    [  +0.008795] pci 0000:00:15.0: PCI bridge to [bus 03]
                    [  +0.000004] pci 0000:00:15.0:   bridge window [io  0xe000-0xefff]
                    [  +0.000003] pci 0000:00:15.0:   bridge window [mem 0xfe900000-0xfe9fffff]
                    [  +0.000005] pci 0000:00:15.0:   bridge window [mem 0xfdf00000-0xfdffffff 64bit pref]
                    [  +0.001946] ACPI: PCI Interrupt Link [LNKA] (IRQs 10 *11 14 15)
                    [  +0.000098] ACPI: PCI Interrupt Link [LNKB] (IRQs *10 11 14 15)
                    [  +0.000102] ACPI: PCI Interrupt Link [LNKC] (IRQs *10 11 14 15)
                    [  +0.000102] ACPI: PCI Interrupt Link [LNKD] (IRQs 10 *11 14 15)
                    [  +0.000084] ACPI: PCI Interrupt Link [LNKE] (IRQs 10 11 14 15) *0
                    [  +0.000068] ACPI: PCI Interrupt Link [LNKF] (IRQs 10 11 14 15) *0
                    [  +0.000066] ACPI: PCI Interrupt Link [LNKG] (IRQs 10 11 14 15) *0
                    [  +0.000065] ACPI: PCI Interrupt Link [LNKH] (IRQs 10 11 14 15) *0
                    [  +0.000173] iommu: Default domain type: Translated
                    [  +0.000000] SCSI subsystem initialized
                    [  +0.000000] libata version 3.00 loaded.
                    [  +0.000000] pci 0000:01:05.0: vgaarb: setting as boot VGA device
                    [  +0.000000] pci 0000:01:05.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
                    [  +0.000000] pci 0000:01:05.0: vgaarb: bridge control possible
                    [  +0.000000] vgaarb: loaded
                    [  +0.000000] ACPI: bus type USB registered
                    [  +0.000000] usbcore: registered new interface driver usbfs
                    [  +0.000000] usbcore: registered new interface driver hub
                    [  +0.000000] usbcore: registered new device driver usb
                    [  +0.000000] pps_core: LinuxPPS API ver. 1 registered
                    [  +0.000000] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
                    [  +0.000000] PTP clock support registered
                    [  +0.000000] EDAC MC: Ver: 3.0.0
                    [  +0.000000] PCI: Using ACPI for IRQ routing
                    [  +0.004575] PCI: pci_cache_line_size set to 64 bytes
                    [  +0.000043] e820: reserve RAM buffer [mem 0x00099c00-0x0009ffff]
                    [  +0.000003] e820: reserve RAM buffer [mem 0xcfe90000-0xcfffffff]
                    [  +0.000124] NetLabel: Initializing
                    [  +0.000001] NetLabel:  domain hash size = 128
                    [  +0.000001] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
                    [  +0.000013] NetLabel:  unlabeled traffic allowed by default
                    [  +0.000569] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
                    [  +0.000004] hpet0: 3 comparators, 32-bit 14.318180 MHz counter
                    [  +0.004982] clocksource: Switched to clocksource tsc-early
                    [  +0.014783] *** VALIDATE bpf ***
                    [  +0.000085] VFS: Disk quotas dquot_6.6.0
                    [  +0.000019] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
                    [  +0.000029] *** VALIDATE ramfs ***
                    [  +0.000004] *** VALIDATE hugetlbfs ***
                    [  +0.000103] AppArmor: AppArmor Filesystem Enabled
                    [  +0.000036] pnp: PnP ACPI init
                    [  +0.000323] system 00:00: [mem 0xcff00000-0xcfffffff] has been reserved
                    [  +0.000006] system 00:00: Plug and Play ACPI device, IDs PNP0c02 (active)
                    [  +0.000071] pnp 00:01: Plug and Play ACPI device, IDs PNP0b00 (active)
                    [  +0.000064] pnp 00:02: Plug and Play ACPI device, IDs PNP0303 PNP030b (disabled)
                    [  +0.000078] pnp 00:03: Plug and Play ACPI device, IDs PNP0f03 PNP0f13 (active)
                    [  +0.001685] system 00:04: [io  0x0e00-0x0e0f] has been reserved
                    [  +0.000002] system 00:04: [io  0x0e80-0x0e8f] has been reserved
                    [  +0.000001] system 00:04: [io  0x0f40-0x0f4f] has been reserved
                    [  +0.000002] system 00:04: [io  0x0a30-0x0a3f] has been reserved
                    [  +0.000003] system 00:04: Plug and Play ACPI device, IDs PNP0c02 (active)
                    [  +0.000156] system 00:05: [mem 0xfec00000-0xfec00fff] could not be reserved
                    [  +0.000002] system 00:05: [mem 0xfee00000-0xfee00fff] has been reserved
                    [  +0.000003] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active)
                    [  +0.000263] system 00:06: [io  0x04d0-0x04d1] has been reserved
                    [  +0.000002] system 00:06: [io  0x040b] has been reserved
                    [  +0.000001] system 00:06: [io  0x04d6] has been reserved
                    [  +0.000001] system 00:06: [io  0x0c00-0x0c01] has been reserved
                    [  +0.000001] system 00:06: [io  0x0c14] has been reserved
                    [  +0.000002] system 00:06: [io  0x0c50-0x0c51] has been reserved
                    [  +0.000001] system 00:06: [io  0x0c52] has been reserved
                    [  +0.000001] system 00:06: [io  0x0c6c] has been reserved
                    [  +0.000001] system 00:06: [io  0x0c6f] has been reserved
                    [  +0.000002] system 00:06: [io  0x0cd0-0x0cd1] has been reserved
                    [  +0.000001] system 00:06: [io  0x0cd2-0x0cd3] has been reserved
                    [  +0.000001] system 00:06: [io  0x0cd4-0x0cd5] has been reserved
                    [  +0.000001] system 00:06: [io  0x0cd6-0x0cd7] has been reserved
                    [  +0.000002] system 00:06: [io  0x0cd8-0x0cdf] has been reserved
                    [  +0.000001] system 00:06: [io  0x0800-0x089f] has been reserved
                    [  +0.000001] system 00:06: [io  0x0b00-0x0b1f] has been reserved
                    [  +0.000001] system 00:06: [io  0x0b20-0x0b3f] has been reserved
                    [  +0.000001] system 00:06: [io  0x0900-0x090f] has been reserved
                      alfa budiman
                      [  +0.000002] system 00:06: [io  0x0910-0x091f] has been reserved
                      [  +0.000001] system 00:06: [io  0xfe00-0xfefe] has been reserved
                      [  +0.000002] system 00:06: [mem 0xffb80000-0xffbfffff] has been reserved
                      [  +0.000002] system 00:06: [mem 0xfec10000-0xfec1001f] has been reserved
                      [  +0.000003] system 00:06: [mem 0xfed80000-0xfed80fff] has been reserved
                      [  +0.000004] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
                      [  +0.000089] system 00:07: [mem 0xe0000000-0xefffffff] has been reserved
                      [  +0.000003] system 00:07: Plug and Play ACPI device, IDs PNP0c02 (active)
                      [  +0.000211] system 00:08: [mem 0x00000000-0x0009ffff] could not be reserved
                      [  +0.000002] system 00:08: [mem 0x000c0000-0x000cffff] could not be reserved
                      [  +0.000001] system 00:08: [mem 0x000e0000-0x000fffff] could not be reserved
                      [  +0.000002] system 00:08: [mem 0x00100000-0xcfefffff] could not be reserved
                      [  +0.000001] system 00:08: [mem 0xfed45000-0xffffffff] could not be reserved
                      [  +0.000003] system 00:08: Plug and Play ACPI device, IDs PNP0c01 (active)
                      [  +0.000139] pnp: PnP ACPI: found 9 devices
                      [  +0.001626] thermal_sys: Registered thermal governor 'fair_share'
                      [  +0.000001] thermal_sys: Registered thermal governor 'bang_bang'
                      [  +0.000001] thermal_sys: Registered thermal governor 'step_wise'
                      [  +0.000000] thermal_sys: Registered thermal governor 'user_space'
                      [  +0.000001] thermal_sys: Registered thermal governor 'power_allocator'
                      [  +0.004623] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
                      [  +0.000044] pci 0000:00:01.0: PCI bridge to [bus 01]
                      [  +0.000003] pci 0000:00:01.0:   bridge window [mem 0xfe700000-0xfe8fffff]
                      [  +0.000002] pci 0000:00:01.0:   bridge window [mem 0xd0000000-0xdfffffff 64bit pref]
                      [  +0.000003] pci 0000:00:14.4: PCI bridge to [bus 02]
                      [  +0.000010] pci 0000:00:15.0: PCI bridge to [bus 03]
                      [  +0.000002] pci 0000:00:15.0:   bridge window [io  0xe000-0xefff]
                      [  +0.000003] pci 0000:00:15.0:   bridge window [mem 0xfdf00000-0xfdffffff 64bit pref]
                      [  +0.000005] pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
                      [  +0.000002] pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
                      [  +0.000001] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
                      [  +0.000002] pci_bus 0000:00: resource 7 [mem 0x000d0000-0x000dffff window]
                      [  +0.000001] pci_bus 0000:00: resource 8 [mem 0xcff00000-0xdfffffff window]
                      [  +0.000001] pci_bus 0000:00: resource 9 [mem 0xf0000000-0xfed44fff window]
                      [  +0.000001] pci_bus 0000:01: resource 0 [io  0xd000-0xdfff]
                      [  +0.000001] pci_bus 0000:01: resource 1 [mem 0xfe700000-0xfe8fffff]
                      [  +0.000002] pci_bus 0000:01: resource 2 [mem 0xd0000000-0xdfffffff 64bit pref]
                      [  +0.000001] pci_bus 0000:02: resource 4 [io  0x0000-0x0cf7 window]
                      [  +0.000001] pci_bus 0000:02: resource 5 [io  0x0d00-0xffff window]
                      [  +0.000002] pci_bus 0000:02: resource 6 [mem 0x000a0000-0x000bffff window]
                      [  +0.000001] pci_bus 0000:02: resource 7 [mem 0x000d0000-0x000dffff window]
                      [  +0.000001] pci_bus 0000:02: resource 8 [mem 0xcff00000-0xdfffffff window]
                      [  +0.000001] pci_bus 0000:02: resource 9 [mem 0xf0000000-0xfed44fff window]
                      [  +0.000002] pci_bus 0000:03: resource 0 [io  0xe000-0xefff]
                      [  +0.000001] pci_bus 0000:03: resource 1 [mem 0xfe900000-0xfe9fffff]
                      [  +0.000001] pci_bus 0000:03: resource 2 [mem 0xfdf00000-0xfdffffff 64bit pref]
                      [  +0.000085] NET: Registered protocol family 2
                      [  +0.000286] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
                      [  +0.001065] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
                      [  +0.000127] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
                      [  +0.000399] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
                      [  +0.000191] TCP: Hash tables configured (established 65536 bind 65536)
                      [  +0.000092] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
                      [  +0.000066] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
                      [  +0.000079] NET: Registered protocol family 1
                      [  +0.000006] NET: Registered protocol family 44
                      [  +0.000007] pci 0000:00:01.0: MSI quirk detected; subordinate MSI disabled
                      [  +0.026585] pci 0000:00:12.0: quirk_usb_early_handoff+0x0/0x6b0 took 25945 usecs
                      [  +0.023987] pci 0000:00:13.0: quirk_usb_early_handoff+0x0/0x6b0 took 23249 usecs
                      [  +0.024000] pci 0000:00:14.5: quirk_usb_early_handoff+0x0/0x6b0 took 23255 usecs
                      [  +0.024028] pci 0000:00:16.0: quirk_usb_early_handoff+0x0/0x6b0 took 23419 usecs
                      [  +0.000226] pci 0000:01:05.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
                      [  +0.000008] pci 0000:01:05.1: D0 power state depends on 0000:01:05.0
                      [  +0.000008] PCI: CLS 64 bytes, default 64
                      [  +0.000069] Trying to unpack rootfs image as initramfs...
                      [  +0.600697] Freeing initrd memory: 42264K
                      [  +0.000478] PCI-DMA: Disabling AGP.
                      [  +0.000083] PCI-DMA: aperture base @ c4000000 size 65536 KB
                      [  +0.000001] PCI-DMA: using GART IOMMU.
                      [  +0.000002] PCI-DMA: Reserving 64MB of IOMMU area in the AGP aperture
                      [  +0.002054] LVT offset 1 assigned for vector 0x400
                      [  +0.000008] LVT offset 1 assigned
                      [  +0.000111] perf: AMD IBS detected (0x0000001f)
                      [  +0.000059] check: Scanning for low memory corruption every 60 seconds
                      [  +0.000412] Initialise system trusted keyrings
                      [  +0.000010] Key type blacklist registered
                      [  +0.000081] workingset: timestamp_bits=36 max_order=21 bucket_order=0
                      [  +0.001453] zbud: loaded
                      [  +0.000382] squashfs: version 4.0 (2009/01/31) Phillip Lougher
                      [  +0.000228] fuse: init (API version 7.31)
                      [  +0.000016] *** VALIDATE fuse ***
                      [  +0.000002] *** VALIDATE fuse ***
                      [  +0.000096] Platform Keyring initialized
                      [  +0.004130] Key type asymmetric registered
                      [  +0.000001] Asymmetric key parser 'x509' registered
                      [  +0.000008] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
                      [  +0.000041] io scheduler mq-deadline registered
                      [  +0.000469] pcieport 0000:00:15.0: PME: Signaling with IRQ 24
                      [  +0.000089] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
                      [  +0.000057] vesafb: mode is 1400x1050x32, linelength=5632, pages=0
                      [  +0.000000] vesafb: scrolling: redraw
                      [  +0.000002] vesafb: Truecolor: size=0:8:8:8, shift=0:16:8:0
                      [  +0.000013] vesafb: framebuffer at 0xd0000000, mapped to 0x(____ptrval____), using 5824k, total 5824k
                      [  +0.000065] fbcon: Deferring console take-over
                      [  +0.000001] fb0: VESA VGA frame buffer device
                      [  +0.000092] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
                      [  +0.000037] ACPI: Power Button [PWRB]
                      [  +0.000035] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
                      [  +0.000025] ACPI: Power Button [PWRF]
                      [  +0.000074] ACPI: ACPI: processor limited to max C-state 1
                      [  +0.000749] thermal LNXTHERM:00: registered as thermal_zone0
                      [  +0.000001] ACPI: Thermal Zone [THRM] (17 C)
                      [  +0.000274] thermal LNXTHERM:01: registered as thermal_zone1
                      [  +0.000001] ACPI: Thermal Zone [THRS] (27 C)
                      [  +0.000136] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
                      [  +0.001662] Linux agpgart interface v0.103
                      [  +0.105441] random: fast init done
                      [  +0.025799] loop: module loaded
                      [  +0.000211] libphy: Fixed MDIO Bus: probed
                      [  +0.000001] tun: Universal TUN/TAP device driver, 1.6
                      [  +0.000028] PPP generic driver version 2.4.2
                      [  +0.000056] VFIO - User Level meta-driver version: 0.3
                      [  +0.000075] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
                      [  +0.000009] ehci-pci: EHCI PCI platform driver
                      [  +0.000190] QUIRK: Enable AMD PLL fix
                      [  +0.000020] ehci-pci 0000:00:12.2: EHCI Host Controller
                      [  +0.000007] ehci-pci 0000:00:12.2: new USB bus registered, assigned bus number 1
                      [  +0.000004] ehci-pci 0000:00:12.2: applying AMD SB700/SB800/Hudson-2/3 EHCI dummy qh workaround
                      [  +0.000008] ehci-pci 0000:00:12.2: debug port 1
                      [  +0.000050] ehci-pci 0000:00:12.2: irq 17, io mem 0xfe6ff800
                      [  +0.015334] ehci-pci 0000:00:12.2: USB 2.0 started, EHCI 1.00
                      [  +0.000061] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
                      [  +0.000001] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
                      [  +0.000002] usb usb1: Product: EHCI Host Controller
                      [  +0.000001] usb usb1: Manufacturer: Linux 5.4.0-84-generic ehci_hcd
                      [  +0.000001] usb usb1: SerialNumber: 0000:00:12.2
                      [  +0.000097] hub 1-0:1.0: USB hub found
                      [  +0.000008] hub 1-0:1.0: 5 ports detected
                      [  +0.000311] ehci-pci 0000:00:13.2: EHCI Host Controller
                      [  +0.000005] ehci-pci 0000:00:13.2: new USB bus registered, assigned bus number 2
                      [  +0.000002] ehci-pci 0000:00:13.2: applying AMD SB700/SB800/Hudson-2/3 EHCI dummy qh workaround
                      [  +0.000008] ehci-pci 0000:00:13.2: debug port 1
                      [  +0.000032] ehci-pci 0000:00:13.2: irq 17, io mem 0xfe6ff400
                      [  +0.015472] ehci-pci 0000:00:13.2: USB 2.0 started, EHCI 1.00
                      [  +0.000034] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
                      [  +0.000002] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
                      [  +0.000001] usb usb2: Product: EHCI Host Controller
                      [  +0.000001] usb usb2: Manufacturer: Linux 5.4.0-84-generic ehci_hcd
                      [  +0.000001] usb usb2: SerialNumber: 0000:00:13.2
                      [  +0.000098] hub 2-0:1.0: USB hub found
                      [  +0.000006] hub 2-0:1.0: 5 ports detected
                      [  +0.000328] ehci-pci 0000:00:16.2: EHCI Host Controller
                      [  +0.000005] ehci-pci 0000:00:16.2: new USB bus registered, assigned bus number 3
                      [  +0.000003] ehci-pci 0000:00:16.2: applying AMD SB700/SB800/Hudson-2/3 EHCI dummy qh workaround
                      [  +0.000008] ehci-pci 0000:00:16.2: debug port 1
                      [  +0.000027] ehci-pci 0000:00:16.2: irq 17, io mem 0xfe6ff000
                      [  +0.015485] ehci-pci 0000:00:16.2: USB 2.0 started, EHCI 1.00
                      [  +0.000032] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
                      [  +0.000001] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
                      [  +0.000001] usb usb3: Product: EHCI Host Controller
                      [  +0.000001] usb usb3: Manufacturer: Linux 5.4.0-84-generic ehci_hcd
                      [  +0.000001] usb usb3: SerialNumber: 0000:00:16.2
                      [  +0.000093] hub 3-0:1.0: USB hub found
                      [  +0.000005] hub 3-0:1.0: 4 ports detected
                      [  +0.000158] ehci-platform: EHCI generic platform driver
                      [  +0.000007] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
                      [  +0.000002] ohci-pci: OHCI PCI platform driver
                      [  +0.000162] ohci-pci 0000:00:12.0: OHCI PCI host controller
                      [  +0.000004] ohci-pci 0000:00:12.0: new USB bus registered, assigned bus number 4
                      [  +0.000023] ohci-pci 0000:00:12.0: irq 18, io mem 0xfe6fe000
                      [  +0.063577] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.04
                      [  +0.000001] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
                      [  +0.000001] usb usb4: Product: OHCI PCI host controller
                      [  +0.000001] usb usb4: Manufacturer: Linux 5.4.0-84-generic ohci_hcd
                      [  +0.000001] usb usb4: SerialNumber: 0000:00:12.0
                      [  +0.000105] hub 4-0:1.0: USB hub found
                      [  +0.000007] hub 4-0:1.0: 5 ports detected
                      [  +0.000366] ohci-pci 0000:00:13.0: OHCI PCI host controller
                      [  +0.000004] ohci-pci 0000:00:13.0: new USB bus registered, assigned bus number 5
                      [  +0.000022] ohci-pci 0000:00:13.0: irq 18, io mem 0xfe6fd000
                      [  +0.063513] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.04
                      [  +0.000002] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
                      [  +0.000001] usb usb5: Product: OHCI PCI host controller
                      [  +0.000001] usb usb5: Manufacturer: Linux 5.4.0-84-generic ohci_hcd
                      [  +0.000001] usb usb5: SerialNumber: 0000:00:13.0
                      [  +0.000132] hub 5-0:1.0: USB hub found
                      [  +0.000007] hub 5-0:1.0: 5 ports detected
                      [  +0.000412] ohci-pci 0000:00:14.5: OHCI PCI host controller
                      [  +0.000004] ohci-pci 0000:00:14.5: new USB bus registered, assigned bus number 6
                      [  +0.000020] ohci-pci 0000:00:14.5: irq 18, io mem 0xfe6fc000
                      [  +0.063385] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.04
                      [  +0.000002] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
                      [  +0.000001] usb usb6: Product: OHCI PCI host controller
                      [  +0.000001] usb usb6: Manufacturer: Linux 5.4.0-84-generic ohci_hcd
                      [  +0.000001] usb usb6: SerialNumber: 0000:00:14.5
                      [  +0.000098] hub 6-0:1.0: USB hub found
                      [  +0.000007] hub 6-0:1.0: 2 ports detected
                      [  +0.000240] ohci-pci 0000:00:16.0: OHCI PCI host controller
                      [  +0.000005] ohci-pci 0000:00:16.0: new USB bus registered, assigned bus number 7
                      [  +0.000014] ohci-pci 0000:00:16.0: irq 18, io mem 0xfe6f3000
                      [  +0.063660] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.04
                      [  +0.000001] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
                      [  +0.000001] usb usb7: Product: OHCI PCI host controller
                      [  +0.000001] usb usb7: Manufacturer: Linux 5.4.0-84-generic ohci_hcd
                      [  +0.000001] usb usb7: SerialNumber: 0000:00:16.0
                      [  +0.000096] hub 7-0:1.0: USB hub found
                      [  +0.000011] hub 7-0:1.0: 4 ports detected
                      [  +0.000168] ohci-platform: OHCI generic platform driver
                      [  +0.000012] uhci_hcd: USB Universal Host Controller Interface driver
                      [  +0.000048] i8042 kbd: probe of 00:02 failed with error -16
                      [  +0.000017] i8042: PNP: PS/2 Controller [PNP0f03:PS2M] at 0x60,0x64 irq 12
                      [  +0.000001] i8042: PNP: PS/2 controller doesn't have KBD irq; using default 1
                      [  +0.000668] serio: i8042 KBD port at 0x60,0x64 irq 1
                      [  +0.000005] serio: i8042 AUX port at 0x60,0x64 irq 12
                      [  +0.000080] mousedev: PS/2 mouse device common for all mice
                      [  +0.000133] rtc_cmos 00:01: RTC can wake from S4
                      [  +0.000171] rtc_cmos 00:01: registered as rtc0
                      [  +0.000016] rtc_cmos 00:01: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
                      [  +0.000007] i2c /dev entries driver
                      [  +0.000049] device-mapper: uevent: version 1.0.3
                      [  +0.000059] device-mapper: ioctl: 4.41.0-ioctl (2019-09-16) initialised: dm-devel@redhat.com
                      [  +0.000016] platform eisa.0: Probing EISA bus 0
                      [  +0.000002] platform eisa.0: EISA: Cannot allocate resource for mainboard
                      [  +0.000002] platform eisa.0: Cannot allocate resource for EISA slot 1
                      [  +0.000001] platform eisa.0: Cannot allocate resource for EISA slot 2
                      [  +0.000001] platform eisa.0: Cannot allocate resource for EISA slot 3
                      [  +0.000001] platform eisa.0: Cannot allocate resource for EISA slot 4
                      [  +0.000001] platform eisa.0: Cannot allocate resource for EISA slot 5
                      [  +0.000001] platform eisa.0: Cannot allocate resource for EISA slot 6
                      [  +0.000001] platform eisa.0: Cannot allocate resource for EISA slot 7
                      [  +0.000001] platform eisa.0: Cannot allocate resource for EISA slot 8
                      [  +0.000001] platform eisa.0: EISA: Detected 0 cards
                      [  +0.000058] ledtrig-cpu: registered to indicate activity on CPUs
                      [  +0.000045] drop_monitor: Initializing network drop monitor service
                      [  +0.000170] NET: Registered protocol family 10
                      [  +0.003827] Segment Routing with IPv6
                      [  +0.000026] NET: Registered protocol family 17
                      [  +0.000039] Key type dns_resolver registered
                      [  +0.000266] RAS: Correctable Errors collector initialized.
                      [  +0.000003] microcode: microcode updated early to new patch_level=0x010000db
                      [  +0.000025] microcode: CPU0: patch_level=0x010000db
                      [  +0.000004] microcode: CPU1: patch_level=0x010000db
                      [  +0.000005] microcode: CPU2: patch_level=0x010000db
                      [  +0.000006] microcode: CPU3: patch_level=0x010000db
                      [  +0.000030] microcode: Microcode Update Driver: v2.2.
                      [  +0.000004] IPI shorthand broadcast: enabled
                      [  +0.000006] sched_clock: Marking stable (1524634188, 260642)->(1530378698, -5483868)
                      [  +0.000065] registered taskstats version 1
                      [  +0.000009] Loading compiled-in X.509 certificates
                      [  +0.001202] Loaded X.509 cert 'Build time autogenerated kernel key: 2e5a5cfcbde5ccff8872bb2bdda0161154af6a9e'
                      [  +0.001116] Loaded X.509 cert 'Canonical Ltd. Live Patch Signing: 14df34d1a87cf37625abec039ef2bf521249b969'
                      [  +0.001095] Loaded X.509 cert 'Canonical Ltd. Kernel Module Signing: 88f752e560a1e0737e31163a466ad7b70a850c19'
                      [  +0.000043] zswap: loaded using pool lzo/zbud
                      [  +0.000101] Key type ._fscrypt registered
                      [  +0.000001] Key type .fscrypt registered
                      [  +0.003386] Key type big_key registered
                      [  +0.001613] Key type encrypted registered
                      [  +0.000003] AppArmor: AppArmor sha1 policy hashing enabled
                      [  +0.000007] ima: No TPM chip found, activating TPM-bypass!
                      [  +0.000005] ima: Allocated hash algorithm: sha1
                      [  +0.000007] ima: No architecture policies found
                      [  +0.000007] evm: Initialising EVM extended attributes:
                      [  +0.000001] evm: security.selinux
                      [  +0.000000] evm: security.SMACK64
                      [  +0.000001] evm: security.SMACK64EXEC
                      [  +0.000000] evm: security.SMACK64TRANSMUTE
                      [  +0.000000] evm: security.SMACK64MMAP
                      [  +0.000001] evm: security.apparmor
                      [  +0.000000] evm: security.ima
                      [  +0.000001] evm: security.capability
                      [  +0.000000] evm: HMAC attrs: 0x1
                      [  +0.000327] PM:   Magic number: 10:105:341
                      [  +0.000134] rtc_cmos 00:01: setting system clock to 2022-06-27T17:18:56 UTC (1656350336)
                      [  +0.000138] acpi_cpufreq: overriding BIOS provided _PSD data
                      [  +0.002236] Freeing unused decrypted memory: 2040K
                      [  +0.000852] Freeing unused kernel image memory: 2716K
                      [  +0.033479] Write protecting the kernel read-only data: 22528k
                      [  +0.000786] Freeing unused kernel image memory: 2008K
                      [  +0.000401] Freeing unused kernel image memory: 1160K
                      [  +0.010615] usb 2-3: new high-speed USB device number 2 using ehci-pci
                      [  +0.003763] x86/mm: Checked W+X mappings: passed, no W+X pages found.
                      [  +0.000003] Run /init as init process
                      [  +0.013105] random: systemd-udevd: uninitialized urandom read (16 bytes read)
                      [  +0.000095] random: systemd-udevd: uninitialized urandom read (16 bytes read)
                      [  +0.000006] random: systemd-udevd: uninitialized urandom read (16 bytes read)
                      [  +0.068209] ahci 0000:00:11.0: version 3.0
                      [  +0.000380] ahci 0000:00:11.0: AHCI 0001.0200 32 slots 6 ports 3 Gbps 0x3f impl SATA mode
                      [  +0.000003] ahci 0000:00:11.0: flags: 64bit ncq sntf ilck pm led clo pmp pio slum part
                      [  +0.002111] piix4_smbus 0000:00:14.0: SMBus Host Controller at 0xb00, revision 0
                      [  +0.000007] piix4_smbus 0000:00:14.0: Using register 0x2c for SMBus port selection
                      [  +0.000292] piix4_smbus 0000:00:14.0: Auxiliary SMBus Host Controller at 0xb20
                      [  +0.004479] scsi host0: ahci
                      [  +0.000562] scsi host1: ahci
                      [  +0.000135] scsi host2: ahci
                      [  +0.001022] scsi host3: ahci
                      [  +0.000451] libphy: r8169: probed
                      [  +0.000503] r8169 0000:03:00.0 eth0: RTL8168e/8111e, 90:fb:a6:8a:97:21, XID 2c1, IRQ 26
                      [  +0.000002] r8169 0000:03:00.0 eth0: jumbo features [frames: 9200 bytes, tx checksumming: ko]
                      [  +0.000045] scsi host4: ahci
                      [  +0.000506] scsi host5: ahci
                      [  +0.000064] ata1: SATA max UDMA/133 abar m1024@0xfe6ffc00 port 0xfe6ffd00 irq 25
                      [  +0.000002] ata2: SATA max UDMA/133 abar m1024@0xfe6ffc00 port 0xfe6ffd80 irq 25
                      [  +0.000002] ata3: SATA max UDMA/133 abar m1024@0xfe6ffc00 port 0xfe6ffe00 irq 25
                      [  +0.000002] ata4: SATA max UDMA/133 abar m1024@0xfe6ffc00 port 0xfe6ffe80 irq 25
                        alfa budiman
                        [  +0.000002] ata5: SATA max UDMA/133 abar m1024@0xfe6ffc00 port 0xfe6fff00 irq 25
                        [  +0.000002] ata6: SATA max UDMA/133 abar m1024@0xfe6ffc00 port 0xfe6fff80 irq 25
                        [  +0.018704] r8169 0000:03:00.0 enp3s0: renamed from eth0
                        [  +0.189661] usb 7-1: new low-speed USB device number 2 using ohci-pci
                        [  +0.104844] ata2: SATA link down (SStatus 0 SControl 300)
                        [  +0.000049] ata3: SATA link down (SStatus 0 SControl 300)
                        [  +0.000045] ata4: SATA link down (SStatus 0 SControl 300)
                        [  +0.003893] ata6: SATA link down (SStatus 0 SControl 300)
                        [Jun27 13:19] usb 2-3: New USB device found, idVendor=0bda, idProduct=0182, bcdDevice=81.9c
                        [  +0.000003] usb 2-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
                        [  +0.000001] usb 2-3: Product: USB2.0-CRW
                        [  +0.000001] usb 2-3: Manufacturer: Generic
                        [  +0.000001] usb 2-3: SerialNumber: 20060413092100000
                        [  +0.055158] tsc: Refined TSC clocksource calibration: 2800.050 MHz
                        [  +0.000006] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x285c6fcfedc, max_idle_ns: 440795225956 ns
                        [  +0.000016] clocksource: Switched to clocksource tsc
                        [  +0.021221] usb 7-1: New USB device found, idVendor=413c, idProduct=2107, bcdDevice= 1.15
                        [  +0.000002] usb 7-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
                        [  +0.000001] usb 7-1: Product: Dell USB Entry Keyboard
                        [  +0.000001] usb 7-1: Manufacturer: Dell
                        [  +0.005893] hidraw: raw HID events driver (C) Jiri Kosina
                        [  +0.014201] usbcore: registered new interface driver usbhid
                        [  +0.000001] usbhid: USB HID core driver
                        [  +0.002417] hid-generic 0003:0BDA:0182.0001: hiddev0,hidraw0: USB HID v1.11 Device [Generic USB2.0-CRW] on usb-0000:00:13.2-3/input1
                        [  +0.000194] input: Dell Dell USB Entry Keyboard as /devices/pci0000:00/0000:00:16.0/usb7/7-1/7-1:1.0/0003:413C:2107.0002/input/input5
                        [  +0.040062] ata5: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
                        [  +0.000022] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
                        [  +0.001911] ata5.00: ATAPI: ATAPI   DVD A  DH16AASH, SA15, max UDMA/100
                        [  +0.001107] ata5.00: configured for UDMA/100
                        [  +0.006108] ata1.00: ATA-8: WDC WD10EADS-22M2B0, 01.00A01, max UDMA/133
                        [  +0.000001] ata1.00: 1953525168 sectors, multi 0: LBA48 NCQ (depth 32), AA
                        [  +0.002982] ata1.00: configured for UDMA/133
                        [  +0.000168] scsi 0:0:0:0: Direct-Access     ATA      WDC WD10EADS-22M 0A01 PQ: 0 ANSI: 5
                        [  +0.000194] sd 0:0:0:0: Attached scsi generic sg0 type 0
                        [  +0.000071] sd 0:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
                        [  +0.000024] sd 0:0:0:0: [sda] Write Protect is off
                        [  +0.000002] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
                        [  +0.000016] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
                        [  +0.001458] scsi 4:0:0:0: CD-ROM            ATAPI    DVD A  DH16AASH  SA15 PQ: 0 ANSI: 5
                        [  +0.006006] hid-generic 0003:413C:2107.0002: input,hidraw1: USB HID v1.10 Keyboard [Dell Dell USB Entry Keyboard] on usb-0000:00:16.0-1/input0
                        [  +0.015733]  sda: sda1
                        [  +0.016380] sd 0:0:0:0: [sda] Attached SCSI disk
                        [  +0.039410] sr 4:0:0:0: [sr0] scsi3-mmc drive: 48x/48x writer dvd-ram cd/rw xa/form2 cdda tray
                        [  +0.000002] cdrom: Uniform CD-ROM driver Revision: 3.20
                        [  +0.048430] sr 4:0:0:0: Attached scsi CD-ROM sr0
                        [  +0.000082] sr 4:0:0:0: Attached scsi generic sg1 type 5
                        [  +0.107877] usb 5-4: new low-speed USB device number 2 using ohci-pci
                        [  +0.108013] usb 3-2: new high-speed USB device number 3 using ehci-pci
                        [  +0.091203] usb 5-4: New USB device found, idVendor=046d, idProduct=c063, bcdDevice=57.00
                        [  +0.000002] usb 5-4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
                        [  +0.000001] usb 5-4: Product: DELL USB Laser Mouse
                        [  +0.000001] usb 5-4: Manufacturer: DELL
                        [  +0.009091] input: DELL DELL USB Laser Mouse as /devices/pci0000:00/0000:00:13.0/usb5/5-4/5-4:1.0/0003:046D:C063.0003/input/input6
                        [  +0.000088] hid-generic 0003:046D:C063.0003: input,hidraw2: USB HID v1.10 Mouse [DELL DELL USB Laser Mouse] on usb-0000:00:13.0-4/input0
                        [  +0.059938] usb 3-2: New USB device found, idVendor=04e8, idProduct=6860, bcdDevice= c.00
                        [  +0.000002] usb 3-2: New USB device strings: Mfr=7, Product=8, SerialNumber=9
                        [  +0.000001] usb 3-2: Product: SAMSUNG_Android
                        [  +0.000001] usb 3-2: Manufacturer: SAMSUNG
                        [  +0.000001] usb 3-2: SerialNumber: R5CN90RVXBP
                        [  +0.255876] usb-storage 2-3:1.0: USB Mass Storage device detected
                        [  +0.000132] scsi host6: usb-storage 2-3:1.0
                        [  +0.000105] usbcore: registered new interface driver usb-storage
                        [  +0.001668] usbcore: registered new interface driver uas
                        [  +0.087526] fbcon: Taking over console
                        [  +0.000106] Console: switching to colour frame buffer device 175x65
                        [  +0.100328] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
                        [  +0.845929] scsi 6:0:0:0: Direct-Access     Generic- Compact Flash    1.00 PQ: 0 ANSI: 0 CCS
                        [  +0.003220] scsi 6:0:0:1: Direct-Access     Generic- xD-Picture       1.00 PQ: 0 ANSI: 0 CCS
                        [  +0.003134] scsi 6:0:0:2: Direct-Access     Generic- SD/MMC           1.00 PQ: 0 ANSI: 0 CCS
                        [  +0.003374] scsi 6:0:0:3: Direct-Access     Generic- MS/MS-Pro/HG     1.00 PQ: 0 ANSI: 0 CCS
                        [  +0.003122] scsi 6:0:0:4: Direct-Access     Generic- MicroSD          1.00 PQ: 0 ANSI: 0 CCS
                        [  +0.000187] sd 6:0:0:0: Attached scsi generic sg2 type 0
                        [  +0.000103] sd 6:0:0:1: Attached scsi generic sg3 type 0
                        [  +0.000111] sd 6:0:0:2: Attached scsi generic sg4 type 0
                        [  +0.000100] sd 6:0:0:3: Attached scsi generic sg5 type 0
                        [  +0.000113] sd 6:0:0:4: Attached scsi generic sg6 type 0
                        [  +0.049382] sd 6:0:0:2: [sdd] Attached SCSI removable disk
                        [  +0.005747] sd 6:0:0:3: [sde] Attached SCSI removable disk
                        [  +0.005490] sd 6:0:0:1: [sdc] Attached SCSI removable disk
                        [  +0.008178] sd 6:0:0:0: [sdb] Attached SCSI removable disk
                        [  +0.005680] sd 6:0:0:4: [sdf] Attached SCSI removable disk
                        [  +0.328394] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
                        [  +0.000126] systemd[1]: Detected architecture x86-64.
                        [  +0.020100] systemd[1]: Set hostname to <modalaiwork-DX4320>.
                        [  +1.911474] random: crng init done
                        [  +0.000003] random: 7 urandom warning(s) missed due to ratelimiting
                        [  +0.332315] systemd[1]: Created slice User and Session Slice.
                        [  +0.000045] systemd[1]: Reached target Remote File Systems.
                        [  +0.000016] systemd[1]: Reached target User and Group Name Lookups.
                        [  +0.000133] systemd[1]: Created slice System Slice.
                        [  +0.000092] systemd[1]: Listening on Journal Socket.
                        [  +0.000055] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
                        [  +0.000050] systemd[1]: Listening on fsck to fsckd communication Socket.
                        [  +0.111421] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
                        [  +0.431780] lp: driver loaded but no devices found
                        [  +0.045726] ppdev: user-space parallel port driver
                        [  +0.142271] Adding 2097148k swap on /swapfile.  Priority:-2 extents:6 across:2260988k FS
                        [  +0.072895] systemd-journald[283]: Received request to flush runtime journal from PID 1
                        [  +5.759461] [drm] radeon kernel modesetting enabled.
                        [  +0.000091] radeon 0000:01:05.0: remove_conflicting_pci_framebuffers: bar 0: 0xd0000000 -> 0xdfffffff
                        [  +0.000003] radeon 0000:01:05.0: remove_conflicting_pci_framebuffers: bar 2: 0xfe8f0000 -> 0xfe8fffff
                        [  +0.000001] radeon 0000:01:05.0: remove_conflicting_pci_framebuffers: bar 5: 0xfe700000 -> 0xfe7fffff
                        [  +0.000002] checking generic (d0000000 5b0000) vs hw (d0000000 10000000)
                        [  +0.000001] fb0: switching to radeondrmfb from VESA VGA
                        [  +0.000088] Console: switching to colour dummy device 80x25
                        [  +0.000016] radeon 0000:01:05.0: vgaarb: deactivate vga console
                        [  +0.000210] [drm] initializing kernel modesetting (RS880 0x1002:0x9715 0x1025:0x0444 0x00).
                        [  +0.000026] resource sanity check: requesting [mem 0x000c0000-0x000dffff], which spans more than PCI Bus 0000:00 [mem 0x000d0000-0x000dffff window]
                        [  +0.000005] caller pci_map_rom+0x71/0x1d0 mapping multiple BARs
                        [  +0.001167] ATOM BIOS: 113
                        [  +0.000017] radeon 0000:01:05.0: VRAM: 256M 0x00000000C0000000 - 0x00000000CFFFFFFF (256M used)
                        [  +0.000001] radeon 0000:01:05.0: GTT: 512M 0x00000000A0000000 - 0x00000000BFFFFFFF
                        [  +0.000005] [drm] Detected VRAM RAM=256M, BAR=256M
                        [  +0.000001] [drm] RAM width 32bits DDR
                        [  +0.000098] [TTM] Zone  kernel: Available graphics memory: 2914450 KiB
                        [  +0.000001] [TTM] Zone   dma32: Available graphics memory: 2097152 KiB
                        [  +0.000000] [TTM] Initializing pool allocator
                        [  +0.000004] [TTM] Initializing DMA pool allocator
                        [  +0.000015] [drm] radeon: 256M of VRAM memory ready
                        [  +0.000001] [drm] radeon: 512M of GTT memory ready.
                        [  +0.000006] [drm] Loading RS780 Microcode
                        [  +0.094017] [drm] radeon: power management initialized
                        [  +0.013669] [drm] GART: num cpu pages 131072, num gpu pages 131072
                        [  +0.015579] [drm] PCIE GART of 512M enabled (table at 0x00000000C0146000).
                        [  +0.000053] radeon 0000:01:05.0: WB enabled
                        [  +0.000003] radeon 0000:01:05.0: fence driver on ring 0 use gpu addr 0x00000000a0000c00 and cpu addr 0x000000003695b0bd
                        [  +0.002186] radeon 0000:01:05.0: fence driver on ring 5 use gpu addr 0x00000000c0056038 and cpu addr 0x0000000026dc017b
                        [  +0.000001] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
                        [  +0.000001] [drm] Driver supports precise vblank timestamp query.
                        [  +0.000001] radeon 0000:01:05.0: radeon: MSI limited to 32-bit
                        [  +0.000013] [drm] radeon: irq initialized.
                        [  +0.005089] cdc_acm 3-2:1.1: ttyACM0: USB ACM device
                        [  +0.000850] usbcore: registered new interface driver cdc_acm
                        [  +0.000001] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
                        [  +0.026195] [drm] ring test on 0 succeeded in 1 usecs
                        [  +0.000044] kvm: Nested Virtualization enabled
                        [  +0.000007] kvm: Nested Paging enabled
                        [  +0.029924] MCE: In-kernel MCE decoding enabled.
                        [  +0.032841] EDAC amd64: Node 0: DRAM ECC disabled.
                        [  +0.000002] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
                                       Either enable ECC checking or force module loading by setting 'ecc_enable_override'.
                                       (Note that use of the override may cause unknown side effects.)
                        [  +0.111826] [drm] ring test on 5 succeeded in 1 usecs
                        [  +0.000004] [drm] UVD initialized successfully.
                        [  +0.000361] [drm] ib test on ring 0 succeeded in 0 usecs
                        [  +0.197537] EDAC amd64: Node 0: DRAM ECC disabled.
                        [  +0.052019] EDAC amd64: Node 0: DRAM ECC disabled.
                        [  +0.031967] EDAC amd64: Node 0: DRAM ECC disabled.
                        [  +0.023584] input: HDA ATI HDMI HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:05.1/sound/card1/input7
                        [  +0.356144] [drm] ib test on ring 5 succeeded
                        [  +0.000417] [drm] Radeon Display Connectors
                        [  +0.000001] [drm] Connector 0:
                        [  +0.000001] [drm]   VGA-1
                        [  +0.000001] [drm]   DDC: 0x7e40 0x7e40 0x7e44 0x7e44 0x7e48 0x7e48 0x7e4c 0x7e4c
                        [  +0.000000] [drm]   Encoders:
                        [  +0.000001] [drm]     CRT1: INTERNAL_KLDSCP_DAC1
                        [  +0.000000] [drm] Connector 1:
                        [  +0.000001] [drm]   HDMI-A-1
                        [  +0.000000] [drm]   HPD3
                        [  +0.000001] [drm]   DDC: 0x7e50 0x7e50 0x7e54 0x7e54 0x7e58 0x7e58 0x7e5c 0x7e5c
                        [  +0.000001] [drm]   Encoders:
                        [  +0.000000] [drm]     DFP3: INTERNAL_KLDSCP_LVTMA
                        [  +0.047690] [drm] fb mappable at 0xD0247000
                        [  +0.000001] [drm] vram apper at 0xD0000000
                        [  +0.000001] [drm] size 8294400
                        [  +0.000000] [drm] fb depth is 24
                        [  +0.000000] [drm]    pitch is 7680
                        [  +0.000088] fbcon: radeondrmfb (fb0) is primary device
                        [  +0.000064] Console: switching to colour frame buffer device 240x67
                        [  +0.000038] radeon 0000:01:05.0: fb0: radeondrmfb frame buffer device
                        [  +0.015804] [drm] Initialized radeon 2.50.0 20080528 for 0000:01:05.0 on minor 0
                        [  +0.672150] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC662 rev1: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:line
                        [  +0.000002] snd_hda_codec_realtek hdaudioC0D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
                        [  +0.000002] snd_hda_codec_realtek hdaudioC0D0:    hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
                        [  +0.000001] snd_hda_codec_realtek hdaudioC0D0:    mono: mono_out=0x0
                        [  +0.000001] snd_hda_codec_realtek hdaudioC0D0:    dig-out=0x1e/0x0
                        [  +0.000001] snd_hda_codec_realtek hdaudioC0D0:    inputs:
                        [  +0.000001] snd_hda_codec_realtek hdaudioC0D0:      Front Mic=0x19
                        [  +0.000002] snd_hda_codec_realtek hdaudioC0D0:      Rear Mic=0x18
                        [  +0.000001] snd_hda_codec_realtek hdaudioC0D0:      Line=0x1a
                        [  +0.010569] input: HDA ATI SB Front Mic as /devices/pci0000:00/0000:00:14.2/sound/card0/input8
                        [  +0.000058] input: HDA ATI SB Rear Mic as /devices/pci0000:00/0000:00:14.2/sound/card0/input9
                        [  +0.000045] input: HDA ATI SB Line as /devices/pci0000:00/0000:00:14.2/sound/card0/input10
                        [  +0.000043] input: HDA ATI SB Line Out as /devices/pci0000:00/0000:00:14.2/sound/card0/input11
                        [  +0.000049] input: HDA ATI SB Front Headphone as /devices/pci0000:00/0000:00:14.2/sound/card0/input12
                        [  +0.323497] audit: type=1400 audit(1656350350.228:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/snapd/snap-confine" pid=434 comm="apparmor_parser"
                        [  +0.000006] audit: type=1400 audit(1656350350.228:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/snapd/snap-confine//mount-namespace-capture-helper" pid=434 comm="apparmor_parser"
                        [  +0.008743] audit: type=1400 audit(1656350350.236:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/man" pid=427 comm="apparmor_parser"
                        [  +0.000004] audit: type=1400 audit(1656350350.236:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_filter" pid=427 comm="apparmor_parser"
                        [  +0.000004] audit: type=1400 audit(1656350350.236:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_groff" pid=427 comm="apparmor_parser"
                        [  +0.098466] audit: type=1400 audit(1656350350.336:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/cups-browsed" pid=600 comm="apparmor_parser"
                        [  +0.011046] audit: type=1400 audit(1656350350.348:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/ippusbxd" pid=606 comm="apparmor_parser"
                        [  +0.004226] audit: type=1400 audit(1656350350.352:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/evince" pid=425 comm="apparmor_parser"
                        [  +0.000004] audit: type=1400 audit(1656350350.352:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/evince//sanitized_helper" pid=425 comm="apparmor_parser"
                        [  +0.000002] audit: type=1400 audit(1656350350.352:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/evince-previewer" pid=425 comm="apparmor_parser"
                        [  +0.342988] usb 3-2: USB disconnect, device number 3
                        [  +0.579709] usb 3-2: new high-speed USB device number 4 using ehci-pci
                        [  +0.161417] usb 3-2: New USB device found, idVendor=04e8, idProduct=6864, bcdDevice= c.00
                        [  +0.000003] usb 3-2: New USB device strings: Mfr=7, Product=8, SerialNumber=9
                        [  +0.429278] usbcore: registered new interface driver cdc_ether
                        [  +0.046172] rndis_host 3-2:1.0 usb0: register 'rndis_host' at usb-0000:00:16.2-2, RNDIS device, 0a:36:05:e6:3d:d5
                        [  +0.000029] usbcore: registered new interface driver rndis_host
                        [  +0.002925] rndis_host 3-2:1.0 enp0s22f2u2: renamed from usb0
                        [ +10.573909] RTL8211DN Gigabit Ethernet r8169-300:00: attached PHY driver [RTL8211DN Gigabit Ethernet] (mii_bus:phy_addr=r8169-300:00, irq=IGNORE)
                        [  +0.283201] r8169 0000:03:00.0 enp3s0: Link is Down
                        [Jun27 13:23] rfkill: input handler disabled
                        [Jun27 13:25] kauditd_printk_skb: 38 callbacks suppressed
                        [  +0.000002] audit: type=1400 audit(1656350713.488:50): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="snap.gnome-characters.hook.configure" pid=2978 comm="apparmor_parser"
                        [  +0.530359] audit: type=1400 audit(1656350714.023:51): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="snap.gnome-characters.gnome-characters" pid=2977 comm="apparmor_parser"
                        [  +0.424940] audit: type=1400 audit(1656350714.447:52): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="snap-update-ns.gnome-characters" pid=2976 comm="apparmor_parser"
                        [  +5.368211] audit: type=1400 audit(1656350719.804:53): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="snap.gnome-calculator.hook.configure" pid=2984 comm="apparmor_parser"
                        [  +1.009739] audit: type=1400 audit(1656350720.815:54): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="snap.gnome-characters.gnome-characters" pid=2986 comm="apparmor_parser"
                        [  +0.083001] audit: type=1400 audit(1656350720.899:55): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="snap.gnome-calculator.gnome-calculator" pid=2983 comm="apparmor_parser"
                        [  +0.376853] audit: type=1400 audit(1656350721.274:56): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="snap.gnome-characters.hook.configure" pid=2987 comm="apparmor_parser"
                        [  +0.782208] audit: type=1400 audit(1656350722.058:57): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="snap-update-ns.gnome-calculator" pid=2982 comm="apparmor_parser"
                        [  +0.040317] audit: type=1400 audit(1656350722.098:58): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="snap-update-ns.gnome-characters" pid=2985 comm="apparmor_parser"
                        [  +0.183722] audit: type=1400 audit(1656350722.281:59): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="snap.gnome-logs.gnome-logs" pid=3006 comm="apparmor_parser"
                        [  +0.120547] audit: type=1400 audit(1656350722.401:60): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="snap.gnome-logs.hook.configure" pid=3013 comm="apparmor_parser"
                        [  +0.354577] audit: type=1400 audit(1656350722.753:61): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="snap.gnome-system-monitor.hook.configure" pid=3016 comm="apparmor_parser"
                        [  +0.138574] audit: type=1400 audit(1656350722.893:62): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="snap-update-ns.gnome-logs" pid=2988 comm="apparmor_parser"
                        [ +28.901058] kauditd_printk_skb: 2 callbacks suppressed
                        [  +0.000002] audit: type=1400 audit(1656350751.787:65): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="snap.gnome-calculator.hook.configure" pid=3135 comm="apparmor_parser"
                        [  +0.697752] audit: type=1400 audit(1656350752.483:66): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="snap.gnome-calculator.gnome-calculator" pid=3134 comm="apparmor_parser"
                        [  +0.302207] audit: type=1400 audit(1656350752.787:67): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="snap.gnome-logs.gnome-logs" pid=3137 comm="apparmor_parser"
                        [  +0.048155] audit: type=1400 audit(1656350752.835:68): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="snap.gnome-logs.hook.configure" pid=3138 comm="apparmor_parser"
                        [  +0.475066] audit: type=1400 audit(1656350753.307:69): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="snap-update-ns.gnome-logs" pid=3136 comm="apparmor_parser"
                        [  +0.199649] audit: type=1400 audit(1656350753.507:70): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="snap-update-ns.gnome-calculator" pid=3133 comm="apparmor_parser"
                        [  +0.158183] audit: type=1400 audit(1656350753.667:71): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="snap.gnome-system-monitor.hook.configure" pid=3141 comm="apparmor_parser"
                        [  +0.541208] audit: type=1400 audit(1656350754.207:72): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="snap.gnome-system-monitor.gnome-system-monitor" pid=3140 comm="apparmor_parser"
                        [  +0.446943] audit: type=1400 audit(1656350754.655:73): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="snap-update-ns.gnome-system-monitor" pid=3139 comm="apparmor_parser"
                        [Jun27 13:28] sd 6:0:0:4: [sdf] 31176704 512-byte logical blocks: (16.0 GB/14.9 GiB)
                        [  +0.026437]  sdf: sdf1 sdf2
                        [  +0.959113] EXT4-fs (sdf2): recovery complete
                        [  +0.006581] EXT4-fs (sdf2): mounted filesystem with ordered data mode. Opts: (null)
                        [  +0.032088] FAT-fs (sdf1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
                        [Jun27 13:30] EXT4-fs (sdf2): resizing filesystem from 2612992 to 3831296 blocks
                        [  +0.413339] EXT4-fs (sdf2): resized filesystem to 3831296
                        [Jun27 13:40] usb 3-2: USB disconnect, device number 4
                        [  +0.002323] rndis_host 3-2:1.0 enp0s22f2u2: unregister 'rndis_host' usb-0000:00:16.2-2, RNDIS device
                        [Jun27 17:13] perf: interrupt took too long (2510 > 2500), lowering kernel.perf_event_max_sample_rate to 79500
                        [Jun28 13:00] usb 3-2: new high-speed USB device number 5 using ehci-pci
                        [  +0.161290] usb 3-2: New USB device found, idVendor=04e8, idProduct=6860, bcdDevice= c.00
                        [  +0.000008] usb 3-2: New USB device strings: Mfr=7, Product=8, SerialNumber=9
                        [  +0.000005] usb 3-2: Product: SAMSUNG_Android
                        [  +0.000004] usb 3-2: Manufacturer: SAMSUNG
                        [  +0.000003] usb 3-2: SerialNumber: R5CN90RVXBP
                        [  +0.004207] cdc_acm 3-2:1.1: ttyACM0: USB ACM device
                        [Jun28 13:01] usb 3-2: USB disconnect, device number 5
                        [  +1.298997] usb 3-2: new high-speed USB device number 6 using ehci-pci
                        [  +0.159383] usb 3-2: New USB device found, idVendor=04e8, idProduct=6864, bcdDevice= c.00
                        [  +0.000003] usb 3-2: Manufacturer: SAMSUNG
                        [  +0.000004] usb 3-2: SerialNumber: R5CN90RVXBP
                        [  +0.007863] rndis_host 3-2:1.0 usb0: register 'rndis_host' at usb-0000:00:16.2-2, RNDIS device, 9e:81:fe:44:1b:6a
                        [  +0.019783] rndis_host 3-2:1.0 enp0s22f2u2: renamed from usb0
                        [Jun28 13:06] usb 3-2: USB disconnect, device number 6
                        [  +0.002601] rndis_host 3-2:1.0 enp0s22f2u2: unregister 'rndis_host' usb-0000:00:16.2-2, RNDIS device
                        [ +15.683247] usb 2-5: new high-speed USB device number 4 using ehci-pci
                        [  +0.161498] usb 2-5: New USB device found, idVendor=04e8, idProduct=6860, bcdDevice= c.00
                        [  +0.000008] usb 2-5: New USB device strings: Mfr=7, Product=8, SerialNumber=9
                        [  +0.000005] usb 2-5: Product: SAMSUNG_Android
                        [  +0.000003] usb 2-5: Manufacturer: SAMSUNG
                        [  +0.000004] usb 2-5: SerialNumber: R5CN90RVXBP
                        [  +0.004356] cdc_acm 2-5:1.1: ttyACM0: USB ACM device
                        [Jun28 13:07] usb 2-5: USB disconnect, device number 4
                        [  +2.369281] usb 3-2: new high-speed USB device number 7 using ehci-pci
                        [  +0.161887] usb 3-2: New USB device found, idVendor=04e8, idProduct=6860, bcdDevice= c.00
                        [  +0.003444] cdc_acm 3-2:1.1: ttyACM0: USB ACM device
                        [  +3.231564] usb 3-2: USB disconnect, device number 7
                        [ +26.690556] usb 2-5: new high-speed USB device number 5 using ehci-pci
                        [  +0.161884] usb 2-5: New USB device found, idVendor=04e8, idProduct=6860, bcdDevice= c.00
                        [  +0.000007] usb 2-5: New USB device strings: Mfr=7, Product=8, SerialNumber=9
                        [  +0.000004] usb 2-5: Manufacturer: SAMSUNG
                        [  +0.000003] usb 2-5: SerialNumber: R5CN90RVXBP
                        [  +0.006341] cdc_acm 2-5:1.1: ttyACM0: USB ACM device
                          @alfa-budiman Well I'm not seeing anything that looks like the RB5 being detected. Might be worth sending in one of your drones for inspection: https://www.modalai.com/pages/rma
                          • Dobry KolaczD Offline
                            Dobry Kolacz
                            wrote on last edited by Dobry Kolacz
                            #26
                            Are you 100% sure your USB C cable is fully plugged into the drone? Some cables are a bit too fat and can't fully seat into the port.
                            • Guillermo AlbaG Offline
                              Guillermo Alba
                              Hello, I have the same problem you are talking about here and I am unable to find a solution, how did you manage to fix it?
                              I have a VM with ubuntu installed and the first image shows that it does not recognize it and in the second image you can see how windows does not recognize the device.
                                @Dekra-Lab What does lsusb look like on the Ubuntu VM with the drone plugged in via. USB-C
                                  Guillermo Alba
                                  This is what you see, connected as you indicate
                                    @Dekra-Lab Okay so the RB5 is not being seen at all by the VM but is seen by the Windows machine running the VM. It sounds like you'll need to enable USB pass-through in your VM to allow it to access USB devices connected to your host machine.
                                    • alfa budimanA Offline
                                      alfa budiman
                                      I encountered this problem a while ago and its just a matter of a usb device on your virtual machine
                                      You can also download adb for windows to verify that the drone is detected by the computer. If it's not detected by your computer at all (on host OS), then it won't be detected by your VM.
