  3. Apriltag relocalization not relocalizing?
apriltag
13 Posts 6 Posters 8.2k Views 2 Watching
  • James StrawsonJ Offline
    James Strawson
    yes, that's the correct rotation matrix for a tag on the ground.
    For a tag on the wall with a center 1m off the ground you can use:
    "T_tag_wrt_fixed": [0, 0, -1],
    "R_tag_to_fixed": [[0, 0, 1], [1, 0, 0], [0, 1, 0]]
    The second video of this docs page walks you through the voxl-vision-hub command line args to help you debug relocalization.
    K 2 Replies Last reply
      K Offline
      K Offline
      Kessie
      @James-Strawson Hi, we are testing this and are keep getting roll/pitch out of bounds while the tag is laying flat on the floor.
        K Offline
        K Offline
        Kessie
        @James-Strawson we are still trying to understand this behaviour.
        After several tests, we noticed that with the default SDK 1.4.1 on Starling 2 Max with C29 camera config :
        • If holding an apriltag in front of the front-tracking camera ([[0, 0, 1], [1, 0, 0], [0, 1, 0]]), we need to turn it counterclockwise 90 degrees to not have the "out of bounds" error
        • If holding an apriltag at the bottom camera ([[0, -1, 0], [1, 0, 0], [0, 0, 1]]), we are unable to remote the error
        We have found this as well : https://forum.modalai.com/topic/2653/stereo-tag-detection-warning-apriltag-roll-pitch-out-of-bounds?_=1741697621820
        However, this code also keeps giving strange out of bounds errors.
        Is it possible to show a working tag_locations.conf for both a tag on the ground and a tag against the wall?
        We are not really experienced in the transforms needed and it seems like a problem with that
        K 1 Reply Last reply
        • K Kessie
          K Offline
          K Offline
          Kessie
          @James-Strawson @Eric-Katzfey,
          Can you show a working example on a dual camera config, please?
          Both flat on the ground as against a wall.
          This would help us a lot!
          Thanks in advance,
          Maarten
          • K Kessie
            Thanks in advance,
            Maarten
            K Offline
            K Offline
            Kessie
            We have managed to solve the transformations and now get the correct tag detection.
            But even with fixed_frame_filter_len set to 1, QVIO and OpenVins are used and we see no relocalisation happening.
            Does someone have a working example which we can look at, please?
            J 1 Reply Last reply
            • K Kessie
              J Offline
              J Offline
              Judoor 0
              @Alex-Kushleyev Is there some news about this issue ?
              • T Offline
                T Offline
                tomverstappen
                Is there already a solution for the problem from Kessie?
                Is there anyone that has a working setup for AprilTag relocalization on the tracking_down camera?
                • Zachary Lowell 0Z Offline
                  Zachary Lowell 0
                  Hello All - I will be trying to recraete this issue in the coming days - will keep you all posted.
                    Zachary Lowell 0
                    @tomverstappen I am unable to recreate the issue with a starling running 1.5.0 - the output from voxl-vision-hub shows the relative coordinate frame from the tag relative to the camera and was able to get the drone to offset correctly.
                    Are there any logs you can paste in here or video?
                    Nitin Varma VegesnaN 1 Reply Last reply
                      Nitin Varma VegesnaN Offline
                      Nitin Varma Vegesna
                      @Zachary-Lowell-0 Was there any fix to this.
                      kernel: #1 SMP PREEMPT Mon Nov 11 22:47:44 UTC 2024 4.19.125
                      hw platform: M0054
                      mach.var: 1.0.1
                      SKU: MRB-D0014-4-V1-C27-T9-M22-X0
                      voxl-suite: 1.4.5
                      Packages:
                      I am getting this issue where I constantly get WARNING, apriltag roll/pitch out of bounds issue with the front or down tracking camera.
                      • Nitin Varma VegesnaN Nitin Varma Vegesna
                        hw platform: M0054
                        mach.var: 1.0.1
                        voxl-suite: 1.4.5
                        Packages:
                        Nitin Varma Vegesna
                        @Nitin-Varma-Vegesna Is there any release that is known to work for April Tag Detection?
                          Zachary Lowell 0
                          @Nitin-Varma-Vegesna said in Apriltag relocalization not relocalizing?:
                          https://gitlab.com/voxl-public/voxl-sdk/services/voxl-tag-detector
                          The dev branch is the most recent - I have to check with the engineering team on this as I am unsure the priority of april tag detection and positioning based off it. Will relay back
