  3. Starling 2 Max Motor Catches
starling
9 Posts 4 Posters 736 Views 2 Watching
  • R Offline
    R Offline
    RyanH
    We've noticed on our Starling 2 Max that one of the motors feels like it catches/seizes, i.e. while spinning it by hand it will spin smoothly, but then will sometimes grab/seize and require force to make it continue to spin. The UAS has not crashed and we do not see any debris in the motor. Is this typical and/or safe, or should we replace the motor (2203.5 KV1500)? We assume the latter, in which case do you sell the motor, and can you give us a SKU/cost? I don't see it listed on your web-site.
    • R RyanH
      @RyanH I'll let another of my associates comment on the purchase of a new motor. But can you also share a px4 log file from such a flight. It would be helpful for us to take a look at it.
      R 1 Reply Last reply
        R Offline
        R Offline
        RyanH
        wrote on last edited by RyanH
        @Eric-Katzfey , we noticed this while preparing for a flight, i.e., just spinning each of the motors/props by hand. After having it catch we did not feel comfortable flying it. The last time we flew the drone was months ago and I don't have a Px4 log from that flight.
        • R RyanH
          @RyanH You don't need to fly the drone to get a log. Perhaps take off the props, arm it, throttle it up a few times, then disarm.
            R Offline
            R Offline
            RyanH
            @Eric-Katzfey , thanks, will try later this week and post the px4 log. In the mean-time, if you have the part number info I might also try and get a purchase going if possible.
            ModeratorM 1 Reply Last reply
            • R RyanH
              @RyanH
              T-motor has been banned in the US, so we can't purchase those directly any longer and have moved to a different motor for the product
              this might be a good place to purchase a replacement motor https://www.amazon.com/TYXTTGY-F2203-5-Brushless-Motor-Cinewhoop/dp/B0F21NFKKW?th=1
              it looks to have the same specs as t-motor
              • ModeratorM Moderator
                @RyanH
                Alex KushleyevA Online
                @RyanH ,
                Sometimes there is small pieces of random magnetic debris that gets stuck in the motor.
                First, you could try using compressed air to clear out the motor.
                Additionally, It could help to spin the motor up and down using voxl-esc command line tools a few times to clear it out (without prop is best, just for safety). Spinning the motor without prop a bunch of times could get the debris dislodged and actually broken up by the moving motor parts, so that the debris is no longer large enough to cause a problem. Reversing motor spin using voxl-esc test tools can help dislodge the debris (you can commend negative power/rpm).
                You can find useful info regarding motor testing here : https://docs.modalai.com/voxl-escs/faq/
                  @RyanH ,
                  R Offline
                  R Offline
                  RyanH
                  @Alex-Kushleyev , we tried the voxl-esc command and the motor seizes while performing the test. We did not get a chance to try reversing the motor spin, but will try that next week. I'm not sure we'll be able to buy the replacement motor mentioned above due to purchasing restrictions on our end, but I'll keep looking around. What motors are you installing on Starling 2 Max now? Do they use the same mount as the old motors, i.e. can I just buy 4 of the newer motors from you and install them on our older drone?
                  Here is a partial output from the voxl-esc test. The issue is with motor 0. You'll see the RPMs go to 0 around 2.5s into the run.
                  What do you want to do?
                  1. scan 3) spin 5) upload_params
                  2. detect 4) upgrade_firmware
                    #? 3
                    enabling bridge
                    bridge enabled
                    [GCC 8.4.0]
                    VOXL Platform: M0054
                  INFO: ESC Information:
                  INFO: ---------------------
                  Board : version 40: ModalAi 4-in-1 ESC (M0129-3)
                  UID : 0x2039333557555311001E002C
                  Firmware : version 39, hash 9c6233d6
                  Bootloader : version 184, hash 10bf24c8
                  UID        : 0x2039333557555311001E0030
                  UID        : 0x2039333557555311001E002E
                  UID        : 0x2039333557555311001E002A
                  [GCC 8.4.0]
                  WARNING: skipping user prompt to start the test due to override
                  [0.015] (0) RPM: 0, PWR: 0, VOLTAGE: 14.583V, TEMPERATURE: 45.60C, CURRENT: 0.000A
                  [0.034] (0) RPM: 13, PWR: 2, VOLTAGE: 14.582V, TEMPERATURE: 45.59C, CURRENT: 0.000A
                  [0.056] (0) RPM: 54, PWR: 11, VOLTAGE: 14.537V, TEMPERATURE: 45.70C, CURRENT: 0.000A
                  [0.072] (0) RPM: 77, PWR: 14, VOLTAGE: 14.513V, TEMPERATURE: 45.65C, CURRENT: 0.000A
                  [0.095] (0) RPM: 91, PWR: 14, VOLTAGE: 14.506V, TEMPERATURE: 45.64C, CURRENT: 0.000A
                  [0.114] (0) RPM: 118, PWR: 14, VOLTAGE: 14.498V, TEMPERATURE: 45.66C, CURRENT: 0.000A
                  [0.138] (0) RPM: 146, PWR: 14, VOLTAGE: 14.498V, TEMPERATURE: 45.70C, CURRENT: 0.000A
                  [0.155] (0) RPM: 185, PWR: 14, VOLTAGE: 14.498V, TEMPERATURE: 45.71C, CURRENT: 0.000A
                  [0.174] (0) RPM: 199, PWR: 14, VOLTAGE: 14.492V, TEMPERATURE: 45.71C, CURRENT: 0.000A
                  [0.198] (0) RPM: 227, PWR: 14, VOLTAGE: 14.487V, TEMPERATURE: 45.70C, CURRENT: 0.000A
                  [0.215] (0) RPM: 266, PWR: 15, VOLTAGE: 14.488V, TEMPERATURE: 45.67C, CURRENT: 0.000A
                  [0.234] (0) RPM: 278, PWR: 15, VOLTAGE: 14.488V, TEMPERATURE: 45.69C, CURRENT: 0.000A
                  [0.258] (0) RPM: 306, PWR: 15, VOLTAGE: 14.491V, TEMPERATURE: 45.69C, CURRENT: 0.000A
                  [0.274] (0) RPM: 346, PWR: 15, VOLTAGE: 14.480V, TEMPERATURE: 45.76C, CURRENT: 0.000A
                  [0.294] (0) RPM: 358, PWR: 15, VOLTAGE: 14.479V, TEMPERATURE: 45.79C, CURRENT: 0.000A
                  [0.316] (0) RPM: 387, PWR: 15, VOLTAGE: 14.473V, TEMPERATURE: 45.81C, CURRENT: 0.000A
                  [0.332] (0) RPM: 415, PWR: 15, VOLTAGE: 14.484V, TEMPERATURE: 45.71C, CURRENT: 0.000A
                  [0.354] (0) RPM: 436, PWR: 15, VOLTAGE: 14.475V, TEMPERATURE: 45.74C, CURRENT: 0.000A
                  [0.379] (0) RPM: 465, PWR: 16, VOLTAGE: 14.481V, TEMPERATURE: 45.77C, CURRENT: 0.000A
                  [0.395] (0) RPM: 491, PWR: 16, VOLTAGE: 14.478V, TEMPERATURE: 45.76C, CURRENT: 0.000A
                  [0.418] (0) RPM: 519, PWR: 16, VOLTAGE: 14.469V, TEMPERATURE: 45.82C, CURRENT: 0.000A
                  [0.435] (0) RPM: 559, PWR: 16, VOLTAGE: 14.468V, TEMPERATURE: 45.85C, CURRENT: 0.000A
                  [0.454] (0) RPM: 572, PWR: 16, VOLTAGE: 14.472V, TEMPERATURE: 45.84C, CURRENT: 0.000A
                  [0.480] (0) RPM: 600, PWR: 16, VOLTAGE: 14.467V, TEMPERATURE: 45.84C, CURRENT: 0.000A
                  [0.499] (0) RPM: 625, PWR: 16, VOLTAGE: 14.467V, TEMPERATURE: 45.83C, CURRENT: 0.000A
                  [0.515] (0) RPM: 666, PWR: 17, VOLTAGE: 14.464V, TEMPERATURE: 45.81C, CURRENT: 0.000A
                  [0.534] (0) RPM: 679, PWR: 17, VOLTAGE: 14.464V, TEMPERATURE: 45.79C, CURRENT: 0.000A
                  [0.559] (0) RPM: 707, PWR: 17, VOLTAGE: 14.457V, TEMPERATURE: 45.88C, CURRENT: 0.000A
                  [0.574] (0) RPM: 745, PWR: 17, VOLTAGE: 14.460V, TEMPERATURE: 45.92C, CURRENT: 0.000A
                  [0.594] (0) RPM: 758, PWR: 17, VOLTAGE: 14.460V, TEMPERATURE: 45.94C, CURRENT: 0.000A
                  [0.616] (0) RPM: 801, PWR: 17, VOLTAGE: 14.453V, TEMPERATURE: 46.02C, CURRENT: 0.000A
                  [0.634] (0) RPM: 825, PWR: 17, VOLTAGE: 14.458V, TEMPERATURE: 45.97C, CURRENT: 0.000A
                  [0.654] (0) RPM: 844, PWR: 17, VOLTAGE: 14.456V, TEMPERATURE: 46.00C, CURRENT: 0.000A
                  [0.674] (0) RPM: 878, PWR: 18, VOLTAGE: 14.460V, TEMPERATURE: 45.99C, CURRENT: 0.000A
                  [0.694] (0) RPM: 898, PWR: 18, VOLTAGE: 14.459V, TEMPERATURE: 45.98C, CURRENT: 0.000A
                  [0.716] (0) RPM: 934, PWR: 18, VOLTAGE: 14.460V, TEMPERATURE: 46.04C, CURRENT: 0.000A
                  [0.734] (0) RPM: 945, PWR: 18, VOLTAGE: 14.458V, TEMPERATURE: 46.02C, CURRENT: 0.000A
                  [0.759] (0) RPM: 973, PWR: 18, VOLTAGE: 14.458V, TEMPERATURE: 46.06C, CURRENT: 0.000A
                  [0.775] (0) RPM: 1013, PWR: 18, VOLTAGE: 14.454V, TEMPERATURE: 46.08C, CURRENT: 0.000A
                  [0.795] (0) RPM: 1024, PWR: 18, VOLTAGE: 14.451V, TEMPERATURE: 46.12C, CURRENT: 0.000A
                  [0.818] (0) RPM: 1052, PWR: 18, VOLTAGE: 14.449V, TEMPERATURE: 46.12C, CURRENT: 0.000A
                  [0.833] (0) RPM: 1090, PWR: 19, VOLTAGE: 14.450V, TEMPERATURE: 46.17C, CURRENT: 0.000A
                  [0.854] (0) RPM: 1102, PWR: 19, VOLTAGE: 14.446V, TEMPERATURE: 46.26C, CURRENT: 0.000A
                  [0.875] (0) RPM: 1146, PWR: 19, VOLTAGE: 14.444V, TEMPERATURE: 46.25C, CURRENT: 0.000A
                  [0.894] (0) RPM: 1158, PWR: 19, VOLTAGE: 14.446V, TEMPERATURE: 46.26C, CURRENT: 0.000A
                  [0.919] (0) RPM: 1187, PWR: 19, VOLTAGE: 14.448V, TEMPERATURE: 46.27C, CURRENT: 0.000A
                  [0.936] (0) RPM: 1226, PWR: 19, VOLTAGE: 14.444V, TEMPERATURE: 46.33C, CURRENT: 0.000A
                  [0.954] (0) RPM: 1238, PWR: 19, VOLTAGE: 14.440V, TEMPERATURE: 46.32C, CURRENT: 0.000A
                  [0.979] (0) RPM: 1267, PWR: 19, VOLTAGE: 14.439V, TEMPERATURE: 46.42C, CURRENT: 0.000A
                  [0.996] (0) RPM: 1306, PWR: 20, VOLTAGE: 14.438V, TEMPERATURE: 46.48C, CURRENT: 0.000A
                  [1.014] (0) RPM: 1318, PWR: 20, VOLTAGE: 14.436V, TEMPERATURE: 46.47C, CURRENT: 0.000A
                  [1.039] (0) RPM: 1347, PWR: 20, VOLTAGE: 14.436V, TEMPERATURE: 46.47C, CURRENT: 0.000A
                  [1.055] (0) RPM: 1386, PWR: 20, VOLTAGE: 14.438V, TEMPERATURE: 46.51C, CURRENT: 0.000A
                  [1.074] (0) RPM: 1398, PWR: 20, VOLTAGE: 14.430V, TEMPERATURE: 46.58C, CURRENT: 0.000A
                  [1.098] (0) RPM: 1426, PWR: 20, VOLTAGE: 14.435V, TEMPERATURE: 46.54C, CURRENT: 0.000A
                  [1.116] (0) RPM: 1466, PWR: 20, VOLTAGE: 14.427V, TEMPERATURE: 46.61C, CURRENT: 0.000A
                  [1.134] (0) RPM: 1478, PWR: 20, VOLTAGE: 14.430V, TEMPERATURE: 46.61C, CURRENT: 0.000A
                  [1.158] (0) RPM: 1506, PWR: 21, VOLTAGE: 14.428V, TEMPERATURE: 46.69C, CURRENT: 0.000A
                  [1.175] (0) RPM: 1546, PWR: 21, VOLTAGE: 14.427V, TEMPERATURE: 46.72C, CURRENT: 0.000A
                  [1.194] (0) RPM: 1558, PWR: 21, VOLTAGE: 14.426V, TEMPERATURE: 46.77C, CURRENT: 0.000A
                  [1.219] (0) RPM: 1586, PWR: 21, VOLTAGE: 14.429V, TEMPERATURE: 46.81C, CURRENT: 0.000A
                  [1.236] (0) RPM: 1627, PWR: 21, VOLTAGE: 14.426V, TEMPERATURE: 46.79C, CURRENT: 0.000A
                  [1.254] (0) RPM: 1638, PWR: 21, VOLTAGE: 14.425V, TEMPERATURE: 46.81C, CURRENT: 0.000A
                  [1.278] (0) RPM: 1665, PWR: 21, VOLTAGE: 14.427V, TEMPERATURE: 46.86C, CURRENT: 0.000A
                  [1.294] (0) RPM: 1705, PWR: 22, VOLTAGE: 14.420V, TEMPERATURE: 46.91C, CURRENT: 0.000A
                  [1.314] (0) RPM: 1718, PWR: 22, VOLTAGE: 14.420V, TEMPERATURE: 46.94C, CURRENT: 0.000A
                  [1.338] (0) RPM: 1746, PWR: 22, VOLTAGE: 14.422V, TEMPERATURE: 46.96C, CURRENT: 0.000A
                  [1.355] (0) RPM: 1785, PWR: 22, VOLTAGE: 14.419V, TEMPERATURE: 47.04C, CURRENT: 0.000A
                  [1.374] (0) RPM: 1798, PWR: 22, VOLTAGE: 14.422V, TEMPERATURE: 47.06C, CURRENT: 0.000A
                  [1.399] (0) RPM: 1825, PWR: 22, VOLTAGE: 14.421V, TEMPERATURE: 47.05C, CURRENT: 0.000A
                  [1.414] (0) RPM: 1864, PWR: 22, VOLTAGE: 14.421V, TEMPERATURE: 47.11C, CURRENT: 0.000A
                  [1.434] (0) RPM: 1877, PWR: 22, VOLTAGE: 14.419V, TEMPERATURE: 47.09C, CURRENT: 0.000A
                  [1.459] (0) RPM: 1906, PWR: 23, VOLTAGE: 14.421V, TEMPERATURE: 47.09C, CURRENT: 0.000A
                  [1.475] (0) RPM: 1945, PWR: 23, VOLTAGE: 14.414V, TEMPERATURE: 47.17C, CURRENT: 0.000A
                  [1.494] (0) RPM: 1957, PWR: 23, VOLTAGE: 14.415V, TEMPERATURE: 47.15C, CURRENT: 0.000A
                  [1.519] (0) RPM: 1986, PWR: 23, VOLTAGE: 14.413V, TEMPERATURE: 47.24C, CURRENT: 0.000A
                  [1.535] (0) RPM: 2112, PWR: 10, VOLTAGE: 14.535V, TEMPERATURE: 47.25C, CURRENT: 0.000A
                  [1.554] (0) RPM: 2194, PWR: 9, VOLTAGE: 14.541V, TEMPERATURE: 47.28C, CURRENT: 0.000A
                  [1.583] (0) RPM: 2194, PWR: 9, VOLTAGE: 14.541V, TEMPERATURE: 47.28C, CURRENT: 0.000A
                  [1.597] (0) RPM: 2178, PWR: 9, VOLTAGE: 14.551V, TEMPERATURE: 47.28C, CURRENT: 0.000A
                  [1.614] (0) RPM: 2173, PWR: 9, VOLTAGE: 14.554V, TEMPERATURE: 47.35C, CURRENT: 0.000A
                  [1.634] (0) RPM: 2159, PWR: 9, VOLTAGE: 14.555V, TEMPERATURE: 47.37C, CURRENT: 0.000A
                  [1.658] (0) RPM: 2157, PWR: 9, VOLTAGE: 14.555V, TEMPERATURE: 47.37C, CURRENT: 0.000A
                  [1.674] (0) RPM: 2157, PWR: 9, VOLTAGE: 14.558V, TEMPERATURE: 47.41C, CURRENT: 0.000A
                  [1.694] (0) RPM: 2177, PWR: 9, VOLTAGE: 14.554V, TEMPERATURE: 47.42C, CURRENT: 0.000A
                  [1.718] (0) RPM: 2143, PWR: 9, VOLTAGE: 14.559V, TEMPERATURE: 47.47C, CURRENT: 0.000A
                  [1.734] (0) RPM: 2135, PWR: 9, VOLTAGE: 14.557V, TEMPERATURE: 47.51C, CURRENT: 0.000A
                  [1.754] (0) RPM: 2136, PWR: 9, VOLTAGE: 14.559V, TEMPERATURE: 47.50C, CURRENT: 0.000A
                  [1.778] (0) RPM: 2125, PWR: 9, VOLTAGE: 14.560V, TEMPERATURE: 47.50C, CURRENT: 0.000A
                  [1.794] (0) RPM: 2124, PWR: 9, VOLTAGE: 14.552V, TEMPERATURE: 47.59C, CURRENT: 0.000A
                  [1.814] (0) RPM: 2125, PWR: 9, VOLTAGE: 14.552V, TEMPERATURE: 47.57C, CURRENT: 0.000A
                  [1.838] (0) RPM: 2103, PWR: 9, VOLTAGE: 14.553V, TEMPERATURE: 47.68C, CURRENT: 0.000A
                  [1.854] (0) RPM: 2093, PWR: 9, VOLTAGE: 14.560V, TEMPERATURE: 47.64C, CURRENT: 0.000A
                  [1.874] (0) RPM: 2096, PWR: 9, VOLTAGE: 14.557V, TEMPERATURE: 47.65C, CURRENT: 0.000A
                  [1.899] (0) RPM: 2105, PWR: 9, VOLTAGE: 14.556V, TEMPERATURE: 47.70C, CURRENT: 0.000A
                  [1.915] (0) RPM: 2108, PWR: 9, VOLTAGE: 14.561V, TEMPERATURE: 47.68C, CURRENT: 0.000A
                  [1.934] (0) RPM: 2090, PWR: 9, VOLTAGE: 14.559V, TEMPERATURE: 47.69C, CURRENT: 0.000A
                  [1.958] (0) RPM: 2096, PWR: 9, VOLTAGE: 14.559V, TEMPERATURE: 47.70C, CURRENT: 0.000A
                  [1.975] (0) RPM: 2079, PWR: 9, VOLTAGE: 14.559V, TEMPERATURE: 47.75C, CURRENT: 0.000A
                  [1.994] (0) RPM: 2073, PWR: 9, VOLTAGE: 14.559V, TEMPERATURE: 47.76C, CURRENT: 0.000A
                  [2.019] (0) RPM: 2008, PWR: 9, VOLTAGE: 14.558V, TEMPERATURE: 47.73C, CURRENT: 0.000A
                  [2.035] (0) RPM: 2076, PWR: 9, VOLTAGE: 14.558V, TEMPERATURE: 47.74C, CURRENT: 0.000A
                  [2.055] (0) RPM: 2066, PWR: 9, VOLTAGE: 14.560V, TEMPERATURE: 47.71C, CURRENT: 0.000A
                  [2.079] (0) RPM: 2093, PWR: 9, VOLTAGE: 14.557V, TEMPERATURE: 47.73C, CURRENT: 0.000A
                  [2.095] (0) RPM: 2058, PWR: 9, VOLTAGE: 14.560V, TEMPERATURE: 47.76C, CURRENT: 0.000A
                  [2.114] (0) RPM: 2068, PWR: 9, VOLTAGE: 14.559V, TEMPERATURE: 47.79C, CURRENT: 0.000A
                  [2.138] (0) RPM: 2058, PWR: 9, VOLTAGE: 14.560V, TEMPERATURE: 47.78C, CURRENT: 0.000A
                  [2.155] (0) RPM: 2054, PWR: 9, VOLTAGE: 14.560V, TEMPERATURE: 47.77C, CURRENT: 0.000A
                  [2.174] (0) RPM: 2062, PWR: 9, VOLTAGE: 14.559V, TEMPERATURE: 47.84C, CURRENT: 0.000A
                  [2.198] (0) RPM: 2057, PWR: 9, VOLTAGE: 14.555V, TEMPERATURE: 47.84C, CURRENT: 0.000A
                  [2.214] (0) RPM: 2044, PWR: 9, VOLTAGE: 14.558V, TEMPERATURE: 47.84C, CURRENT: 0.000A
                  [2.234] (0) RPM: 2002, PWR: 9, VOLTAGE: 14.554V, TEMPERATURE: 47.89C, CURRENT: 0.000A
                  [2.254] (0) RPM: 2041, PWR: 9, VOLTAGE: 14.559V, TEMPERATURE: 47.86C, CURRENT: 0.000A
                  [2.274] (0) RPM: 2037, PWR: 9, VOLTAGE: 14.557V, TEMPERATURE: 47.88C, CURRENT: 0.000A
                  [2.294] (0) RPM: 2052, PWR: 9, VOLTAGE: 14.556V, TEMPERATURE: 47.91C, CURRENT: 0.000A
                  [2.315] (0) RPM: 2044, PWR: 9, VOLTAGE: 14.552V, TEMPERATURE: 47.90C, CURRENT: 0.000A
                  [2.334] (0) RPM: 2035, PWR: 9, VOLTAGE: 14.552V, TEMPERATURE: 47.91C, CURRENT: 0.000A
                  [2.359] (0) RPM: 2015, PWR: 9, VOLTAGE: 14.557V, TEMPERATURE: 47.90C, CURRENT: 0.000A
                  [2.375] (0) RPM: 2038, PWR: 9, VOLTAGE: 14.560V, TEMPERATURE: 47.88C, CURRENT: 0.000A
                  [2.394] (0) RPM: 2020, PWR: 9, VOLTAGE: 14.559V, TEMPERATURE: 47.90C, CURRENT: 0.000A
                  [2.419] (0) RPM: 2030, PWR: 9, VOLTAGE: 14.562V, TEMPERATURE: 47.86C, CURRENT: 0.000A
                  [2.436] (0) RPM: 2039, PWR: 9, VOLTAGE: 14.559V, TEMPERATURE: 47.84C, CURRENT: 0.000A
                  [2.454] (0) RPM: 1981, PWR: 9, VOLTAGE: 14.558V, TEMPERATURE: 47.88C, CURRENT: 0.000A
                  [2.480] (0) RPM: 1562, PWR: 11, VOLTAGE: 14.513V, TEMPERATURE: 47.91C, CURRENT: 0.000A
                  [2.496] (0) RPM: 0, PWR: 0, VOLTAGE: 14.541V, TEMPERATURE: 47.99C, CURRENT: 0.000A
                  [2.514] (0) RPM: 0, PWR: 0, VOLTAGE: 14.555V, TEMPERATURE: 47.98C, CURRENT: 0.000A
                  [2.538] (0) RPM: 28, PWR: 5, VOLTAGE: 14.553V, TEMPERATURE: 47.96C, CURRENT: 0.000A
                  [2.555] (0) RPM: 67, PWR: 14, VOLTAGE: 14.502V, TEMPERATURE: 47.96C, CURRENT: 0.000A
                  [2.573] (0) RPM: 92, PWR: 14, VOLTAGE: 14.491V, TEMPERATURE: 47.87C, CURRENT: 0.000A
                  [2.596] (0) RPM: 109, PWR: 14, VOLTAGE: 14.485V, TEMPERATURE: 47.89C, CURRENT: 0.000A
                  [2.614] (0) RPM: 133, PWR: 14, VOLTAGE: 14.484V, TEMPERATURE: 47.89C, CURRENT: 0.000A
                  [2.638] (0) RPM: 162, PWR: 14, VOLTAGE: 14.484V, TEMPERATURE: 47.92C, CURRENT: 0.000A
                  [2.654] (0) RPM: 200, PWR: 14, VOLTAGE: 14.484V, TEMPERATURE: 47.92C, CURRENT: 0.000A
                  [2.675] (0) RPM: 213, PWR: 14, VOLTAGE: 14.482V, TEMPERATURE: 47.92C, CURRENT: 0.000A
                  [2.699] (0) RPM: 241, PWR: 15, VOLTAGE: 14.484V, TEMPERATURE: 47.91C, CURRENT: 0.000A
                  [2.719] (0) RPM: 266, PWR: 15, VOLTAGE: 14.481V, TEMPERATURE: 47.93C, CURRENT: 0.000A
                  [2.734] (0) RPM: 293, PWR: 15, VOLTAGE: 14.478V, TEMPERATURE: 47.93C, CURRENT: 0.000A
                  [2.758] (0) RPM: 320, PWR: 15, VOLTAGE: 14.475V, TEMPERATURE: 47.93C, CURRENT: 0.000A
                  [2.774] (0) RPM: 360, PWR: 15, VOLTAGE: 14.475V, TEMPERATURE: 47.94C, CURRENT: 0.000A
                  [2.794] (0) RPM: 373, PWR: 15, VOLTAGE: 14.474V, TEMPERATURE: 47.92C, CURRENT: 0.000A
                  [2.820] (0) RPM: 401, PWR: 15, VOLTAGE: 14.463V, TEMPERATURE: 47.92C, CURRENT: 0.000A
                  [2.837] (0) RPM: 426, PWR: 15, VOLTAGE: 14.465V, TEMPERATURE: 47.95C, CURRENT: 0.000A
                  [2.854] (0) RPM: 466, PWR: 16, VOLTAGE: 14.464V, TEMPERATURE: 47.97C, CURRENT: 0.000A
                  [2.874] (0) RPM: 485, PWR: 16, VOLTAGE: 14.463V, TEMPERATURE: 47.98C, CURRENT: 0.000A
                  [2.894] (0) RPM: 520, PWR: 16, VOLTAGE: 14.456V, TEMPERATURE: 48.02C, CURRENT: 0.000A
                  [2.914] (0) RPM: 533, PWR: 16, VOLTAGE: 14.458V, TEMPERATURE: 48.02C, CURRENT: 0.000A
                  [2.938] (0) RPM: 561, PWR: 16, VOLTAGE: 14.454V, TEMPERATURE: 48.07C, CURRENT: 0.000A
                  [2.955] (0) RPM: 600, PWR: 16, VOLTAGE: 14.454V, TEMPERATURE: 48.01C, CURRENT: 0.000A
                  [2.974] (0) RPM: 612, PWR: 16, VOLTAGE: 14.456V, TEMPERATURE: 48.04C, CURRENT: 0.000A
                  [2.999] (0) RPM: 640, PWR: 16, VOLTAGE: 14.452V, TEMPERATURE: 48.05C, CURRENT: 0.000A
                  [3.015] (0) RPM: 680, PWR: 17, VOLTAGE: 14.450V, TEMPERATURE: 48.08C, CURRENT: 0.000A
                  [3.034] (0) RPM: 692, PWR: 17, VOLTAGE: 14.455V, TEMPERATURE: 48.08C, CURRENT: 0.000A
                  [3.058] (0) RPM: 721, PWR: 17, VOLTAGE: 14.447V, TEMPERATURE: 48.06C, CURRENT: 0.000A
                  [3.076] (0) RPM: 761, PWR: 17, VOLTAGE: 14.444V, TEMPERATURE: 48.17C, CURRENT: 0.000A
                  [3.094] (0) RPM: 772, PWR: 17, VOLTAGE: 14.440V, TEMPERATURE: 48.17C, CURRENT: 0.000A
                  [3.119] (0) RPM: 801, PWR: 17, VOLTAGE: 14.443V, TEMPERATURE: 48.17C, CURRENT: 0.000A
                  [3.136] (0) RPM: 840, PWR: 17, VOLTAGE: 14.441V, TEMPERATURE: 48.16C, CURRENT: 0.000A
                  [3.154] (0) RPM: 853, PWR: 18, VOLTAGE: 14.436V, TEMPERATURE: 48.20C, CURRENT: 0.000A
                  [3.179] (0) RPM: 880, PWR: 18, VOLTAGE: 14.437V, TEMPERATURE: 48.16C, CURRENT: 0.000A
                  [3.195] (0) RPM: 920, PWR: 18, VOLTAGE: 14.436V, TEMPERATURE: 48.23C, CURRENT: 0.000A
                  [3.214] (0) RPM: 933, PWR: 18, VOLTAGE: 14.433V, TEMPERATURE: 48.25C, CURRENT: 0.000A
                  [3.238] (0) RPM: 960, PWR: 18, VOLTAGE: 14.432V, TEMPERATURE: 48.24C, CURRENT: 0.000A
                  [3.255] (0) RPM: 1000, PWR: 18, VOLTAGE: 14.428V, TEMPERATURE: 48.24C, CURRENT: 0.000A
                  [3.274] (0) RPM: 1012, PWR: 18, VOLTAGE: 14.425V, TEMPERATURE: 48.23C, CURRENT: 0.000A
                  [3.299] (0) RPM: 1040, PWR: 18, VOLTAGE: 14.424V, TEMPERATURE: 48.27C, CURRENT: 0.000A
                  [3.322] (0) RPM: 1065, PWR: 19, VOLTAGE: 14.416V, TEMPERATURE: 48.29C, CURRENT: 0.000A
                  [3.334] (0) RPM: 1096, PWR: 19, VOLTAGE: 14.421V, TEMPERATURE: 48.32C, CURRENT: 0.000A
                  [3.358] (0) RPM: 1121, PWR: 19, VOLTAGE: 14.416V, TEMPERATURE: 48.31C, CURRENT: 0.000A
                  [3.375] (0) RPM: 1160, PWR: 19, VOLTAGE: 14.414V, TEMPERATURE: 48.40C, CURRENT: 0.000A
                  [3.394] (0) RPM: 1172, PWR: 19, VOLTAGE: 14.416V, TEMPERATURE: 48.38C, CURRENT: 0.000A
                  [3.419] (0) RPM: 1200, PWR: 19, VOLTAGE: 14.412V, TEMPERATURE: 48.43C, CURRENT: 0.000A
                  [3.438] (0) RPM: 1225, PWR: 19, VOLTAGE: 14.414V, TEMPERATURE: 48.41C, CURRENT: 0.000A
                  [3.454] (0) RPM: 1252, PWR: 19, VOLTAGE: 14.411V, TEMPERATURE: 48.48C, CURRENT: 0.000A
                  [3.479] (0) RPM: 1278, PWR: 20, VOLTAGE: 14.408V, TEMPERATURE: 48.48C, CURRENT: 0.000A
                  [3.494] (0) RPM: 1306, PWR: 20, VOLTAGE: 14.407V, TEMPERATURE: 48.48C, CURRENT: 0.000A
                  [3.518] (0) RPM: 1332, PWR: 20, VOLTAGE: 14.400V, TEMPERATURE: 48.51C, CURRENT: 0.000A
                  [3.535] (0) RPM: 1372, PWR: 20, VOLTAGE: 14.397V, TEMPERATURE: 48.54C, CURRENT: 0.000A
                  [3.554] (0) RPM: 1385, PWR: 20, VOLTAGE: 14.393V, TEMPERATURE: 48.55C, CURRENT: 0.000A
                  [3.576] (0) RPM: 1398, PWR: 20, VOLTAGE: 14.386V, TEMPERATURE: 48.55C, CURRENT: 0.000A
                  [3.594] (0) RPM: 1452, PWR: 20, VOLTAGE: 14.393V, TEMPERATURE: 48.60C, CURRENT: 0.000A
                  [3.614] (0) RPM: 1465, PWR: 20, VOLTAGE: 14.391V, TEMPERATURE: 48.60C, CURRENT: 0.000A
                  [3.639] (0) RPM: 1493, PWR: 21, VOLTAGE: 14.382V, TEMPERATURE: 48.65C, CURRENT: 0.000A
                  [3.655] (0) RPM: 1533, PWR: 21, VOLTAGE: 14.392V, TEMPERATURE: 48.68C, CURRENT: 0.000A
                  [3.675] (0) RPM: 1545, PWR: 21, VOLTAGE: 14.390V, TEMPERATURE: 48.68C, CURRENT: 0.000A
                  [3.699] (0) RPM: 1573, PWR: 21, VOLTAGE: 14.387V, TEMPERATURE: 48.73C, CURRENT: 0.000A
                  [3.715] (0) RPM: 1613, PWR: 21, VOLTAGE: 14.386V, TEMPERATURE: 48.71C, CURRENT: 0.000A
                  [3.734] (0) RPM: 1625, PWR: 21, VOLTAGE: 14.387V, TEMPERATURE: 48.69C, CURRENT: 0.000A
                  [3.759] (0) RPM: 1652, PWR: 21, VOLTAGE: 14.381V, TEMPERATURE: 48.75C, CURRENT: 0.000A
                  [3.775] (0) RPM: 1692, PWR: 22, VOLTAGE: 14.378V, TEMPERATURE: 48.79C, CURRENT: 0.000A
                  [3.806] (0) RPM: 1722, PWR: 22, VOLTAGE: 14.370V, TEMPERATURE: 48.82C, CURRENT: 0.000A
                  [3.813] (0) RPM: 1740, PWR: 22, VOLTAGE: 14.368V, TEMPERATURE: 48.83C, CURRENT: 0.000A
                  [3.834] (0) RPM: 1772, PWR: 22, VOLTAGE: 14.369V, TEMPERATURE: 48.92C, CURRENT: 0.000A
                  [3.854] (0) RPM: 1784, PWR: 22, VOLTAGE: 14.373V, TEMPERATURE: 48.89C, CURRENT: 0.000A
                  [3.874] (0) RPM: 1825, PWR: 22, VOLTAGE: 14.360V, TEMPERATURE: 48.97C, CURRENT: 0.000A
                  [3.895] (0) RPM: 1838, PWR: 22, VOLTAGE: 14.355V, TEMPERATURE: 49.00C, CURRENT: 0.000A
                  [3.919] (0) RPM: 1865, PWR: 22, VOLTAGE: 14.361V, TEMPERATURE: 49.01C, CURRENT: 0.000A
                  [3.935] (0) RPM: 1906, PWR: 23, VOLTAGE: 14.358V, TEMPERATURE: 49.00C, CURRENT: 0.000A
                  [3.955] (0) RPM: 1918, PWR: 23, VOLTAGE: 14.358V, TEMPERATURE: 49.01C, CURRENT: 0.000A
                  [3.978] (0) RPM: 1945, PWR: 23, VOLTAGE: 14.356V, TEMPERATURE: 49.04C, CURRENT: 0.000A
                  [3.995] (0) RPM: 1985, PWR: 23, VOLTAGE: 14.352V, TEMPERATURE: 49.11C, CURRENT: 0.000A
                  [4.014] (0) RPM: 1998, PWR: 23, VOLTAGE: 14.355V, TEMPERATURE: 49.11C, CURRENT: 0.000A
                  [4.038] (0) RPM: 1999, PWR: 23, VOLTAGE: 14.519V, TEMPERATURE: 49.13C, CURRENT: 0.000A
                  [4.055] (0) RPM: 0, PWR: 0, VOLTAGE: 14.538V, TEMPERATURE: 49.15C, CURRENT: 0.000A
                  [4.075] (0) RPM: 13, PWR: 2, VOLTAGE: 14.549V, TEMPERATURE: 49.11C, CURRENT: 0.000A
                  [4.098] (0) RPM: 41, PWR: 8, VOLTAGE: 14.528V, TEMPERATURE: 49.11C, CURRENT: 0.000A
                  [4.114] (0) RPM: 79, PWR: 14, VOLTAGE: 14.484V, TEMPERATURE: 49.12C, CURRENT: 0.000A
                  [4.134] (0) RPM: 92, PWR: 14, VOLTAGE: 14.481V, TEMPERATURE: 49.14C, CURRENT: 0.000A
                  [4.158] (0) RPM: 120, PWR: 14, VOLTAGE: 14.469V, TEMPERATURE: 49.20C, CURRENT: 0.000A
                  [4.175] (0) RPM: 160, PWR: 14, VOLTAGE: 14.468V, TEMPERATURE: 49.23C, CURRENT: 0.000A
                  [4.194] (0) RPM: 178, PWR: 14, VOLTAGE: 14.467V, TEMPERATURE: 49.28C, CURRENT: 0.000A
                  [4.218] (0) RPM: 199, PWR: 14, VOLTAGE: 14.459V, TEMPERATURE: 49.29C, CURRENT: 0.000A
                  [4.235] (0) RPM: 239, PWR: 15, VOLTAGE: 14.460V, TEMPERATURE: 49.34C, CURRENT: 0.000A
                  [4.254] (0) RPM: 252, PWR: 15, VOLTAGE: 14.461V, TEMPERATURE: 49.33C, CURRENT: 0.000A
                  [4.278] (0) RPM: 280, PWR: 15, VOLTAGE: 14.461V, TEMPERATURE: 49.32C, CURRENT: 0.000A
                  [4.295] (0) RPM: 319, PWR: 15, VOLTAGE: 14.453V, TEMPERATURE: 49.35C, CURRENT: 0.000A
                  [4.315] (0) RPM: 332, PWR: 15, VOLTAGE: 14.452V, TEMPERATURE: 49.38C, CURRENT: 0.000A
                  [4.339] (0) RPM: 360, PWR: 15, VOLTAGE: 14.452V, TEMPERATURE: 49.40C, CURRENT: 0.000A
                  [4.355] (0) RPM: 400, PWR: 15, VOLTAGE: 14.451V, TEMPERATURE: 49.45C, CURRENT: 0.000A
                  [4.374] (0) RPM: 425, PWR: 15, VOLTAGE: 14.447V, TEMPERATURE: 49.45C, CURRENT: 0.000A
                  [4.394] (0) RPM: 444, PWR: 16, VOLTAGE: 14.449V, TEMPERATURE: 49.47C, CURRENT: 0.000A
                  [4.414] (0) RPM: 479, PWR: 16, VOLTAGE: 14.443V, TEMPERATURE: 49.50C, CURRENT: 0.000A
                  [4.434] (0) RPM: 492, PWR: 16, VOLTAGE: 14.442V, TEMPERATURE: 49.55C, CURRENT: 0.000A
                  [4.459] (0) RPM: 520, PWR: 16, VOLTAGE: 14.443V, TEMPERATURE: 49.53C, CURRENT: 0.000A
                  [4.476] (0) RPM: 560, PWR: 16, VOLTAGE: 14.442V, TEMPERATURE: 49.51C, CURRENT: 0.000A
                  [4.494] (0) RPM: 571, PWR: 16, VOLTAGE: 14.444V, TEMPERATURE: 49.55C, CURRENT: 0.000A
                  [4.518] (0) RPM: 600, PWR: 16, VOLTAGE: 14.440V, TEMPERATURE: 49.54C, CURRENT: 0.000A
                  [4.535] (0) RPM: 640, PWR: 16, VOLTAGE: 14.433V, TEMPERATURE: 49.65C, CURRENT: 0.000A
                  [4.554] (0) RPM: 640, PWR: 16, VOLTAGE: 14.433V, TEMPERATURE: 49.65C, CURRENT: 0.000A
                  [4.576] (0) RPM: 694, PWR: 17, VOLTAGE: 14.438V, TEMPERATURE: 49.64C, CURRENT: 0.000A
                  [4.594] (0) RPM: 718, PWR: 17, VOLTAGE: 14.436V, TEMPERATURE: 49.62C, CURRENT: 0.000A
                  [4.614] (0) RPM: 737, PWR: 17, VOLTAGE: 14.433V, TEMPERATURE: 49.62C, CURRENT: 0.000A
                  [4.635] (0) RPM: 772, PWR: 17, VOLTAGE: 14.425V, TEMPERATURE: 49.74C, CURRENT: 0.000A
                  [4.654] (0) RPM: 798, PWR: 17, VOLTAGE: 14.429V, TEMPERATURE: 49.68C, CURRENT: 0.000A
                  [4.674] (0) RPM: 818, PWR: 17, VOLTAGE: 14.425V, TEMPERATURE: 49.73C, CURRENT: 0.000A
                  [4.695] (0) RPM: 852, PWR: 18, VOLTAGE: 14.428V, TEMPERATURE: 49.75C, CURRENT: 0.000A
                  [4.714] (0) RPM: 877, PWR: 18, VOLTAGE: 14.429V, TEMPERATURE: 49.73C, CURRENT: 0.000A
                  [4.737] (0) RPM: 896, PWR: 18, VOLTAGE: 14.429V, TEMPERATURE: 49.71C, CURRENT: 0.000A
                  [4.755] (0) RPM: 932, PWR: 18, VOLTAGE: 14.419V, TEMPERATURE: 49.80C, CURRENT: 0.000A
                  [4.775] (0) RPM: 952, PWR: 18, VOLTAGE: 14.421V, TEMPERATURE: 49.79C, CURRENT: 0.000A
                  [4.800] (0) RPM: 974, PWR: 18, VOLTAGE: 14.427V, TEMPERATURE: 49.70C, CURRENT: 0.000A
                  [4.820] (0) RPM: 997, PWR: 18, VOLTAGE: 14.414V, TEMPERATURE: 49.75C, CURRENT: 0.000A
                  [4.839] (0) RPM: 1026, PWR: 18, VOLTAGE: 14.416V, TEMPERATURE: 49.83C, CURRENT: 0.000A
                  [4.859] (0) RPM: 1051, PWR: 18, VOLTAGE: 14.414V, TEMPERATURE: 49.83C, CURRENT: 0.000A
                  [4.878] (0) RPM: 1077, PWR: 19, VOLTAGE: 14.413V, TEMPERATURE: 49.92C, CURRENT: 0.000A
                  [4.894] (0) RPM: 1104, PWR: 19, VOLTAGE: 14.416V, TEMPERATURE: 49.78C, CURRENT: 0.000A
                  [4.920] (0) RPM: 1133, PWR: 19, VOLTAGE: 14.406V, TEMPERATURE: 49.88C, CURRENT: 0.000A
                  [4.940] (0) RPM: 1157, PWR: 19, VOLTAGE: 14.406V, TEMPERATURE: 49.94C, CURRENT: 0.000A
                  [4.957] (0) RPM: 1179, PWR: 19, VOLTAGE: 14.404V, TEMPERATURE: 49.95C, CURRENT: 0.000A
                  [4.974] (0) RPM: 1224, PWR: 19, VOLTAGE: 14.404V, TEMPERATURE: 50.01C, CURRENT: 0.000A
                  [4.994] (0) RPM: 1238, PWR: 19, VOLTAGE: 14.398V, TEMPERATURE: 50.01C, CURRENT: 0.000A
                  Finished!
                  [4.994015] TX=504, RX=502 packets, RX CRC ERRORS=0
                  Average RPMs: 1005.63 0.00 0.00 0.00
                  Average RPM deviation between ESCs : 1005.63
                  [GCC 8.4.0]
                  • R RyanH
                      #? 3
                      enabling bridge
                      bridge enabled
                      [GCC 8.4.0]
                    [GCC 8.4.0]
                    Finished!
                    [GCC 8.4.0]
                    @RyanH , from the spin log above, i can only tell that the motor attempts to spin up but re-starts after the open-loop sinusoidal spinup is done and the ESC detects that the motor is not spinning.
                    You should try to clear the debris by spinning the motor by hand first (or use compressed air) and then use the test script to spin for longer periods of time without propeller (changing speeds, etc).
                    You could use a spin step command to automate increasing and decreasing spin speed (without rpm control, since it's not needed):
                    ./voxl-esc-spin-step.py --id 0 --step-delay 2.5 --step-frequency 1 --power 20 --step-amplitude 30
