<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Apriltag relocalization not relocalizing?]]></title><description><![CDATA[<p dir="auto">Hi,<br />
We have enabled en_tag_fixed_frame in voxl-vision-hub to use apriltag detection as a way to relocalize indoor.<br />
Am i correct to assume that the following is a tag located on the ground at point 0,0,0?<br />
"T_tag_wrt_fixed":      [0, 0, 0],<br />
"R_tag_to_fixed":       &lsqb;&lsqb;0, -1, 0], [1, 0, 0], [0, 0, 1&rsqb;&rsqb;</p>
<p dir="auto">What would be the rotation matrix for a tag located forward against the wall?<br />
What's the best way to test that the relocalisation actually happens?</p>
<hr />
<h2>system-image: 1.7.10-M0054-14.1a-perf<br />
kernel:       #1 SMP PREEMPT Fri Sep 27 21:59:02 UTC 2024 4.19.125</h2>
<h2>hw platform:  M0054<br />
mach.var:     1.0.1</h2>
<p dir="auto">voxl-suite:   1.3.5</p>
]]></description><link>https://forum.modalai.com/topic/4120/apriltag-relocalization-not-relocalizing</link><generator>RSS for Node</generator><lastBuildDate>Wed, 22 Jul 2026 20:45:33 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/4120.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 24 Jan 2025 14:18:11 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Apriltag relocalization not relocalizing? on Wed, 18 Feb 2026 21:23:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nitin-varma-vegesna" aria-label="Profile: Nitin-Varma-Vegesna">@<bdi>Nitin-Varma-Vegesna</bdi></a> said in <a href="/post/25287">Apriltag relocalization not relocalizing?</a>:</p>
<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nitin-varma-vegesna" aria-label="Profile: Nitin-Varma-Vegesna">@<bdi>Nitin-Varma-Vegesna</bdi></a> Is there any release that is known to work for April Tag Detection?</p>
</blockquote>
<p dir="auto"><div class="card col-md-9 col-lg-6 position-relative link-preview p-0">
<a href="https://gitlab.com/voxl-public/voxl-sdk/services/voxl-tag-detector" title="voxl / VOXL SDK / Services / voxl-tag-detector · GitLab">
<img src="https://gitlab.com/uploads/-/system/project/avatar/24706185/tag.png" class="card-img-top not-responsive" style="max-height: 15rem;" alt="Link Preview Image" onerror="this.parentElement.remove()" />
</a>
<div class="card-body">
<h5 class="card-title">
<a class="text-decoration-none" href="https://gitlab.com/voxl-public/voxl-sdk/services/voxl-tag-detector">
</a>
</h5>
<p class="card-text line-clamp-3">Detect and publish apriltags from multiple cameras</p>
</div>
<a href="https://gitlab.com/voxl-public/voxl-sdk/services/voxl-tag-detector" class="card-footer text-body-secondary small d-flex gap-2 align-items-center lh-2">
<img src="https://gitlab.com/assets/favicon-72a2cad5025aa931d6ea56c3201d1f18e68a8cd39788c7c80d5b2b82aa5143ef.png" alt="favicon" class="not-responsive overflow-hiddden" style="max-width: 21px; max-height: 21px;" onerror="this.remove()"/>
<p class="d-inline-block text-truncate mb-0">GitLab <span class="text-secondary">(gitlab.com)</span></p>
</a>
</div></p>
<p dir="auto">The dev branch is the most recent - I have to check with the engineering team on this as I am unsure the priority of april tag detection and positioning based off it. Will relay back</p>
]]></description><link>https://forum.modalai.com/post/25292</link><guid isPermaLink="true">https://forum.modalai.com/post/25292</guid><dc:creator><![CDATA[Zachary Lowell 0]]></dc:creator><pubDate>Wed, 18 Feb 2026 21:23:21 GMT</pubDate></item><item><title><![CDATA[Reply to Apriltag relocalization not relocalizing? on Wed, 18 Feb 2026 17:39:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nitin-varma-vegesna" aria-label="Profile: Nitin-Varma-Vegesna">@<bdi>Nitin-Varma-Vegesna</bdi></a> Is there any release that is known to work for April Tag Detection?</p>
]]></description><link>https://forum.modalai.com/post/25287</link><guid isPermaLink="true">https://forum.modalai.com/post/25287</guid><dc:creator><![CDATA[Nitin Varma Vegesna]]></dc:creator><pubDate>Wed, 18 Feb 2026 17:39:01 GMT</pubDate></item><item><title><![CDATA[Reply to Apriltag relocalization not relocalizing? on Wed, 18 Feb 2026 01:17:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/zachary-lowell-0" aria-label="Profile: Zachary-Lowell-0">@<bdi>Zachary-Lowell-0</bdi></a> Was there any fix to this.</p>
<p dir="auto">────────────────────────────────────────────────────────────────────────────────<br />
system-image: 1.8.02-M0054-14.1a-perf<br />
kernel: #1 SMP PREEMPT Mon Nov 11 22:47:44 UTC 2024 4.19.125<br />
mach.var: 1.0.1<br />
SKU: MRB-D0014-4-V1-C27-T9-M22-X0<br />
voxl-suite: 1.4.5<br />
Packages:</p>
<p dir="auto">I am getting this issue where I constantly get WARNING, apriltag roll/pitch out of bounds issue with the front or down tracking camera.</p>
]]></description><link>https://forum.modalai.com/post/25286</link><guid isPermaLink="true">https://forum.modalai.com/post/25286</guid><dc:creator><![CDATA[Nitin Varma Vegesna]]></dc:creator><pubDate>Wed, 18 Feb 2026 01:17:34 GMT</pubDate></item><item><title><![CDATA[Reply to Apriltag relocalization not relocalizing? on Fri, 19 Sep 2025 15:38:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tomverstappen" aria-label="Profile: tomverstappen">@<bdi>tomverstappen</bdi></a> I am unable to recreate the issue with a starling running 1.5.0 - the output from voxl-vision-hub shows the relative coordinate frame from the tag relative to the camera and was able to get the drone to offset correctly.</p>
<p dir="auto">Are there any logs you can paste in here or video?</p>
]]></description><link>https://forum.modalai.com/post/23819</link><guid isPermaLink="true">https://forum.modalai.com/post/23819</guid><dc:creator><![CDATA[Zachary Lowell 0]]></dc:creator><pubDate>Fri, 19 Sep 2025 15:38:23 GMT</pubDate></item><item><title><![CDATA[Reply to Apriltag relocalization not relocalizing? on Thu, 11 Sep 2025 17:14:27 GMT]]></title><description><![CDATA[<p dir="auto">Hello All - I will be trying to recraete this issue in the coming days - will keep you all posted.</p>
]]></description><link>https://forum.modalai.com/post/23738</link><guid isPermaLink="true">https://forum.modalai.com/post/23738</guid><dc:creator><![CDATA[Zachary Lowell 0]]></dc:creator><pubDate>Thu, 11 Sep 2025 17:14:27 GMT</pubDate></item><item><title><![CDATA[Reply to Apriltag relocalization not relocalizing? on Wed, 03 Sep 2025 22:19:25 GMT]]></title><description><![CDATA[<p dir="auto">Is there already a solution for the problem from Kessie?</p>
<p dir="auto">Is there anyone that has a working setup for AprilTag relocalization on the tracking_down camera?</p>
]]></description><link>https://forum.modalai.com/post/23677</link><guid isPermaLink="true">https://forum.modalai.com/post/23677</guid><dc:creator><![CDATA[tomverstappen]]></dc:creator><pubDate>Wed, 03 Sep 2025 22:19:25 GMT</pubDate></item><item><title><![CDATA[Reply to Apriltag relocalization not relocalizing? on Thu, 24 Jul 2025 15:44:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/alex-kushleyev" aria-label="Profile: Alex-Kushleyev">@<bdi>Alex-Kushleyev</bdi></a>  Is there some news about this issue ?</p>
]]></description><link>https://forum.modalai.com/post/23284</link><guid isPermaLink="true">https://forum.modalai.com/post/23284</guid><dc:creator><![CDATA[Judoor 0]]></dc:creator><pubDate>Thu, 24 Jul 2025 15:44:34 GMT</pubDate></item><item><title><![CDATA[Reply to Apriltag relocalization not relocalizing? on Tue, 01 Apr 2025 13:53:34 GMT]]></title><description><![CDATA[<p dir="auto">We have managed to solve the transformations and now get the correct tag detection.<br />
But even with fixed_frame_filter_len set to 1, QVIO and OpenVins are used and we see no relocalisation happening.</p>
<p dir="auto">Does someone have a working example which we can look at, please?</p>
]]></description><link>https://forum.modalai.com/post/21623</link><guid isPermaLink="true">https://forum.modalai.com/post/21623</guid><dc:creator><![CDATA[Kessie]]></dc:creator><pubDate>Tue, 01 Apr 2025 13:53:34 GMT</pubDate></item><item><title><![CDATA[Reply to Apriltag relocalization not relocalizing? on Mon, 17 Mar 2025 06:27:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/james-strawson" aria-label="Profile: James-Strawson">@<bdi>James-Strawson</bdi></a>  <a class="plugin-mentions-user plugin-mentions-a" href="/user/eric-katzfey" aria-label="Profile: Eric-Katzfey">@<bdi>Eric-Katzfey</bdi></a>,<br />
Can you show a working example on a dual camera config, please?<br />
Both flat on the ground as against a wall.<br />
This would help us a lot!</p>
<p dir="auto">Thanks in advance,<br />
Maarten</p>
]]></description><link>https://forum.modalai.com/post/21381</link><guid isPermaLink="true">https://forum.modalai.com/post/21381</guid><dc:creator><![CDATA[Kessie]]></dc:creator><pubDate>Mon, 17 Mar 2025 06:27:48 GMT</pubDate></item><item><title><![CDATA[Reply to Apriltag relocalization not relocalizing? on Tue, 11 Mar 2025 12:58:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/james-strawson" aria-label="Profile: James-Strawson">@<bdi>James-Strawson</bdi></a> we are still trying to understand this behaviour.<br />
After several tests, we noticed that with the default SDK 1.4.1 on Starling 2 Max with C29 camera config :</p>
<ul>
<li>If holding an apriltag in front of the front-tracking camera (&lsqb;&lsqb;0, 0, 1], [1, 0, 0], [0, 1, 0&rsqb;&rsqb;), we need to turn it counterclockwise 90 degrees to not have the "out of bounds" error</li>
<li>If holding an apriltag at the bottom camera (&lsqb;&lsqb;0, -1, 0], [1, 0, 0], [0, 0, 1&rsqb;&rsqb;), we are unable to remote the error</li>
</ul>
<p dir="auto">We have found this as well : <a href="https://forum.modalai.com/topic/2653/stereo-tag-detection-warning-apriltag-roll-pitch-out-of-bounds?_=1741697621820">https://forum.modalai.com/topic/2653/stereo-tag-detection-warning-apriltag-roll-pitch-out-of-bounds?_=1741697621820</a><br />
However, this code also keeps giving strange out of bounds errors.<br />
Is it possible to show a working tag_locations.conf for both a tag on the ground and a tag against the wall?<br />
We are not really experienced in the transforms needed and it seems like a problem with that</p>
]]></description><link>https://forum.modalai.com/post/21319</link><guid isPermaLink="true">https://forum.modalai.com/post/21319</guid><dc:creator><![CDATA[Kessie]]></dc:creator><pubDate>Tue, 11 Mar 2025 12:58:47 GMT</pubDate></item><item><title><![CDATA[Reply to Apriltag relocalization not relocalizing? on Mon, 10 Feb 2025 08:59:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/james-strawson" aria-label="Profile: James-Strawson">@<bdi>James-Strawson</bdi></a> Hi, we are testing this and are keep getting roll/pitch out of bounds while the tag is laying flat on the floor.</p>
]]></description><link>https://forum.modalai.com/post/20857</link><guid isPermaLink="true">https://forum.modalai.com/post/20857</guid><dc:creator><![CDATA[Kessie]]></dc:creator><pubDate>Mon, 10 Feb 2025 08:59:55 GMT</pubDate></item><item><title><![CDATA[Reply to Apriltag relocalization not relocalizing? on Wed, 29 Jan 2025 21:54:33 GMT]]></title><description><![CDATA[<p dir="auto">yes, that's the correct rotation matrix for a tag on the ground.</p>
<p dir="auto">For a tag on the wall with a center 1m off the ground you can use:<br />
"T_tag_wrt_fixed": [0, 0, -1],<br />
"R_tag_to_fixed": &lsqb;&lsqb;0, 0, 1], [1, 0, 0], [0, 1, 0&rsqb;&rsqb;</p>
<p dir="auto">The second video of this docs page walks you through the voxl-vision-hub command line args to help you debug relocalization.</p>
]]></description><link>https://forum.modalai.com/post/20700</link><guid isPermaLink="true">https://forum.modalai.com/post/20700</guid><dc:creator><![CDATA[James Strawson]]></dc:creator><pubDate>Wed, 29 Jan 2025 21:54:33 GMT</pubDate></item></channel></rss>
