  3. can't connect m500 drone to qgroundcontrol
3 Posts 1 Posters 705 Views
  • Syed OmairS Offline
    Syed OmairS Offline
    Syed Omair
    wrote on last edited by Syed Omair
    I have seen multiple posts on this forum with the same issue and tried multiple solutions but none of them seem to work
    some of the things I have tried.
    • changing sdk versions (tldr: upgraded from 0.9.4 -> 0.9.5, it wasn't working.)
      voxl upgrade guide
      "connected to voxl-mavlink-server but no messages from PX4"
    • checked and "external_fc" is false
      "Connected to voxl-mavlink-server but no messages from PX4" again 🙂
    • tried monitoring if mavlink is sending messages. and nothing works.
      mavlink monitoring
    • something that is potentially interesting. this down here wasn't the case before.
      below is the output to voxl-qvio-server
    • followed this guide.
      Connect m500 to PX4
    • checked for loose connections. unplugged and plugged everything back in
      loose connection
    • I want to try this solution but I can't get a wired connection to qgroundcontrol. any help with that would be appreciated
      wired connection to qgc solution
    Thank you for your time and help,
    Omair
    Syed OmairS 1 Reply Last reply
    • Syed OmairS Syed Omair
        voxl upgrade guide
        mavlink monitoring
        Connect m500 to PX4
        loose connection
      Omair
      Syed OmairS Offline
      Syed OmairS Offline
      Syed Omair
        Syed OmairS Offline
        Syed Omair
        for anyone who has the voxl-qvio issue where it says state FAIL, just try centering (using your fingers and wiggling) the voxl board and it will work. I think it just needs to be centered.
