    Two USB cameras
    VOXL
    • wilkinsafW
      wilkinsaf ModalAI Team
      I made a pull request earlier on what I THOUGHT was support for two usb (uvc) cameras using two instances of voxl-uvc-server to communicate to the two cameras.
      However, it did not work. In accordance with what @Eric-Katzfey said in the pull request: "I don't think libuvc allows it" Which from my testing, proves him right.
      My question is: If we wanted two fold:
      1. Is there a way to stream two usb cameras? I was looking at this post and it seems like most of the solutions are a bit hacked together (lowering video bandwidth, etc...)
      2. We were thinking of taking of the the usb cameras, converting it to a MIPI, and incorporating a Dual Camera Adapter . However, it appears this specific camera adapter only works for RB5 platform. Is there another way we could possibly make this work?
      Thank you
      • Chad SweetC
        Chad Sweet ModalAI Team
        What if you used 2 processes? Would libuvc work with two separate voxl-uvc-server instances?
        never mind, i see that's what you tried
        • Chad SweetC
          Probably a rabbit hole, but you could try to figure out where libuvc fails? Doesn't seem like there is a technical reason it wouldn't work
          wilkinsafW 1 Reply Last reply Reply Quote 0
          • wilkinsafW
            wilkinsaf ModalAI Team @Chad Sweet
            @Chad-Sweet
            That is what I was thinking. I'll check in with the boss and see what he wants to do. Thanks!
