  3. Urgent Support needed for Drone not armed after RC controller calibration
starling
29 Posts 2 Posters 6.9k Views 1 Watching
    @oiler251 Are you using QGroundControl to calibrate the RC? When on the calibration tab and you move the sticks around does everything look okay? What do all of the RC<x>_MIN, MAX, and TRIM values look like? Is it just channel 8 that has strange values?
    O Offline
    O Offline
    oiler251
    @Eric-Katzfey RC calibration was performed via Starling 2 Max web-GUI (192.168.8.1) under debug RC Calibration. This was the first time i ran the RC calibration as the drone was not fly as normal. During RC calibration, it reported as channel 7. Then, i repeated again which reported channel 8 then.
    I am available at 443-910-5825 if you are available for a call.
    • O oiler251
      @oiler251 Do you get the same result when calibrating with QGroundControl? What are all of your RC<x>_MIN, MAX, and TRIM values after the calibration?
      O 2 Replies Last reply
        O Offline
        O Offline
        oiler251
        @Eric-Katzfey Can you share me the instructions how to run RC calibration using QGroundControl? I have QGroundControl software installed.
          O Offline
          O Offline
          oiler251
          @Eric-Katzfey Do I need Wi-Fi connection for QGroundControl software? currently, i am connected to starling 2 max via USB-cable.
          • O oiler251
            @oiler251 Yes, you would need an IP connection of some sort, WiFi is usually the easiest. If that's not available then I suppose you should just stick with voxl-portal. I was just trying to get more information to help troubleshoot the issue you are having. That's why I asked for the parameter values. Is it possible for you to provide those values?
              O Offline
              O Offline
              oiler251
              @Eric-Katzfey Here is the error from QGroundControl Software?
              [15:04:57.827 ] Critical: Preflight Fail: RC ERROR: RC8_TRIM > MAX (1030/0)
              [15:04:57.777 ] Critical: Preflight Fail: RC ERROR: RC7_TRIM > MAX (1030/0)
              [15:04:57.726 ] Critical: Preflight Fail: RC ERROR: RC6_TRIM > MAX (1030/0)
              [15:04:57.677 ] Critical: Preflight Fail: RC ERROR: RC5_TRIM > MAX (1030/0)
              [15:04:57.627 ] Critical: Preflight: GPS Horizontal Pos Error too high
              [15:04:57.577 ] Critical: Preflight Fail: horizontal velocity unstable
              [15:04:55.808 ] Critical: Preflight Fail: RC ERROR: RC8_TRIM > MAX (1030/0)
              [15:04:55.758 ] Critical: Preflight Fail: RC ERROR: RC7_TRIM > MAX (1030/0)
              [15:04:55.708 ] Critical: Preflight Fail: RC ERROR: RC6_TRIM > MAX (1030/0)
              [15:04:55.659 ] Critical: Preflight Fail: RC ERROR: RC5_TRIM > MAX (1030/0)
              [15:04:55.608 ] Critical: Preflight: GPS Horizontal Pos Error too high
              [15:04:55.560 ] Critical: Preflight Fail: horizontal velocity unstable
              [15:04:53.810 ] Critical: Preflight Fail: RC ERROR: RC8_TRIM > MAX (1030/0)
              [15:04:53.759 ] Critical: Preflight Fail: RC ERROR: RC7_TRIM > MAX (1030/0)
              [15:04:53.709 ] Critical: Preflight Fail: RC ERROR: RC6_TRIM > MAX (1030/0)
              [15:04:53.661 ] Critical: Preflight Fail: RC ERROR: RC5_TRIM > MAX (1030/0)
              [15:04:53.609 ] Critical: Preflight: GPS Horizontal Pos Error too high
              [15:04:53.550 ] Critical: Preflight Fail: horizontal velocity unstable
              [15:04:43.460 ] Critical: Preflight Fail: RC ERROR: RC8_TRIM > MAX (1030/0)
              [15:04:43.409 ] Critical: Preflight Fail: RC ERROR: RC7_TRIM > MAX (1030/0)
              [15:04:43.358 ] Critical: Preflight Fail: RC ERROR: RC6_TRIM > MAX (1030/0)
              [15:04:43.309 ] Critical: Preflight Fail: RC ERROR: RC5_TRIM > MAX (1030/0)
              [15:04:43.258 ] Critical: Preflight: GPS Horizontal Pos Error too high
              [15:04:43.202 ] Critical: Preflight Fail: horizontal velocity unstable
              [15:04:38.277 ] Critical: Preflight Fail: RC ERROR: RC8_TRIM > MAX (1030/0)
              [15:04:38.210 ] Critical: Preflight Fail: RC ERROR: RC7_TRIM > MAX (1030/0)
              [15:04:38.160 ] Critical: Preflight Fail: RC ERROR: RC6_TRIM > MAX (1030/0)
              [15:04:38.110 ] Critical: Preflight Fail: RC ERROR: RC5_TRIM > MAX (1030/0)
              [15:04:38.062 ] Critical: Preflight: GPS Horizontal Pos Error too high
              [15:04:38.009 ] Critical: Preflight Fail: horizontal velocity unstable
              [15:04:25.981 ] Critical: Preflight Fail: RC ERROR: RC8_TRIM > MAX (1030/0)
              [15:04:25.931 ] Critical: Preflight Fail: RC ERROR: RC7_TRIM > MAX (1030/0)
              [15:04:25.881 ] Critical: Preflight Fail: RC ERROR: RC6_TRIM > MAX (1030/0)
              [15:04:25.832 ] Critical: Preflight Fail: RC ERROR: RC5_TRIM > MAX (1030/0)
              [15:04:25.783 ] Critical: Preflight: GPS Horizontal Pos Error too high
              [15:04:25.731 ] Critical: Preflight Fail: horizontal velocity unstable
              [15:04:23.955 ] Critical: Preflight Fail: RC ERROR: RC8_TRIM > MAX (1030/0)
              [15:04:23.904 ] Critical: Preflight Fail: RC ERROR: RC7_TRIM > MAX (1030/0)
              [15:04:23.855 ] Critical: Preflight Fail: RC ERROR: RC6_TRIM > MAX (1030/0)
              [15:04:23.803 ] Critical: Preflight Fail: RC ERROR: RC5_TRIM > MAX (1030/0)
              [15:04:23.757 ] Critical: Preflight: GPS Horizontal Pos Error too high
              [15:04:23.704 ] Critical: Preflight Fail: horizontal velocity unstable
              [15:04:21.871 ] Critical: Preflight Fail: RC ERROR: RC8_TRIM > MAX (1030/0)
              [15:04:21.823 ] Critical: Preflight Fail: RC ERROR: RC7_TRIM > MAX (1030/0)
              [15:04:21.772 ] Critical: Preflight Fail: RC ERROR: RC6_TRIM > MAX (1030/0)
              [15:04:21.723 ] Critical: Preflight Fail: RC ERROR: RC5_TRIM > MAX (1030/0)
              [15:04:21.671 ] Critical: Preflight: GPS Horizontal Pos Error too high
              [15:04:19.823 ] Critical: Preflight Fail: RC ERROR: RC8_TRIM > MAX (1030/0)
              [15:04:19.787 ] Critical: Preflight Fail: RC ERROR: RC7_TRIM > MAX (1030/0)
              [15:04:19.730 ] Critical: Preflight Fail: RC ERROR: RC6_TRIM > MAX (1030/0)
              [15:04:19.676 ] Critical: Preflight Fail: RC ERROR: RC5_TRIM > MAX (1030/0)
              [15:04:19.626 ] Critical: Preflight: GPS Horizontal Pos Drift too high
              [15:04:19.573 ] Critical: Preflight Fail: horizontal velocity unstable
              [15:04:17.816 ] Critical: Preflight Fail: RC ERROR: RC8_TRIM > MAX (1030/0)
              [15:04:17.766 ] Critical: Preflight Fail: RC ERROR: RC7_TRIM > MAX (1030/0)
              [15:04:17.716 ] Critical: Preflight Fail: RC ERROR: RC6_TRIM > MAX (1030/0)
              [15:04:17.665 ] Critical: Preflight Fail: RC ERROR: RC5_TRIM > MAX (1030/0)
              [15:04:17.615 ] Critical: Preflight: GPS Horizontal Pos Drift too high
              [15:04:17.562 ] Critical: Preflight Fail: horizontal velocity unstable
              [15:04:06.714 ] Critical: Preflight Fail: RC ERROR: RC8_TRIM > MAX (1030/0)
              [15:04:06.661 ] Critical: Preflight Fail: RC ERROR: RC7_TRIM > MAX (1030/0)
              [15:04:06.614 ] Critical: Preflight Fail: RC ERROR: RC6_TRIM > MAX (1030/0)
              [15:04:06.562 ] Critical: Preflight Fail: RC ERROR: RC5_TRIM > MAX (1030/0)
              [15:04:06.514 ] Critical: Preflight: GPS Horizontal Pos Drift too high
              [15:04:04.759 ] Critical: Preflight Fail: RC ERROR: RC8_TRIM > MAX (1030/0)
              [15:04:04.753 ] Critical: Preflight Fail: RC ERROR: RC7_TRIM > MAX (1030/0)
              [15:04:04.743 ] Critical: Preflight Fail: RC ERROR: RC6_TRIM > MAX (1030/0)
              [15:04:04.556 ] Critical: Preflight Fail: RC ERROR: RC5_TRIM > MAX (1030/0)
              [15:04:04.508 ] Critical: Preflight: GPS Horizontal Pos Drift too high
              [15:04:04.457 ] Critical: Preflight Fail: horizontal velocity unstable
              [15:03:55.896 ] Critical: Preflight Fail: RC ERROR: RC8_TRIM > MAX (1030/0)
              [15:03:55.895 ] Critical: Preflight Fail: RC ERROR: RC7_TRIM > MAX (1030/0)
              [15:03:55.895 ] Critical: Preflight Fail: RC ERROR: RC6_TRIM > MAX (1030/0)
              [15:03:55.895 ] Critical: Preflight Fail: RC ERROR: RC5_TRIM > MAX (1030/0)
              [15:03:55.495 ] Critical: Preflight: GPS Horizontal Pos Drift too high
              [15:03:53.675 ] Critical: Preflight Fail: RC ERROR: RC8_TRIM > MAX (1030/0)
              [15:03:53.619 ] Critical: Preflight Fail: RC ERROR: RC7_TRIM > MAX (1030/0)
              [15:03:53.574 ] Critical: Preflight Fail: RC ERROR: RC6_TRIM > MAX (1030/0)
              [15:03:53.539 ] Critical: Preflight Fail: RC ERROR: RC5_TRIM > MAX (1030/0)
              [15:03:53.472 ] Critical: Preflight: GPS Horizontal Pos Drift too high
              [15:03:53.418 ] Critical: Preflight Fail: horizontal velocity unstable
              [15:03:49.083 ] Critical: Preflight Fail: RC ERROR: RC8_TRIM > MAX (1030/0)
              [15:03:49.033 ] Critical: Preflight Fail: RC ERROR: RC7_TRIM > MAX (1030/0)
              [15:03:48.982 ] Critical: Preflight Fail: RC ERROR: RC6_TRIM > MAX (1030/0)
              [15:03:48.932 ] Critical: Preflight Fail: RC ERROR: RC5_TRIM > MAX (1030/0)
              [15:03:48.884 ] Critical: Preflight: GPS Horizontal Pos Drift too high
              [15:03:47.064 ] Critical: Preflight Fail: RC ERROR: RC8_TRIM > MAX (1030/0)
              [15:03:47.014 ] Critical: Preflight Fail: RC ERROR: RC7_TRIM > MAX (1030/0)
              [15:03:46.963 ] Critical: Preflight Fail: RC ERROR: RC6_TRIM > MAX (1030/0)
              [15:03:46.928 ] Critical: Preflight Fail: RC ERROR: RC5_TRIM > MAX (1030/0)
              [15:03:46.863 ] Critical: Preflight: GPS Horizontal Pos Drift too high
              [15:03:46.813 ] Critical: Preflight Fail: horizontal velocity unstable
              [15:03:45.054 ] Critical: Preflight Fail: RC ERROR: RC8_TRIM > MAX (1030/0)
              [15:03:45.005 ] Critical: Preflight Fail: RC ERROR: RC7_TRIM > MAX (1030/0)
              [15:03:44.954 ] Critical: Preflight Fail: RC ERROR: RC6_TRIM > MAX (1030/0)
              [15:03:44.904 ] Critical: Preflight Fail: RC ERROR: RC5_TRIM > MAX (1030/0)
              [15:03:44.853 ] Critical: Preflight: GPS Hor Speed Drift too high
              [15:03:44.806 ] Critical: Preflight Fail: horizontal velocity unstable
              [15:03:43.072 ] Critical: Preflight Fail: RC ERROR: RC8_TRIM > MAX (1030/0)
              [15:03:43.022 ] Critical: Preflight Fail: RC ERROR: RC7_TRIM > MAX (1030/0)
              [15:03:42.981 ] Critical: Preflight Fail: RC ERROR: RC6_TRIM > MAX (1030/0)
              [15:03:42.924 ] Critical: Preflight Fail: RC ERROR: RC5_TRIM > MAX (1030/0)
              [15:03:42.875 ] Critical: Preflight: GPS Horizontal Pos Drift too high
              [15:03:42.822 ] Critical: Preflight Fail: horizontal velocity unstable
              [15:03:35.458 ] Critical: Preflight Fail: RC ERROR: RC8_TRIM > MAX (1030/0)
              [15:03:35.410 ] Critical: Preflight Fail: RC ERROR: RC7_TRIM > MAX (1030/0)
              [15:03:35.358 ] Critical: Preflight Fail: RC ERROR: RC6_TRIM > MAX (1030/0)
              [15:03:35.307 ] Critical: Preflight Fail: RC ERROR: RC5_TRIM > MAX (1030/0)
              [15:03:35.258 ] Critical: Preflight: GPS Horizontal Pos Drift too high
              [15:03:33.848 ] Critical: Preflight Fail: RC ERROR: RC8_TRIM > MAX (1030/0)
              [15:03:33.335 ] Critical: Preflight Fail: RC ERROR: RC7_TRIM > MAX (1030/0)
              [15:03:33.286 ] Critical: Preflight Fail: RC ERROR: RC6_TRIM > MAX (1030/0)
              [15:03:33.236 ] Critical: Preflight Fail: RC ERROR: RC5_TRIM > MAX (1030/0)
              [15:03:33.221 ] Critical: Preflight: GPS Hor Speed Drift too high
              [15:03:30.845 ] Critical: Preflight Fail: RC ERROR: RC8_TRIM > MAX (1030/0)
              [15:03:30.844 ] Critical: Preflight Fail: RC ERROR: RC7_TRIM > MAX (1030/0)
              [15:03:30.844 ] Critical: Preflight Fail: RC ERROR: RC6_TRIM > MAX (1030/0)
              [15:03:30.467 ] Critical: Preflight Fail: RC ERROR: RC5_TRIM > MAX (1030/0)
              [15:03:30.467 ] Critical: Preflight: GPS Vertical Pos Drift too high
              [15:03:28.579 ] Critical: Preflight Fail: RC ERROR: RC8_TRIM > MAX (1030/0)
              [15:03:28.529 ] Critical: Preflight Fail: RC ERROR: RC7_TRIM > MAX (1030/0)
              [15:03:28.481 ] Critical: Preflight Fail: RC ERROR: RC6_TRIM > MAX (1030/0)
              [15:03:28.428 ] Critical: Preflight Fail: RC ERROR: RC5_TRIM > MAX (1030/0)
              [15:03:28.378 ] Critical: Preflight: GPS Vertical Pos Drift too high
              [15:03:28.326 ] Critical: Preflight Fail: horizontal velocity unstable
              [15:03:26.303 ] Critical: Preflight Fail: RC ERROR: RC8_TRIM > MAX (1030/0)
              [15:03:26.303 ] Critical: Preflight Fail: RC ERROR: RC7_TRIM > MAX (1030/0)
              [15:03:26.303 ] Critical: Preflight Fail: RC ERROR: RC6_TRIM > MAX (1030/0)
              [15:03:26.302 ] Critical: Preflight Fail: RC ERROR: RC5_TRIM > MAX (1030/0)
              [15:03:26.302 ] Critical: Preflight: GPS Vertical Pos Drift too high
              [15:03:22.281 ] Critical: Preflight Fail: RC ERROR: RC8_TRIM > MAX (1030/0)
              [15:03:22.281 ] Critical: Preflight Fail: RC ERROR: RC7_TRIM > MAX (1030/0)
              [15:03:22.131 ] Critical: Preflight Fail: RC ERROR: RC6_TRIM > MAX (1030/0)
              [15:03:22.131 ] Critical: Preflight Fail: RC ERROR: RC5_TRIM > MAX (1030/0)
              [15:03:22.130 ] Critical: Preflight: GPS Horizontal Pos Drift too high
              [15:03:20.530 ] Critical: Preflight Fail: RC ERROR: RC8_TRIM > MAX (1030/0)
              [15:03:20.530 ] Critical: Preflight Fail: RC ERROR: RC7_TRIM > MAX (1030/0)
              [15:03:20.530 ] Critical: Preflight Fail: RC ERROR: RC6_TRIM > MAX (1030/0)
              [15:03:20.530 ] Critical: Preflight Fail: RC ERROR: RC5_TRIM > MAX (1030/0)
              [15:03:20.530 ] Critical: Preflight: GPS Horizontal Pos Drift too high
              [15:03:20.529 ] Critical: Preflight Fail: RC ERROR: RC8_TRIM > MAX (1030/0)
              [15:03:20.529 ] Critical: Preflight Fail: RC ERROR: RC7_TRIM > MAX (1030/0)
              [15:03:20.529 ] Critical: Preflight Fail: RC ERROR: RC6_TRIM > MAX (1030/0)
              [15:03:20.528 ] Critical: Preflight Fail: RC ERROR: RC5_TRIM > MAX (1030/0)
              [15:03:20.527 ] Critical: Preflight: GPS Horizontal Pos Drift too high
              [15:03:20.516 ] Critical: Preflight Fail: horizontal velocity unstable
              [15:03:20.516 ] Critical: Preflight Fail: RC ERROR: RC8_TRIM > MAX (1030/0)
              [15:03:20.515 ] Critical: Preflight Fail: RC ERROR: RC7_TRIM > MAX (1030/0)
                O Offline
                O Offline
                oiler251
                @Eric-Katzfey Below is the px4 parameters.
                voxl2:/$ px4-param show
                Symbols: x = used, + = saved, * = unsaved
                x ASPD_SCALE_1 [0,23] : 1.0000
                x + BAT1_CAPACITY [1,42] : 3950.0000
                x + BAT1_N_CELLS [2,45] : 4
                x + BAT1_R_INTERNAL [3,46] : 0.0220
                x BAT1_SOURCE [4,48] : 0
                x + BAT1_V_CHARGED [5,50] : 4.1000
                x + BAT1_V_EMPTY [6,52] : 2.8000
                x BAT1_V_LOAD_DROP [7,53] : 0.1000
                x + BAT_AVRG_CURRENT [8,68] : 3.4000
                x + BAT_CRIT_THR [9,69] : 0.1000
                x BAT_EMERGEN_THR [10,70] : 0.0500
                x BAT_LOW_THR [11,71] : 0.1500
                x BAT_N_CELLS [12,72] : 3
                x BAT_V_CHARGED [13,73] : 4.0500
                x BAT_V_EMPTY [14,74] : 3.6000
                x BAT_V_LOAD_DROP [15,75] : 0.3000
                x + CAL_ACC0_ID [16,77] : 2490378
                x + CAL_ACC0_PRIO [17,78] : 50
                x CAL_ACC0_ROT [18,79] : -1
                x + CAL_ACC0_XOFF [19,80] : 0.0013
                x CAL_ACC0_XSCALE [20,81] : 1.0000
                x + CAL_ACC0_YOFF [21,82] : 0.0019
                x CAL_ACC0_YSCALE [22,83] : 1.0000
                x + CAL_ACC0_ZOFF [23,84] : 0.0507
                x CAL_ACC0_ZSCALE [24,85] : 1.0000
                x CAL_ACC1_ID [25,86] : 0
                x CAL_ACC2_ID [26,95] : 0
                x CAL_ACC3_ID [27,104] : 0
                x CAL_AIR_CMODEL [28,113] : 0
                x CAL_AIR_TUBED_MM [29,114] : 1.5000
                x CAL_AIR_TUBELEN [30,115] : 0.2000
                x CAL_BARO0_ID [31,116] : 0
                x CAL_BARO1_ID [32,119] : 0
                x CAL_BARO2_ID [33,122] : 0
                x CAL_BARO3_ID [34,125] : 0
                x + CAL_GYRO0_ID [35,128] : 2490378
                x + CAL_GYRO0_PRIO [36,129] : 50
                x CAL_GYRO0_ROT [37,130] : -1
                x + CAL_GYRO0_XOFF [38,131] : 0.0010
                x + CAL_GYRO0_YOFF [39,132] : 0.0099
                x + CAL_GYRO0_ZOFF [40,133] : -0.0099
                x CAL_GYRO1_ID [41,134] : 0
                x CAL_GYRO2_ID [42,140] : 0
                x CAL_GYRO3_ID [43,146] : 0
                x + CAL_MAG0_ID [44,152] : 527625
                x + CAL_MAG0_PRIO [45,153] : 75
                x + CAL_MAG0_ROT [46,154] : 0
                x CAL_MAG0_XCOMP [47,155] : 0.0000
                x + CAL_MAG0_XODIAG [48,156] : 0.0051
                x + CAL_MAG0_XOFF [49,157] : -0.1336
                x + CAL_MAG0_XSCALE [50,158] : 0.9732
                x CAL_MAG0_YCOMP [51,159] : 0.0000
                x + CAL_MAG0_YODIAG [52,160] : -0.0198
                x + CAL_MAG0_YOFF [53,161] : -0.2072
                x + CAL_MAG0_YSCALE [54,162] : 1.0103
                x CAL_MAG0_ZCOMP [55,163] : 0.0000
                x + CAL_MAG0_ZODIAG [56,164] : 0.0136
                x + CAL_MAG0_ZOFF [57,165] : 0.0588
                x + CAL_MAG0_ZSCALE [58,166] : 1.0181
                x CAL_MAG1_ID [59,167] : 0
                x CAL_MAG1_ROT [60,169] : -1
                x CAL_MAG2_ID [61,182] : 0
                x CAL_MAG2_ROT [62,184] : -1
                x CAL_MAG3_ID [63,197] : 0
                x CAL_MAG3_ROT [64,199] : -1
                x CAL_MAG_COMP_TYP [65,212] : 0
                x CAL_MAG_SIDES [66,213] : 63
                x CA_AIRFRAME [67,224] : 0
                x CA_FAILURE_MODE [68,225] : 0
                x CA_METHOD [69,240] : 2
                x CA_R0_SLEW [70,241] : 0.0000
                x CA_R10_SLEW [71,242] : 0.0000
                x CA_R11_SLEW [72,243] : 0.0000
                x CA_R1_SLEW [73,244] : 0.0000
                x CA_R2_SLEW [74,245] : 0.0000
                x CA_R3_SLEW [75,246] : 0.0000
                x CA_R4_SLEW [76,247] : 0.0000
                x CA_R5_SLEW [77,248] : 0.0000
                x CA_R6_SLEW [78,249] : 0.0000
                x CA_R7_SLEW [79,250] : 0.0000
                x CA_R8_SLEW [80,251] : 0.0000
                x CA_R9_SLEW [81,252] : 0.0000
                x CA_ROTOR0_AX [82,253] : 0.0000
                x CA_ROTOR0_AY [83,254] : 0.0000
                x CA_ROTOR0_AZ [84,255] : -1.0000
                x CA_ROTOR0_CT [85,256] : 6.5000
                x CA_ROTOR0_KM [86,257] : 0.0500
                x + CA_ROTOR0_PX [87,258] : 0.0850
                x + CA_ROTOR0_PY [88,259] : 0.0625
                x CA_ROTOR0_PZ [89,260] : 0.0000
                x CA_ROTOR10_AX [90,262] : 0.0000
                x CA_ROTOR10_AY [91,263] : 0.0000
                x CA_ROTOR10_AZ [92,264] : -1.0000
                x CA_ROTOR10_CT [93,265] : 6.5000
                x CA_ROTOR10_KM [94,266] : 0.0500
                x CA_ROTOR10_PX [95,267] : 0.0000
                x CA_ROTOR10_PY [96,268] : 0.0000
                x CA_ROTOR10_PZ [97,269] : 0.0000
                x CA_ROTOR11_AX [98,271] : 0.0000
                x CA_ROTOR11_AY [99,272] : 0.0000
                x CA_ROTOR11_AZ [100,273] : -1.0000
                x CA_ROTOR11_CT [101,274] : 6.5000
                x CA_ROTOR11_KM [102,275] : 0.0500
                x CA_ROTOR11_PX [103,276] : 0.0000
                x CA_ROTOR11_PY [104,277] : 0.0000
                x CA_ROTOR11_PZ [105,278] : 0.0000
                x CA_ROTOR1_AX [106,280] : 0.0000
                x CA_ROTOR1_AY [107,281] : 0.0000
                x CA_ROTOR1_AZ [108,282] : -1.0000
                x CA_ROTOR1_CT [109,283] : 6.5000
                x CA_ROTOR1_KM [110,284] : 0.0500
                x + CA_ROTOR1_PX [111,285] : -0.0850
                x + CA_ROTOR1_PY [112,286] : -0.0625
                x CA_ROTOR1_PZ [113,287] : 0.0000
                x CA_ROTOR2_AX [114,289] : 0.0000
                x CA_ROTOR2_AY [115,290] : 0.0000
                x CA_ROTOR2_AZ [116,291] : -1.0000
                x CA_ROTOR2_CT [117,292] : 6.5000
                x + CA_ROTOR2_KM [118,293] : -0.0500
                x + CA_ROTOR2_PX [119,294] : 0.0850
                x + CA_ROTOR2_PY [120,295] : -0.0625
                x CA_ROTOR2_PZ [121,296] : 0.0000
                x CA_ROTOR3_AX [122,298] : 0.0000
                x CA_ROTOR3_AY [123,299] : 0.0000
                x CA_ROTOR3_AZ [124,300] : -1.0000
                x CA_ROTOR3_CT [125,301] : 6.5000
                x + CA_ROTOR3_KM [126,302] : -0.0500
                x + CA_ROTOR3_PX [127,303] : -0.0850
                x + CA_ROTOR3_PY [128,304] : 0.0625
                x CA_ROTOR3_PZ [129,305] : 0.0000
                x CA_ROTOR4_AX [130,307] : 0.0000
                x CA_ROTOR4_AY [131,308] : 0.0000
                x CA_ROTOR4_AZ [132,309] : -1.0000
                x CA_ROTOR4_CT [133,310] : 6.5000
                x CA_ROTOR4_KM [134,311] : 0.0500
                x CA_ROTOR4_PX [135,312] : 0.0000
                x CA_ROTOR4_PY [136,313] : 0.0000
                x CA_ROTOR4_PZ [137,314] : 0.0000
                x CA_ROTOR5_AX [138,316] : 0.0000
                x CA_ROTOR5_AY [139,317] : 0.0000
                x CA_ROTOR5_AZ [140,318] : -1.0000
                x CA_ROTOR5_CT [141,319] : 6.5000
                x CA_ROTOR5_KM [142,320] : 0.0500
                x CA_ROTOR5_PX [143,321] : 0.0000
                x CA_ROTOR5_PY [144,322] : 0.0000
                x CA_ROTOR5_PZ [145,323] : 0.0000
                x CA_ROTOR6_AX [146,325] : 0.0000
                x CA_ROTOR6_AY [147,326] : 0.0000
                x CA_ROTOR6_AZ [148,327] : -1.0000
                x CA_ROTOR6_CT [149,328] : 6.5000
                x CA_ROTOR6_KM [150,329] : 0.0500
                x CA_ROTOR6_PX [151,330] : 0.0000
                x CA_ROTOR6_PY [152,331] : 0.0000
                x CA_ROTOR6_PZ [153,332] : 0.0000
                x CA_ROTOR7_AX [154,334] : 0.0000
                x CA_ROTOR7_AY [155,335] : 0.0000
                x CA_ROTOR7_AZ [156,336] : -1.0000
                x CA_ROTOR7_CT [157,337] : 6.5000
                x CA_ROTOR7_KM [158,338] : 0.0500
                x CA_ROTOR7_PX [159,339] : 0.0000
                x CA_ROTOR7_PY [160,340] : 0.0000
                x CA_ROTOR7_PZ [161,341] : 0.0000
                x CA_ROTOR8_AX [162,343] : 0.0000
                x CA_ROTOR8_AY [163,344] : 0.0000
                x CA_ROTOR8_AZ [164,345] : -1.0000
                x CA_ROTOR8_CT [165,346] : 6.5000
                x CA_ROTOR8_KM [166,347] : 0.0500
                x CA_ROTOR8_PX [167,348] : 0.0000
                x CA_ROTOR8_PY [168,349] : 0.0000
                x CA_ROTOR8_PZ [169,350] : 0.0000
                x CA_ROTOR9_AX [170,352] : 0.0000
                x CA_ROTOR9_AY [171,353] : 0.0000
                x CA_ROTOR9_AZ [172,354] : -1.0000
                x CA_ROTOR9_CT [173,355] : 6.5000
                x CA_ROTOR9_KM [174,356] : 0.0500
                x CA_ROTOR9_PX [175,357] : 0.0000
                x CA_ROTOR9_PY [176,358] : 0.0000
                x CA_ROTOR9_PZ [177,359] : 0.0000
                x + CA_ROTOR_COUNT [178,361] : 4
                x CA_R_REV [179,362] : 0
                x CA_SV0_SLEW [180,372] : 0.0000
                x CA_SV1_SLEW [181,373] : 0.0000
                x CA_SV2_SLEW [182,374] : 0.0000
                x CA_SV3_SLEW [183,375] : 0.0000
                x CA_SV4_SLEW [184,376] : 0.0000
                x CA_SV5_SLEW [185,377] : 0.0000
                x CA_SV6_SLEW [186,378] : 0.0000
                x CA_SV7_SLEW [187,379] : 0.0000
                x CBRK_AIRSPD_CHK [188,454] : 0
                x CBRK_FLIGHTTERM [189,456] : 121212
                x CBRK_IO_SAFETY [190,457] : 22027
                x + CBRK_SUPPLY_CHK [191,458] : 894281
                x CBRK_USB_CHK [192,459] : 197848
                x CBRK_VTOLARMING [193,460] : 0
                x COM_ACT_FAIL_ACT [194,461] : 0
                x COM_ARM_ARSP_EN [195,462] : 1
                x COM_ARM_AUTH_ID [196,463] : 10
                x COM_ARM_AUTH_MET [197,464] : 0
                x COM_ARM_AUTH_REQ [198,465] : 0
                x COM_ARM_AUTH_TO [199,466] : 1.0000
                x COM_ARM_BAD_INOV [200,467] : 0
                x COM_ARM_CHK_ESCS [201,468] : 0
                x COM_ARM_EKF_BIAS [202,469] : 3.0000
                x COM_ARM_EKF_HGT [203,470] : 1.0000
                x COM_ARM_EKF_POS [204,471] : 0.5000
                x COM_ARM_EKF_VEL [205,472] : 0.5000
                x COM_ARM_EKF_YAW [206,473] : 0.5000
                x COM_ARM_HFLT_CHK [207,474] : 1
                x COM_ARM_IMU_ACC [208,475] : 0.7000
                x COM_ARM_IMU_GYR [209,476] : 0.2500
                x COM_ARM_MAG_ANG [210,477] : 60
                x COM_ARM_MAG_STR [211,478] : 2
                x COM_ARM_MIS_REQ [212,479] : 0
                x COM_ARM_ODID [213,480] : 0
                x + COM_ARM_SDCARD [214,481] : 0
                x COM_ARM_SWISBTN [215,482] : 0
                x COM_ARM_WO_GPS [216,483] : 1
                x + COM_CPU_MAX [217,484] : -1.0000
                x COM_DISARM_FORCE [218,485] : 0
                x + COM_DISARM_LAND [219,486] : 0.1000
                x + COM_DISARM_PRFLT [220,487] : 20.0000
                x COM_DL_LOSS_T [221,488] : 10
                x COM_FAIL_ACT_T [222,489] : 5.0000
                x + COM_FLIGHT_UUID [223,490] : 743
                x + COM_FLTMODE1 [224,491] : 0
                x COM_FLTMODE2 [225,492] : -1
                x + COM_FLTMODE3 [226,493] : 8
                x COM_FLTMODE4 [227,494] : -1
                x COM_FLTMODE5 [228,495] : -1
                x + COM_FLTMODE6 [229,496] : 11
                x COM_FLT_PROFILE [230,497] : 0
                x COM_FLT_TIME_MAX [231,498] : -1
                x COM_FORCE_SAFETY [232,499] : 0
                x COM_HLDL_LOSS_T [233,500] : 120
                x COM_HLDL_REG_T [234,501] : 0
                x COM_HOME_EN [235,502] : 1
                x COM_HOME_IN_AIR [236,503] : 0
                x COM_IMB_PROP_ACT [237,504] : 0
                x + COM_KILL_DISARM [238,505] : 0.0000
                x COM_LKDOWN_TKO [239,506] : 3.0000
                x COM_LOW_BAT_ACT [240,507] : 0
                x COM_MOT_TEST_EN [241,508] : 1
                x COM_OBC_LOSS_T [242,509] : 5.0000
                x COM_OBL_RC_ACT [243,510] : 0
                x COM_OBS_AVOID [244,511] : 0
                x COM_OF_LOSS_T [245,512] : 1.0000
                x COM_PARACHUTE [246,513] : 0
                x COM_POSCTL_NAVL [247,514] : 0
                x COM_POS_FS_DELAY [248,515] : 1
                x COM_POS_FS_EPH [249,516] : 5.0000
                x COM_POS_LOW_EPH [250,517] : -1.0000
                x COM_POWER_COUNT [251,518] : 1
                x COM_PREARM_MODE [252,519] : 0
                x COM_QC_ACT [253,520] : 0
                x COM_RCL_EXCEPT [254,521] : 0
                x COM_RC_ARM_HYST [255,522] : 1000
                x COM_RC_IN_MODE [256,523] : 3
                x COM_RC_LOSS_T [257,524] : 0.5000
                x COM_RC_OVERRIDE [258,525] : 1
                x COM_RC_STICK_OV [259,526] : 30.0000
                x + COM_SPOOLUP_TIME [260,527] : 2.0000
                x COM_TAKEOFF_ACT [261,528] : 0
                x COM_VEL_FS_EVH [262,529] : 1.0000
                x COM_WIND_MAX [263,530] : -1.0000
                x COM_WIND_WARN [264,531] : -1.0000
                x CP_DELAY [265,532] : 0.4000
                x CP_DIST [266,533] : -1.0000
                x CP_GO_NO_DATA [267,534] : 0
                x CP_GUIDE_ANG [268,535] : 30.0000
                x EKF2_ABIAS_INIT [269,543] : 0.2000
                x EKF2_ABL_ACCLIM [270,544] : 25.0000
                x EKF2_ABL_GYRLIM [271,545] : 3.0000
                x EKF2_ABL_LIM [272,546] : 0.4000
                x EKF2_ABL_TAU [273,547] : 0.5000
                x EKF2_ACC_B_NOISE [274,548] : 0.0030
                x EKF2_ACC_NOISE [275,549] : 0.3500
                x EKF2_AID_MASK [276,550] : 0
                x EKF2_ANGERR_INIT [277,551] : 0.1000
                x EKF2_ARSP_THR [278,552] : 0.0000
                x EKF2_ASPD_MAX [279,553] : 20.0000
                x EKF2_ASP_DELAY [280,554] : 100.0000
                x EKF2_AVEL_DELAY [281,555] : 5.0000
                x EKF2_BARO_CTRL [282,556] : 1
                x EKF2_BARO_DELAY [283,557] : 0.0000
                x EKF2_BARO_GATE [284,558] : 5.0000
                x EKF2_BARO_NOISE [285,559] : 3.5000
                x EKF2_BCOEF_X [286,560] : 100.0000
                x EKF2_BCOEF_Y [287,561] : 100.0000
                x EKF2_BETA_GATE [288,562] : 5.0000
                x EKF2_BETA_NOISE [289,563] : 0.3000
                x EKF2_DECL_TYPE [290,564] : 7
                x EKF2_DRAG_CTRL [291,565] : 0
                x EKF2_DRAG_NOISE [292,566] : 2.5000
                x EKF2_EAS_NOISE [293,567] : 1.4000
                x EKF2_EVA_NOISE [294,568] : 0.1000
                x EKF2_EVP_GATE [295,569] : 5.0000
                x EKF2_EVP_NOISE [296,570] : 0.1000
                x EKF2_EVV_GATE [297,571] : 3.0000
                x EKF2_EVV_NOISE [298,572] : 0.1000
                x + EKF2_EV_CTRL [299,573] : 0
                x EKF2_EV_DELAY [300,574] : 0.0000
                x EKF2_EV_HGT_TO [301,575] : 5000
                x EKF2_EV_NOISE_MD [302,576] : 0
                x EKF2_EV_POS_TO [303,577] : 1000
                x EKF2_EV_POS_X [304,578] : 0.0000
                x EKF2_EV_POS_Y [305,579] : 0.0000
                x EKF2_EV_POS_Z [306,580] : 0.0000
                x EKF2_EV_QMIN [307,581] : 0
                x EKF2_FUSE_BETA [308,582] : 0
                x EKF2_GBIAS_INIT [309,583] : 0.1000
                x EKF2_GND_EFF_DZ [310,584] : 4.0000
                x EKF2_GND_MAX_HGT [311,585] : 0.5000
                x EKF2_GPS_CHECK [312,586] : 245
                x EKF2_GPS_CTRL [313,587] : 7
                x EKF2_GPS_DELAY [314,588] : 110.0000
                x EKF2_GPS_POS_X [315,589] : 0.0000
                x EKF2_GPS_POS_Y [316,590] : 0.0000
                x EKF2_GPS_POS_Z [317,591] : 0.0000
                x EKF2_GPS_P_GATE [318,592] : 5.0000
                x EKF2_GPS_P_NOISE [319,593] : 0.5000
                x EKF2_GPS_V_GATE [320,594] : 5.0000
                x EKF2_GPS_V_NOISE [321,595] : 0.3000
                x EKF2_GRAV_NOISE [322,596] : 1.0000
                x EKF2_GSF_TAS [323,597] : 15.0000
                x EKF2_GYR_B_LIM [324,598] : 0.1500
                x EKF2_GYR_B_NOISE [325,599] : 0.0010
                x EKF2_GYR_NOISE [326,600] : 0.0150
                x EKF2_HDG_GATE [327,601] : 2.6000
                x EKF2_HEAD_NOISE [328,602] : 0.3000
                x EKF2_HGT_REF [329,603] : 1
                x EKF2_IMU_CTRL [330,604] : 3
                x + EKF2_IMU_POS_X [331,605] : 0.0050
                x + EKF2_IMU_POS_Y [332,606] : 0.0080
                x + EKF2_IMU_POS_Z [333,607] : -0.0116
                x EKF2_MAG_ACCLIM [334,608] : 0.5000
                x EKF2_MAG_B_NOISE [335,609] : 0.0001
                x EKF2_MAG_CHECK [336,610] : 1
                x + EKF2_MAG_DECL [337,611] : -11.0090
                x EKF2_MAG_DELAY [338,612] : 0.0000
                x EKF2_MAG_E_NOISE [339,613] : 0.0010
                x EKF2_MAG_GATE [340,614] : 3.0000
                x EKF2_MAG_NOISE [341,615] : 0.0500
                x EKF2_MAG_TYPE [342,616] : 0
                x EKF2_MAG_YAWLIM [343,617] : 0.2000
                x EKF2_MCOEF [344,618] : 0.1500
                x EKF2_MIN_RNG [345,619] : 0.1000
                x EKF2_NOAID_NOISE [346,622] : 10.0000
                x EKF2_NOAID_TOUT [347,623] : 5000000
                x EKF2_OF_CTRL [348,624] : 0
                x EKF2_OF_DELAY [349,625] : 20.0000
                x EKF2_OF_GATE [350,626] : 3.0000
                x EKF2_OF_N_MAX [351,627] : 0.5000
                x EKF2_OF_N_MIN [352,628] : 0.1500
                x EKF2_OF_POS_X [353,629] : 0.0000
                x EKF2_OF_POS_Y [354,630] : 0.0000
                x EKF2_OF_POS_Z [355,631] : 0.0000
                x EKF2_OF_QMIN [356,632] : 1
                x EKF2_PCOEF_XN [357,633] : 0.0000
                x EKF2_PCOEF_XP [358,634] : 0.0000
                x EKF2_PCOEF_YN [359,635] : 0.0000
                x EKF2_PCOEF_YP [360,636] : 0.0000
                x EKF2_PCOEF_Z [361,637] : 0.0000
                x EKF2_PREDICT_US [362,638] : 10000
                x EKF2_REQ_EPH [363,639] : 3.0000
                x EKF2_REQ_EPV [364,640] : 5.0000
                x + EKF2_REQ_GPS_H [365,641] : 5.0000
                x EKF2_REQ_HDRIFT [366,642] : 0.1000
                x EKF2_REQ_NSATS [367,643] : 6
                x EKF2_REQ_PDOP [368,644] : 2.5000
                x + EKF2_REQ_SACC [369,645] : 1.5000
                x EKF2_REQ_VDRIFT [370,646] : 0.2000
                x EKF2_RNG_A_HMAX [371,647] : 5.0000
                x EKF2_RNG_A_IGATE [372,648] : 1.0000
                x EKF2_RNG_A_VMAX [373,649] : 1.0000
                x + EKF2_RNG_CTRL [374,650] : 0
                x EKF2_RNG_DELAY [375,651] : 5.0000
                x EKF2_RNG_GATE [376,652] : 5.0000
                x EKF2_RNG_K_GATE [377,653] : 1.0000
                x EKF2_RNG_NOISE [378,654] : 0.1000
                x EKF2_RNG_PITCH [379,655] : 0.0000
                x EKF2_RNG_POS_X [380,656] : 0.0000
                x EKF2_RNG_POS_Y [381,657] : 0.0000
                x EKF2_RNG_POS_Z [382,658] : 0.0000
                x EKF2_RNG_QLTY_T [383,659] : 1.0000
                x EKF2_RNG_SFE [384,660] : 0.0500
                x EKF2_SYNT_MAG_Z [385,666] : 0
                x EKF2_TAS_GATE [386,667] : 3.0000
                x EKF2_TAU_POS [387,668] : 0.2500
                x EKF2_TAU_VEL [388,669] : 0.2500
                x EKF2_TERR_GRAD [389,670] : 0.5000
                x EKF2_TERR_MASK [390,671] : 3
                x EKF2_TERR_NOISE [391,672] : 5.0000
                x EKF2_WIND_NSD [392,673] : 0.0100
                x FD_ACT_EN [393,679] : 1
                x FD_ACT_MOT_C2T [394,680] : 2.0000
                x FD_ACT_MOT_THR [395,681] : 0.2000
                x FD_ACT_MOT_TOUT [396,682] : 100
                x FD_ESCS_EN [397,683] : 1
                x FD_EXT_ATS_EN [398,684] : 0
                x FD_EXT_ATS_TRIG [399,685] : 1900
                x FD_FAIL_P [400,686] : 60
                x FD_FAIL_P_TTRI [401,687] : 0.3000
                x FD_FAIL_R [402,688] : 60
                x FD_FAIL_R_TTRI [403,689] : 0.3000
                x FD_IMB_PROP_THR [404,690] : 30
                x FLW_TGT_ALT_M [405,691] : 0
                x FLW_TGT_DST [406,692] : 8.0000
                x FLW_TGT_FA [407,693] : 180.0000
                x FLW_TGT_HT [408,694] : 8.0000
                x FLW_TGT_MAX_VEL [409,695] : 5.0000
                x FLW_TGT_RS [410,696] : 0.1000
                x FW_AIRSPD_MAX [411,700] : 20.0000
                x FW_AIRSPD_TRIM [412,703] : 15.0000
                x FW_ARSP_MODE [413,704] : 0
                x FW_PSP_OFF [414,754] : 0.0000
                x FW_T_CLMB_R_SP [415,783] : 3.0000
                x FW_T_SINK_R_SP [416,792] : 2.0000
                x GF_ACTION [417,816] : 2
                x GF_ALTMODE [418,817] : 0
                x GF_COUNT [419,818] : -1
                x GF_MAX_HOR_DIST [420,819] : 0.0000
                x GF_MAX_VER_DIST [421,820] : 0.0000
                x GF_PREDICT [422,821] : 0
                x GF_SOURCE [423,822] : 0
                x GND_SPEED_THR_SC [424,833] : 1.0000
                x GPIO_CTL_CH [425,840] : 0
                x GPS_1_GNSS [426,841] : 0
                x GPS_1_PROTOCOL [427,842] : 1
                x GPS_DUMP_COMM [428,845] : 0
                x GPS_PITCH_OFFSET [429,846] : 0.0000
                x GPS_SAT_INFO [430,847] : 0
                x GPS_UBX_BAUD2 [431,848] : 230400
                x GPS_UBX_CFG_INTF [432,849] : 0
                x GPS_UBX_DYNMODEL [433,850] : 7
                x GPS_UBX_MODE [434,851] : 0
                x GPS_YAW_OFFSET [435,852] : 0.0000
                x HTE_ACC_GATE [436,870] : 3.0000
                x HTE_HT_ERR_INIT [437,871] : 0.1000
                x HTE_HT_NOISE [438,872] : 0.0036
                x HTE_THR_RANGE [439,873] : 0.2000
                x HTE_VXY_THR [440,874] : 10.0000
                x HTE_VZ_THR [441,875] : 2.0000
                x + IMU_ACCEL_CUTOFF [442,876] : 60.0000
                x + IMU_DGYRO_CUTOFF [443,877] : 40.0000
                x + IMU_GYRO_CUTOFF [444,879] : 80.0000
                x IMU_GYRO_DNF_BW [445,880] : 15.0000
                x + IMU_GYRO_DNF_EN [446,881] : 1
                x IMU_GYRO_DNF_HMC [447,882] : 3
                x IMU_GYRO_DNF_MIN [448,883] : 25.0000
                x IMU_GYRO_NF0_BW [449,889] : 20.0000
                x IMU_GYRO_NF0_FRQ [450,890] : 0.0000
                x IMU_GYRO_NF1_BW [451,891] : 20.0000
                x IMU_GYRO_NF1_FRQ [452,892] : 0.0000
                x + IMU_GYRO_RATEMAX [453,893] : 800
                x IMU_INTEG_RATE [454,894] : 200
                x LNDMC_ALT_GND [455,916] : 2.0000
                x LNDMC_ALT_MAX [456,917] : -1.0000
                x + LNDMC_ROT_MAX [457,918] : 30.0000
                x + LNDMC_TRIG_TIME [458,919] : 0.5000
                x LNDMC_XY_VEL_MAX [459,920] : 1.5000
                x LNDMC_Z_VEL_MAX [460,921] : 0.2500
                x + LND_FLIGHT_T_HI [461,922] : 6
                x + LND_FLIGHT_T_LO [462,923] : -1544484235
                x + MAN_ARM_GESTURE [463,974] : 0
                x MAV_COMP_ID [464,990] : 1
                x MAV_FWDEXTSP [465,991] : 1
                x MAV_HASH_CHK_EN [466,992] : 1
                x MAV_HB_FORW_EN [467,993] : 1
                x MAV_PROTO_VER [468,994] : 0
                x MAV_RADIO_TOUT [469,995] : 5
                x MAV_SIK_RADIO_ID [470,996] : 0
                x MAV_SYS_ID [471,997] : 1
                x + MAV_TYPE [472,998] : 2
                x MAV_USEHILGPS [473,999] : 0
                x MC_ACRO_EXPO [474,1002] : 0.6900
                x MC_ACRO_EXPO_Y [475,1003] : 0.6900
                x MC_ACRO_P_MAX [476,1004] : 720.0000
                x MC_ACRO_R_MAX [477,1005] : 720.0000
                x MC_ACRO_SUPEXPO [478,1006] : 0.7000
                x MC_ACRO_SUPEXPOY [479,1007] : 0.7000
                x MC_ACRO_Y_MAX [480,1008] : 540.0000
                x MC_AIRMODE [481,1009] : 0
                x MC_AT_APPLY [482,1010] : 1
                x MC_AT_AXES [483,1011] : 3
                x MC_AT_RISE_TIME [484,1013] : 0.1400
                x MC_AT_START [485,1014] : 0
                x MC_AT_SYSID_AMP [486,1015] : 0.7000
                x MC_BAT_SCALE_EN [487,1016] : 0
                x MC_INJECT_AMP [488,1017] : 0.0500
                x MC_INJECT_CNT [489,1018] : 12
                x MC_INJECT_EN [490,1019] : 0
                x MC_INJECT_INC [491,1020] : 1.0000
                x MC_INJECT_REST_T [492,1021] : 1.0000
                x MC_INJECT_RPY [493,1022] : 2
                x MC_INJECT_SINE_T [494,1023] : 5.0000
                x MC_INJECT_START [495,1024] : 3.0000
                x MC_MAN_TILT_TAU [496,1025] : 0.0000
                x MC_ORBIT_RAD_MAX [497,1026] : 1000.0000
                x + MC_PITCHRATE_D [498,1027] : 0.0011
                x MC_PITCHRATE_FF [499,1028] : 0.0000
                x + MC_PITCHRATE_I [500,1029] : 0.0960
                x MC_PITCHRATE_K [501,1030] : 1.0000
                x + MC_PITCHRATE_MAX [502,1031] : 130.0000
                x + MC_PITCHRATE_P [503,1032] : 0.0640
                x + MC_PITCH_CUTOFF [504,1033] : 25.0000
                x + MC_PITCH_P [505,1034] : 8.0000
                x MC_PR_INT_LIM [506,1035] : 0.3000
                x + MC_ROLLRATE_D [507,1036] : 0.0013
                x MC_ROLLRATE_FF [508,1037] : 0.0000
                x + MC_ROLLRATE_I [509,1038] : 0.1000
                x MC_ROLLRATE_K [510,1039] : 1.0000
                x + MC_ROLLRATE_MAX [511,1040] : 130.0000
                x + MC_ROLLRATE_P [512,1041] : 0.0640
                x + MC_ROLL_CUTOFF [513,1042] : 25.0000
                x + MC_ROLL_P [514,1043] : 8.0000
                x MC_RR_INT_LIM [515,1044] : 0.3000
                x MC_THR_CURVE_ACR [516,1045] : 0
                x MC_YAWRATE_D [517,1046] : 0.0000
                x MC_YAWRATE_FF [518,1047] : 0.0000
                x + MC_YAWRATE_I [519,1048] : 0.5000
                x MC_YAWRATE_K [520,1049] : 1.0000
                x + MC_YAWRATE_MAX [521,1050] : 150.0000
                x + MC_YAWRATE_P [522,1051] : 0.0700
                x + MC_YAW_CUTOFF [523,1052] : 15.0000
                x MC_YAW_P [524,1053] : 2.8000
                x MC_YAW_WEIGHT [525,1054] : 0.4000
                x MC_YR_INT_LIM [526,1055] : 0.3000
                x MIS_DIST_1WP [527,1056] : 900.0000
                x MIS_LND_ABRT_ALT [528,1057] : 30
                x MIS_MNT_YAW_CTL [529,1058] : 0
                x MIS_PD_TO [530,1059] : 5.0000
                x MIS_TAKEOFF_ALT [531,1060] : 2.5000
                x MIS_TKO_LAND_REQ [532,1061] : 0
                x MIS_YAW_ERR [533,1062] : 12.0000
                x MIS_YAW_TMT [534,1063] : -1.0000
                x MODALAI_CONFIG [535,1083] : 0
                x MOT_SLEW_MAX [536,1085] : 0.0000
                x MPC_ACC_DOWN_MAX [537,1086] : 3.0000
                x + MPC_ACC_HOR [538,1087] : 6.0000
                x + MPC_ACC_HOR_MAX [539,1088] : 1000.0000
                x MPC_ACC_UP_MAX [540,1089] : 4.0000
                x MPC_ALT_MODE [541,1090] : 0
                x MPC_HOLD_DZ [542,1091] : 0.1000
                x + MPC_HOLD_MAX_XY [543,1092] : 0.0000
                x + MPC_HOLD_MAX_Z [544,1093] : 0.0000
                x MPC_JERK_AUTO [545,1094] : 4.0000
                x + MPC_JERK_MAX [546,1095] : 40.0000
                x MPC_LAND_ALT1 [547,1096] : 10.0000
                x MPC_LAND_ALT2 [548,1097] : 5.0000
                x MPC_LAND_ALT3 [549,1098] : 1.0000
                x MPC_LAND_CRWL [550,1099] : 0.3000
                x MPC_LAND_RADIUS [551,1100] : 1000.0000
                x MPC_LAND_RC_HELP [552,1101] : 0
                x + MPC_LAND_SPEED [553,1102] : 1.2000
                x + MPC_MANTHR_MIN [554,1103] : 0.0400
                x + MPC_MAN_TILT_MAX [555,1104] : 45.0000
                x MPC_MAN_Y_MAX [556,1105] : 150.0000
                x MPC_MAN_Y_TAU [557,1106] : 0.0800
                x MPC_POS_MODE [558,1107] : 4
                x MPC_THR_CURVE [559,1108] : 0
                x + MPC_THR_HOVER [560,1109] : 0.1300
                x + MPC_THR_MAX [561,1110] : 0.6000
                x + MPC_THR_MIN [562,1111] : 0.0400
                x MPC_THR_XY_MARG [563,1112] : 0.3000
                x MPC_TILTMAX_AIR [564,1113] : 45.0000
                x MPC_TILTMAX_LND [565,1114] : 12.0000
                x + MPC_TKO_RAMP_T [566,1115] : 2.0000
                x MPC_TKO_SPEED [567,1116] : 1.5000
                x MPC_USE_HTE [568,1117] : 1
                x MPC_VELD_LP [569,1118] : 5.0000
                x + MPC_VEL_MANUAL [570,1119] : 20.0000
                x MPC_VEL_MAN_BACK [571,1120] : -1.0000
                x MPC_VEL_MAN_SIDE [572,1121] : -1.0000
                x + MPC_XY_CRUISE [573,1122] : 15.0000
                x MPC_XY_ERR_MAX [574,1123] : 2.0000
                x + MPC_XY_MAN_EXPO [575,1124] : 0.4500
                x MPC_XY_P [576,1125] : 0.9500
                x MPC_XY_TRAJ_P [577,1126] : 0.5000
                x MPC_XY_VEL_ALL [578,1127] : -10.0000
                x MPC_XY_VEL_D_ACC [579,1128] : 0.2000
                x MPC_XY_VEL_I_ACC [580,1129] : 0.4000
                x + MPC_XY_VEL_MAX [581,1130] : 20.0000
                x MPC_XY_VEL_P_ACC [582,1131] : 1.8000
                x MPC_YAWRAUTO_MAX [583,1132] : 45.0000
                x + MPC_YAW_EXPO [584,1133] : 0.3000
                x MPC_YAW_MODE [585,1134] : 0
                x + MPC_Z_MAN_EXPO [586,1135] : 0.1000
                x + MPC_Z_P [587,1136] : 5.0000
                x MPC_Z_VEL_ALL [588,1137] : -3.0000
                x MPC_Z_VEL_D_ACC [589,1138] : 0.0000
                x MPC_Z_VEL_I_ACC [590,1139] : 2.0000
                x + MPC_Z_VEL_MAX_DN [591,1140] : 4.0000
                x + MPC_Z_VEL_MAX_UP [592,1141] : 10.0000
                x + MPC_Z_VEL_P_ACC [593,1142] : 8.0000
                x + MPC_Z_V_AUTO_DN [594,1143] : 3.0000
                x + MPC_Z_V_AUTO_UP [595,1144] : 10.0000
                x NAV_ACC_RAD [596,1148] : 10.0000
                x NAV_DLL_ACT [597,1149] : 0
                x NAV_FORCE_VT [598,1150] : 1
                x NAV_FW_ALTL_RAD [599,1151] : 5.0000
                x NAV_FW_ALT_RAD [600,1152] : 10.0000
                x NAV_LOITER_RAD [601,1153] : 80.0000
                x NAV_MC_ALT_RAD [602,1154] : 0.8000
                x NAV_MIN_LTR_ALT [603,1155] : -1.0000
                x NAV_RCL_ACT [604,1156] : 2
                x NAV_TRAFF_AVOID [605,1157] : 1
                x NAV_TRAFF_A_HOR [606,1158] : 500.0000
                x NAV_TRAFF_A_VER [607,1159] : 500.0000
                x NAV_TRAFF_COLL_T [608,1160] : 60
                x PLD_BTOUT [609,1215] : 5.0000
                x PLD_FAPPR_ALT [610,1216] : 0.1000
                x PLD_HACC_RAD [611,1217] : 0.2000
                x PLD_MAX_SRCH [612,1218] : 3
                x PLD_SRCH_ALT [613,1219] : 10.0000
                x PLD_SRCH_TOUT [614,1220] : 10.0000
                x RC10_DZ [615,1267] : 0.0000
                x RC10_MAX [616,1268] : 2000.0000
                x RC10_MIN [617,1269] : 1000.0000
                x RC10_REV [618,1270] : 1.0000
                x RC10_TRIM [619,1271] : 1500.0000
                x RC11_DZ [620,1272] : 0.0000
                x RC11_MAX [621,1273] : 2000.0000
                x RC11_MIN [622,1274] : 1000.0000
                x RC11_REV [623,1275] : 1.0000
                x RC11_TRIM [624,1276] : 1500.0000
                x RC12_DZ [625,1277] : 0.0000
                x RC12_MAX [626,1278] : 2000.0000
                x RC12_MIN [627,1279] : 1000.0000
                x RC12_REV [628,1280] : 1.0000
                x RC12_TRIM [629,1281] : 1500.0000
                x RC13_DZ [630,1282] : 0.0000
                x RC13_MAX [631,1283] : 2000.0000
                x RC13_MIN [632,1284] : 1000.0000
                x RC13_REV [633,1285] : 1.0000
                x RC13_TRIM [634,1286] : 1500.0000
                x RC14_DZ [635,1287] : 0.0000
                x RC14_MAX [636,1288] : 2000.0000
                x RC14_MIN [637,1289] : 1000.0000
                x RC14_REV [638,1290] : 1.0000
                x RC14_TRIM [639,1291] : 1500.0000
                x RC15_DZ [640,1292] : 0.0000
                x RC15_MAX [641,1293] : 2000.0000
                x RC15_MIN [642,1294] : 1000.0000
                x RC15_REV [643,1295] : 1.0000
                x RC15_TRIM [644,1296] : 1500.0000
                x RC16_DZ [645,1297] : 0.0000
                x RC16_MAX [646,1298] : 2000.0000
                x RC16_MIN [647,1299] : 1000.0000
                x RC16_REV [648,1300] : 1.0000
                x RC16_TRIM [649,1301] : 1500.0000
                x RC17_DZ [650,1302] : 0.0000
                x RC17_MAX [651,1303] : 2000.0000
                x RC17_MIN [652,1304] : 1000.0000
                x RC17_REV [653,1305] : 1.0000
                x RC17_TRIM [654,1306] : 1500.0000
                x RC18_DZ [655,1307] : 0.0000
                x RC18_MAX [656,1308] : 2000.0000
                x RC18_MIN [657,1309] : 1000.0000
                x RC18_REV [658,1310] : 1.0000
                x RC18_TRIM [659,1311] : 1500.0000
                x RC1_DZ [660,1312] : 10.0000
                x + RC1_MAX [661,1313] : 2012.0000
                x + RC1_MIN [662,1314] : 1004.0000
                x RC1_REV [663,1315] : 1.0000
                x + RC1_TRIM [664,1316] : 1505.0000
                x RC2_DZ [665,1317] : 10.0000
                x + RC2_MAX [666,1318] : 2012.0000
                x + RC2_MIN [667,1319] : 998.0000
                x RC2_REV [668,1320] : 1.0000
                x + RC2_TRIM [669,1321] : 1508.0000
                x RC3_DZ [670,1322] : 10.0000
                x + RC3_MAX [671,1323] : 1971.0000
                x + RC3_MIN [672,1324] : 990.0000
                x RC3_REV [673,1325] : 1.0000
                x + RC3_TRIM [674,1326] : 1365.0000
                x RC4_DZ [675,1327] : 10.0000
                x + RC4_MAX [676,1328] : 2006.0000
                x + RC4_MIN [677,1329] : 1011.0000
                x RC4_REV [678,1330] : 1.0000
                x + RC4_TRIM [679,1331] : 1505.0000
                x RC5_DZ [680,1332] : 10.0000
                x + RC5_MAX [681,1333] : 0.0000
                x + RC5_MIN [682,1334] : 0.0000
                x RC5_REV [683,1335] : 1.0000
                x + RC5_TRIM [684,1336] : 1030.0000
                x RC6_DZ [685,1337] : 10.0000
                x + RC6_MAX [686,1338] : 0.0000
                x + RC6_MIN [687,1339] : 0.0000
                x RC6_REV [688,1340] : 1.0000
                x + RC6_TRIM [689,1341] : 1030.0000
                x RC7_DZ [690,1342] : 10.0000
                x + RC7_MAX [691,1343] : 0.0000
                x + RC7_MIN [692,1344] : 0.0000
                x RC7_REV [693,1345] : 1.0000
                x + RC7_TRIM [694,1346] : 1030.0000
                x RC8_DZ [695,1347] : 10.0000
                x + RC8_MAX [696,1348] : 0.0000
                x + RC8_MIN [697,1349] : 0.0000
                x RC8_REV [698,1350] : 1.0000
                x + RC8_TRIM [699,1351] : 1030.0000
                x RC9_DZ [700,1352] : 0.0000
                x RC9_MAX [701,1353] : 2000.0000
                x RC9_MIN [702,1354] : 1000.0000
                x RC9_REV [703,1355] : 1.0000
                x RC9_TRIM [704,1356] : 1500.0000
                x RC_ARMSWITCH_TH [705,1357] : 0.7500
                x + RC_CHAN_CNT [706,1358] : 16
                x RC_ENG_MOT_TH [707,1360] : 0.7500
                x RC_FAILS_THR [708,1361] : 0
                x RC_GEAR_TH [709,1362] : 0.7500
                x RC_KILLSWITCH_TH [710,1364] : 0.7500
                x RC_LOITER_TH [711,1365] : 0.7500
                x RC_MAP_ACRO_SW [712,1366] : 0
                x + RC_MAP_ARM_SW [713,1367] : 7
                x RC_MAP_AUX1 [714,1368] : 0
                x RC_MAP_AUX2 [715,1369] : 0
                x RC_MAP_AUX3 [716,1370] : 0
                x RC_MAP_AUX4 [717,1371] : 0
                x RC_MAP_AUX5 [718,1372] : 0
                x RC_MAP_AUX6 [719,1373] : 0
                x RC_MAP_ENG_MOT [720,1374] : 0
                x RC_MAP_FAILSAFE [721,1375] : 0
                x RC_MAP_FLAPS [722,1376] : 0
                x + RC_MAP_FLTMODE [723,1377] : 6
                x RC_MAP_FLTM_BTN [724,1378] : 0
                x RC_MAP_GEAR_SW [725,1379] : 0
                x + RC_MAP_KILL_SW [726,1380] : 5
                x RC_MAP_LOITER_SW [727,1381] : 0
                x RC_MAP_MAN_SW [728,1382] : 0
                x RC_MAP_MODE_SW [729,1383] : 0
                x RC_MAP_OFFB_SW [730,1384] : 0
                x RC_MAP_PARAM1 [731,1385] : 0
                x RC_MAP_PARAM2 [732,1386] : 0
                x RC_MAP_PARAM3 [733,1387] : 0
                x + RC_MAP_PITCH [734,1388] : 2
                x RC_MAP_POSCTL_SW [735,1389] : 0
                x RC_MAP_RATT_SW [736,1390] : 0
                x RC_MAP_RETURN_SW [737,1391] : 0
                x + RC_MAP_ROLL [738,1392] : 1
                x RC_MAP_STAB_SW [739,1393] : 0
                x + RC_MAP_THROTTLE [740,1394] : 3
                x RC_MAP_TRANS_SW [741,1395] : 0
                x + RC_MAP_YAW [742,1396] : 4
                x RC_OFFB_TH [743,1397] : 0.7500
                x RC_RETURN_TH [744,1398] : 0.7500
                x RC_TRANS_TH [745,1402] : 0.7500
                x RTL_CONE_ANG [746,1403] : 45
                x RTL_DESCEND_ALT [747,1404] : 30.0000
                x RTL_HDG_MD [748,1405] : 0
                x RTL_LAND_DELAY [749,1406] : 0.0000
                x RTL_LOITER_RAD [750,1407] : 80.0000
                x RTL_MIN_DIST [751,1408] : 10.0000
                x RTL_PLD_MD [752,1409] : 0
                x RTL_RETURN_ALT [753,1410] : 60.0000
                x RTL_TIME_FACTOR [754,1411] : 1.1000
                x RTL_TIME_MARGIN [755,1412] : 100
                x RTL_TYPE [756,1413] : 0
                x SDLOG_BOOT_BAT [757,1424] : 0
                x SDLOG_DIRS_MAX [758,1425] : 0
                x SDLOG_MISSION [759,1428] : 0
                x SDLOG_MODE [760,1429] : 0
                x + SDLOG_PROFILE [761,1430] : 129
                x SDLOG_UTC_OFFSET [762,1431] : 0
                x SDLOG_UUID [763,1432] : 1
                x SENS_BARO_QNH [764,1434] : 1013.2500
                x SENS_BARO_RATE [765,1435] : 20.0000
                x SENS_BOARD_ROT [766,1436] : 0
                x + SENS_BOARD_X_OFF [767,1437] : -0.7805
                x + SENS_BOARD_Y_OFF [768,1438] : 0.2225
                x SENS_BOARD_Z_OFF [769,1439] : 0.0000
                x SENS_DPRES_OFF [770,1442] : 0.0000
                x SENS_GPS_MASK [771,1484] : 7
                x SENS_GPS_PRIME [772,1485] : 0
                x SENS_GPS_TAU [773,1486] : 10.0000
                x SENS_IMU_AUTOCAL [774,1487] : 0
                x SENS_IMU_MODE [775,1488] : 1
                x SENS_MAG_AUTOCAL [776,1494] : 0
                x SENS_MAG_AUTOROT [777,1495] : 0
                x SENS_MAG_MODE [778,1496] : 1
                x SENS_MAG_RATE [779,1497] : 15.0000
                x SENS_MAG_SIDES [780,1498] : 63
                x SYS_AUTOCONFIG [781,1645] : 0
                x + SYS_AUTOSTART [782,1646] : 4001
                x SYS_CAL_TDEL [783,1651] : 24
                x SYS_CAL_TMAX [784,1652] : 10
                x SYS_CAL_TMIN [785,1653] : 5
                x SYS_FAC_CAL_MODE [786,1655] : 0
                x SYS_FAILURE_EN [787,1656] : 0
                x SYS_HAS_BARO [788,1657] : 1
                x SYS_HAS_GPS [789,1658] : 1
                x SYS_HAS_MAG [790,1659] : 1
                x SYS_HAS_NUM_DIST [791,1660] : 0
                x SYS_HITL [792,1661] : 0
                x SYS_MC_EST_GROUP [793,1662] : 2
                x SYS_RGB_MAXBRT [794,1663] : 1.0000
                x SYS_STCK_EN [795,1664] : 1
                x SYS_VEHICLE_RESP [796,1666] : -0.4000
                x TC_A_ENABLE [797,1740] : 0
                x + TC_B0_ID [798,1741] : 12018473
                x + TC_B0_TMAX [799,1742] : 72.3200
                x + TC_B0_TMIN [800,1743] : 61.7500
                x + TC_B0_TREF [801,1744] : 67.0300
                x + TC_B0_X0 [802,1745] : 0.5761
                x + TC_B0_X1 [803,1746] : -2.0090
                x TC_B0_X2 [804,1747] : 0.0000
                x TC_B0_X3 [805,1748] : 0.0000
                x TC_B0_X4 [806,1749] : 0.0000
                x TC_B0_X5 [807,1750] : 0.0000
                x TC_B1_ID [808,1751] : 0
                x TC_B1_TMAX [809,1752] : 75.0000
                x TC_B1_TMIN [810,1753] : 5.0000
                x TC_B1_TREF [811,1754] : 40.0000
                x TC_B1_X0 [812,1755] : 0.0000
                x TC_B1_X1 [813,1756] : 0.0000
                x TC_B1_X2 [814,1757] : 0.0000
                x TC_B1_X3 [815,1758] : 0.0000
                x TC_B1_X4 [816,1759] : 0.0000
                x TC_B1_X5 [817,1760] : 0.0000
                x TC_B2_ID [818,1761] : 0
                x TC_B2_TMAX [819,1762] : 75.0000
                x TC_B2_TMIN [820,1763] : 5.0000
                x TC_B2_TREF [821,1764] : 40.0000
                x TC_B2_X0 [822,1765] : 0.0000
                x TC_B2_X1 [823,1766] : 0.0000
                x TC_B2_X2 [824,1767] : 0.0000
                x TC_B2_X3 [825,1768] : 0.0000
                x TC_B2_X4 [826,1769] : 0.0000
                x TC_B2_X5 [827,1770] : 0.0000
                x TC_B3_ID [828,1771] : 0
                x TC_B3_TMAX [829,1772] : 75.0000
                x TC_B3_TMIN [830,1773] : 5.0000
                x TC_B3_TREF [831,1774] : 40.0000
                x TC_B3_X0 [832,1775] : 0.0000
                x TC_B3_X1 [833,1776] : 0.0000
                x TC_B3_X2 [834,1777] : 0.0000
                x TC_B3_X3 [835,1778] : 0.0000
                x TC_B3_X4 [836,1779] : 0.0000
                x TC_B3_X5 [837,1780] : 0.0000
                x + TC_B_ENABLE [838,1781] : 1
                x TC_G_ENABLE [839,1846] : 0
                x + THR_MDL_FAC [840,1866] : 0.9000
                x TRIG_MODE [841,1872] : 0
                x UAVCAN_ENABLE [842,1913] : 0
                x + VOXL_ESC_BAUD [843,2095] : 2000000
                x + VOXL_ESC_CONFIG [844,2096] : 1
                x + VOXL_ESC_FUNC1 [845,2097] : 102
                x + VOXL_ESC_FUNC2 [846,2098] : 103
                x + VOXL_ESC_FUNC3 [847,2099] : 101
                x + VOXL_ESC_FUNC4 [848,2100] : 104
                x VOXL_ESC_MODE [849,2101] : 0
                x VOXL_ESC_PUB_BST [850,2102] : 1
                x VOXL_ESC_REV [851,2103] : 0
                x + VOXL_ESC_RPM_MAX [852,2104] : 12000
                x + VOXL_ESC_RPM_MIN [853,2105] : 2000
                x VOXL_ESC_SDIR1 [854,2106] : 0
                x VOXL_ESC_SDIR2 [855,2107] : 0
                x VOXL_ESC_SDIR3 [856,2108] : 0
                x VOXL_ESC_SDIR4 [857,2109] : 0
                x VOXL_ESC_T_COSP [858,2110] : 0.9900
                x VOXL_ESC_T_DEAD [859,2111] : 20
                x VOXL_ESC_T_EXPO [860,2112] : 35
                x VOXL_ESC_T_MINF [861,2113] : 0.1500
                x VOXL_ESC_T_OVER [862,2114] : 0
                x VOXL_ESC_T_PERC [863,2115] : 90
                x VOXL_ESC_T_WARN [864,2116] : 0
                x + VOXL_ESC_VLOG [865,2117] : 1
                x VTO_LOITER_ALT [866,2118] : 80.0000
                x VT_B_DEC_MSS [867,2123] : 2.0000
                x WV_EN [868,2156] : 0
                x WV_GAIN [869,2157] : 1.0000
                x WV_ROLL_MIN [870,2158] : 1.0000
                x WV_YRATE_MAX [871,2159] : 90.0000
                x XRCE_DDS_DOM_ID [872,2160] : 0
                x XRCE_DDS_KEY [873,2161] : 1
                874/2162 parameters used.
                • O Offline
                  O Offline
                  oiler251
                  I calibrated RC controller via QGRoundControl. I don't see Trim error but there is GPS POS drift too high message and does not take off. Is there a way to reset everything back to factory setting.
                  Unless someone available on Monday to support his effort over the phone as my team is not expert with the device and the programming parameters.
                  • O oiler251
                    @oiler251 Ah, okay, so the RC errors go away when you calibrate with QGC? Now you have a different error with GPS? Based on the parameters it looks like channels 1 through 4 were calibrated correctly but 5 through 8 look messed up. Those are channels associated with switch settings.
                    O 3 Replies Last reply
                    • O oiler251
                      @oiler251 How many satellites do you see with GPS? What if you set EKF2_GPS_CHECK to 1. Does that then allow arming? There are a bunch of parameters that can be set to tune how sensitive it is to various GPS statistics.
                      O 1 Reply Last reply
                        O Offline
                        O Offline
                        oiler251
                        @Eric-Katzfey Last few steps of the calibration are not sure not which switch to press/toggle for left and right switches on top. That could be the reason 5 through 8 are messed up.
                          O Offline
                          O Offline
                          oiler251
                          @Eric-Katzfey GPS is 0. EKF2_GPS_CHECK is 245 and i cannot update it to 1.
                            O Offline
                            O Offline
                            oiler251
                            @Eric-Katzfey Below is the px4-parameters.
                            voxl2:~$ px4-param show
                            x + CAL_ACC0_XOFF [19,80] : 0.0104
                            x + CAL_ACC0_XSCALE [20,81] : 0.9994
                            x + CAL_ACC0_YOFF [21,82] : 0.0122
                            x + CAL_ACC0_YSCALE [22,83] : 1.0011
                            x + CAL_ACC0_ZOFF [23,84] : 0.2113
                            x + CAL_ACC0_ZSCALE [24,85] : 0.9873
                            x + CAL_MAG0_XOFF [49,157] : -0.1164
                            x + CAL_MAG0_XSCALE [50,158] : 0.9666
                            x + CAL_MAG0_YOFF [53,161] : -0.2084
                            x + CAL_MAG0_YSCALE [54,162] : 1.0124
                            x + CAL_MAG0_ZOFF [57,165] : 0.0563
                            x + CAL_MAG0_ZSCALE [58,166] : 1.0239
                            x COM_FLTMODE3 [226,493] : -1
                            x COM_FLTMODE6 [229,496] : -1
                            x + RC1_MAX [661,1313] : 2007.0000
                            x + RC1_MIN [662,1314] : 989.0000
                            x + RC1_TRIM [664,1316] : 1496.0000
                            x + RC2_MAX [666,1318] : 2005.0000
                            x RC2_MIN [667,1319] : 1000.0000
                            x + RC2_TRIM [669,1321] : 1000.0000
                            x + RC3_MAX [671,1323] : 1972.0000
                            x + RC3_MIN [672,1324] : 1002.0000
                            x + RC3_TRIM [674,1326] : 1449.0000
                            x + RC4_MAX [676,1328] : 1993.0000
                            x + RC4_MIN [677,1329] : 1027.0000
                            x + RC4_TRIM [679,1331] : 1496.0000
                            x + RC5_MAX [681,1333] : 1980.0000
                            x + RC5_MIN [682,1334] : 1030.0000
                            x + RC5_TRIM [684,1336] : 1505.0000
                            x + RC6_MAX [686,1338] : 1980.0000
                            x + RC6_MIN [687,1339] : 1030.0000
                            x + RC6_TRIM [689,1341] : 1505.0000
                            x + RC7_MAX [691,1343] : 1980.0000
                            x + RC7_MIN [692,1344] : 1030.0000
                            x + RC7_TRIM [694,1346] : 1505.0000
                            x + RC8_MAX [696,1348] : 1980.0000
                            x + RC8_MIN [697,1349] : 1030.0000
                            x + RC8_TRIM [699,1351] : 1505.0000
                            x + RC_MAP_ARM_SW [713,1367] : 4
                            x + RC_MAP_PITCH [734,1388] : 3
                            x + RC_MAP_THROTTLE [740,1394] : 2
                            x + SENS_BOARD_X_OFF [767,1437] : 1.5968
                            x + SENS_BOARD_Y_OFF [768,1438] : -0.2765
                              O Offline
                              O Offline
                              oiler251
                              @Eric-Katzfey Please, advise if we can setup phone call or video call to resolve the issue?
                              Our team has an upcoming event that require the drone to be functional.
                              Also, advise if we need to ship it to your team to fix it otherwise.
                              • O oiler251
                                O Offline
                                O Offline
                                oiler251
                                @oiler251 Below is the Flight Mode configuration and GPS status.
                                • O oiler251
                                  O Offline
                                  O Offline
                                  oiler251
                                  @Eric-Katzfey Below is the error message on QGroundControl.
                                  • O oiler251
                                    @oiler251 Why can't you set EKF2_GPS_CHECK to 1? What happens when you try? Your last screen shot shows 2 errors. The high throttle error just means you have to put throttle to lowest position before arming.
                                    • O oiler251
                                      @oiler251 Here's what ChatGPT says:
                                      The pre-arm message “GPS Horizontal Position Drift too high” is gated by **EKF2_REQ_HDRIFT**.
                                      If you truly need to relax that check, raise **EKF2_REQ_HDRIFT** (default is often ~0.5 m/s). For example, set it closer to **1.0 m/s** so the EKF will accept more horizontal drift while on the ground and allow arming. The related on-ground GPS checks are toggled by the **EKF2_GPS_CHECK** bitmask (bits **5** and **7** cover horizontal drift and horizontal speed, respectively), but changing the threshold via EKF2_REQ_HDRIFT is the usual tweak. ([PX4 Documentation][1])
                                      Quick steps in QGroundControl: Parameters → search “EKF2_REQ_HDRIFT” → increase slightly → write & reboot.
                                      ⚠️ Note: loosening this check masks a real reception problem (antenna placement, multipath, EMI). If possible, fix the root cause instead of weakening safety checks. ([discuss.px4.io][2])
                                      [1]: https://docs.px4.io/v1.14/en/advanced_config/parameter_reference.html?utm_source=chatgpt.com "Parameter Reference | PX4 User Guide (v1.14)"
                                      [2]: https://discuss.px4.io/t/pixhawk-4-preflight-gps-horizontal-pos-error-too-high/21010?utm_source=chatgpt.com "Pixhawk 4 preflight gps horizontal pos error too high"
                                        O Offline
                                        O Offline
                                        oiler251
                                        @Eric-Katzfey The current value of EKF2_GPS_CHECK is 245. I clicked on the number and replaced the 245 with 1 and clicked save button. It does not replace the number.
                                        Regarding throttle error msg, it appears when the left gimble is to the bottom right corner which is what the VOXL developer bootcamp instruction.
                                        Is there an expert who can support over the phone or video call?
                                        If there is none, then can you provide your supervisor contact information that i can forward to my manager to take care of the issue.
                                        My team need basic drone functionality where we can take off the drone and land.
                                        Eric KatzfeyE 4 Replies Last reply
                                        • O oiler251
                                          @oiler251 It seems like in QGC you cannot just change that value directly, you have to uncheck all of the boxes instead of the satellite count one. Then it will go to 1. Then you can save, reboot and try to arm. I think before doing that, however, you should first try to change EKF2_REQ_HDRIFT to 1.0 as suggested. That is a more precise way to make the adjustment.
