  3. Power issues at the initial startup
2 Posts 2 Posters 83 Views 1 Watching
  • M Offline
    M Offline
    mmirtaba
    wrote last edited by
    Hardware: Starling 2 Max order number 8701
    Software version: (paste the output of voxl-version)
    Configuration / services: (paste the output of voxl-inspect-services)
    What I am trying to do: Initial setup, driver installation
    What actually happens: Today, I attempted the initial setup and driver installation of the Starling Max 2 drone by following the user manual, which provides two connection methods: Wi-Fi and USB-C. Since the desktop computer did not have a Wi-Fi module, I chose the USB-C method. I first connected the batteries, and the drone started normally with its LEDs lighting up. I then connected the drone to the desktop using a USB-C cable. While searching for the required drivers, I noticed a burning smell and found that the drone had become extremely hot. I immediately disconnected both the USB-C cable and the batteries to prevent further damage.
    Steps to reproduce:
    Logs / pictures: (attach files; PX4 logs -> https://logs.px4.io)
    VinnyV 1 Reply Last reply
    • M mmirtaba
      Steps to reproduce:
      Hi @mmirtaba,
      Sorry for the slow reply. Disconnecting the USB-C cable and the batteries right away was the right call.
      Please do not power the drone again, from the batteries or from USB. Open an RMA here and reference order 8701: https://www.modalai.com/pages/rma
      Every Starling 2 Max is flight tested before it ships. So we can start looking into it before the unit arrives, please reply here with:
      • Photos of the drone, including any part that looks discolored or damaged
      • Where the heat and the smell seemed to come from, if you noticed
      • Which port on the drone the USB-C cable was plugged into, and what it connected to on the desktop (a USB-C port, or a USB-A port through an adapter)
      • Which operating system the desktop runs, and what "searching for the required drivers" involved (for example a Windows pop-up, Device Manager, or downloading something)
      • Roughly how long the drone was running on batteries before you plugged in the USB-C cable
      • Roughly how long after plugging in the cable you noticed the smell
