    "wlan" not starting (LTE-Module attached, possible conflict w/ camera on USB-Port?)
    VOXL Flight
    • m4v3rM
      m4v3r
      Hi guys and gals 🙂
      Sorry for coming up with such a probably weird and quirky issue again and also I really tried my hardest with the title here, so please have some lenience with me here...
      I startup the drone with an LTE module (v2) attached and a camera connected to the VOXL-Flight's USB port.
      Scanning wifi-IP's this VOXL doesn't show up anymore and I can't connect to it through a GS nor SSH.
      Now the thing is, as soon as I pull the camera from the VOXL's USB the wifi on the VOXL starts up and it will connect to a GS and I can SSH in normally.
      I tried plugging the camera back in and the wifi (wlan) on the VOXL actually ceases to work again.
      Are there possibly any resource conflicts going on here?
      Should I try connecting the camera to the LTE module instead? (As I understand this doubles as a USB-hub?)
      thanks for any insights.
      cheers
      Ch.B.
        tom admin
        @m4v3r Could you post a picture of your setup so we can get a good idea of what you're working with?
        m4v3rM 1 Reply Last reply Reply Quote 0
        • m4v3rM
          m4v3r @tom
          @tom yes, will try and do so tomorrow.
          actually it might not be feasible for me to snap actual photos I just made an image showing the basic concept
          Ch.B.
          m4v3rM 1 Reply Last reply Reply Quote 1
          • m4v3rM
            m4v3r @m4v3r
            One more thing to add I can think of is
            that on another drone the same setup but without the LTE module is working normally.
            Please tell me if it would make a big difference to have actual photos and I'll see what I can do... 😉
            Ch.B.
              tom admin
              @m4v3r The LTE module shouldn't affect it, unless it is a power issue. I'll ping the team on this one.
              • Chad SweetC
                Chad Sweet ModalAI Team
                @m4v3r @tom Have you looked at this thread? Seems similar
                https://forum.modalai.com/topic/247/how-am-i-able-to-change-from-wifi-to-lte-connection?_=1634754422256
                • m4v3rM
                  m4v3r
                  Hey,
                  just wanted to give an update it looks like the problem was a hardware fault.
                  The behavior stayed the same after detaching the LTE and the setup works on a different VOXL Flight, so yeah...^^
                  cheers
                  Ch.B.
