  3. How to install and configure OpenVPN?
37 Posts 2 Posters 11.4k Views 1 Watching
    wrote on last edited by tom
    #18
    @Djalma-Ribeiro The fact that the IP is the same on that OpenVPN screenshot makes me think that you're attempting to use the same key file here as you are on your drone. If that's true, it won't work and the devices will keep kicking each other off the network. You need to use a unique key for each device.
    The first test before you try to connect to QGC would be to connect both devices to the VPN with their unique keys and then attempt to ping from the drone to your pc or from pc to drone. That way you can ensure the two can communicate with each other before you try getting PX4 / QGC involved.
    Once you have the pinging working, you can set the IP of the ground station on your drone in /etc/modalai/qgc-ip.cfg(file name may be slightly different)
    • D Offline
      D Offline
      Djalma Ribeiro
      Now I understand a little more! By the way, thank you very much for your help.
      I have both the pc and the drone online on OpenVPN:
      But neither can find the other by ping.
      Is there anything else I'm forgetting?
        @Djalma-Ribeiro Are you using a windows machine? All of our devices use Ubuntu 18.04 so I don't have much experience with it.
        However on Windows, I know that some of our customers have had to disable all their firewalls in order to allow the traffic to come through.
        D 1 Reply Last reply
          D Offline
          D Offline
          Djalma Ribeiro
          @tom I managed to make the ping work by putting the drone in host and the pc in network.
          Do I have to use UDP or TCP to connect to the QGC?
            @Djalma-Ribeiro By default it'll use UDP. See this page for the next steps: https://docs.modalai.com/Qualcomm-Flight-RB5-user-guide-px4/
            You will have to modify the rb5-net-check service and change the line ExecStart=/usr/bin/rb5-net-check wlan0 192.168 to ExecStart=/usr/bin/rb5-net-check tun0 100.96 in order to tell the drone to wait for the VPN network interface to come up before sending out PX4 packets.
            Then you will have to modify the previously mentioned /etc/modalai/qgc-ip.cfg and adding the IP of your PC on the VPN in order to tell PX4 where to send packets.
            You can also look at : /etc/modalai/full-m0052.config in order to see the PX4 startup config
              D Offline
              D Offline
              Djalma Ribeiro
              @tom I didn't find the file /etc/modalai/qgc-ip.cfg
                @Djalma-Ribeiro Okay you may have a slightly older version of the SDK. Go ahead and download the latest SDK from: https://developer.modalai.com/asset/4
                and then follow the instructions here to install:
                https://docs.modalai.com/Qualcomm-Flight-RB5-sdk-installation/
                This way we know you're using the latest SDK. This qgc-ip file was added in a later release
                  D Offline
                  D Offline
                  Djalma Ribeiro
                  @tom 😢
                  root@qrb5165-rb5:/home/rb5-flight-sdk-1.1.3# ./update-sdk.sh
                  bash: ./update-sdk.sh: Permission denied
                    @Djalma-Ribeiro Looks like the permissions got lost somewhere along the way, you can use chmod +x update-sdk.sh to make it executable, then try again
                      D Offline
                      D Offline
                      Djalma Ribeiro
                      @tom you are the best! thanks
                      • D Djalma Ribeiro
                        D Offline
                        D Offline
                        Djalma Ribeiro
                        Well, I managed to update, redid the settings and he is connected to the internet. But I still can't connect the QGC.
                        I didn't understand one thing. Why the drone and the pc are online in the "Connectors" of "Networks" but both can't find each other by ping?
                        You can only ping if one of them is a Host Connector and the other is a Networks Connector.
                        I believe it is not Firewall because I have already disabled it.
                        Any idea?
                          @Djalma-Ribeiro I have no experience with having an OpenVPN online account and hosting through there so I can't provide any info on any of those settings. We host our own VPN servers using Google Cloud. That doesn't mean you can't do what you're doing, I just have no experience in that area.
                          You might get better answers to those questions on the OpenVPN forum (https://forums.openvpn.net/)
                          It's possible you have to configure the server's firewall as well to allow traffic on the ports that PX4 uses but that's just a guess
                            D Offline
                            D Offline
                            Djalma Ribeiro
                            @tom Is there an easier way to connect the QGC to the drone? Even if on each connection I need to manually inform the ips.
                            I need to make the drone connect via LTE/5G urgently.
                              @Djalma-Ribeiro We usually recommend just connecting over WiFi before jumping into cellular + VPN. Have you done that yet to familiarize yourself with the process of connecting to QGC?
                                D Offline
                                D Offline
                                Djalma Ribeiro
                                @tom wifi yes
                                  @Djalma-Ribeiro As long as you have your VPN set up correctly it should be the exact same idea. The only change is that you will have to specify the IP of your ground station in the qgc-ip file. I can't help too much with the OpenVPN side of things other than what is in our docs.
                                    D Offline
                                    D Offline
                                    Djalma Ribeiro
                                    @tom how do i update openvpn in drone?
                                      @Djalma-Ribeiro RB5 is running Ubuntu 18.04, so any installation / updating instructions for Ubuntu 18 should also be applicable to RB5
                                      • D Offline
                                        D Offline
                                        Djalma Ribeiro
                                        I was able to configure the VPN using this video: https://www.youtube.com/watch?v=IsyNtovozVU
                                        How do I make the drone auto-initialize the vpn?
                                          @Djalma-Ribeiro You can create a systemd service file and enable it to run on boot and have it execute the OpenVPN connection command.
                                          Here is an example on how we have used it in the past on a VOXL:
                                          [Unit]
                                          After=voxl-time-sync.service
                                          Requires=voxl-time-sync.service
                                          [Service]
                                          Type=forking
                                          ExecStartPre=/bin/sleep 2
                                          ExecStart=/usr/sbin/openvpn --script-security 2 --daemon --config /etc/openvpn/KEY_FILE
                                          [Install]
                                          WantedBy=default.target
                                          Won't be exactly the same as above but that's the general idea.
