    Voxl ESC not responding and not detected
    ESCs
    201
    • Jetson NanoJ
      Jetson Nano
      Hello @Vinny @Eric-Katzfey @Alex-Kushleyev @modaltb
      I am facing an error with my Voxl FPV ESC. The ESC is not responding to any command. While plug in power the ESC is only blinking 3 LED for the initialization, then there is no LED blinking.
      The ESC was working fine, during a flight test the motor suddenly stopped and the drone was landed safely somehow, but after that the motors are not starting, there are no visible damages.
      I am attaching the terminal results, I tried to upgrade the firmware, alchange the parameter file, but the ESC is not responding. I also checked with various baudrate, the result is same, no response.
      :~/Downloads/voxl-esc-master/voxl-esc-tools$ sudo python3 voxl-esc-scan.py
      Detected Python version : 3.10.12 (main, Mar  3 2026, 11:56:32) [GCC 11.4.0]
      Found voxl-esc tools bin version: 1.10
      INFO: All COM ports:
      	/dev/ttyUSB0 : FT232R USB UART - FT232R USB UART
      INFO: UART Port Candidates:
      	/dev/ttyUSB0
      INFO: Scanning for ESC firmware: /dev/ttyUSB0, baud: 2000000
      INFO: Scanning for ESC bootloader: /dev/ttyUSB0, baud: 230400
      WARNING: No ESC(s) detected
      	/dev/ttyUSB0
      INFO: Scanning for ESC firmware: /dev/ttyUSB0, baud: 250000
      	/dev/ttyUSB0
      INFO: Scanning for ESC firmware: /dev/ttyUSB0, baud: 921600
      	/dev/ttyUSB0
      INFO: Scanning for ESC firmware: /dev/ttyUSB0, baud: 57600
      ERROR: not all ESCs found
      please help me out here, is there any way to figure out why is this happening and how to solve it, I had a similar instance earlier, but the ESC was responsive and one motor was glitching. it was stopping during rotation. changing motor did not help, so i changed the ESC and it worked.
      what I do to maintain the ESC safety and working.
      • Jetson NanoJ
        Jetson Nano @Jetson Nano
        Hi Guys,
        Any update would be great appreciated.
          Alex Kushleyev ModalAI Team @Jetson Nano
          @Jetson-Nano ,
          In a case like this, if the ESC works and suddenly stops working, the resulting state is probably a hardware problem (possibly caused by software action or hardware damage). In this state, it is probably impossible to recover the ESC using software and remote diagnostics would be difficult and you would probably not be able to fix the ESC hardware anyway.
          Do you have any additional information that could help us understand what happened and the frequency of occurrence? you mentioned two occurrences "recently" -- any more details? What motor/prop/battery was used and was there anything unusual that happened during the test? Do you have a px4 log from the flight? (you could share it privately if needed).
          If you are able to ship two failed ESC boards back to us for investigation, i'll ask our team if we can send you new replacement(s).
          • Jetson NanoJ
            Jetson Nano @Alex Kushleyev
            Hello @Alex-Kushleyev ,
            Thank you for getting back to us.
            Please find below a detailed summary of the failure scenarios observed during our recent flight testing activities. We would appreciate your assistance in analyzing these events and identifying any potential root causes.
            System Configuration
            • VOXL 2 → Flight Controller V2 → ESC
            • Motor: T-Motor F60 Pro LV, 2020KV
            • Propeller: 5-inch Three-Blade Propeller
            • Battery: 6S, 5000mAh (21700 Cells)
            Scenario 1 – VOXL FPV ESC Failure
            During flight, the drone was operating normally when the rear-left motor suddenly stopped, causing the aircraft to lose stability and topple.
            Following a system reboot, the affected motor exhibited abnormal behavior:
            • The motor would begin rotating briefly.
            • It would then stop unexpectedly.
            • This cycle would continuously repeat.
            The same behavior was reproduced while running the ESC spin.py test utility.
            As part of troubleshooting, we:
            • Updated the ESC firmware to the latest available version.
            • Applied the recommended parameter changes.
            • Repeated motor and ESC validation tests.
            However, the issue persisted, and no improvement was observed.
            Scenario 2 – VOXL FPV ESC No Longer Initializes
            In a separate flight test using a replacement ESC, the drone was in a stable hover when the front-left motor stopped unexpectedly, causing the aircraft to topple.
            Following the incident:
            • The affected ESC no longer initializes correctly.
            • During power-up, the ESC LEDs briefly illuminate and then turn off.
            • The ESC does not appear to complete its startup sequence.
            Troubleshooting performed:
            • Connected the ESC directly to a computer.
            • Attempted to establish communication and detect the ESC.
            • Performed multiple power cycles and reconnection attempts.
            Unfortunately, the ESC could not be detected, and communication could not be established. The terminal output associated with this issue was shared previously in our earlier correspondence.
            Scenario 3 – Third-Party ESC Evaluation
            To further isolate the issue, we replaced the VOXL FPV ESC with a NeutronRC X-CLASS 4IN1 ESC V2 (3–8S, 70A) configured using the DShot protocol.
            During testing, we observed the following:
            • ESC temperature increased rapidly, reaching approximately 80°C to 90°C within two minutes of flight.
            • One motor would subsequently stop during flight.
            • The aircraft would lose stability and crash.
            • During or immediately after impact, the ESC appeared to reboot.
            • Following the reboot, the system would operate normally again.
            This behavior has been consistently observed across five separate flight tests, with each flight resulting in a similar failure sequence and crash.
            Additional Observations
            While reviewing the available flight logs, we observed elevated ESC temperatures:
            • General ESC operating temperature ranged between 75°C and 88°C during the affected flights.
            • ESC(0) reached a peak temperature of approximately 88°C.
            • During earlier flight tests under similar operating conditions, ESC temperatures typically ranged between 60°C and 75°C.
            Installation and Thermal Management Details
            The ESC is installed inside a closed enclosure with the following thermal arrangement:
            • Bottom-mounted aluminum heatsink.
            • Thermal interface material between the ESC and heatsink.
            • Side walls constructed from aluminum structural members.
            Despite the presence of thermal conduction paths, the elevated temperatures observed during flight raise concerns regarding thermal dissipation and potential thermal shutdown behavior.
            Flight Logs
            Log File:
            https://drive.google.com/file/d/1wxv7VZub4-7onK6YdgcJ8kSpGhpZ40mY/view?usp=sharing
            Note: Access approval may be required to view the file. If the link is inaccessible, please send an access request and we will grant permissions immediately.
            Given that similar symptoms have been observed across both the VOXL FPV ESC and a third-party ESC platform, we would greatly appreciate your guidance on:
            • Potential root causes of the motor shutdown events.
            • Whether the observed temperatures are within acceptable operating limits.
            • Recommended diagnostics or logging parameters to further isolate the issue.
            • Any known interactions between the motor, propeller, battery, and ESC configuration that could contribute to these failures.
            Please let us know if any additional logs, hardware details, configuration files, or test data are required from our side.
            Thank you for your continued support and assistance.
            • Jetson NanoJ
              Hi Guys,
              The requested data is provided above.
                @Jetson-Nano ,
                Thank you for providing detailed description of the tests. I just requested access to the logs.
                Please see the following comments:
                • ESC temperature: the VOXL FPV ESC is rated for pretty high operating temperatures. For example, the MCUs are rated to run at up to 125C MCU temperature. I would not recommend running the ESC above 100C, however I am confident that the ESC will perform fine even above 100C. We typically recommend designing the system such that ESC temperature does not exceed 80C under normal flight conditions - this gives plenty of margin before a failure would occur. Did you take note of the ESC temps of VOXL ESC?
                • VOXL FPV ESC reports two types of temperatures: two of the IDs (ID 0, 3) are measuring the ESC temps from separate temperature sensors located on top and bottom of the ESC. IDs 1 and 2 are reporting the MCU temps (the temperature of the MCU silicon). The MCU temps at steady state are typically a bit higher (5-7 deg C higher) because the MCU itself generates a little heat internally.
                • VOXL ESC not responding after a crash : the likely reason is mechanical damage as a result of the crash. Components can be knocked off during the crash. If the ESC powers on briefly (you see the leds blink initially, but then the ESC turns off), then the likely issue is some kind of short or high load on one of the regulated ESC power rails (5V or 3.3V) -- the high current drain (due to some issue) results in the voltage regulator to turn off due to over-current, resulting in the ESCs shutting down. If only 3 out of 4 LEDs blink, then it is possible that one ESC channel has some sort of a short (due to mechanical damage) and it does not turn on, eventually causing the power rails to be disabled due to over-current.
                • motor suddenly stopping in flight: this is often a result of a mechanical issue related to mounting the motor to the frame. Sometimes the motor mounting screws are too long and they can penetrate the motor windings and cause intermittent failures just like this. We have experienced this ourselves several times when long screws were used and were touching the motor windings. Alternatively, something could be touching the ESC itself and intermittently affecting operation of the ESC
                • once I see the px4 log with the FPV ESC, i can check if one of the motors was operating abnormally before it stopped spinning. There is some additional information in the log that can tell us if a particular motor requires more power to spin (compare to the others).
                Questions:
                • do you have px4 logs of the VOXL ESC with one of the motors shutting down in flight?
                • is it possible that the aluminum enclosure is making contact with the ESC components, causing some kind of short? especially during crash, perhaps the ESC is making contact with the enclosure?
                • did you check if the motor temperature was OK after successful flights?
                • what was the total current draw during flight when the failure occurred? (should see that in the px4 log)
                • Jetson NanoJ
                  Thank you for your response and for helping us investigate this issue.
                  Please find our responses below to the questions raised:
                  1. Do you have PX4 logs of the VOXL ESC with one of the motors shutting down in flight?
                  Response:
                  Yes. The log file previously shared contains the PX4 flight log corresponding to the incident where one of the motors shut down during flight, resulting in loss of stability and the subsequent crash. The attached log is the same dataset we have been using for the failure analysis.
                  1. Is it possible that the aluminum enclosure is making contact with the ESC components, causing some kind of short? Especially during a crash, perhaps the ESC is making contact with the enclosure?
                  Response:
                  We do not believe there is any direct electrical contact between the ESC and the aluminum enclosure.
                  The ESC is mechanically isolated as follows:
                  A dedicated 3D-printed mounting structure is used between the ESC and the aluminum enclosure side walls.
                  Nylon spacers are used to maintain separation from the bottom-mounted aluminum heatsink.
                  The ESC is securely mounted and does not have any exposed conductive surfaces in contact with the enclosure during normal operation.
                  Based on the current mechanical arrangement, an enclosure-induced short circuit appears unlikely. However, we will perform an additional inspection of the assembly to verify clearances and mounting integrity.
                  1. Did you check if the motor temperature was OK after successful flights?
                  Response:
                  Yes. During successful flight tests, the motor temperatures were observed to be within normal operating limits and no abnormal heating was noticed.
                  1. What was the total current draw during flight when the failure occurred?
                  Response:
                  We have not yet extracted and analyzed the total current consumption at the exact moment of failure from the PX4 logs.I am currently coordinating with our team to review the logs in detail and obtain the current draw data during the affected flight. Once the analysis is completed, we will share the findings with you for further evaluation.
                  Please let us know if there are any additional parameters, diagnostic logs, or hardware inspections that you would recommend. We appreciate your continued support and guidance in helping us identify the root cause of this issue.
                  Thank you.
                    @Jetson-Nano ,
                    I looked at the log you shared. There is something strange going on with the voltage sensing on all 4 ESCs at the same time.
                    Voltage Plot
                    RPM Plot
                    ESC Temperature Plot
                    My thoughts:
                    • Since you said that you are using a 6S Li-Ion, it should not be possible for voltage to go up to 30+ volts.
                    • Voltage sensing and Temperature sensing are exhibiting very unusual spikes - i have never seen this before.
                    • the ESC temp before the crash is around 52C, so that is not an issue at all
                    • Looking at the RPM plot, i see RPM (actual) humps at around t=58.750s, which is where the measured voltage is reported dipping. Connecting the two pieces information, i am guessing that the actual battery voltage stayed the same, and the ESC measured (incorrectly) wrong voltage, and RPM controller tried to compensate, driving the actual rpm higher (since the battery voltage was still pretty high).
                    Final thoughts:
                    • it seems that multiple ADC channels on the ESC are affected (voltage, temperature measurements). A possible reason for this is the ESC MCU power supply (3.3V) is not constant. This could happen if 3.3V regulator on the ESC is overloaded by something (else) or the main 5V switching regulator is overloaded and drops out, causing a dropout on 3.3V.
                    • All 4 ESC channels are responding almost identically (before one motor stops), which would mean that a software bug is very unlikely. This is a hardware issue that is somehow affecting the ADC (and probably other components) of the ESC.
                    Please double check your system design to make sure that the ESC power supplies are not affected.
                    • Jetson NanoJ
                      Thank you for your continued support and assistance with this investigation.
                      Please find attached the system architecture diagram (power flow) of our platform for your review.
                      We would appreciate it if you could review the architecture and advise whether there are any potential concerns related to the power distribution, grounding scheme, wiring, connectors, ESC installation, or any other aspect that could contribute to the behavior we observed with the VOXL FPV ESC.
                      Additionally, we would like to highlight a few observations from our testing activities.
                      The abnormal ESC behavior was not present during the initial flight tests. The aircraft completed multiple successful flights before the failures began to occur. This leads us to believe that a direct short circuit caused by the frame, enclosure, or mounting arrangement may be less likely, as such an issue would typically manifest from the beginning of testing rather than after several successful flight cycles.
                      To further isolate the issue, we replaced the VOXL FPV ESC with a third-party NeutronRC X-CLASS 4IN1 ESC (70A). Following the replacement, the aircraft has been operating normally and has successfully completed multiple flight tests without any motor shutdown events or ESC-related failures.
                      At present, the third-party ESC continues to function correctly, and we have not observed any of the symptoms previously encountered with the VOXL FPV ESC. Motor operation, flight stability, and overall system performance remain normal.
                      This observation is particularly important because the remainder of the system configuration has remained largely unchanged, including:
                      VOXL2
                      Power distribution architecture
                      Motors
                      Propellers
                      Battery configuration
                      Airframe and enclosure
                      Given that the issue is not reproducible with the third-party ESC, we are trying to better understand whether there may be any specific factors related to the VOXL FPV ESC installation, operation, thermal conditions, configuration, or hardware that could have contributed to the failures we observed.
                      For reference, the ESC installation includes:
                      An aluminum heatsink mounted beneath the ESC
                      Nylon spacers providing electrical isolation
                      A dedicated 3D-printed mounting structure preventing contact with the aluminum enclosure
                      Based on the current mechanical arrangement, we do not believe there is any direct electrical contact between the ESC and the enclosure.
                      We would greatly appreciate your guidance on any additional troubleshooting procedures that you would recommend for the VOXL FPV ESC, including:
                      Hardware inspections
                      Diagnostic tests
                      Additional logging parameters
                      Thermal validation methods
                      Power system checks
                      Known failure modes or common causes for the symptoms observed
                      If there are any specific measurements, logs, or test procedures that would help narrow down the root cause, we would be happy to perform them and share the results.
                      Thank you once again for your continued support and technical guidance.
                      We look forward to your recommendations on the next steps.
                      Thank you
                        Hi @Jetson-Nano,
                        Can you please clarify the following - in your original post, you mentioned that the third party ESC also had issues, however in the post above you said no issues. I am quoting your notes from above:
                        I just wanted to clarify what actually happened and then we can investigate further. Than, you for providing the diagram, i think it looks OK.
                        I have never seen this behavior where the ESC reports incorrect voltage and these short spikes in temperature. This may point to a hardware issue on the ESC board, but i do not actually know where it might be or what would cause it. Have you visually inspected the FPV ESC that has this issue to see if any components appear damaged or anything looks unusual?
