  3. Compatible ToF sensor setup with VOXL2 Mini
18 Posts 5 Posters 9.5k Views 3 Watching
    @Morten-Nissov ,
    Yes the old TOF (V1) is EOL and we only have the TOF V2 available now, but due to increase power requirements, the connector had to change. The Starling Front End board (M0173) provides the connector to plug in the M0178 tof assembly (look at https://docs.modalai.com/voxl2-coax-camera-bundles/ C26, or C27).
    The Starling camera front end is only compatible with VOXL2, not VOXL2 mini. However, if you just wanted to plug in TOF V2 directly into VOX2 Mini, we now have M0172, which you can find a pictured here : https://forum.modalai.com/topic/4125/indoor-navigation-using-4-depth-sensors . M0172 splits the VOXL2 dual camera connector into a TOF-compatible 40-pin molex connector and the uCoax connector for the cameras that use uCoax.
    We don't have M0172 officially available, but if you want to try it we can make it available in the shop. So you would need (M0172 adapter + MSU-M0178-1-01 (the whole TOF sensor assembly) ).
    The connection order would look like this:
    VOXL2 (mini) <-> M0172 <-> M0177 <-> M0178 <-> actual TOF sensor
    (everything to the right of M0172 is sold in this kit : https://www.modalai.com/products/m0178?variant=48528287793456)
    This would work for either VOXL2 or VOXL2 mini. The only down side i see is that M0177 is pretty short. I am not sure if we have an extension available, but will check.
    EDIT: Here is the extension that can go between M0172 and M0177 : https://www.modalai.com/products/msu-m0170
    Morten NissovM Offline
    Morten Nissov
    wrote on last edited by Morten Nissov
    @Alex-Kushleyev Thanks for getting back so quickly! We just have a couple of follow-up questions:
    If we use this M0172 are we still able to have a tracking camera running? Such that the total setup looks something like: VOXL2 mini w/ M0178 ToF and M0014 tracking camera. If yes, then it would be great if the M0172 could be made available in the shop
      @Morten-Nissov ,
      Morten Nissov
      @Alex-Kushleyev Hi again Alex, sorry for disturb just wanted to hear if you had seen the previous message? And if you could make the M0172 available?
      • Morten NissovM Morten Nissov
        Hi @Morten-Nissov ,
        Sorry for the delay. We will get the M0172 board available for purchase ASAP.
        Since your configuration uses M0014 camera, which would not be able to plug into M0172 splitter, here is your connection option:
        • VOXL2 Mini J6:
          • M0076 or M0135 interposer + M0014 camera
        • VOXL2 Mini J7:
          • M0172 interposer + TOF
        (You could swap the connections, such as TOF is connected to J6, and vice versa). You would simply need to update the sensormodules (camera drivers) used, according to the slot id of each camera.)
        When using VOXL2 mini with TOF, our guidance is to use only one TOF V2 per VOXL2 mini
        • the TOF V2 sensor uses 5V power input, however VOXL 2 Mini only has a budget of 900mA on the 5V rail because the input voltage to the mini is 3.8V and there is a step-up regulator to 5.0V. This is different from VOXL2, which uses an APM / ESC to supply 5V 6A into VOXL2.
        • the TOF V2 internally uses 3.3V and the pulsed current draw in different operating modes can be found here : https://docs.modalai.com/M0178/#irs2975-operating-modes . Using multiple TOF sensors on voxl2 mini can result in exceeding the current limit on the 5V regulator.
        Keep in mind that you will still be able to plug in additional cameras if you need to:
        • a uCoax camera plugged into M0172 (M0161, M0166, etc)
        • any camera that uses older connector plugged into M0135 (M0014, M0107, etc)
        One thing to keep in mind when using M0076 and M0135 is because they were originally designed for VOXL2, though compatible with VOXL2 mini, the interposers may interfere with the mini's mounting holes, because M0076 / M0135 (when inserted) have slight overlap with the mounting holes. However, the overlap may not be an issue if you dont have stand-offs on the side where M0076 / M0135 plugs into VOXL2 mini.
        We will update this thread once M0172 is available in the shop.
        VinnyV 1 Reply Last reply
          Hi @Morten-Nissov ,
          • VOXL2 Mini J6:
          • VOXL2 Mini J7:
          @Alex-Kushleyev @Morten-Nissov , The team just posted the M0172 for sale.
          Sorry for the delays....
          https://www.modalai.com/products/mdk-m0172-1-00
          Morten NissovM 2 Replies Last reply
          • VinnyV Vinny
            Morten Nissov
            @Vinny Sorry thought I had responded, thanks!
            • VinnyV Vinny
              Morten Nissov
              @Vinny @Alex-Kushleyev
              We are trying to configure Voxl 2 Mini with the ToF sensor and a tracking camera with the , and we're having trouble with getting the ToF sensor to work. This is with the new ToF sensor and the new interposer you suggested for us to use.
              The cameras are attached in the following way:
              J7 <-> M0135 (JL) <-> M0014
              J6 <-> M0172 (J1L) <-> M0170 <-> tof
              The voxl suite we have on the board is: voxl-suite: 1.5.0
              To configure the cameras we run:
              voxl-configure-sku
              choosing options 23 (voxl-configure-sku) and 5 (pmd-tof ov7251 tracking).
              The output was the following:
              Your answers would construct the following SKU:
              family code:   MCCA-M0104 (voxl2-mini-board-only (MCCA-M0104))
              compute board: 6 (voxl2-mini)
              hw version:    1
              cam config:    05
              modem config:   ()
              tx config:      ()
              extras config:  ()
              SKU:           MCCA-M0104-C05-T0-M0-X0
              This sku will be saved to persistent memory so VOXL
              will remember what it is installed in, even between
              system image flashes.
              So we run: voxl-configure-mpa and reboot
              To inspect the cameras, we run voxl-inspect-cam -a , but we were able to see only the tracking camera:
              | Pipe Name |  bytes  | wide |  hgt |exp(ms)| gain | frame id |latency(ms)|  fps |  mbps  | format
              |  tracking |  307200 |  640 |  480 |  2.51 |   51 |      204 |     11.5  | 30.0 |   73.7 | RAW8
              So we restarted the service voxl-camera-server , but we got the following error + warnings:
              configuration for 2 cameras:
              cam #0
                  sensor type:         pmd-tof
                  isEnabled:           1
                  camId:               0
                  camId2:              -1
                  fps:                 5
                  en_rotate:           1
                  en_rotate2:          0
                  en_preview:          1
                  pre_width:           224
                  pre_height:          1557
                  en_raw_preview:      1
                  en_small_video:      0
                  small_video_width:   -1
                  small_video_height:  -1
                  en_large_video:      0
                  large_video_width:   -1
                  large_video_height:  -1
                  en_misp:             0
                  misp_width:          -1
                  misp_height:         -1
                  en_snapshot:         0
                  snap_width:          -1
                  snap_height:         -1
                  exif_focal_length:   0.000000
                  exif_focal_len_35mm_format:0
                  exif_fnumber:        0.000000
                  ae_mode:             off
                  msv_exposure_min_us: 20
                  msv_exposure_max_us: 33000
                  gain_min           : 54
                  gain_max           : 8000
                  standby_enabled:     0
                  decimator:           5
                  independent_exposure:0
              cam #1
                  sensor type:         ov7251
                  isEnabled:           1
                  camId:               1
                  camId2:              -1
                  fps:                 30
                  en_rotate:           0
                  en_rotate2:          0
                  en_preview:          1
                  pre_width:           640
                  pre_height:          480
                  en_raw_preview:      1
                  en_small_video:      0
                  en_large_video:      0
                  en_misp:             0
                  misp_width:          -1
                  misp_height:         -1
                  en_snapshot:         0
                  snap_width:          -1
                  snap_height:         -1
                  ae_mode:             lme_msv
                  gain_min           : 54
                  gain_max           : 8000
                  standby_enabled:     0
                  decimator:           1
              fsync_en:            0
              fsync_gpio:          109
              connected to mavlink pipe
              Connected to cpu-monitor
              Starting Camera: tof (id #0)
              ERROR:   Camera 0 failed to find supported preview config: 224x1557
              WARNING: Failed to start cam tof due to invalid resolution
              WARNING: assuming cam is missing and trying to compensate
              Starting Camera: tracking (originally id #1) with id offset: 1
              setting ov7251 BLC register for cam id 0
              ------ voxl-camera-server: Started 1 of 2 cameras
              Note, we also tried to modify the preview resolution, as well as disabling the preview entirely. But making these changes to the /etc/modalai/voxl-camera-server.conf file didn't seem to change the actual configuration used, as reported when running voxl-camera-server in terminal.
              Do you have any suggestions for how we can get this working?
              Morten NissovM 1 Reply Last reply
                voxl-configure-sku
                hw version:    1
                cam config:    05
                modem config:   ()
                tx config:      ()
                extras config:  ()
                cam #0
                    isEnabled:           1
                    camId:               0
                    camId2:              -1
                    fps:                 5
                    en_rotate:           1
                    en_rotate2:          0
                    en_preview:          1
                    pre_width:           224
                    pre_height:          1557
                    en_raw_preview:      1
                    en_small_video:      0
                    en_large_video:      0
                    en_misp:             0
                    misp_width:          -1
                    misp_height:         -1
                    en_snapshot:         0
                    snap_width:          -1
                    snap_height:         -1
                    ae_mode:             off
                    gain_min           : 54
                    gain_max           : 8000
                    standby_enabled:     0
                    decimator:           5
                cam #1
                    sensor type:         ov7251
                    isEnabled:           1
                    camId:               1
                    camId2:              -1
                    fps:                 30
                    en_rotate:           0
                    en_rotate2:          0
                    en_preview:          1
                    pre_width:           640
                    pre_height:          480
                    en_raw_preview:      1
                    en_small_video:      0
                    en_large_video:      0
                    en_misp:             0
                    misp_width:          -1
                    misp_height:         -1
                    en_snapshot:         0
                    snap_width:          -1
                    snap_height:         -1
                    ae_mode:             lme_msv
                    gain_min           : 54
                    gain_max           : 8000
                    standby_enabled:     0
                    decimator:           1
                fsync_en:            0
                fsync_gpio:          109
                Morten Nissov
                Additional debugging:
                Moreover, we test some other configurations:
                • J7 <-> M0135 (JL) <-> M0014
                • J6 <-> M0172 (J1L) <-> M0170 <-> tof
                We copied the files: com.qti.sensormodule.ov7251_*.bin and com.qti.sensormodule.irs2975c_*.bin into the folder: /usr/lib/camera
                We used the command: camera-server-config-helper tracking:ov7251:0 tof:pmd-tof:2 giving the following output:
                successfully wrote this camera config to disk:
                cam #0
                    sensor type:         ov7251
                    isEnabled:           1
                    camId:               0
                    camId2:              -1
                    fps:                 30
                    en_rotate:           0
                    en_rotate2:          0
                    en_preview:          1
                    pre_width:           640
                    pre_height:          480
                    en_raw_preview:      1
                    en_small_video:      0
                    en_large_video:      0
                    en_misp:             0
                    misp_width:          -1
                    misp_height:         -1
                    en_snapshot:         0
                    snap_width:          -1
                    snap_height:         -1
                    ae_mode:             lme_msv
                    gain_min           : 54
                    gain_max           : 8000
                    standby_enabled:     0
                    decimator:           1
                cam #1
                    isEnabled:           1
                    camId:               2
                    camId2:              -1
                    fps:                 5
                    en_rotate:           1
                    en_rotate2:          0
                    en_preview:          1
                    pre_width:           224
                    pre_height:          1557
                    en_raw_preview:      1
                    en_small_video:      0
                    en_large_video:      0
                    en_misp:             0
                    misp_width:          -1
                    misp_height:         -1
                    en_snapshot:         0
                    snap_width:          -1
                    snap_height:         -1
                    ae_mode:             off
                    gain_min           : 54
                    gain_max           : 8000
                    standby_enabled:     0
                    decimator:           5
                fsync_en:            0
                fsync_gpio:          109
                camera_server_config_helper is done
                Then we run voxl-camera-server giving the following output:
                cam #0
                    sensor type:         ov7251
                    isEnabled:           1
                    camId:               0
                    camId2:              -1
                    fps:                 30
                    en_rotate:           0
                    en_rotate2:          0
                    en_preview:          1
                    pre_width:           640
                    pre_height:          480
                    en_raw_preview:      1
                    en_small_video:      0
                    en_large_video:      0
                    en_misp:             0
                    misp_width:          -1
                    misp_height:         -1
                    en_snapshot:         0
                    snap_width:          -1
                    snap_height:         -1
                    ae_mode:             lme_msv
                    gain_min           : 54
                    gain_max           : 8000
                    standby_enabled:     0
                    decimator:           1
                cam #1
                    isEnabled:           1
                    camId:               2
                    camId2:              -1
                    fps:                 5
                    en_rotate:           1
                    en_rotate2:          0
                    en_preview:          1
                    pre_width:           224
                    pre_height:          1557
                    en_raw_preview:      1
                    en_small_video:      0
                    en_large_video:      0
                    en_misp:             0
                    misp_width:          -1
                    misp_height:         -1
                    en_snapshot:         0
                    snap_width:          -1
                    snap_height:         -1
                    ae_mode:             off
                    gain_min           : 54
                    gain_max           : 8000
                    standby_enabled:     0
                    decimator:           5
                fsync_en:            0
                fsync_gpio:          109
                Starting Camera: tracking (id #0)
                Starting Camera: tof (id #2)
                WARNING: cam tof (id 2) does not seem to be alive
                And running voxl-inspect-cam -a still gives the following output:
                |  tracking |  307200 |  640 |  480 |  2.28 |   51 |      294 |     11.5  | 30.0 |   73.7 | RAW8
                To be sure that all the parts were working, we tested two M0172 and 2 ToF sensors, which were actually working on VOXL 2. We also swapped the tracking camera and the ToF sensor (J6 <-> J7), copying the .bin files according to and adjusting the ID numbers.
                  cam #0
                      sensor type:         ov7251
                      isEnabled:           1
                      camId:               0
                      camId2:              -1
                      fps:                 30
                      en_rotate:           0
                      en_rotate2:          0
                      en_preview:          1
                      pre_width:           640
                      pre_height:          480
                      en_raw_preview:      1
                      en_small_video:      0
                      en_large_video:      0
                      en_misp:             0
                      misp_width:          -1
                      misp_height:         -1
                      en_snapshot:         0
                      snap_width:          -1
                      snap_height:         -1
                      ae_mode:             lme_msv
                      gain_min           : 54
                      gain_max           : 8000
                      standby_enabled:     0
                      decimator:           1
                  cam #1
                      isEnabled:           1
                      camId:               2
                      camId2:              -1
                      fps:                 5
                      en_rotate:           1
                      en_rotate2:          0
                      en_preview:          1
                      pre_width:           224
                      pre_height:          1557
                      en_raw_preview:      1
                      en_small_video:      0
                      en_large_video:      0
                      en_misp:             0
                      misp_width:          -1
                      misp_height:         -1
                      en_snapshot:         0
                      snap_width:          -1
                      snap_height:         -1
                      ae_mode:             off
                      gain_min           : 54
                      gain_max           : 8000
                      standby_enabled:     0
                      decimator:           5
                  fsync_en:            0
                  fsync_gpio:          109
                  cam #0
                      sensor type:         ov7251
                      isEnabled:           1
                      camId:               0
                      camId2:              -1
                      fps:                 30
                      en_rotate:           0
                      en_rotate2:          0
                      en_preview:          1
                      pre_width:           640
                      pre_height:          480
                      en_raw_preview:      1
                      en_small_video:      0
                      en_large_video:      0
                      en_misp:             0
                      misp_width:          -1
                      misp_height:         -1
                      en_snapshot:         0
                      snap_width:          -1
                      snap_height:         -1
                      ae_mode:             lme_msv
                      gain_min           : 54
                      gain_max           : 8000
                      standby_enabled:     0
                      decimator:           1
                  cam #1
                      isEnabled:           1
                      camId:               2
                      camId2:              -1
                      fps:                 5
                      en_rotate:           1
                      en_rotate2:          0
                      en_preview:          1
                      pre_width:           224
                      pre_height:          1557
                      en_raw_preview:      1
                      en_small_video:      0
                      en_large_video:      0
                      en_misp:             0
                      misp_width:          -1
                      misp_height:         -1
                      en_snapshot:         0
                      snap_width:          -1
                      snap_height:         -1
                      ae_mode:             off
                      gain_min           : 54
                      gain_max           : 8000
                      standby_enabled:     0
                      decimator:           5
                  fsync_en:            0
                  fsync_gpio:          109
                  #10
                  @Morten-Nissov , please only put one sensormodule with the correct slot number in /usr/lib/camera. This will help eliminate any confusion.
                  Also, does voxl-camera-server -l actually detect your TOF module?
                  It seems your camera id is actually incorrect. It should be 1. The slot id is 2 (which is tied to the hardware), but the software camera Id is assigned as the cameras are probed in each slot. voxl-camera-server -l will tell you (at the top) which cameras have been detected, which slot and camera ids.
                    Morten Nissov
                    @Alex-Kushleyev Thanks for getting back to us so quickly.
                    We removed all the com.qti.sensormodule.ov7251_*.bin and the com.qti.sensormodule.irs2975c_*.bin files.
                    Then we ran, as you suggested, the command: voxl-camera-server -l. The output was:
                    DEBUG:   Cam idx: 0, Cam slot: 0, Slave Address: 0x00E2, Sensor Id: 0x7750
                    DEBUG:   Cam idx: 1, Cam slot: 2, Slave Address: 0x007A, Sensor Id: 0x2975
                    DEBUG:          of configurations that have full pipelines
                    DEBUG:   Number of cameras: 2
                    Stats for camera: 0
                     640 x  480
                     640 x  480
                     640 x  480
                     640 x  480 HAL_PIXEL_FORMAT_RAW10
                     640 x  480 HAL_PIXEL_FORMAT_RAW12
                     640 x  480 HAL_PIXEL_FORMAT_RAW16
                     640 x  480 HAL_PIXEL_FORMAT_RAW_OPAQUE
                            min = 54
                            max = 3451
                            3451
                            min = 0ns
                            max = 1266732525ns
                    Stats for camera: 1
                     240 x 1629
                     240 x 1629 HAL_PIXEL_FORMAT_RAW10
                     240 x 1629 HAL_PIXEL_FORMAT_RAW12
                     240 x 1629 HAL_PIXEL_FORMAT_RAW16
                     240 x 1629 HAL_PIXEL_FORMAT_RAW_OPAQUE
                            min = 54
                            max = 0
                            min = 0ns
                            max = 0ns
                    Number of cameras detected: 2
                    Given the output, we copied the files com.qti.sensormodule.ov7251_0.bin and com.qti.sensormodule.irs2975c_2.bin into /usr/lib/camera folder.
                    Then we ran: camera-server-config-helper tracking:ov7251:0 tof:pmd-tof:2 and got the following output:
                    cam #0
                        sensor type:         ov7251
                        isEnabled:           1
                        camId:               0
                        camId2:              -1
                        fps:                 30
                        en_rotate:           0
                        en_rotate2:          0
                        en_preview:          1
                        pre_width:           640
                        pre_height:          480
                        en_raw_preview:      1
                        en_small_video:      0
                        en_large_video:      0
                        en_misp:             0
                        misp_width:          -1
                        misp_height:         -1
                        en_snapshot:         0
                        snap_width:          -1
                        snap_height:         -1
                        ae_mode:             lme_msv
                        gain_min           : 54
                        gain_max           : 8000
                        standby_enabled:     0
                        decimator:           1
                    cam #1
                        isEnabled:           1
                        camId:               2
                        camId2:              -1
                        fps:                 5
                        en_rotate:           1
                        en_rotate2:          0
                        en_preview:          1
                        pre_width:           224
                        pre_height:          1557
                        en_raw_preview:      1
                        en_small_video:      0
                        en_large_video:      0
                        en_misp:             0
                        misp_width:          -1
                        misp_height:         -1
                        en_snapshot:         0
                        snap_width:          -1
                        snap_height:         -1
                        ae_mode:             off
                        gain_min           : 54
                        gain_max           : 8000
                        standby_enabled:     0
                        decimator:           5
                    fsync_en:            0
                    fsync_gpio:          109
                    Finally, we ran: voxl-camera-server, and we got:
                    cam #0
                        sensor type:         ov7251
                        isEnabled:           1
                        camId:               0
                        camId2:              -1
                        fps:                 30
                        en_rotate:           0
                        en_rotate2:          0
                        en_preview:          1
                        pre_width:           640
                        pre_height:          480
                        en_raw_preview:      1
                        en_small_video:      0
                        en_large_video:      0
                        en_misp:             0
                        misp_width:          -1
                        misp_height:         -1
                        en_snapshot:         0
                        snap_width:          -1
                        snap_height:         -1
                        ae_mode:             lme_msv
                        gain_min           : 54
                        gain_max           : 8000
                        standby_enabled:     0
                        decimator:           1
                    cam #1
                        isEnabled:           1
                        camId:               2
                        camId2:              -1
                        fps:                 5
                        en_rotate:           1
                        en_rotate2:          0
                        en_preview:          1
                        pre_width:           224
                        pre_height:          1557
                        en_raw_preview:      1
                        en_small_video:      0
                        en_large_video:      0
                        en_misp:             0
                        misp_width:          -1
                        misp_height:         -1
                        en_snapshot:         0
                        snap_width:          -1
                        snap_height:         -1
                        ae_mode:             off
                        gain_min           : 54
                        gain_max           : 8000
                        standby_enabled:     0
                        decimator:           5
                    fsync_en:            0
                    fsync_gpio:          109
                    Just to make sure that only one camera was working, we ran: voxl-inspect-cam -a and got:
                    | Pipe Name |  bytes  | wide |  hgt |exp(ms)| gain | frame id |latency(ms)|  fps |  mbt
                    |  tracking |  307200 |  640 |  480 |  5.04 |  111 |      179 |     11.6  | 30.0 |   73.7 | RAW8
                    What do you think?
                      Stats for camera: 0
                       640 x  480
                       640 x  480
                       640 x  480
                              min = 54
                              max = 3451
                              3451
                              min = 0ns
                              max = 1266732525ns
                      Stats for camera: 1
                       240 x 1629
                              min = 54
                              max = 0
                              min = 0ns
                              max = 0ns
                      cam #0
                          sensor type:         ov7251
                          isEnabled:           1
                          camId:               0
                          camId2:              -1
                          fps:                 30
                          en_rotate:           0
                          en_rotate2:          0
                          en_preview:          1
                          pre_width:           640
                          pre_height:          480
                          en_raw_preview:      1
                          en_small_video:      0
                          en_large_video:      0
                          en_misp:             0
                          misp_width:          -1
                          misp_height:         -1
                          en_snapshot:         0
                          snap_width:          -1
                          snap_height:         -1
                          ae_mode:             lme_msv
                          gain_min           : 54
                          gain_max           : 8000
                          standby_enabled:     0
                          decimator:           1
                      cam #1
                          isEnabled:           1
                          camId:               2
                          camId2:              -1
                          fps:                 5
                          en_rotate:           1
                          en_rotate2:          0
                          en_preview:          1
                          pre_width:           224
                          pre_height:          1557
                          en_raw_preview:      1
                          en_small_video:      0
                          en_large_video:      0
                          en_misp:             0
                          misp_width:          -1
                          misp_height:         -1
                          en_snapshot:         0
                          snap_width:          -1
                          snap_height:         -1
                          ae_mode:             off
                          gain_min           : 54
                          gain_max           : 8000
                          standby_enabled:     0
                          decimator:           5
                      fsync_en:            0
                      fsync_gpio:          109
                      cam #0
                          sensor type:         ov7251
                          isEnabled:           1
                          camId:               0
                          camId2:              -1
                          fps:                 30
                          en_rotate:           0
                          en_rotate2:          0
                          en_preview:          1
                          pre_width:           640
                          pre_height:          480
                          en_raw_preview:      1
                          en_small_video:      0
                          en_large_video:      0
                          en_misp:             0
                          misp_width:          -1
                          misp_height:         -1
                          en_snapshot:         0
                          snap_width:          -1
                          snap_height:         -1
                          ae_mode:             lme_msv
                          gain_min           : 54
                          gain_max           : 8000
                          standby_enabled:     0
                          decimator:           1
                      cam #1
                          isEnabled:           1
                          camId:               2
                          camId2:              -1
                          fps:                 5
                          en_rotate:           1
                          en_rotate2:          0
                          en_preview:          1
                          pre_width:           224
                          pre_height:          1557
                          en_raw_preview:      1
                          en_small_video:      0
                          en_large_video:      0
                          en_misp:             0
                          misp_width:          -1
                          misp_height:         -1
                          en_snapshot:         0
                          snap_width:          -1
                          snap_height:         -1
                          ae_mode:             off
                          gain_min           : 54
                          gain_max           : 8000
                          standby_enabled:     0
                          decimator:           5
                      fsync_en:            0
                      fsync_gpio:          109
                      What do you think?
                      @Morten-Nissov said in Compatible ToF sensor setup with VOXL2 Mini:
                      Please use camera id 1 in your voxl-camera-server.conf instead of 2. The slot # is 2 but camera id is 1.
                      Luca ZanattaL 2 Replies Last reply
                        Luca ZanattaL Offline
                        Luca Zanatta
                          Luca Zanatta
                          wrote on last edited by Luca Zanatta
                          #14
                          Hi, I'm Luca, and I'm currently working on the ModalAI voxl2 mini. Thanks for your help and your quick answers.
                          To recap: I ran voxl-camera-server -l, and I got:
                          Stats for camera: 0
                           640 x  480
                           640 x  480
                           640 x  480
                                  min = 54
                                  max = 3451
                                  3451
                                  min = 0ns
                                  max = 1266732525ns
                          Stats for camera: 1
                           240 x 1629
                                  min = 54
                                  max = 0
                                  min = 0ns
                                  max = 0ns
                          Instead of checking the Cam slot, I have to check Cam idx. So I ran the following command: camera-server-config-helper tracking:ov7251:0 tof:pmd-tof:1 and got the following output:
                          cam #0
                              sensor type:         ov7251
                              isEnabled:           1
                              camId:               0
                              camId2:              -1
                              fps:                 30
                              en_rotate:           0
                              en_rotate2:          0
                              en_preview:          1
                              pre_width:           640
                              pre_height:          480
                              en_raw_preview:      1
                              en_small_video:      0
                              en_large_video:      0
                              en_misp:             0
                              misp_width:          -1
                              misp_height:         -1
                              en_snapshot:         0
                              snap_width:          -1
                              snap_height:         -1
                              ae_mode:             lme_msv
                              gain_min           : 54
                              gain_max           : 8000
                              standby_enabled:     0
                              decimator:           1
                          cam #1
                              isEnabled:           1
                              camId:               1
                              camId2:              -1
                              fps:                 5
                              en_rotate:           1
                              en_rotate2:          0
                              en_preview:          1
                              pre_width:           224
                              pre_height:          1557
                              en_raw_preview:      1
                              en_small_video:      0
                              en_large_video:      0
                              en_misp:             0
                              misp_width:          -1
                              misp_height:         -1
                              en_snapshot:         0
                              snap_width:          -1
                              snap_height:         -1
                              ae_mode:             off
                              gain_min           : 54
                              gain_max           : 8000
                              standby_enabled:     0
                              decimator:           5
                          fsync_en:            0
                          fsync_gpio:          109
                          Finally, I ran voxl-camera-server and got the following error:
                          cam #0
                              sensor type:         ov7251
                              isEnabled:           1
                              camId:               0
                              camId2:              -1
                              fps:                 30
                              en_rotate:           0
                              en_rotate2:          0
                              en_preview:          1
                              pre_width:           640
                              pre_height:          480
                              en_raw_preview:      1
                              en_small_video:      0
                              en_large_video:      0
                              en_misp:             0
                              misp_width:          -1
                              misp_height:         -1
                              en_snapshot:         0
                              snap_width:          -1
                              snap_height:         -1
                              ae_mode:             lme_msv
                              gain_min           : 54
                              gain_max           : 8000
                              standby_enabled:     0
                              decimator:           1
                          cam #1
                              isEnabled:           1
                              camId:               1
                              camId2:              -1
                              fps:                 5
                              en_rotate:           1
                              en_rotate2:          0
                              en_preview:          1
                              pre_width:           224
                              pre_height:          1557
                              en_raw_preview:      1
                              en_small_video:      0
                              en_large_video:      0
                              en_misp:             0
                              misp_width:          -1
                              misp_height:         -1
                              en_snapshot:         0
                              snap_width:          -1
                              snap_height:         -1
                              ae_mode:             off
                              gain_min           : 54
                              gain_max           : 8000
                              standby_enabled:     0
                              decimator:           5
                          fsync_en:            0
                          fsync_gpio:          109
                          Starting Camera: tof (id #1)
                          ERROR:   Camera 1 failed to find supported preview config: 224x1557
                          Do you have any suggestions?
                          Thanks for your help,
                          Luca
                          • Luca ZanattaL Luca Zanatta
                            Stats for camera: 0
                             640 x  480
                             640 x  480
                             640 x  480
                                    min = 54
                                    max = 3451
                                    3451
                                    min = 0ns
                                    max = 1266732525ns
                            Stats for camera: 1
                             240 x 1629
                                    min = 54
                                    max = 0
                                    min = 0ns
                                    max = 0ns
                            cam #0
                                sensor type:         ov7251
                                isEnabled:           1
                                camId:               0
                                camId2:              -1
                                fps:                 30
                                en_rotate:           0
                                en_rotate2:          0
                                en_preview:          1
                                pre_width:           640
                                pre_height:          480
                                en_raw_preview:      1
                                en_small_video:      0
                                en_large_video:      0
                                en_misp:             0
                                misp_width:          -1
                                misp_height:         -1
                                en_snapshot:         0
                                snap_width:          -1
                                snap_height:         -1
                                ae_mode:             lme_msv
                                gain_min           : 54
                                gain_max           : 8000
                                standby_enabled:     0
                                decimator:           1
                            cam #1
                                isEnabled:           1
                                camId:               1
                                camId2:              -1
                                fps:                 5
                                en_rotate:           1
                                en_rotate2:          0
                                en_preview:          1
                                pre_width:           224
                                pre_height:          1557
                                en_raw_preview:      1
                                en_small_video:      0
                                en_large_video:      0
                                en_misp:             0
                                misp_width:          -1
                                misp_height:         -1
                                en_snapshot:         0
                                snap_width:          -1
                                snap_height:         -1
                                ae_mode:             off
                                gain_min           : 54
                                gain_max           : 8000
                                standby_enabled:     0
                                decimator:           5
                            fsync_en:            0
                            fsync_gpio:          109
                            cam #0
                                sensor type:         ov7251
                                isEnabled:           1
                                camId:               0
                                camId2:              -1
                                fps:                 30
                                en_rotate:           0
                                en_rotate2:          0
                                en_preview:          1
                                pre_width:           640
                                pre_height:          480
                                en_raw_preview:      1
                                en_small_video:      0
                                en_large_video:      0
                                en_misp:             0
                                misp_width:          -1
                                misp_height:         -1
                                en_snapshot:         0
                                snap_width:          -1
                                snap_height:         -1
                                ae_mode:             lme_msv
                                gain_min           : 54
                                gain_max           : 8000
                                standby_enabled:     0
                                decimator:           1
                            cam #1
                                isEnabled:           1
                                camId:               1
                                camId2:              -1
                                fps:                 5
                                en_rotate:           1
                                en_rotate2:          0
                                en_preview:          1
                                pre_width:           224
                                pre_height:          1557
                                en_raw_preview:      1
                                en_small_video:      0
                                en_large_video:      0
                                en_misp:             0
                                misp_width:          -1
                                misp_height:         -1
                                en_snapshot:         0
                                snap_width:          -1
                                snap_height:         -1
                                ae_mode:             off
                                gain_min           : 54
                                gain_max           : 8000
                                standby_enabled:     0
                                decimator:           5
                            fsync_en:            0
                            fsync_gpio:          109
                            Luca
                            #15
                            @Luca-Zanatta , I believe your issue is that you are specifying the wrong type of TOF sensor. There are two types:
                            • pmd-tof (old, EOL)
                            • pmd-tof-liow2 (a.k.a irs2975c)
                            Based on your sensor id (Slave Address: 0x007A, Sensor Id: 0x2975), you have pmd-tof-liow2, so you should run camera-server-config-helper tracking:ov7251:0 tof:pmd-tof-liow2:1).
                            When you configured for pmd-tof, the camera server config was incorrectly set for the old TOF sensor, which has resolution of 224x1557. The new TOF sensor has resolution of 240x1629
                            Please try. Sorry i did not catch that earlier.
                            Luca ZanattaL S 2 Replies Last reply
                              Luca Zanatta
                              Hi @Alex-Kushleyev,
                              Now it's working!
                              Thank you so much for your help and quick answers.
                              Best,
                              Luca
                              • E erik referenced this topic on
                                S Offline
                                S Offline
                                Sarika Sharma
                                @Alex-Kushleyev @Luca-Zanatta I am also facing the same issue, can you please tell how to solve resolution problem.
                                I have tried to manually add preview width and preview height in vim /etc/modalai/voxl-camera-server.conf But when i run voxl-camera-server it still gives previous resolution 240*1557 and hence pmd-tof is not detected.
                                • S Sarika Sharma
                                  @Sarika-Sharma ,
                                  The preview width and height parameters are always in the camera config file, so if you added them, they are duplicates (and will be ignored).
                                  Please read through this thread as it has pretty detailed explanation how to configure the correct tof sensor (old or new) for a custom configuration.
                                  Camera-server-config-helper is indeed helpful. If you use it correctly, you should not have to manually modify the resolution in the config file.
                                  If you still cannot get this to work, please let me know what cameras you have plugged in (and which camera ports) on your voxl 2 mini.
