  3. VOXL 2 J18 port for External FC
15 Posts 2 Posters 1.5k Views 1 Watching
  • Jetson NanoJ Jetson Nano
    @Eric-Katzfey I tried lower baudrate also, the behaviour is similar.
    @Jetson-Nano Do you still get those messages from voxl-mavlink-server about dropped packets from external AP?
      @Jetson-Nano Are you using WiFi to connect with QGC?
        Jetson NanoJ Offline
        Jetson Nano
        Veteran
        @Eric-Katzfey yes I still had that messages popping up
          Jetson Nano
          Veteran
          @Eric-Katzfey No I was using the Microhard module. Irrespective of the communication module, these many time should the sysid change and the packet lose should not occure, right?
            Jetson Nano
            Veteran
            #10
            I changed the Mavlink version to what you had mentioned here, I felt the errors were similar
            Link
            this is when baudrate is 57600
            voxl2:~$ voxl-mavlink-server
            loading our own config file
            primary_static_gcs_ip:        192.168.168.200
            primary_static_gcs_ip_port:   14550
            secondary_static_gcs_ip:      192.169.168.2
            secondary_static_gcs_ip_port: 14550
            onboard_port_to_autopilot:    14556
            onboard_port_from_autopilot:  14557
            gcs_port_to_autopilot:        14558
            gcs_port_from_autopilot:      14559
            en_external_uart_ap:          1
            autopilot_uart_bus:           12
            autopilot_uart_baudrate:      57600
            autopilot_mission_delay_start:      -1
            autopilot_mission_delay_sound:      0
            autopilot_mission_force_restart:      0
            autopilot_mission_notif_dur:      0.10
            udp_mtu:                      0
            gcs_timeout_s                 1.00
            en_external_ap_timesync:      1
            en_external_ap_heartbeat:     1
            Successfully opened bus 12 at baudrate 57600
            starting qrb5165 external AP receive thread
            Adding primary GCS IP address from conf file to list: 192.168.168.200:14550
            Added new UDP connection to 192.168.168.200:14550
            Adding secondary manual gcs IP address to udp connection list: 192.169.168.2:14550
            Added new UDP connection to 192.169.168.2:14550
            CONNECTED to GCS at 192.168.168.200:14550
            Waiting to detect autopilot sys id...
            ^C
            received SIGINT Ctrl-C
            Starting shutdown sequence
            Stopping autopilot io module
            exiting read thread
            qrb5165 external ap interface stopped
            Stopping gcs io module
            WARNING: Received 12 bytes of data from SLPI while SLPI uart not in use (topic uart_data)
            WARNING: Received 41 bytes of data from SLPI while SLPI uart not in use (topic uart_data)
            WARNING: Received 32 bytes of data from SLPI while SLPI uart not in use (topic uart_data)
            WARNING: Received 36 bytes of data from SLPI while SLPI uart not in use (topic uart_data)
            WARNING: Received 18 bytes of data from SLPI while SLPI uart not in use (topic uart_data)
            exiting gcs udp listener thread
            udp gcs io stopped
            Stopping pipe io module
            closing remaining client pipes
            closing remaining server pipes
            Removing PID file
            exiting
            this is when baudrate is 921600
            autopilot_uart_baudrate:      921600
            udp_mtu:                      0
            gcs_timeout_s                 1.00
            Successfully opened bus 12 at baudrate 921600
            Detected Autopilot Mavlink SYSID 130
            WARNING: UART parser dropped 1 packets from external AP at i=8
            WARNING: UART parser dropped 1 packets from external AP at i=1
            WARNING: UART parser dropped 1 packets from external AP at i=7
            WARNING: UART parser dropped 1 packets from external AP at i=6
            WARNING: UART parser dropped 1 packets from external AP at i=0
            WARNING: UART parser dropped 1 packets from external AP at i=10
            ^C
            exiting read thread
            WARNING: Received 11 bytes of data from SLPI while SLPI uart not in use (topic uart_data)
            WARNING: Received 54 bytes of data from SLPI while SLPI uart not in use (topic uart_data)
            WARNING: Received 10 bytes of data from SLPI while SLPI uart not in use (topic uart_data)
            WARNING: Received 7 bytes of data from SLPI while SLPI uart not in use (topic uart_data)
            WARNING: Received 9 bytes of data from SLPI while SLPI uart not in use (topic uart_data)
            udp gcs io stopped
            Removing PID file
            exiting
            voxl2:~$
              Link
              udp_mtu:                      0
              gcs_timeout_s                 1.00
              ^C
              exiting read thread
              udp gcs io stopped
              Removing PID file
              exiting
              udp_mtu:                      0
              gcs_timeout_s                 1.00
              ^C
              exiting read thread
              udp gcs io stopped
              Removing PID file
              exiting
              voxl2:~$
              Jetson Nano
              Veteran
              voxl-mavlink-server -z
              voxl2:~$ voxl-mavlink-server -z
              Enabling UDP to slpi recv debugging
              Enabling qrb5165 external AP recv debugging
              Enabling UDP to slpi send debugging
              Enabling qrb5165 external AP send debugging
              Enabling UDP GCS recv debugging
              Enabling UDP GCS send debugging
              udp_mtu:                      0
              gcs_timeout_s                 1.00
              onboard  pipe  ID:  84 compid: 197
              to AP msg ID:    84 sysid:130   to bus: 12
              onboard  pipe  ID: 330 compid: 197
              to AP msg ID:   330 sysid:130   to bus: 12
              onboard  pipe  ID:   0 compid: 196
              to AP msg ID:     0 sysid:130   to bus: 12
              from GCS    ID:   0 port: 14550 IP: 192.168.168.200
              to AP msg ID:     0 sysid:255   to bus: 12
              from gcs pipe ID:   0  compid: 190
              from gcs pipe ID:   0 compid: 100
              to GCS      msgid:    0 compid 100
                udp_mtu:                      0
                gcs_timeout_s                 1.00
                @Jetson-Nano Looks like you are never receiving anything FROM the AP. Only sending stuff TO it. Can you put an oscilloscope on the RX / TX UART lines to see what the traffic looks like. For some reason it doesn't seem like the UART is setup properly on either the FC or the DSP so with an oscilloscope you can better see what is going on.
                  Jetson Nano
                  Veteran
                  @Eric-Katzfey I am facing a different error,
                  voxl2:/$ voxl-mavlink-server
                  udp_mtu:                      0
                  gcs_timeout_s                 1.00
                  existing instance of voxl-mavlink-server found, attempting to stop it
                  ERROR:   Received error from ring_buf_push in p_slpi_receive_callback: ERR_NO_SPACE
                    udp_mtu:                      0
                    gcs_timeout_s                 1.00
                    Jetson Nano
                    Veteran
                    #14
                    These mentioned errors were only observed while using microhard unit
                    voxl2:/$ voxl-mavlink-server -z
                    udp_mtu:                      200
                    gcs_timeout_s                 1.00
                    RECV  msg ID:    74 sysid:  1 from bus: 12
                    RECV  msg ID:    30 sysid:  1 from bus: 12
                    RECV  msg ID:    31 sysid:  1 from bus: 12
                    RECV  msg ID:   105 sysid:  1 from bus: 12
                    RECV  msg ID:    32 sysid:  1 from bus: 12
                    RECV  msg ID:   331 sysid:  1 from bus: 12
                    RECV  msg ID:     1 sysid:  1 from bus: 12
                    RECV  msg ID:   411 sysid:  1 from bus: 12
                    RECV  msg ID:   132 sysid:  1 from bus: 12
                    RECV  msg ID:   111 sysid:  1 from bus: 12
                    RECV  msg ID:   141 sysid:  1 from bus: 12
                    RECV  msg ID:    83 sysid:  1 from bus: 12
                    RECV  msg ID:   245 sysid:  1 from bus: 12
                    RECV  msg ID:    85 sysid:  1 from bus: 12
                    RECV  msg ID:    36 sysid:  1 from bus: 12
                    RECV  msg ID:   106 sysid:  1 from bus: 12
                    to GCS      msgid:  105 compid   1
                    to GCS      msgid:   32 compid   1
                    to GCS      msgid:   30 compid   1
                    to ob pipe  ID: 331  compid:   1
                    to gcs pipe ID: 331  compid:   1
                    to GCS      msgid:  331 compid   1
                    to ob pipe  ID:  31  compid:   1
                    to gcs pipe ID:  31  compid:   1
                    to GCS      msgid:   31 compid   1
                    to ob pipe  ID:  30  compid:   1
                    to gcs pipe ID:  30  compid:   1
                    to ob pipe  ID: 105  compid:   1
                    to gcs pipe ID: 105  compid:   1
                    to ob pipe  ID:  32  compid:   1
                    to gcs pipe ID:  32  compid:   1
                    to ob pipe  ID: 132  compid:   1
                    to gcs pipe ID: 132  compid:   1
                    to GCS      msgid:  132 compid   1
                    to AP msg ID:   111 sysid:  1   to bus: 12
                    to gcs pipe ID: 111  compid:   1
                    to GCS      msgid:  111 compid   1
                    to ob pipe  ID: 141  compid:   1
                    to gcs pipe ID: 141  compid:   1
                    to GCS      msgid:  141 compid   1
                    to ob pipe  ID:  83  compid:   1
                    to gcs pipe ID:  83  compid:   1
                    to GCS      msgid:   83 compid   1
                    to ob pipe  ID:  85  compid:   1
                    to gcs pipe ID:  85  compid:   1
                    to GCS      msgid:   85 compid   1
                    to ob pipe  ID:  36  compid:   1
                    to gcs pipe ID:  36  compid:   1
                    to GCS      msgid:   36 compid   1
                    to ob pipe  ID:  74  compid:   1
                    to gcs pipe ID:  74  compid:   1
                    to GCS      msgid:   74 compid   1
                    to ob pipe  ID: 106  compid:   1
                    to gcs pipe ID: 106  compid:   1
                    to GCS      msgid:  106 compid   1
                    RECV  msg ID:     0 sysid:  1 from bus: 12
                    to ob pipe  ID:   0  compid:   1
                    to gcs pipe ID:   0  compid:   1
                    to AP msg ID:    84 sysid:  1   to bus: 12
                    RECV  msg ID:   410 sysid:  1 from bus: 12
                    to ob pipe  ID: 410  compid:   1
                    to gcs pipe ID: 410  compid:   1
                    to GCS      msgid:  410 compid   1
                    onboard  pipe  ID: 331 compid: 197
                    to AP msg ID:   331 sysid:  1   to bus: 12
                    to AP msg ID:   330 sysid:  1   to bus: 12
                    to AP msg ID:     0 sysid:  1   to bus: 12
                    to ob pipe  ID: 245  compid:   1
                    to gcs pipe ID: 245  compid:   1
                    to GCS      msgid:  245 compid   1
                      udp_mtu:                      200
                      gcs_timeout_s                 1.00
                      Jetson Nano
                      Veteran
                      #15
                      hey,
                      I observed something while the above behaviour still persists.
                      The modem and the camera server is showing not running while checking through the inspect services command.
                      I do not know whether this is related to this issue, but the voxl 2 is rebooting after sometime, the reboot is not constant and I am not able to able to find the reason for the reboot. Can everything be related to each other.
                      I am using the Microhard modem
