  3. Station Mode Issue with Voxl Suite 1.6.3
23 Posts 4 Posters 3.5k Views 1 Watching
    @SKA , can you please try to power down the wifi device and power it back up (using the commands below) and check the output of dmesg.
    #turn off USB VBUS
    voxl-gpio write 157 0
    #turn on USB VBUS
    voxl-gpio write 157 1
    my dmesg output:
    [   24.123592] usb 1-1: USB disconnect, device number 2
    [   24.152384] RTW: rtw_ndev_uninit(wlan0) if1
    [   24.172973] RTW: rtw_dev_unload: driver not in IPS
    [   33.464284] usb 1-1: new high-speed USB device number 3 using xhci-hcd
    [   33.602465] usb 1-1: New USB device found, idVendor=0bda, idProduct=c820, bcdDevice= 2.00
    [   33.602487] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
    [   33.602502] usb 1-1: Product: 802.11ac NIC
    [   33.602517] usb 1-1: Manufacturer: Realtek
    [   33.602531] usb 1-1: SerialNumber: 123456
    [   33.614447] RTW: [HALMAC]55772M
                   HALMAC_MAJOR_VER = 1
                   HALMAC_PROTOTYPE_VER = 6
                   HALMAC_MINOR_VER = 6
                   HALMAC_PATCH_VER = 22
    [   33.760178] vdd_tof: disabling
    [   33.760182] vdd_hap_boost: disabling
    [   33.835010] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x40d00
    [   33.835034] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x40d00
    [   33.835055] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x40d00
    [   33.835075] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x40d00
    [   33.835095] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x40d00
    [   33.835115] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x40d00
    [   33.951477] RTW: HW EFUSE
    [   33.951489] RTW: 0x000: 29 81 00 BC  09 00 21 00  6E 04 A4 34  10 00 30 0B
    [   33.951530] RTW: 0x010: 26 26 26 26  26 26 27 27  27 27 27 13  FF FF FF FF
    [   33.951570] RTW: 0x020: FF FF 2D 2D  2D 2D 2D 2D  2D 2D 2D 2D  2D 2D 2D 2D
    [   33.951632] RTW: 0x030: 13 FF FF FF  FF FF E0 FF  FF FF 28 28  28 28 28 28
    [   33.951671] RTW: 0x040: 28 28 28 28  28 02 FF FF  FF FF FF FF  FF FF FF FF
    [   33.951710] RTW: 0x050: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
    [   33.951749] RTW: 0x060: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
    [   33.951788] RTW: 0x070: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
    [   33.951827] RTW: 0x080: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
    [   33.951866] RTW: 0x090: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
    [   33.951904] RTW: 0x0A0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
    [   33.951943] RTW: 0x0B0: FF FF FF FF  FF FF FF FF  7F 1A 1B 00  FF FF FF FF
    [   33.951982] RTW: 0x0C0: FF 22 00 00  00 E6 00 00  00 FF 26 FF  FF FF FF FF
    [   33.952179] RTW: 0x0D0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
    [   33.952291] RTW: 0x0E0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
    [   33.952331] RTW: 0x0F0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
    [   33.952369] RTW: 0x100: DA 0B 20 C8  C3 46 02 00  C0 CA B3 A4  EC 09 03 52
    [   33.952408] RTW: 0x110: 65 61 6C 74  65 6B 0E 03  38 30 32 2E  31 31 61 63
    [   33.952447] RTW: 0x120: 20 4E 49 43  08 03 31 32  33 34 35 36  FF FF FF FF
    [   33.952486] RTW: 0x130: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
    [   33.952533] RTW: 0x140: FF FF FF FF  00 00 31 0F  FF FF FF FF  FF FF FF FF
    [   33.952602] RTW: 0x150: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
    [   33.952641] RTW: 0x160: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
    [   33.952691] RTW: 0x170: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
    [   33.952730] RTW: 0x180: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
    [   33.952769] RTW: 0x190: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
    [   33.952808] RTW: 0x1A0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
    [   33.952847] RTW: 0x1B0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
    [   33.952885] RTW: 0x1C0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
    [   33.952924] RTW: 0x1D0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
    [   33.952963] RTW: 0x1E0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
    [   33.953002] RTW: 0x1F0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
    [   33.953329] RTW: hal_com_config_channel_plan chplan:0x7F
    [   34.184253] RTW: [RF_PATH] ver_id.RF_TYPE:RF_1T1R
    [   34.184263] RTW: [RF_PATH] HALSPEC's rf_reg_trx_path_bmp:0x11, rf_reg_path_avail_num:1, max_tx_cnt:1
    [   34.184269] RTW: [RF_PATH] PG's trx_path_bmp:0x00, max_tx_cnt:0
    [   34.184276] RTW: [RF_PATH] Registry's trx_path_bmp:0x00, tx_path_lmt:0, rx_path_lmt:0
    [   34.184283] RTW: [RF_PATH] HALDATA's trx_path_bmp:0x11, max_tx_cnt:1
    [   34.184288] RTW: [RF_PATH] HALDATA's rf_type:RF_1T1R, NumTotalRFPath:1
    [   34.184296] RTW: [TRX_Nss] HALSPEC - tx_nss:1, rx_nss:1
    [   34.184301] RTW: [TRX_Nss] Registry - tx_nss:0, rx_nss:0
    [   34.184307] RTW: [TRX_Nss] HALDATA - tx_nss:1, rx_nss:1
    [   34.184315] RTW: txpath=0x1, rxpath=0x1
    [   34.184321] RTW: txpath_1ss:0x1, num:1
    [   34.185543] RTW: rtw_regsty_chk_target_tx_power_valid return _FALSE for band:0, path:0, rs:0, t:-1
    [   34.188733] RTW: rtw_ndev_init(wlan0) if1 mac_addr=00:c0:ca:b3:a4:ec
    [   35.507557] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
    Also, here is output of tail -n 100 /var/log/syslog:
    Apr  3 18:17:22 m0054 dhcpcd[2755]: wlan0: carrier lost
    Apr  3 18:17:22 m0054 wpa_supplicant[1996]: wlan0: CTRL-EVENT-DISCONNECTED bssid=5c:e9:31:0a:78:23 reason=3 locally_generated=1
    Apr  3 18:17:22 m0054 kernel: [  402.693093] RTW: rtw_ndev_uninit(wlan0) if1
    Apr  3 18:17:22 m0054 systemd[1]: Starting Load/Save RF Kill Switch Status...
    Apr  3 18:17:22 m0054 systemd-rfkill[4368]: Failed to open device rfkill3: No such device
    Apr  3 18:17:22 m0054 systemd[1]: Started Load/Save RF Kill Switch Status.
    Apr  3 18:17:22 m0054 dhcpcd[2755]: wlan0: deleting address fe80::5c1e:5176:405d:82d8
    Apr  3 18:17:22 m0054 dhcpcd[2755]: wlan0: deleting default route via 192.168.10.1
    Apr  3 18:17:22 m0054 dhcpcd[2755]: wlan0: deleting route to 192.168.10.0/24
    Apr  3 18:17:22 m0054 dhcpcd[2755]: wlan0: removing interface
    Apr  3 18:17:29 m0054 kernel: [  409.880457] usb 1-1: new high-speed USB device number 5 using xhci-hcd
    Apr  3 18:17:30 m0054 kernel: [  410.369086] RTW: HW EFUSE
    Apr  3 18:17:30 m0054 kernel: [  410.369100] RTW: 0x000: 29 81 00 BC  09 00 21 00  6E 04 A4 34  10 00 30 0B
    Apr  3 18:17:30 m0054 kernel: [  410.369142] RTW: 0x010: 26 26 26 26  26 26 27 27  27 27 27 13  FF FF FF FF
    Apr  3 18:17:30 m0054 kernel: [  410.369221] RTW: 0x030: 13 FF FF FF  FF FF E0 FF  FF FF 28 28  28 28 28 28
    Apr  3 18:17:30 m0054 kernel: [  410.369299] RTW: 0x050: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
    Apr  3 18:17:30 m0054 kernel: [  410.369377] RTW: 0x070: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
    Apr  3 18:17:30 m0054 kernel: [  410.369454] RTW: 0x090: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
    Apr  3 18:17:30 m0054 kernel: [  410.369532] RTW: 0x0B0: FF FF FF FF  FF FF FF FF  7F 1A 1B 00  FF FF FF FF
    Apr  3 18:17:30 m0054 kernel: [  410.369609] RTW: 0x0D0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
    Apr  3 18:17:30 m0054 kernel: [  410.369687] RTW: 0x0F0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
    Apr  3 18:17:30 m0054 kernel: [  410.369764] RTW: 0x110: 65 61 6C 74  65 6B 0E 03  38 30 32 2E  31 31 61 63
    Apr  3 18:17:30 m0054 kernel: [  410.369842] RTW: 0x130: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
    Apr  3 18:17:30 m0054 kernel: [  410.369920] RTW: 0x150: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
    Apr  3 18:17:30 m0054 kernel: [  410.369997] RTW: 0x170: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
    Apr  3 18:17:30 m0054 kernel: [  410.370075] RTW: 0x190: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
    Apr  3 18:17:30 m0054 kernel: [  410.370153] RTW: 0x1B0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
    Apr  3 18:17:30 m0054 kernel: [  410.370230] RTW: 0x1D0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
    Apr  3 18:17:30 m0054 kernel: [  410.370308] RTW: 0x1F0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
    Apr  3 18:17:30 m0054 kernel: [  410.562635] RTW: [RF_PATH] ver_id.RF_TYPE:RF_1T1R
    Apr  3 18:17:30 m0054 kernel: [  410.562646] RTW: [RF_PATH] HALSPEC's rf_reg_trx_path_bmp:0x11, rf_reg_path_avail_num:1, max_tx_cnt:1
    Apr  3 18:17:30 m0054 kernel: [  410.562653] RTW: [RF_PATH] PG's trx_path_bmp:0x00, max_tx_cnt:0
    Apr  3 18:17:30 m0054 kernel: [  410.562665] RTW: [RF_PATH] HALDATA's trx_path_bmp:0x11, max_tx_cnt:1
    Apr  3 18:17:30 m0054 kernel: [  410.562680] RTW: [TRX_Nss] HALSPEC - tx_nss:1, rx_nss:1
    Apr  3 18:17:30 m0054 kernel: [  410.562686] RTW: [TRX_Nss] Registry - tx_nss:0, rx_nss:0
    Apr  3 18:17:30 m0054 kernel: [  410.562691] RTW: [TRX_Nss] HALDATA - tx_nss:1, rx_nss:1
    Apr  3 18:17:30 m0054 kernel: [  410.562700] RTW: txpath=0x1, rxpath=0x1
    Apr  3 18:17:30 m0054 kernel: [  410.562707] RTW: txpath_1ss:0x1, num:1
    Apr  3 18:17:30 m0054 kernel: [  410.563928] RTW: rtw_regsty_chk_target_tx_power_valid return _FALSE for band:0, path:0, rs:0, t:-1
    Apr  3 18:17:30 m0054 kernel: [  410.567269] RTW: rtw_ndev_init(wlan0) if1 mac_addr=00:c0:ca:b3:a4:ec
    Apr  3 18:17:30 m0054 systemd[1]: Starting Load/Save RF Kill Switch Status...
    Apr  3 18:17:30 m0054 systemd-rfkill[4511]: Failed to parse state file /var/lib/systemd/rfkill/platform-xhci-hcd.0.auto-usb-0:1:1.2:wlan: Invalid argument
    Apr  3 18:17:30 m0054 systemd[1]: Started Load/Save RF Kill Switch Status.
    Apr  3 18:17:31 m0054 dhcpcd[2755]: wlan0: waiting for carrier
    Apr  3 18:17:31 m0054 systemd-udevd[4512]: link_config: autonegotiation is unset or enabled, the speed and duplex are not writable.
    Apr  3 18:17:36 m0054 kernel: [  416.679144] RTW: wlan0- hw port(0) mac_addr =00:c0:ca:b3:a4:ec
    Apr  3 18:17:36 m0054 wpa_supplicant[1996]: wlan0: Trying to associate with 5c:e9:31:0a:78:24 (SSID='xxxxxx' freq=5200 MHz)
    Apr  3 18:17:36 m0054 wpa_supplicant[1996]: FT: Invalid key management type (2)
    Apr  3 18:17:36 m0054 kernel: [  416.734679] RTW: rtw_set_802_11_connect(wlan0)  fw_state=0x00000008
    Apr  3 18:17:36 m0054 kernel: [  416.868146] RTW: start auth
    Apr  3 18:17:36 m0054 kernel: [  416.871600] RTW: auth success, start assoc
    Apr  3 18:17:36 m0054 kernel: [  416.883349] RTW: assoc success
    Apr  3 18:17:36 m0054 wpa_supplicant[1996]: wlan0: Associated with 5c:e9:31:0a:78:24
    Apr  3 18:17:36 m0054 wpa_supplicant[1996]: wlan0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
    Apr  3 18:17:36 m0054 kernel: [  416.888060] RTW: curr_tx_rate : CCK_1M (L)
    Apr  3 18:17:36 m0054 kernel: [  416.888070] RTW: curr_retry_ratio : 0
    Apr  3 18:17:36 m0054 kernel: [  416.888075] RTW: ra_mask : 0x00000000003ffff0
    Apr  3 18:17:36 m0054 kernel: [  416.898522] RTW: recv eapol packet 1/4
    Apr  3 18:17:36 m0054 wpa_supplicant[1996]: wlan0: WPA: Key negotiation completed with 5c:e9:31:0a:78:24 [PTK=CCMP GTK=CCMP]
    Apr  3 18:17:36 m0054 wpa_supplicant[1996]: wlan0: CTRL-EVENT-CONNECTED - Connection to 5c:e9:31:0a:78:24 completed [id=0 id_str=]
    Apr  3 18:17:36 m0054 kernel: [  416.925772] RTW: set group key camid:1, addr:5c:e9:31:0a:78:24, kid:1, type:AES
    Apr  3 18:17:36 m0054 dhcpcd[2755]: wlan0: carrier acquired
    Apr  3 18:17:36 m0054 dhcpcd[2755]: wlan0: IAID ca:b3:a4:ec
    Apr  3 18:17:36 m0054 dhcpcd[2755]: wlan0: adding address fe80::5c1e:5176:405d:82d8
    Apr  3 18:17:37 m0054 dhcpcd[2755]: wlan0: soliciting an IPv6 router
    Apr  3 18:17:37 m0054 dhcpcd[2755]: wlan0: rebinding lease of 192.168.10.179
    Apr  3 18:17:37 m0054 dhcpcd[2755]: wlan0: truncated packet (179) from 127.0.0.1
    Apr  3 18:17:37 m0054 dhcpcd[2755]: wlan0: truncated packet (207) from 127.0.0.1
    Apr  3 18:17:37 m0054 dhcpcd[2755]: wlan0: probing address 192.168.10.179/24
    Apr  3 18:17:42 m0054 dhcpcd[2755]: wlan0: leased 192.168.10.179 for 7200 seconds
    Apr  3 18:17:42 m0054 dhcpcd[2755]: wlan0: adding route to 192.168.10.0/24
    Apr  3 18:17:42 m0054 dhcpcd[2755]: wlan0: adding default route via 192.168.10.1
    Apr  3 18:17:50 m0054 dhcpcd[2755]: wlan0: no IPv6 Routers available
    Alex KushleyevA S 2 Replies Last reply
      @SKA , please check the output of syslog, it may contain a hint as to why wlan0 has a static ip, maybe dhcpcd is not working properly.
        S Offline
        S Offline
        SKA
        wrote on last edited by SKA
        #16
        @Alex-Kushleyev When I run tail -n 100 /var/log/syslog, I don't see any messages coming from m0104 dhcpcd or m0104 wpa_supplicant
        edit: I turned the USB VBUS off and on, and saw this pop up on syslog:
        Apr  3 16:07:44 m0104 dhcpcd[2276]: wlan0: probing for an IPv4LL address
        • S SKA
          #17
          @SKA , can you also please check journalctl -u dhcpcd to see if there is anything interesting there?
          Apr 03 18:10:27 m0054 systemd[1]: Starting LSB: IPv4 DHCP client with IPv4LL support...
          Apr 03 18:10:27 m0054 dhcpcd[1982]: grep: /etc/network/interfaces: No such file or directory
          Apr 03 18:10:28 m0054 dhcpcd[2095]: DUID 00:01:00:01:2b:93:59:dc:ea:a6:9f:04:b1:61
          Apr 03 18:10:28 m0054 dhcpcd[2095]: wlan0: IAID ca:b3:a4:ec
          Apr 03 18:10:28 m0054 dhcpcd[2095]: wlan0: adding address fe80::10c0:dcc6:145e:c4cd
          Apr 03 18:10:28 m0054 dhcpcd[2095]: bond0: waiting for carrier
          Apr 03 18:10:28 m0054 dhcpcd[2095]: dummy0: waiting for carrier
          Apr 03 18:10:28 m0054 dhcpcd[2095]: wlan0: carrier lost
          Apr 03 18:10:28 m0054 dhcpcd[2095]: wlan0: deleting address fe80::10c0:dcc6:145e:c4cd
          Apr 03 18:10:28 m0054 dhcpcd[2095]: wlan0: carrier acquired
          Apr 03 18:10:28 m0054 dhcpcd[2095]: dummy0: carrier acquired
          Apr 03 18:10:28 m0054 dhcpcd[2095]: dummy0: IAID 5b:b6:cf:20
          Apr 03 18:10:28 m0054 dhcpcd[2095]: dummy0: adding address fe80::8837:2803:320d:3a20
          Apr 03 18:10:29 m0054 dhcpcd[2095]: dummy0: soliciting a DHCP lease
          Apr 03 18:10:29 m0054 dhcpcd[2095]: dummy0: soliciting an IPv6 router
          Apr 03 18:10:34 m0054 dhcpcd[2095]: wlan0: carrier acquired
          Apr 03 18:10:34 m0054 dhcpcd[2095]: wlan0: IAID ca:b3:a4:ec
          Apr 03 18:10:35 m0054 dhcpcd[2095]: wlan0: soliciting an IPv6 router
          Apr 03 18:10:35 m0054 dhcpcd[2095]: wlan0: rebinding lease of 192.168.10.179
          Apr 03 18:10:35 m0054 dhcpcd[2095]: wlan0: probing address 192.168.10.179/24
          Apr 03 18:10:40 m0054 dhcpcd[2095]: wlan0: leased 192.168.10.179 for 7200 seconds
          Apr 03 18:10:40 m0054 dhcpcd[2095]: wlan0: adding route to 192.168.10.0/24
          Apr 03 18:10:40 m0054 dhcpcd[2095]: wlan0: adding default route via 192.168.10.1
          Apr 03 18:10:40 m0054 dhcpcd[2095]: forked to background, child pid 2755
          Apr 03 18:10:40 m0054 systemd[1]: Started LSB: IPv4 DHCP client with IPv4LL support.
          Apr 03 18:10:41 m0054 dhcpcd[2755]: dummy0: no IPv6 Routers available
          S 1 Reply Last reply
            S Offline
            S Offline
            SKA
            #18
            @Alex-Kushleyev Here's what I see! I wonder if this is the problem:
            voxl2-mini (M0104):/$ journalctl -u dhcpcd
            -- Logs begin at Thu 2023-03-02 12:58:02 UTC, end at Fri 2026-04-03 16:11:48 UTC. --
            Mar 02 12:58:04 m0104 systemd[1]: Starting LSB: IPv4 DHCP client with IPv4LL support...
            Mar 02 12:58:04 m0104 dhcpcd[1250]: grep: /etc/network/interfaces: No such file or directory
            Mar 02 12:58:05 m0104 dhcpcd[1309]: no interfaces have a carrier
            Mar 02 12:58:05 m0104 dhcpcd[1309]: forked to background, child pid 1503
            Mar 02 12:58:05 m0104 systemd[1]: Started LSB: IPv4 DHCP client with IPv4LL support.
            Mar 02 12:58:06 m0104 dhcpcd[1503]: bond0: waiting for carrier
            Mar 02 12:58:06 m0104 dhcpcd[1503]: dummy0: waiting for carrier
            Mar 02 12:58:06 m0104 dhcpcd[1503]: wlan0: waiting for carrier
            Mar 02 12:58:06 m0104 dhcpcd[1503]: dummy0: carrier acquired
            Mar 02 12:58:06 m0104 dhcpcd[1503]: DUID 00:01:00:01:2b:93:59:de:b6:a9:9d:64:6d:02
            Mar 02 12:58:06 m0104 dhcpcd[1503]: dummy0: IAID 9d:64:6d:02
            Mar 02 12:58:06 m0104 dhcpcd[1503]: dummy0: adding address fe80::54fe:595c:4ff6:b95c
            Mar 02 12:58:06 m0104 dhcpcd[1503]: dummy0: soliciting a DHCP lease
            Mar 02 12:58:07 m0104 dhcpcd[1503]: dummy0: soliciting an IPv6 router
            Mar 02 12:58:10 m0104 dhcpcd[1503]: wlan0: carrier acquired
            Mar 02 12:58:10 m0104 dhcpcd[1503]: wlan0: IAID ca:b3:a6:89
            Mar 02 12:58:10 m0104 dhcpcd[1503]: wlan0: adding address fe80::bc34:9301:bd06:6b68
            Mar 02 12:58:11 m0104 dhcpcd[1503]: wlan0: soliciting a DHCP lease
            Mar 02 12:58:11 m0104 dhcpcd[1503]: wlan0: soliciting an IPv6 router
            Mar 02 12:58:12 m0104 dhcpcd[1503]: wlan0: offered 10.10.10.116 from 10.10.10.1
            Mar 02 12:58:12 m0104 dhcpcd[1503]: wlan0: probing address 10.10.10.116/24
            Mar 02 12:58:17 m0104 dhcpcd[1503]: wlan0: leased 10.10.10.116 for 86400 seconds
            Mar 02 12:58:17 m0104 dhcpcd[1503]: wlan0: adding route to 10.10.10.0/24
            Mar 02 12:58:17 m0104 dhcpcd[1503]: wlan0: adding default route via 10.10.10.1
            Mar 02 12:58:19 m0104 dhcpcd[1503]: dummy0: no IPv6 Routers available
            Mar 02 12:58:24 m0104 dhcpcd[1503]: wlan0: no IPv6 Routers available
            -- Reboot --
            Apr 03 15:39:02 m0104 systemd[1]: Starting LSB: IPv4 DHCP client with IPv4LL support...
            Apr 03 15:39:02 m0104 dhcpcd[1899]: grep: /etc/network/interfaces: No such file or directory
            Apr 03 15:39:03 m0104 dhcpcd[2026]: no interfaces have a carrier
            Apr 03 15:39:03 m0104 dhcpcd[2262]: bond0: waiting for carrier
            Apr 03 15:39:03 m0104 dhcpcd[2262]: dummy0: waiting for carrier
            Apr 03 15:39:03 m0104 dhcpcd[2262]: wlan0: waiting for carrier
            Apr 03 15:39:03 m0104 dhcpcd[2262]: dummy0: carrier acquired
            Apr 03 15:39:03 m0104 dhcpcd[2026]: forked to background, child pid 2262
            Apr 03 15:39:03 m0104 systemd[1]: Started LSB: IPv4 DHCP client with IPv4LL support.
            Apr 03 15:39:03 m0104 dhcpcd[2262]: DUID 00:01:00:01:2b:93:59:de:b6:a9:9d:64:6d:02
            Apr 03 15:39:03 m0104 dhcpcd[2262]: dummy0: IAID 7e:3c:18:e8
            Apr 03 15:39:03 m0104 dhcpcd[2262]: dummy0: adding address fe80::e48d:a57d:cf5f:95ce
            Apr 03 15:39:03 m0104 dhcpcd[2262]: dummy0: soliciting an IPv6 router
            Apr 03 15:39:04 m0104 dhcpcd[2262]: dummy0: soliciting a DHCP lease
            Apr 03 15:39:12 m0104 dhcpcd[2262]: wlan0: carrier acquired
            Apr 03 15:39:12 m0104 dhcpcd[2262]: wlan0: IAID ca:b3:a6:89
            Apr 03 15:39:12 m0104 dhcpcd[2262]: wlan0: adding address fe80::bc34:9301:bd06:6b68
            Apr 03 15:39:12 m0104 dhcpcd[2262]: wlan0: soliciting a DHCP lease
            Apr 03 15:39:12 m0104 dhcpcd[2262]: wlan0: offered 10.10.10.116 from 10.10.10.1
            Apr 03 15:39:12 m0104 dhcpcd[2262]: wlan0: probing address 10.10.10.116/24
            Apr 03 15:39:13 m0104 dhcpcd[2262]: wlan0: soliciting an IPv6 router
            Apr 03 15:39:15 m0104 dhcpcd[2262]: dummy0: no IPv6 Routers available
            Apr 03 15:39:17 m0104 dhcpcd[2262]: wlan0: leased 10.10.10.116 for 86400 seconds
            Apr 03 15:39:17 m0104 dhcpcd[2262]: wlan0: adding route to 10.10.10.0/24
            Apr 03 15:39:17 m0104 dhcpcd[2262]: wlan0: adding default route via 10.10.10.1
            Apr 03 15:39:26 m0104 dhcpcd[2262]: wlan0: no IPv6 Routers available
            -- Reboot --
            Apr 03 15:39:54 m0104 systemd[1]: Starting LSB: IPv4 DHCP client with IPv4LL support...
            -- Reboot --
            -- Reboot --
            -- Reboot --
            -- Reboot --
            -- Reboot --
            -- Reboot --
            -- Reboot --
            --More--
            • S SKA
              -- Reboot --
              -- Reboot --
              -- Reboot --
              -- Reboot --
              -- Reboot --
              -- Reboot --
              -- Reboot --
              -- Reboot --
              -- Reboot --
              --More--
              @SKA ,
              I have the same same error, but wifi is working (/etc/network/interfaces: No such file or directory).
              I also see that your dhcp client is able to get an ip address 10.10.10.116 for wlan0, which is strange that you don't see that ip address in ifconfig..
                @SKA ,
                can you please check output of ifconfig ? i wonder if wlan0 is not the primary interface for some reason
                  S Offline
                  S Offline
                  SKA
                  wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 2312
                          inet 169.254.233.208  netmask 255.255.0.0  broadcast 169.254.255.255
                          inet6 fe80::ddc:47bd:f5ec:71dd  prefixlen 64  scopeid 0x20<link>
                          ether 10:5a:95:c7:9e:69  txqueuelen 1000  (Ethernet)
                          RX packets 0  bytes 0 (0.0 B)
                          TX packets 0  bytes 0 (0.0 B)
                          TX errors 0  dropped 30 overruns 0  carrier 0  collisions 0
                  • S SKA
                    @SKA , thank you for providing all the information. We are doing more testing and will get back to you. So far cannot reproduce.
                    M 1 Reply Last reply
                      M Offline
                      M Offline
                      Matt69
                      @Alex-Kushleyev I reflashed 1.6.3 on the VOXL 2 twice and it seemed to fix it the second time. Weird that it fixed it and I am also unable to reproduce the issue again. At least it works now lol.
