  3. How to install and configure OpenVPN?
37 Posts 2 Posters 11.4k Views 1 Watching
    @Djalma-Ribeiro Okay you may have a slightly older version of the SDK. Go ahead and download the latest SDK from: https://developer.modalai.com/asset/4
    and then follow the instructions here to install:
    https://docs.modalai.com/Qualcomm-Flight-RB5-sdk-installation/
    This way we know you're using the latest SDK. This qgc-ip file was added in a later release
    D Offline
    D Offline
    Djalma Ribeiro
    @tom 😢
    root@qrb5165-rb5:/home/rb5-flight-sdk-1.1.3# ./update-sdk.sh
    bash: ./update-sdk.sh: Permission denied
      @Djalma-Ribeiro Looks like the permissions got lost somewhere along the way, you can use chmod +x update-sdk.sh to make it executable, then try again
      D 1 Reply Last reply
        D Offline
        D Offline
        Djalma Ribeiro
        @tom you are the best! thanks
        • D Djalma Ribeiro
          D Offline
          D Offline
          Djalma Ribeiro
          Well, I managed to update, redid the settings and he is connected to the internet. But I still can't connect the QGC.
          I didn't understand one thing. Why the drone and the pc are online in the "Connectors" of "Networks" but both can't find each other by ping?
          You can only ping if one of them is a Host Connector and the other is a Networks Connector.
          I believe it is not Firewall because I have already disabled it.
          Any idea?
            @Djalma-Ribeiro I have no experience with having an OpenVPN online account and hosting through there so I can't provide any info on any of those settings. We host our own VPN servers using Google Cloud. That doesn't mean you can't do what you're doing, I just have no experience in that area.
            You might get better answers to those questions on the OpenVPN forum (https://forums.openvpn.net/)
            It's possible you have to configure the server's firewall as well to allow traffic on the ports that PX4 uses but that's just a guess
              D Offline
              D Offline
              Djalma Ribeiro
              @tom Is there an easier way to connect the QGC to the drone? Even if on each connection I need to manually inform the ips.
              I need to make the drone connect via LTE/5G urgently.
                @Djalma-Ribeiro We usually recommend just connecting over WiFi before jumping into cellular + VPN. Have you done that yet to familiarize yourself with the process of connecting to QGC?
                  D Offline
                  D Offline
                  Djalma Ribeiro
                  @tom wifi yes
                    @Djalma-Ribeiro As long as you have your VPN set up correctly it should be the exact same idea. The only change is that you will have to specify the IP of your ground station in the qgc-ip file. I can't help too much with the OpenVPN side of things other than what is in our docs.
                      D Offline
                      D Offline
                      Djalma Ribeiro
                      @tom how do i update openvpn in drone?
                        @Djalma-Ribeiro RB5 is running Ubuntu 18.04, so any installation / updating instructions for Ubuntu 18 should also be applicable to RB5
                        • D Offline
                          D Offline
                          Djalma Ribeiro
                          I was able to configure the VPN using this video: https://www.youtube.com/watch?v=IsyNtovozVU
                          How do I make the drone auto-initialize the vpn?
                            @Djalma-Ribeiro You can create a systemd service file and enable it to run on boot and have it execute the OpenVPN connection command.
                            Here is an example on how we have used it in the past on a VOXL:
                            [Unit]
                            After=voxl-time-sync.service
                            Requires=voxl-time-sync.service
                            [Service]
                            Type=forking
                            ExecStartPre=/bin/sleep 2
                            ExecStart=/usr/sbin/openvpn --script-security 2 --daemon --config /etc/openvpn/KEY_FILE
                            [Install]
                            WantedBy=default.target
                            Won't be exactly the same as above but that's the general idea.
