    how to stop wlan0 mac address randomization
    Qualcomm Flight RB5 5G Drone
    1103
    • shane_langhansS
      shane_langhans
      I've noticed that every time the rb5 boots, the mac address for wlan0 interface changes. This is inconvenient, because I can't set the network router to reserve an IP address for it. Every time it boots, i have to use the adb shell to check what IP address ended up being assigned if i want to stream video or ssh to use vio and voa clients.
      I saw some forums like this one that said to change /etc/NetworkManager/NetworkManager.conf, but there's is no network manager directory in /etc directory.
      I tried creating /etc/NetworkManager/conf.d directory and adding a file there with the contents:
      [device]
      match-device=interface-name:wlan0
      wifi.scan-rand-mac-address=no
      but that didn't help.
      Any ideas for how to use a constant mac address?
        Eric Katzfey ModalAI Team @shane_langhans
        @shane_langhans Yes, this is a known issue. We have opened a support ticket with Qualcomm and are awaiting a solution.
        Bo ZhangB 1 Reply Last reply Reply Quote 0
          Hey @shane_langhans ,
          Yeah, this has been a pet peeve for me too. To officially fix it, we're waiting on QCOM for a proper fix.
          As a work around, do you have a range of IPs that are not being used in the router's DHCP pool? If so, maybe you can statically assign an IP within that range? For instance, you can setup service script that calls a script like this to set the IP:
          #!/bin/bash
          drone_IP='192.168.168.101'
          microhard_radio_gw='192.168.168.1'
          ifconfig eth0 down
          ifconfig eth0 $drone_IP netmask 255.255.255.0 up
          ip route add default via $microhard_radio_gw dev eth0
          See if this works, then we can drop it into a service like this in /etc/systemd/system:
          [Unit]
          After=sdsprpcd.service
          Requires=sdsprpcd.service
          [Service]
          Type=oneshot
          ExecStartPre=/bin/sleep 10
          ExecStart=/home/root/microhard_radio_config_iface.sh
          [Install]
          WantedBy=default.target
          RobertoR 1 Reply Last reply Reply Quote 0
          • RobertoR
            Roberto @Guest
            • Bo ZhangB
              Bo Zhang @Eric Katzfey
              @Eric-Katzfey Hi, how is this ticket going now?
              @Eric-Katzfey said in how to stop wlan0 mac address randomization:
                Eric Katzfey ModalAI Team @Bo Zhang
                @Bo-Zhang Unfortunately, we have not received a solution.
                • Bo ZhangB
                  Bo Zhang
                  I just managed to set ethernet MAC with rc.local by writing the following into /etc/rc.local,
                  #!/bin/sh
                  ifconfig eth0 down
                  ifconfig eth0 hw ether 00:xx:xx:xx:xx:xx
                  ifconfig eth0 up
                  Remember to replace with your MAC to be fixed and to make sure rc.local service is up with the commands below.
                  chmod +x /etc/rc.local
                  systemctl start rc.local
                  systemctl enable rc.local
                  systemctl status rc.local
                  reboot
                  If it doesn't work, check the service status with systemctl to see what went wrong.
                  • M mbahrami referenced this topic on
                  • Amin BassiriA
                    Amin Bassiri
                    follow this
                    adb shell
                    sudo nano /etc/dhcpcd.conf
                    copy your ip in the page like this:
                    interface wlan0
                    static ip_address=192.168.1.35/24
                    static routers=192.168.1.7
                    static domain_name_servers=192.168.1.7
                    have look at this link also. https://www.makeuseof.com/raspberry-pi-set-static-ip/
