  3. M0213 Wifi board pinout and availability
15 Posts 3 Posters 4.9k Views 2 Watching
  • Muqing CaoM Offline
    Muqing CaoM Offline
    Muqing Cao
    Hi, can we get the pinout for the M0213 wifi board? Specifically the two connection ports on the front and back of the board.
    Also, can we get more of these boards?
      Muqing CaoM Offline
      Muqing Cao
      A picture of the board:
        Muqing CaoM Offline
        Muqing Cao
        Any support for this issue? Thanks!
        • VinnyV Offline
          Hi @muqing-cao Sorry we are lacking in the docs here, but the M0213 was a direct replacement to the M0141 board. So the 12-pin connector (J3) directly matches the info for J5 here: https://docs.modalai.com/usb2-type-a-breakout-add-on/
            Muqing CaoM Offline
            Muqing Cao
              Muqing CaoM Offline
              Muqing Cao
              Thanks for your reply!
              What we are trying is to make this M0213 wifi board work with the 5G add-on board: https://docs.modalai.com/5G-Modem-datasheet/
              The problem is this 5G board does not have the same connector to plug M0213 onto.
              Could you give us suggestion on how we can wire the cables to make wifi connection using M0213 with the 5G board?
              • VinnyV Offline
                wrote on last edited by Vinny
                Hi @muqing-cao The M0213 board is not meant to plug into any other board than VOXL 2 directly. The best bet is to use a USB WiFi dongle connected to the 5G Modem Plug-in board. We provide several USB connections and cables to help that use case.
                https://docs.modalai.com/cable-datasheets/
                Muqing CaoM 1 Reply Last reply
                  Muqing CaoM Offline
                  Muqing Cao
                  Thanks for your reply! The reason we want to use the M0213 board instead of the ALFA dongle is that, in our tests, we find that the M213 wifi board has much better signal strength and better multi-mesh access point transition. The supported ALFA dongle does not seem to support multi access point transition. Therefore, we would still want to use the M0213 board through wiring the required pins. We would really appreciate any suggestion on this.
                  If there are any other wifi dongle that works with the system and has better signal strength and multi access point transition, please also let us know. We tried to test some other dongles and it does not work, due to that the voxl's linux kernel is built with very limited wifi drivers.
                  • H Offline
                    H Offline
                    Hamed_Mozaffari
                    Hi, I purchased a new Starling 2 Max SKU: MRB-D0012-4-V4-C29-M36-T8-K3.
                    I am using RadioMaster AX12 to view the video feed on the QGroundControl app on the controller. The speed of the video stream is very low (every 10 seconds, one frame). I checked many things using AI, and it seems that all settings are fine on the drone and wifi side. Would you mind providing details on how I can increase the video stream?
                    Also, there was no charger in the box to charge the batteries. Should I buy one, or can I charge them using the drone itself?
                    Why does arming with a power supply cause severe damage? I am thinking of using a power supply for flying using tethering and a better charger.
                    For 4G or 5G connectivity, could I purchase an accessory for the drone and use that for the camera feed?
                    • H Hamed_Mozaffari
                      Muqing CaoM Offline
                      Muqing CaoM Offline
                      Muqing Cao
                      @Hamed_Mozaffari please start a new post to increase your chance of getting replied and also not divert the main topic of this post
                      • VinnyV Vinny
                        Muqing CaoM Offline
                        Muqing CaoM Offline
                        Muqing Cao
                        wrote on last edited by Muqing Cao
                        #11
                        @Vinny I would still like to get help on either getting M0213 board to work with 5g modem add-on board, or some suggestions on better dongles with better signal and multi-access point transition. thanks!
                        • VinnyV Offline
                          Hi @muqing-cao I am glad you like the M0213, as it does offer more power than most USB-A dongles, which is why we went to it.
                          The Only thing I can think of is to buy an MCBL-00022 and when plugged into the M0090 5G Modem Board USB 10-pin JST port, you have a standard USB host port, and maybe Bots Unlimited makes a USB-A version you can use. We just do not offer a clean/direct solution to accomplish what you are asking for.
                          • VinnyV Vinny referenced this topic on
                          • VinnyV Vinny
                            Muqing CaoM Offline
                            Muqing CaoM Offline
                            Muqing Cao
                            @Vinny Ah I see, thanks. A follow up question, is there a way for us to connect to another USB device if we plug in the M0213 board to the voxl2? It seems there is no more USB exposed.
                            • VinnyV Offline
                              Hi @muqing-cao Correct, M0213 does not have a USB hub on it like M0090.
                              • VinnyV Vinny
                                Muqing CaoM Offline
                                Muqing CaoM Offline
                                Muqing Cao
                                @Vinny we recently experienced wifi disconnection issue with the m0213 board. During flight the wifi just completely disconnected with does not regain connectivity. It seems that the wifi chipset stopped working. We had to do a complete power cycle to regain connectivity. It happened several times during our test. Could you suggest how to resolve this issue? Or is there a way to do soft-reset of the board if we detect wifi connectivity loss?
