    Warning PX4 disconnected from UART
    1829
    • M
      mohammednaveed
      Hi all,
      I am getting this message on my Voxl flight deck
      Warning PX4 disconnected from UART.
      I had this issue yesterday as well, I thought it might be a cable issue but everything was fine. So I reset my flight core and set it up again and uploaded this parameter file from GitHub parameter
      The error then went away yesterday. But today again i got this error message.I checked this Post and my parameters are the same. I again uploaded the GitHub parameters like before but no luck.
      yocto:~$ voxl-vision-px4 -d
      loading our own config file
      qgc_ip:                     192.168.1.114
      en_localhost_mavlink_udp    1
      en_secondary_qgc:           0
      qgc_udp_port_number:        14550
      udp_mtu:                    512
      en_vio:                     1
      en_voa:                     1
      en_send_vio_to_qgc:         1
      en_send_voa_to_qgc:         1
      en_set_clock_from_gps:      1
      en_force_onboard_mav1_mode: 1
      en_reset_px4_on_error:      1
      qvio_auto_reset_quality:    0.000500
      en_adsb:                    0
      adsb_uart_bus:              7
      adsb_uart_baudrate:         57600
      px4_uart_bus:               5
      px4_uart_baudrate:          921600
      follow_tag_id:              0
      en_tag_fixed_frame:         0
      fixed_frame_filter_len:     5
      starting geometry module
      starting px4 monitor
      starting uart mavlink
      Successfully opened mavparser
      starting udp mavlink
      Adding manual QGC IP address to udp connection list: 192.168.1.114
      Added new UDP connection to 192.168.1.114
      starting px4 shell
      starting fixed pose input
      starting vio manager
      starting tag manager
      starting voa manager
      Connected to voxl-qvio-server
      done updating transforms to use imu: imu0
      WARNING PX4 DISCONNECTED FROM UART
      Thanks & Regards,
      Mohammed Naveed
      • modaltbM
        modaltb ModalAI Team
        Hi @mohammednaveed ,
        Sorry for the lag, is this still showing up as an issue?
        One way I try to trouble shoot the MAVLink connection over the UART from the VOXL processor(s) to Flight Core STM32 is using: https://docs.modalai.com/voxl-vision-px4-nuttx-shell/#interactive-mode
        From the other side, if you can open a MAVLink connection over USB to the Flight Core, and run mavlink status from the nutshell, to see if you have any active traffic?
        • M
          mohammednaveed
          Hi @modaltb
          Its alright!
          It still shows up randomly, will try your suggested method and get back soon!
          Thanks & Regards,
          Mohammed Naveed
          • M
            mohammednaveed
            Hi @modaltb
            I checked it today, the issue still exists!
            I followed your instructions and have attached the following messages. This is only happening on this Voxl flight deck unit, my other unit is working perfectly.
            en_secondary_qgc:           0
            udp_mtu:                    512
            en_vio:                     1
            en_voa:                     1
            en_adsb:                    0
            adsb_uart_bus:              7
            px4_uart_bus:               5
            follow_tag_id:              0
            uart send msgid:   0 sysid:  0 compid:197
            starting px4 shell
            uart send msgid:   0 sysid:255 compid:190
            ^C
            received SIGINT Ctrl-C
            Starting shutdown sequence
            Stopping adsb
            stopping voa manager
            stopping tag manager
            stopping vio manager
            stopping fixed pose in module
            stopping px4 shell module
            Stopping udp mavlink module
            exiting QGC udp listener thread
            exiting localhost udp listener thread
            udp_mavlink stopped
            Stopping uart mavlink module
            waiting for uart reader thread to join
            waiting for SDSP mavparser to close
            Stopping px4 monitor
            closing remaining client pipes
            closing remaining server pipes
            Removing PID file
            exiting
            • M
              mohammednaveed
              Is there a possibility that my VOXL board is bricked? Since the issue hasn't been resolved.
              • modaltbM
                The screen shot from QGC is of the unit with the issue? I'm a little confused as it shows a connection here which is that connecting to the VOXL:
                If you can adb into the VOXL side and also get a MAVLink connection over USB to the Flight Core side, I'd say no it's not bricked.
                I'm wondering if we are missing something else. Are you modifying the PX4 FW or software on VOXL at all?
                What else are you running if anything on VOXL?
                There's a physical UART connecting the two, there are discrete components on the board such as ESD diodes, is the hardware being altered or installed into anything or just used in a Flight Deck? It's sounding like software and maybe an edge case with timing if it's intermittent though... if hardware issue it wouldn't work at all..
                • M
                  mohammednaveed
                  Hi @modaltb
                  No I can ADB into the voxl, so its not bricked!
                  This board is brand new and we were just configuring the flight core and we had just updated the custom firmware from v0.0.5 to v0.2.3.
                  We just wanted to do VOA.
                  However we found the issue, it seems to be a hardware issue!
                  The J12 port to which the TELEM cable is connected to is not working correctly. I physically inspected if there are any damages but couldnt find anything wrong.
                  This voxl was not able to communicate with another flight core as well. But once we shifted to J10 port it started to work correctly.
                  So is it still hardware issue?
                  Thanks & Regards,
                  Mohammed Naveed
                  • modaltbM
                    AH ok I thought you had a VOXL-Flight, but it sounds like you have a VOXL and an external flight controller?
                    J12 is on the VOXL:
                    On VOXL-Flight, it's internally routed.
                    OK, we have a loop back test that you can use to test the hardware on J12.
                    If you can connect pins 2/3 together via a custom cable, you can try the loop back test to see if the HW is OK: https://gitlab.com/voxl-public/core-libs/libvoxl_io/-/blob/master/lib/apps/voxl-uart-loopback.c#L54
                    • M
                      mohammednaveed
                      Hi @modaltb
                      Sorry if i didnt mention this earlier. Its a VOXL flight deck which is having this issue. My other VOXL flight deck is working fine and we tried to interchange the board and see where the issue was and found out to be the J12 port. In the other flight deck J12 is working correctly.
                      I'll try the loop back test.
                      Thanks & Regards,
                      Mohammed Naveed
                      • D
                        DarkKnightCH @mohammednaveed
                        @mohammednaveed Hi, have you solved your issue? Do you know where the issue is from?
                        • J
                          janikaoh @modaltb
                          @modaltb Hi there! May I ask how the loopback test is conducted? How do you get the github file to run on VOXL? Thank you!
                          • Syed OmairS Syed Omair referenced this topic on
