  3. Warning PX4 disconnected from UART
11 Posts 4 Posters 2.4k Views 1 Watching
  • M Offline
    M Offline
    mohammednaveed
    Hi all,
    I am getting this message on my Voxl flight deck
    Warning PX4 disconnected from UART.
    I had this issue yesterday as well, I thought it might be a cable issue but everything was fine. So I reset my flight core and set it up again and uploaded this parameter file from GitHub parameter
    The error then went away yesterday. But today again i got this error message.I checked this Post and my parameters are the same. I again uploaded the GitHub parameters like before but no luck.
    yocto:~$ voxl-vision-px4 -d
    loading our own config file
    qgc_ip:                     192.168.1.114
    en_localhost_mavlink_udp    1
    en_secondary_qgc:           0
    secondary_qgc_ip:           192.168.1.214
    qgc_udp_port_number:        14550
    localhost_udp_port_number:  14551
    udp_mtu:                    512
    en_vio:                     1
    en_voa:                     1
    en_send_vio_to_qgc:         1
    en_send_voa_to_qgc:         1
    en_set_clock_from_gps:      1
    en_force_onboard_mav1_mode: 1
    en_reset_px4_on_error:      1
    qvio_auto_reset_quality:    0.000500
    en_adsb:                    0
    adsb_uart_bus:              7
    adsb_uart_baudrate:         57600
    px4_uart_bus:               5
    px4_uart_baudrate:          921600
    offboard_mode:              off
    follow_tag_id:              0
    en_tag_fixed_frame:         0
    fixed_frame_filter_len:     5
    loading extrinsics config file
    starting geometry module
    starting px4 monitor
    starting uart mavlink
    Successfully opened mavparser
    starting udp mavlink
    Adding manual QGC IP address to udp connection list: 192.168.1.114
    Added new UDP connection to 192.168.1.114
    starting px4 shell
    starting fixed pose input
    starting vio manager
    starting tag manager
    starting voa manager
    Connected to voxl-qvio-server
    done updating transforms to use imu: imu0
    WARNING PX4 DISCONNECTED FROM UART
    Thanks & Regards,
    Mohammed Naveed
      Hi @mohammednaveed ,
      Sorry for the lag, is this still showing up as an issue?
      One way I try to trouble shoot the MAVLink connection over the UART from the VOXL processor(s) to Flight Core STM32 is using: https://docs.modalai.com/voxl-vision-px4-nuttx-shell/#interactive-mode
      From the other side, if you can open a MAVLink connection over USB to the Flight Core, and run mavlink status from the nutshell, to see if you have any active traffic?
      • M Offline
        M Offline
        mohammednaveed
        Hi @modaltb
        Its alright!
        It still shows up randomly, will try your suggested method and get back soon!
        Thanks & Regards,
        Mohammed Naveed
        • M Offline
          M Offline
          mohammednaveed
          wrote on last edited by mohammednaveed
          Hi @modaltb
          I checked it today, the issue still exists!
          I followed your instructions and have attached the following messages. This is only happening on this Voxl flight deck unit, my other unit is working perfectly.
          en_secondary_qgc:           0
          udp_mtu:                    512
          en_vio:                     1
          en_voa:                     1
          en_adsb:                    0
          adsb_uart_bus:              7
          px4_uart_bus:               5
          offboard_mode:              off
          follow_tag_id:              0
          uart send msgid:   0 sysid:  0 compid:197
          starting px4 shell
          uart send msgid:   0 sysid:255 compid:190
          ^C
          received SIGINT Ctrl-C
          Starting shutdown sequence
          Stopping adsb
          stopping voa manager
          stopping tag manager
          stopping vio manager
          stopping fixed pose in module
          stopping px4 shell module
          Stopping udp mavlink module
          exiting QGC udp listener thread
          exiting localhost udp listener thread
          udp_mavlink stopped
          Stopping uart mavlink module
          waiting for uart reader thread to join
          waiting for SDSP mavparser to close
          Stopping px4 monitor
          closing remaining client pipes
          closing remaining server pipes
          Removing PID file
          exiting
          • M Offline
            M Offline
            mohammednaveed
            Is there a possibility that my VOXL board is bricked? Since the issue hasn't been resolved.
              The screen shot from QGC is of the unit with the issue? I'm a little confused as it shows a connection here which is that connecting to the VOXL:
              If you can adb into the VOXL side and also get a MAVLink connection over USB to the Flight Core side, I'd say no it's not bricked.
              I'm wondering if we are missing something else. Are you modifying the PX4 FW or software on VOXL at all?
              What else are you running if anything on VOXL?
              There's a physical UART connecting the two, there are discrete components on the board such as ESD diodes, is the hardware being altered or installed into anything or just used in a Flight Deck? It's sounding like software and maybe an edge case with timing if it's intermittent though... if hardware issue it wouldn't work at all..
              • M Offline
                M Offline
                mohammednaveed
                Hi @modaltb
                No I can ADB into the voxl, so its not bricked!
                This board is brand new and we were just configuring the flight core and we had just updated the custom firmware from v0.0.5 to v0.2.3.
                We just wanted to do VOA.
                However we found the issue, it seems to be a hardware issue!
                The J12 port to which the TELEM cable is connected to is not working correctly. I physically inspected if there are any damages but couldnt find anything wrong.
                This voxl was not able to communicate with another flight core as well. But once we shifted to J10 port it started to work correctly.
                So is it still hardware issue?
                Thanks & Regards,
                Mohammed Naveed
                  AH ok I thought you had a VOXL-Flight, but it sounds like you have a VOXL and an external flight controller?
                  J12 is on the VOXL:
                  On VOXL-Flight, it's internally routed.
                  OK, we have a loop back test that you can use to test the hardware on J12.
                  If you can connect pins 2/3 together via a custom cable, you can try the loop back test to see if the HW is OK: https://gitlab.com/voxl-public/core-libs/libvoxl_io/-/blob/master/lib/apps/voxl-uart-loopback.c#L54
                  J 1 Reply Last reply
                  • M Offline
                    M Offline
                    mohammednaveed
                    Hi @modaltb
                    Sorry if i didnt mention this earlier. Its a VOXL flight deck which is having this issue. My other VOXL flight deck is working fine and we tried to interchange the board and see where the issue was and found out to be the J12 port. In the other flight deck J12 is working correctly.
                    I'll try the loop back test.
                    Thanks & Regards,
                    Mohammed Naveed
                    D 1 Reply Last reply
                    • M mohammednaveed
                      Hi @modaltb
                      Thanks & Regards,
                      Mohammed Naveed
                      D Offline
                      D Offline
                      DarkKnightCH
                      @mohammednaveed Hi, have you solved your issue? Do you know where the issue is from?
                      • modaltbM modaltb
                        J12 is on the VOXL:
                        janikaoh
                        @modaltb Hi there! May I ask how the loopback test is conducted? How do you get the github file to run on VOXL? Thank you!
                        • Syed OmairS Syed Omair referenced this topic on
