  3. Repairing M0138
Repairing M0138
2 Posts 2 Posters 86 Views 1 Watching
  • S Offline
    S Offline
    sjt277
    wrote last edited by
    Hardware: (board / drone / SKU, serial # if you have it)
    M0138
    Software version: (paste the output of voxl-version)
    Python codes
    Configuration / services: (paste the output of voxl-inspect-services)
    Doesn't respond to USB uart
    What happened:
    I was connecting the M0138 to a 24V power supply for bench test. It turned on the led in the bootup sequence but afterwards stopped completely responding. I tried plugging it in and out but wouldn't start up again. Then I tried touching the components and the Vreg Inductor seems to be getting very hot, all other components seem fine. Is there a way to repair it? How would I do that? The purchase was made few months back and I don't want the ESC to scrap and want to make some use out of it.
    Logs / pictures: (attach files; PX4 logs -> https://logs.px4.io)
    • Alex KushleyevA Offline
      @sjt277 , I am sorry this happened to you. In order to help evaluate the issue, can you please post photos of both sides of the M0138 ESC board (high resolution, please, you could share a link if the forum does not accept it).
      Also please point out in the picture which component is getting hot. Also, since you are using a power supply, it should provide the current draw when you attempt to power on the ESC. Please let us know the voltage and current reading on the power supply and whether it is changing.
      Did the ESC work at first (spinning motors) and then stopped working at some point?
      Please note that testing ESCs using a power supply often lead to permanent damage due to regenerative spikes when the motor is braking (causing over-voltage). https://docs.modalai.com/voxl-escs/faq/#unboxing-and-testing-new-standalone-esc
