  3. Which LTE CARRIER SHOULD I ORDER FOR CANADA
cellular
19 Posts 4 Posters 3.2k Views 4 Watching
  • Aldo Castro FreireA Offline
    Aldo Castro Freire
    Yes I followed the instructions. Yes I know the apn carrier of my provider. I used before. Also my wifi set up is on does it matter?
      Aldo Castro Freire
      This is the apn I used: just type ltemobile.apn
      When it ask for it in the configuration.
      https://www.rogers.com/customer/support/article/rogers-lte-apn-settings
      • Aldo Castro FreireA Aldo Castro Freire
        @Aldo-Castro-Freire Can you post the outputs of both systemctl status -l voxl-modem and ifconfig
          Aldo Castro Freire
          these are the outputs:
          Aldo Castro FreireA 1 Reply Last reply
            Aldo Castro Freire
            wait the first one changed:
              Have you tested this SIM card previously? With another phone perhaps to determine that it is activated correctly?
                wrote on last edited by tom
                #15
                Antoher thing to try is to disable the modem startup script using systemctl disable voxl-modem and then rebooting your voxl. After you reboot, ADB back in and run voxl-modem-start.sh. This should allow you to see the script's entire output.
                  Aldo Castro Freire
                  okay that worked, one more question for the openVPN I am new to yocto linux, how do I know if the daemon was able to connect to the openVPN server, my IP still the same.
                    OpenVPN will usually create a new network interface, similar to tun or tun0 and should route traffic through there. If you run ifconfig you will see a list of network interfaces. You will also need to make sure that OpenVPN is starting after you have connected to the internet as it will most likely fail to connect to the VPN and not retry with default settings.
                      Aldo Castro Freire
                      @tom thanks apparently the openvpn version needed to be updated the default version that comes with voxl does not work for me
                      modaltbM 1 Reply Last reply
                        modaltbM Offline
                        modaltbM Offline
                        modaltb
                        @Aldo-Castro-Freire thanks for the feedback, do you mind sharing the openVPN Client and Server versions you ended up using that worked?
                        We've tested using server v2.4.8, voxl-vpn (v2.1.3 inside that), and OpenVPN Connect ver 3.2.2 on Adroid.
